TJA1052i Questions
TJA1052i Questions
prakashbhumired
Customer: Digilux Automation, India
For the isolated CAN transceiver (TJA1052i), is there below data (approximate) available?
  • Bus Loading
  • Length
  • Number of Nodes
I see the data is more less understandable from (https://www.nxp.com/docs/en/supporting-information/AH1014_v1_4_Application_Hints_TJA1042_43_48_51.pd... ) for the "no-isolated" ones.
Bur for TJA1052i, the app.note (https://www.nxp.com/docs/en/supporting-information/AH1301_Application_Hints_TJA1052i.pdf ) is not giving enough information.
Customer has below requirement:
They need a support upto 100 devices with a cable extendable up to 500 meters.
Any baudrade above 10kbps should be fine for their application.
Can someone comment on above questions &  if the TJA1052i can meet customer application?
Prakash
