I am creating images with yocto.
I use wayland.
The following configuration is considered.
/dev/fb1 ← Weston + Qt
/dev/fb0 ← gstreamer
"device = /dev/fb1" was specified in the boot argument of weston.
From the weston startup log, it looks like you are using "/dev/fb1". However, Weston + Qt works with "/dev/fb0".
The starting command argument of weston that I tried is as follows.
" --Device=/dev/fb0 --backend=fbdev-backend.so ''
Is there a way to solve this?
Thank you.
