Windows 7 driver for Cable, USB Type-A to DB9F
bharat_chaudhar
I have LS1028ARDB
The box came with a "Cable, USB Type-A to DB9F (Windows 10 support), 1 m" as documented in Getting Started with LS1028ARDB | NXP
I'm unable to get the driver for windows 7. Is there link available for this?
Bharat
Pavel
Usually these cables use the PL2303 chip or CP210x or chip from FTDI.
See the following page about drivers for the PL2303:
http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41
See the following page about driver for CP210x:
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
See the following page about driver for FTDI:
https://www.ftdichip.com/Drivers/VCP.htm
Pavel Chubakov
Pavel
Pavel Chubakov
bharat_chaudhar
Thanks it turned out to be PL2303.
I connected the converter to a Linux machine that recognized it as Prolific PL2303.
I then refereed your reply for link to the driver.
Bharat
