i.MX8M Mini MIPI PHY Register Base Address
t-sugiyama
I have a question about the contents of i.MX 8M Mini Applications Processor Reference Manual(Rev.2, 08/2019).
I think it is wrong that the base address of Register described in Chapter 13.6.10 MIPI PHY Memory Map/Register Definition is 0.
I want to know the correct base address.
Thanks.
Tetsuya.
Yuri
  I've sent You information via e-mail. Hope it helps.
Yuri
Yuri
Yuri
walter_mueller
Hi Yuri
I have the same question as t-sugiyama, about the access to the MIPI DPHY registers.
Could I get the information too, that explains the access method or "correct absolute address" in the iMX8M-Mini address space.
Walter
Yuri
@walter_mueller
  please create separate thread / request.
https://www.nxp.com/support/support:SUPPORTHOME?tid=sbmenu
Yuri.
