HOW TO start working on imx6 solox processor using yacto
ramakrishnathum
I have to  start working on imx6 solox processor
1.How to get the imx6 solox  SDK and required documents like Yacto documentation, data sheets, and reference manual.
Labels (2)
ramakrishnathum
Thanks for the help,
Any application note for emmc upgrade using A/B upgrade mechanism?
kunalkotecha1
Senior Contributor II
gusarambula
Hello Ramakrishna Thumu,
To the list of useful resources Kunal mentioned, I would add the Linux for i.MX landing page:
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/embedded-...
I would recommend starting with the documentation for thee Kernel revision you are interested in. The latest Linux BSP release with support for the i.MX6SX would be L4.14.98_2.3.1. These BSP releases support NXP boards only. Once you download the documentation a good starting point is the included i.MX Yocto Project User’s Guide.
If you will be using a third-party board, it may also be good to check the Community BSP. You can see the documentation for this BSP on the link below:
http://freescale.github.io/
I hope this helps!
