IMXRT1010: fine tune on-board mic
yokonav
I am using  "sai/evkmimxrt1010_sai_edma_record_playback" example. When I attach an earphone to the output jack and listen to the audio captured by the on-board microphone, it has some noise. Is there any settings which can be used to fine tune, for example modify gain?
