Mohammed TAOUG
I have a problem with S12Z_AUTOSAR_OS_4_0_80_RTM_1_0_1P2
Discussion created by Mohammed TAOUG on Mar 18, 2020
Latest reply on Mar 26, 2020 by Hung Nguyen Phi
Hello Guys,
I have installed Tresos V23.0.0 in order to use it to generate OS code sources for S12Z, I used sample project as example "Os_Sample_Sc1" provided with S12Z_AUTOSAR_OS_4_0_80_RTM_1_0_1P2
I also installed the MCAL S12ZVC_MCAL4_0_RTM_1_0_0
when I try to generate or verify code, the following issues appeared on my screen: (see enclosed screenshot)
Failed to run generator "Os_TS_T34D1M4I0R80GeneratorId" (mode: "verify") for module "Os_TS_T34D1M4I0R80"
do you have any idea about this issue ?
Thank you in advance.
