SAI transfer S32K_148
hjy1
   I'm using SD32 creating project from example, but not successful.
   My SD32 version is 2.0.
   It happen below,
Alexis_A
Hello Fish,
The SDK version that is looking for the processor expert is 1.197 so this is an old version for the SDK, I think the SDK path was corrupted so I will suggest installing the new SDK  version that can be found in the following link:
Automotive S32 SDK for Arm® devices | NXP
Also, I will recommend installing the new S32DS version (2.2 version, link here).
I hope this helps you.
Alexis Andalon
