Hi.
I'm facing with a trouble.
During my Debug activity with IAR EWB 8.42 for ARM, I found that PORTS initialization fails on two specific ports: PTA and/or PTC.
The other three ports initializations are OK (PTB, PTD, PTE).
In details, the emulator used (J-Link Ultra+), is redirected to a DefaultISR (Reset) because it tries to access to a "
Port C control (address 0x4004B000)", |
" but in the memory window, it appears like an unavailable data. Why?
Maybe the S32K116 definition file used by IAR EWB - J-Link is wrong?
Below a picture of a setup of mine:
Is anyone able to give me an escape way?
Many thanks in advance.
Claudio Ampala
Solved! Go to Solution.
Thank You Daniel.
Meanwhile I found it by myself ...
