"Initialization of TED-Kit 2 with serial number "AH06IOXS"failed.This TED-Kit 2box cannot be used and is not shown in hardware view."
57799345
mario_castaneda
Hi su yazhou,
I hope you are doing great.
I will get in contact with you internally.
Mario
wxf5555
I CAN FIX NXP TED KIT2
mednassim
hello
@57799345  @Sreejesh @lingduranshao
did You find the solution?
Sreejesh
I'm also getting the same initialization failed popup while connecting the ted-kit 2.
shrikant_koli
I am also getting same error.
Please guide me , because in my case serial number is different.
please look at the attachment.
mednassim
have you solved the problem?
if no, I can help you
shrikant_koli
Thanks for reaching.
in my case that problem is solved.
32mao
I met the same problem, may I ask how to solve it?
shrikant_koli
Hi 32mao,
You need to restore the the firmware whichever available into the TED-Kit.
that will solved your problem.
32mao
Thank you for your answer, but I don't know how to restore the firmware. I can see that there are some ".hex" files in the "firmware" folder. Do I need to remove the box?
shrikant_koli
please asked to the supplier they will provide you the user manual with hex file for how to restore the TED-KIT firmware.
32mao
I haven't been able to contact the supplier. I called him but didn't get through. I wrote him an email but didn't get back. I am very urgent about this matter now. Can you tell me how you recovered it at that time? Does this need another software?
32mao
I solved this problem. I need to remove the box and see the board inside, which has the J-LINK interface, through which I can burn firmware.
shrikant_koli
for flashing the hex file you need to download the flashmagic software.
may be one of the tutorial is available on YouTube(How to use flash magic software).
32mao
Ok, thank you for your quick reply.
mario_castaneda
Hi su yazhou,
Mario
Ismael_Gallegos
I have the same problem, any solution for that? Thanks
mednassim
HAW CAN I SOLVE THIS PROBLEM
lingduranshao
So, you can do nothing ,right?
