Solved! Go to Solution.
The NHS3152 IC must run firmware on its Cortex M0+. That application firmware is responsible for configuring the HW blocks, starting an ADC conversion (or temperature, or I2D, or whatever), and using the outcome to create an NDEF message which a tag reader can read out.
The SDK provides a demo application app_demo_dp_tadherence to show how this can be used in a therapy adherence/compliance use case.
Best,
Dries.
thanks!
Best,
Dries.
