LS1043A - Secure boot from QSPI
jeremy_sauget
I am using an LS1043A based board and I am trying to use secure booting from QPSI. As I am facing some issues, I did some research but I did not find any example or previous post saying it as already been done successfully.
Does anyone already did it ?
Thanks in advance for your help.
ufedor
Secure boot from QSPI is supported for the LS1043A.
It is possible to use LS1046ARDB QSPI secure boot as example.
jeremy_sauget
Hi ufedor,
Thanks for your answer. I already had a look on LS1046A example but I was interested in having a ready to go example to test on my LS1043A board to see if I can make it work before applying it to my specific case.
ufedor
There is no such example for the LS1043A because the LS1043ARDB lacks a SPI flash connected to the QSPI interface.
