I would like to enable a DHCP server on my yocto build (L4.14.98_2.0.0).
I tried to enable by just adding:
CORE_IMAGE_EXTRA_INSTALL += "dhcp-server"
to my local.conf but it seems to not be enough.
I also tried adding a udhcpd.conf file to my /etc/ folder but it does not look like the clients are honoring anything in it.
Is there a step by step setup for building in a dhcp server as part of the yocto image build?
Hi davidvescovi
Please add below line to local.conf file and compile.
Shivani
you can refer to the link as below:
