Close cameras error when use max9286 cameras on imx8qm Android P OS
Question asked by yingjin yan on Feb 28, 2020
Latest reply on Mar 18, 2020 by Diego Adrian Cuevas
hi nxp ,
I found some errors when closing cameras that is openned at the same time on imx8qm platform with Android P OS. Please help me analysis  to resolve ,Thanks a lot for your reply.
The error log as follw:
--------- beginning of main
02-22 03:47:55.943 I/SELinux ( 3160): SELinux: Loaded service_contexts from:
02-22 03:47:55.943 I/SELinux ( 3160):     /vendor/etc/selinux/vndservice_contexts
02-22 03:47:55.958 I/SELinux ( 3158): SELinux: Loaded service_contexts from:
02-22 03:47:55.959 I/SELinux ( 3158):     /system/etc/selinux/plat_service_contexts
02-22 03:47:44.978 W/auditd  ( 3157): type=2000 audit(0.0:1): state=initialized audit_enabled=0 res=1
02-22 03:47:53.988 I/auditd  ( 3157): type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
02-22 03:47:54.008 W/auditd  ( 3157): type=1404 audit(0.0:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
02-22 03:47:54.216 W/init    (    1): type=1400 audit(0.0:4): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:54.220 I/chatty  (    1): uid=0(root) /init identical 4 lines
02-22 03:47:54.220 W/init    (    1): type=1400 audit(0.0:9): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:54.220 W/init    (    1): type=1400 audit(0.0:10): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:54.220 W/init    (    1): type=1400 audit(0.0:11): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.984 W/init    ( 2537): type=1400 audit(0.0:38): avc: denied { getattr } for path="/data/cache" dev="mmcblk0p12" ino=131094 scontext=u:r:vendor_init:s0 tcontext=u:object_r:cache_file:s0 tclass=dir permissive=0
02-22 03:47:55.984 W/init    (    1): type=1400 audit(0.0:39): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.988 I/chatty  (    1): uid=0(root) /init identical 4 lines
02-22 03:47:55.988 W/init    (    1): type=1400 audit(0.0:44): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.988 W/init    (    1): type=1400 audit(0.0:45): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.988 W/init    (    1): type=1400 audit(0.0:46): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:55.990 I/hwservicemanager( 3159): hwservicemanager is ready now.
02-22 03:47:56.051 I/ServiceManagement( 3168): Removing namespace from process name android.hardware.boot@1.0-service to boot@1.0-service.
02-22 03:47:56.052 I/android.hardware.boot@1.0-service( 3168): Registration complete for android.hardware.boot@1.0::IBootControl/default.
02-22 03:47:56.067 I/android.hardware.keymaster@3.0-impl( 3169): Fetching keymaster device name default
02-22 03:47:56.067 I/android.hardware.keymaster@3.0-impl( 3169): Could not find any keystore module, using software-only implementation.
02-22 03:47:56.068 I/ServiceManagement( 3169): Removing namespace from process name android.hardware.keymaster@3.0-service to keymaster@3.0-service.
02-22 03:47:56.069 I/android.hardware.keymaster@3.0-service( 3169): Registration complete for android.hardware.keymaster@3.0::IKeymasterDevice/default.
--------- beginning of system
02-22 03:47:56.105 I/vold    ( 3170): Vold 3.0 (the awakening) firing up
02-22 03:47:56.106 V/vold    ( 3170): Detected support for: ext4 vfat
02-22 03:47:56.110 V/vold    ( 3170): Found unmanaged dm device named vroot
02-22 03:47:56.110 V/vold    ( 3170): Found unmanaged dm device named vendor
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop3: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop1: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop0: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop4: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop5: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop7: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop2: No such device or address
02-22 03:47:56.110 W/vold    ( 3170): Failed to LOOP_GET_STATUS64 /dev/block/loop6: No such device or address
02-22 03:47:56.113 D/vold    ( 3170): VoldNativeService::start() completed OK
02-22 03:47:56.120 I/vold    ( 3170): e4crypt_initialize_global_de
02-22 03:47:56.126 D/vold    ( 3170): Key exists, using: /data/unencrypted/key
02-22 03:47:56.131 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:47:56.132 I/vold    ( 3170): List of Keymaster HALs found:
02-22 03:47:56.133 I/vold    ( 3170): Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.133 I/vold    ( 3170): Using SoftwareKeymasterDevice from Google for encryption.  Security level: SOFTWARE, HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.139 D/vold    ( 3170): Added key 247563587 (ext4:0bfa77f9264d39c3) to keyring 625017044 in process 3170
02-22 03:47:56.139 D/vold    ( 3170): Added key 368405187 (f2fs:0bfa77f9264d39c3) to keyring 625017044 in process 3170
02-22 03:47:56.140 D/vold    ( 3170): Added key 895425416 (fscrypt:0bfa77f9264d39c3) to keyring 625017044 in process 3170
02-22 03:47:56.141 I/vold    ( 3170): Wrote system DE key reference to:/data/unencrypted/ref
02-22 03:47:56.219 D/vold    ( 3170): e4crypt_init_user0
02-22 03:47:56.219 D/vold    ( 3170): Preparing: /data/misc/vold/user_keys
02-22 03:47:56.220 D/vold    ( 3170): Preparing: /data/misc/vold/user_keys/ce
02-22 03:47:56.220 D/vold    ( 3170): Preparing: /data/misc/vold/user_keys/de
02-22 03:47:56.221 D/vold    ( 3170): Skipping non-de-key ..
02-22 03:47:56.224 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:47:56.226 I/vold    ( 3170): List of Keymaster HALs found:
02-22 03:47:56.226 I/vold    ( 3170): Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.226 I/vold    ( 3170): Using SoftwareKeymasterDevice from Google for encryption.  Security level: SOFTWARE, HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:47:56.227 D/vold    ( 3170): Added key 195702228 (ext4:24f6ce487e658803) to keyring 625017044 in process 3170
02-22 03:47:56.227 D/vold    ( 3170): Added key 1034099187 (f2fs:24f6ce487e658803) to keyring 625017044 in process 3170
02-22 03:47:56.227 D/vold    ( 3170): Added key 422420984 (fscrypt:24f6ce487e658803) to keyring 625017044 in process 3170
02-22 03:47:56.227 D/vold    ( 3170): Installed de key for user 0
02-22 03:47:56.227 D/vold    ( 3170): Skipping non-de-key .
02-22 03:47:56.227 D/vold    ( 3170): e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
02-22 03:47:56.227 D/vold    ( 3170): Preparing: /data/system/users/0
02-22 03:47:56.228 D/vold    ( 3170): Preparing: /data/misc/profiles/cur/0
02-22 03:47:56.228 D/vold    ( 3170): Preparing: /data/system_de/0
02-22 03:47:56.228 D/vold    ( 3170): Preparing: /data/misc_de/0
02-22 03:47:56.229 D/vold    ( 3170): Preparing: /data/vendor_de/0
02-22 03:47:56.229 D/vold    ( 3170): Preparing: /data/user_de/0
02-22 03:47:56.230 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/system_de/0 which matches expected value
02-22 03:47:56.230 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/misc_de/0 which matches expected value
02-22 03:47:56.231 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/vendor_de/0 which matches expected value
02-22 03:47:56.232 I/vold    ( 3170): Found policy 24f6ce487e658803 at /data/user_de/0 which matches expected value
02-22 03:47:56.232 V/vold    ( 3170): /system/bin/vold_prepare_subdirs
02-22 03:47:56.232 V/vold    ( 3170):     prepare
02-22 03:47:56.232 V/vold    ( 3170):     0
02-22 03:47:56.232 V/vold    ( 3170):     1
02-22 03:47:56.258 I/vold_prepare_subdirs( 3170): SELinux: Loaded file_contexts
02-22 03:47:56.261 D/vold_prepare_subdirs( 3214): Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_de/0/vold
02-22 03:47:56.261 D/vold_prepare_subdirs( 3214): Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_de/0/storaged
02-22 03:47:56.262 D/vold_prepare_subdirs( 3214): Setting up mode 700 uid 1000 gid 1000 context u:object_r:fingerprint_vendor_data_file:s0 on path: /data/vendor_de/0/fpdata
02-22 03:47:56.282 I//system/bin/tzdatacheck( 3216): timezone distro dir /data/misc/zoneinfo/current does not exist. No action required.
02-22 03:47:56.470 I/android.hardware.wifi@1.0-service( 3224): Wifi Hal is booting up...
02-22 03:47:56.471 I/ServiceManagement( 3224): Removing namespace from process name android.hardware.wifi@1.0-service to wifi@1.0-service.
02-22 03:47:56.482 I/Netd    ( 3219): Netd 1.0 starting
02-22 03:47:56.487 D/TetherController( 3219): Setting IP forward enable = 0
02-22 03:47:56.513 I/ServiceManagement( 3229): Removing namespace from process name android.hidl.allocator@1.0-service to allocator@1.0-service.
02-22 03:47:56.517 I/ServiceManagement( 3232): Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-service.
02-22 03:47:56.517 I/health@2.0/( 3230): health@2.0/backup: Hal starting main loop...
02-22 03:47:56.517 I/health@2.0/( 3230): health@2.0/backup Hal is starting up...
02-22 03:47:56.518 I/android.hardware.bluetooth@1.0-service( 3232): Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
02-22 03:47:56.521 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.health@1.0::IHealth/default in either framework or device manifest.
02-22 03:47:56.526 I/health@2.0/( 3230): health@2.0/backup: Hal init done
02-22 03:47:56.555 I/Netd    ( 3219): Creating child chains: 53.1ms
02-22 03:47:56.555 I/Netd    ( 3219): Setting up OEM hooks: 0.1ms
02-22 03:47:56.555 I/Netd    ( 3219): Setting up FirewallController hooks: 0.0ms
02-22 03:47:56.557 I/Netd    ( 3219): Setting up TetherController hooks: 1.4ms
02-22 03:47:56.558 I/Netd    ( 3219): Setting up BandwidthController hooks: 1.7ms
02-22 03:47:56.559 I/Netd    ( 3219): Setting up IdletimerController hooks: 0.1ms
02-22 03:47:56.650 I/ServiceManagement( 3246): Removing namespace from process name android.hardware.power@1.0-service to power@1.0-service.
02-22 03:47:56.652 I/android.hardware.power@1.0-service( 3246): Registration complete for android.hardware.power@1.0::IPower/default.
02-22 03:47:56.653 I/ServiceManagement( 3240): Removing namespace from process name android.hardware.gatekeeper@1.0-service to gatekeeper@1.0-service.
02-22 03:47:56.655 I/android.hardware.gatekeeper@1.0-service( 3240): Registration complete for android.hardware.gatekeeper@1.0::IGatekeeper/default.
02-22 03:47:56.666 I/installd( 3263): installd firing up
02-22 03:47:56.693 I/health@2.0/( 3243): health@2.0/default: Hal starting main loop...
02-22 03:47:56.693 I/health@2.0/( 3243): health@2.0/default Hal is starting up...
02-22 03:47:56.695 I/ServiceManagement( 3243): Removing namespace from process name android.hardware.health@2.0-service.imx to health@2.0-service.imx.
02-22 03:47:56.696 I/health@2.0/( 3243): health@2.0/default: Hal init done
02-22 03:47:56.715 E/        ( 3247): couldn't find 'FSL_SENS_HUB' input device
02-22 03:47:56.715 I//system/bin/tombstoned( 3274): tombstoned successfully initialized
02-22 03:47:56.716 I/ServiceManagement( 3248): Removing namespace from process name android.hardware.usb@1.1-service.imx to usb@1.1-service.imx.
02-22 03:47:56.727 D/android.hardware.drm@1.0-service( 3237): android.hardware.drm@1.0-service starting...
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: connect
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: fcntl
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: sendto
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: socket
02-22 03:47:56.736 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: allowing syscall: writev
02-22 03:47:56.740 I/android.hardware.usb@1.1-service.imx( 3248): USB HAL Ready.
02-22 03:47:56.747 W//vendor/bin/hw/android.hardware.configstore@1.1-service( 3235): libminijail[3235]: logging seccomp filter failures
02-22 03:47:56.747 I/ServiceManagement( 3235): Removing namespace from process name android.hardware.configstore@1.1-service to configstore@1.1-service.
02-22 03:47:56.757 D/android.hardware.cas@1.0-service( 3234): android.hardware.cas@1.0-service starting...
02-22 03:47:56.758 I/ServiceManagement( 3234): Removing namespace from process name android.hardware.cas@1.0-service to cas@1.0-service.
02-22 03:47:56.759 I/usbd    ( 3276): Usb HAL found.
02-22 03:47:56.759 I/usbd    ( 3276): peristent prop is adb
02-22 03:47:56.762 I/Netd    ( 3219): initializing traffic control: 203.1ms
02-22 03:47:56.762 I/android.hardware.usb.gadget@1.0-service.imx( 3248): setCurrentUsbFunctions None
02-22 03:47:56.762 I/android.hardware.usb.gadget@1.0-service.imx( 3248): Gadget cannot be pulled down
02-22 03:47:56.765 W/hw-IPCThreadState( 3276): Calling IPCThreadState::self() during shutdown is dangerous, expect a crash.
--------- beginning of crash
02-22 03:47:56.765 F/libc    ( 3276): Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x178 in tid 3282 (HwBinder:3276_1), pid 3276 (usbd)
02-22 03:47:56.770 I/Netd    ( 3219): Disabling bandwidth control: 8.7ms
02-22 03:47:56.772 E/Netd    ( 3219): cannot find interface dummy0
02-22 03:47:56.772 I/Netd    ( 3219): Initializing RouteController: 1.9ms
02-22 03:47:56.773 D/XfrmController( 3219): Sending Netlink XFRM Message: XFRM_MSG_FLUSHSA
02-22 03:47:56.773 D/XfrmController( 3219): Sending Netlink XFRM Message: XFRM_MSG_FLUSHPOLICY
02-22 03:47:56.773 I/Netd    ( 3219): Initializing XfrmController: 0.7ms
02-22 03:47:56.774 E/Netd    ( 3219): Unable to create netlink socket: Protocol not supported
02-22 03:47:56.774 W/Netd    ( 3219): Unable to open qlog quota socket, check if xt_quota2 can send via UeventHandler
02-22 03:47:56.775 D/MDnsDS  ( 3219): MDnsSdListener::Hander starting up
02-22 03:47:56.777 I/Netd    ( 3219): Registering NetdNativeService: 2.1ms
02-22 03:47:56.778 I/Netd    ( 3219): Starting CommandListener: 0.3ms
02-22 03:47:56.778 E/lights  ( 3244): cannot open backlight file /sys/class/backlight/56228000.mipi_dsi_bridge.0/max_brightness
02-22 03:47:56.778 E/light   ( 3244): light_open lights backlight failed: -22
02-22 03:47:56.778 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.779 E/light   ( 3244): light_open lights keyboard failed: -22
02-22 03:47:56.779 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.779 W/libc    ( 3248): Unable to set property "sys.usb.ffs.ready" to "0": error code: 0x18
02-22 03:47:56.779 E/light   ( 3244): light_open lights buttons failed: -22
02-22 03:47:56.779 E/light   ( 3244): light_open lights battery failed: -22
02-22 03:47:56.779 I/android.hardware.usb.gadget@1.0-service.imx( 3248): mMonitor not running
02-22 03:47:56.780 E/light   ( 3244): light_open lights notifications failed: -22
02-22 03:47:56.780 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.780 E/light   ( 3244): light_open lights attention failed: -22
02-22 03:47:56.780 D/MDnsDS  ( 3219): MDnsSdListener starting to monitor
02-22 03:47:56.780 D/MDnsDS  ( 3219): Going to poll with pollCount 1
02-22 03:47:56.787 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.thermal@1.1::IThermal/default in either framework or device manifest.
02-22 03:47:56.788 I/ServiceManagement( 3245): Removing namespace from process name android.hardware.memtrack@1.0-service to memtrack@1.0-service.
02-22 03:47:56.788 W/thermalserviced( 3251): Unable to get Thermal HAL V1.1, vendor thermal event notification not available
02-22 03:47:56.789 I/android.hardware.memtrack@1.0-service( 3245): Registration complete for android.hardware.memtrack@1.0::IMemtrack/default.
02-22 03:47:56.789 I/Netd    ( 3219): Registering NetdHwService: 11.0ms
02-22 03:47:56.789 I/Netd    ( 3219): Netd started in 307ms
02-22 03:47:56.794 E/light   ( 3244): light_open lights bluetooth failed: -22
02-22 03:47:56.794 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.795 E/light   ( 3244): light_open lights wifi failed: -22
02-22 03:47:56.795 E/light   ( 3244): Light passthrough failed to load legacy HAL.
02-22 03:47:56.795 I/light   ( 3244): Could not open any lights.
02-22 03:47:56.795 W/statsd  ( 3267): statscompanion service unavailable!
02-22 03:47:56.796 I/ServiceManagement( 3244): Removing namespace from process name android.hardware.light@2.0-service to light@2.0-service.
02-22 03:47:56.797 I/statsd  ( 3267): using statsd socket
02-22 03:47:56.797 I/android.hardware.light@2.0-service( 3244): Registration complete for android.hardware.light@2.0::ILight/default.
02-22 03:47:56.804 I/gatekeeperd( 3272): Starting gatekeeperd...
02-22 03:47:56.808 I/ServiceManagement( 3241): Removing namespace from process name android.hardware.graphics.allocator@2.0-service to allocator@2.0-service.
02-22 03:47:56.817 I/android.hardware.graphics.allocator@2.0-service( 3241): Registration complete for android.hardware.graphics.allocator@2.0::IAllocator/default.
02-22 03:47:56.823 I/android.hardware.camera.provider@2.4-service( 3233): Camera provider Service is starting.
02-22 03:47:56.838 I/ServiceManagement( 3237): Removing namespace from process name android.hardware.drm@1.0-service to drm@1.0-service.
02-22 03:47:56.839 E/DEBUG   ( 3303): failed to open directory /proc/3282/fd: No such file or directory
02-22 03:47:56.839 E/crash_dump64( 3303): failed to open /proc/3282: No such file or directory
02-22 03:47:56.839 F/crash_dump64( 3303): crash_dump.cpp:398] failed to get process threads: No such file or directory
02-22 03:47:56.839 I/android.hardware.drm@1.0-service( 3237): Registration complete for android.hardware.drm@1.0::IDrmFactory/default.
02-22 03:47:56.840 I//system/bin/tombstoned( 3274): received crash request for pid 3282
02-22 03:47:56.841 I/ServiceManagement( 3237): Removing namespace from process name android.hardware.drm@1.0-service to drm@1.0-service.
02-22 03:47:56.843 I/wificond( 3269): wificond is starting up...
02-22 03:47:56.844 W//system/bin/tombstoned( 3274): crash socket received short read of length 0 (expected 12)
02-22 03:47:56.848 I/android.hardware.drm@1.0-service( 3237): Registration complete for android.hardware.drm@1.0::ICryptoFactory/default.
02-22 03:47:56.854 I/mediaserver( 3253): ServiceManager: 0xfee8eba3d480
02-22 03:47:56.871 I/hwcomposer( 3242): hwc_device_open,1239
02-22 03:47:56.875 I/ServiceManagement( 3242): Removing namespace from process name android.hardware.graphics.composer@2.1-service to composer@2.1-service.
02-22 03:47:56.880 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.883 I/ServiceManagement( 3231): Removing namespace from process name android.hardware.audio@2.0-service to audio@2.0-service.
02-22 03:47:56.884 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.887 I/audiohalservice( 3231): Registration complete for android.hardware.audio@4.0::IDevicesFactory/default.
02-22 03:47:56.888 I/android.hardware.graphics.composer@2.1-service( 3242): Registration complete for android.hardware.graphics.composer@2.1::IComposer/default.
02-22 03:47:56.897 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:47:56.900 I/keystore( 3264): found android.hardware.keymaster@3.0::IKeymasterDevice with interface name default and seclevel SOFTWARE
02-22 03:47:56.900 W/keystore( 3264): No secure Keymaster implementation found, but device offers insecure Keymaster HAL. Using as default.
02-22 03:47:56.904 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.925 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.934 I/audiohalservice( 3231): Registration complete for android.hardware.audio.effect@4.0::IEffectsFactory/default.
02-22 03:47:56.934 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.soundtrigger@2.1::ISoundTriggerHw/default in either framework or device manifest.
02-22 03:47:56.937 I/adbd    ( 3308): initializing functionfs
02-22 03:47:56.938 I/adbd    ( 3308): opening control endpoint /dev/usb-ffs/adb/ep0
02-22 03:47:56.939 E/audiohalservice( 3231): Could not get passthrough implementation for android.hardware.soundtrigger@2.1::ISoundTriggerHw/default.
02-22 03:47:56.939 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.soundtrigger@2.0::ISoundTriggerHw/default in either framework or device manifest.
02-22 03:47:56.940 E/audiohalservice( 3231): Could not get passthrough implementation for android.hardware.soundtrigger@2.0::ISoundTriggerHw/default.
02-22 03:47:56.940 W/audiohalservice( 3231): Could not register soundtrigger API 2.0 nor 2.1
02-22 03:47:56.940 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default in either framework or device manifest.
02-22 03:47:56.940 E/audiohalservice( 3231): Could not get passthrough implementation for android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default.
02-22 03:47:56.940 W/audiohalservice( 3231): Could not register Bluetooth audio offload 1.0
02-22 03:47:56.945 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.955 I/adbd    ( 3308): functionfs successfully initialized
02-22 03:47:56.955 I/adbd    ( 3308): registering usb transport
02-22 03:47:56.964 I/update_engine( 3275): [0222/034756.963862:INFO:main.cc(182)] Chrome OS Update Engine starting
02-22 03:47:56.966 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:56.968 I/update_engine( 3275): [0222/034756.968109:INFO:boot_control_android.cc(64)] Loaded boot control hidl hal.
02-22 03:47:56.968 I/update_engine( 3275): [0222/034756.968232:INFO:daemon_state_android.cc(43)] Booted in dev mode.
02-22 03:47:56.986 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.004 W/usb@1.1-service( 3248): type=1400 audit(0.0:558): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.007 I/chatty  ( 3248): uid=0(root) usb@1.1-service identical 1 line
02-22 03:47:57.024 I/chatty  ( 3248): uid=0(root) usb@1.1-service identical 1 line
02-22 03:47:57.030 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.030 I/mediametrics( 3266): ServiceManager: 0xf87f5b83d740
02-22 03:47:57.030 D/MediaAnalyticsService( 3266): MediaAnalyticsService created
02-22 03:47:57.048 W/usb@1.1-service( 3248): type=1400 audit(0.0:560): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.050 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.068 W/usb@1.1-service( 3248): type=1400 audit(0.0:561): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.071 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.071 I/FslCameraHAL( 3233): enumSensorSet
02-22 03:47:57.072 I/FslCameraHAL( 3233): matchDevNodes
02-22 03:47:57.072 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video5
02-22 03:47:57.072 W/FslCameraHAL( 3233): getNodeName dev path:/dev/video5 is not capture
02-22 03:47:57.072 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video3
02-22 03:47:57.073 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.073 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_3
02-22 03:47:57.082 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video13
02-22 03:47:57.088 W/usb@1.1-service( 3248): type=1400 audit(0.0:562): avc: denied { read } for name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=11475 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
02-22 03:47:57.091 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.110 I/FslCameraHAL( 3233): getNodeName: node name:vpu encoder
02-22 03:47:57.110 I/FslCameraHAL( 3233): getNodeName CHIP_IDENT dev path:/dev/video13 failed
02-22 03:47:57.110 I/FslCameraHAL( 3233): getNodeNames: node name:vpu encoder,vpu encoder
02-22 03:47:57.111 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.118 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video1
02-22 03:47:57.119 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.119 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_1
02-22 03:47:57.126 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video6
02-22 03:47:57.126 W/FslCameraHAL( 3233): getNodeName dev path:/dev/video6 is not capture
02-22 03:47:57.126 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video4
02-22 03:47:57.132 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.134 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.134 I/FslCameraHAL( 3233): getNodeName CHIP_IDENT dev path:/dev/video4 failed
02-22 03:47:57.134 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,mxc-isi
02-22 03:47:57.142 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video2
02-22 03:47:57.142 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.142 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_2
02-22 03:47:57.150 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video12
02-22 03:47:57.152 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.168 D/AndroidRuntime( 3220): >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
02-22 03:47:57.172 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.184 W/FslCameraHAL( 3233): getNodeName dev path:/dev/video12 is not capture
02-22 03:47:57.184 I/FslCameraHAL( 3233): getNodeName: dev path:/dev/video0
02-22 03:47:57.185 I/FslCameraHAL( 3233): getNodeName: node name:mxc-isi
02-22 03:47:57.185 I/FslCameraHAL( 3233): getNodeNames: node name:mxc-isi,imx8_max9286_mipi_0
02-22 03:47:57.191 V/MediaUtils( 3265): physMem: 5996650496
02-22 03:47:57.191 V/MediaUtils( 3265): requested limit: 1199330080
02-22 03:47:57.191 V/MediaUtils( 3265): actual limit: 3221225471
02-22 03:47:57.191 V/MediaUtils( 3265): original limits: -1/-1
02-22 03:47:57.191 V/MediaUtils( 3265): new limits: 3221225471/-1
02-22 03:47:57.193 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:0, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:0, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_3, dev:/dev/video3, node:max9286_mipi, index:0
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 0: name mxc-isi,imx8_max9286_mipi_3, Facing 0, orientation 0, dev path /dev/video3
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:1, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:1, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:max9286_mipi, index:1
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_1, dev:/dev/video1, node:max9286_mipi, index:1
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 1: name mxc-isi,imx8_max9286_mipi_1, Facing 2, orientation 0, dev path /dev/video1
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:2, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:2, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:max9286_mipi, index:2
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,mxc-isi, dev:/dev/video4, node:max9286_mipi, index:2
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_2, dev:/dev/video2, node:max9286_mipi, index:2
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 2: name mxc-isi,imx8_max9286_mipi_2, Facing 2, orientation 0, dev path /dev/video2
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchPropertyName: index:3, max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): index:3, propName:max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:vpu encoder,vpu encoder, dev:/dev/video13, node:max9286_mipi, index:3
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,mxc-isi, dev:/dev/video4, node:max9286_mipi, index:3
02-22 03:47:57.195 I/FslCameraHAL( 3233): matchNodeName: sensor:mxc-isi,imx8_max9286_mipi_0, dev:/dev/video0, node:max9286_mipi, index:3
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 3: name mxc-isi,imx8_max9286_mipi_0, Facing 2, orientation 0, dev path /dev/video0
02-22 03:47:57.195 I/FslCameraHAL( 3233): **************************************** test start *************************************
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 0: name mxc-isi,imx8_max9286_mipi_3, Facing 0, orientation 0, dev path /dev/video3, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 1: name mxc-isi,imx8_max9286_mipi_1, Facing 2, orientation 0, dev path /dev/video1, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 2: name mxc-isi,imx8_max9286_mipi_2, Facing 2, orientation 0, dev path /dev/video2, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera ID 3: name mxc-isi,imx8_max9286_mipi_0, Facing 2, orientation 0, dev path /dev/video0, mExisting true, mPropertyName max9286_mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): **************************************** test end *************************************
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:0 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:0: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp Max9286Mipi
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:1 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:1: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:2 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:2: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): create id:3 Max9286Mipi device
02-22 03:47:57.195 I/FslCameraHAL( 3233): Camera:3: new camera device
02-22 03:47:57.195 I/FslCameraHAL( 3233): camera number is 4
02-22 03:47:57.195 I/CamProvider@2.4-impl( 3233): Loaded "Default Camera HAL" camera module
02-22 03:47:57.196 I/FslCameraHAL( 3233): getCameraInfo: camera id 0: info=0xffc10fd0
02-22 03:47:57.196 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.196 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.196 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.196 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.196 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.196 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.196 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.202 I/FslCameraHAL( 3233): getCameraInfo: camera id 1: info=0xffc10fd0
02-22 03:47:57.202 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.202 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.202 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.202 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.202 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.202 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.202 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: failed to get path of fd 4: No such file or directory
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: connect
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: fcntl
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: sendto
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: socket
02-22 03:47:57.207 W//system/bin/mediaextractor( 3265): libminijail[3265]: allowing syscall: writev
02-22 03:47:57.208 W//system/bin/mediaextractor( 3265): libminijail[3265]: compile_file: <fd>(47): nonexistent syscall 'ftruncate64'
02-22 03:47:57.208 W//system/bin/mediaextractor( 3265): libminijail[3265]: logging seccomp filter failures
02-22 03:47:57.209 I/FslCameraHAL( 3233): getCameraInfo: camera id 2: info=0xffc10fd0
02-22 03:47:57.213 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.213 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.213 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.213 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.213 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.213 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.213 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.213 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.222 I/zygote64( 3220): option[0]=-Xzygote
02-22 03:47:57.222 I/zygote64( 3220): option[1]=-Xusetombstonedtraces
02-22 03:47:57.222 I/zygote64( 3220): option[2]=exit
02-22 03:47:57.222 I/zygote64( 3220): option[3]=vfprintf
02-22 03:47:57.222 I/zygote64( 3220): option[4]=sensitiveThread
02-22 03:47:57.222 I/zygote64( 3220): option[5]=-verbose:gc
02-22 03:47:57.222 I/zygote64( 3220): option[6]=-Xms16m
02-22 03:47:57.222 I/zygote64( 3220): option[7]=-Xmx512m
02-22 03:47:57.222 I/zygote64( 3220): option[8]=-XX:HeapGrowthLimit=192m
02-22 03:47:57.222 I/zygote64( 3220): option[9]=-XX:HeapMinFree=512k
02-22 03:47:57.222 I/zygote64( 3220): option[10]=-XX:HeapMaxFree=8m
02-22 03:47:57.222 I/zygote64( 3220): option[11]=-XX:HeapTargetUtilization=0.75
02-22 03:47:57.222 I/zygote64( 3220): option[12]=-Xusejit:true
02-22 03:47:57.222 I/zygote64( 3220): option[13]=-Xjitsaveprofilinginfo
02-22 03:47:57.222 I/zygote64( 3220): option[14]=-XjdwpOptions:suspend=n,server=y
02-22 03:47:57.222 I/zygote64( 3220): option[15]=-XjdwpProvider:default
02-22 03:47:57.222 I/zygote64( 3220): option[16]=-Xlockprofthreshold:500
02-22 03:47:57.222 I/zygote64( 3220): option[17]=-Ximage-compiler-option
02-22 03:47:57.222 I/zygote64( 3220): option[18]=--runtime-arg
02-22 03:47:57.222 I/zygote64( 3220): option[19]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[20]=-Xms64m
02-22 03:47:57.223 I/zygote64( 3220): option[21]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[22]=--runtime-arg
02-22 03:47:57.223 I/zygote64( 3220): option[23]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[24]=-Xmx64m
02-22 03:47:57.223 I/zygote64( 3220): option[25]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[26]=--profile-file=/system/etc/boot-image.prof
02-22 03:47:57.223 I/zygote64( 3220): option[27]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[28]=--compiler-filter=speed-profile
02-22 03:47:57.223 I/zygote64( 3220): option[29]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[30]=--runtime-arg
02-22 03:47:57.223 I/zygote64( 3220): option[31]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[32]=-Xms64m
02-22 03:47:57.223 I/zygote64( 3220): option[33]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[34]=--runtime-arg
02-22 03:47:57.223 I/zygote64( 3220): option[35]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[36]=-Xmx512m
02-22 03:47:57.223 I/zygote64( 3220): option[37]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[38]=--instruction-set-variant=cortex-a53
02-22 03:47:57.223 I/zygote64( 3220): option[39]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[40]=--instruction-set-variant=cortex-a53
02-22 03:47:57.223 I/zygote64( 3220): option[41]=-Ximage-compiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[42]=--instruction-set-features=default
02-22 03:47:57.223 I/zygote64( 3220): option[43]=-Xcompiler-option
02-22 03:47:57.223 I/zygote64( 3220): option[44]=--instruction-set-features=default
02-22 03:47:57.223 I/zygote64( 3220): option[45]=-Duser.locale=zh-Hans-CN
02-22 03:47:57.223 I/zygote64( 3220): option[46]=--cpu-abilist=arm64-v8a
02-22 03:47:57.223 I/zygote64( 3220): option[47]=-Xfingerprint:Android/mek_8q/mek_8q:9/2.0.1-ga-rc1/neolix01061131:userdebug/dev-keys
02-22 03:47:57.225 I/FslCameraHAL( 3233): getCameraInfo: camera id 3: info=0xffc10fd0
02-22 03:47:57.225 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp initSensorStaticData
02-22 03:47:57.227 I/FslCameraHAL( 3233): enum frame size w:1280, h:720
02-22 03:47:57.227 I/FslCameraHAL( 3233): SupportedPictureSizes: 1280 x 720
02-22 03:47:57.227 I/FslCameraHAL( 3233): SupportedPreviewSizes: 1280 x 720
02-22 03:47:57.227 I/FslCameraHAL( 3233): FrameDuration is 33331760, 30000000000
02-22 03:47:57.227 I/FslCameraHAL( 3233): mMaxWidth:1280, mMaxHeight:720
02-22 03:47:57.227 I/FslCameraHAL( 3233): ImxdpuCsi, mFocalLength:3.370000, mPhysicalWidth:3.628800, mPhysicalHeight 2.721600
02-22 03:47:57.234 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.238 I/ServiceManagement( 3233): Removing namespace from process name android.hardware.camera.provider@2.4-service to provider@2.4-service.
02-22 03:47:57.239 I/android.hardware.camera.provider@2.4-service( 3233): Registration complete for android.hardware.camera.provider@2.4::ICameraProvider/legacy/0.
02-22 03:47:57.240 I/media.codec( 3270): mediacodecservice starting
02-22 03:47:57.243 I/zygote64( 3220): VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm64 --instruction-set=arm64 --verify
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: failed to get path of fd 4: No such file or directory
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: clock_gettime
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: connect
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: fcntl64
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: socket
02-22 03:47:57.245 W/media.codec( 3270): libminijail[3270]: allowing syscall: writev
02-22 03:47:57.247 W/media.codec( 3270): libminijail[3270]: compile_file: <fd>(61): nonexistent syscall 'create'
02-22 03:47:57.247 W/media.codec( 3270): libminijail[3270]: compile_file: <fd>(63): nonexistent syscall 'mkfifo'
02-22 03:47:57.247 W/media.codec( 3270): libminijail[3270]: logging seccomp filter failures
02-22 03:47:57.252 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::startGraphicsAllocatorService retrieved: 0
02-22 03:47:57.253 I/SurfaceFlinger( 3250): Using HWComposer service: 'default'
02-22 03:47:57.253 I/SurfaceFlinger( 3250): SurfaceFlinger is starting
02-22 03:47:57.254 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.255 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncEventPhaseOffsetNs retrieved: 1000000 (default)
02-22 03:47:57.255 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncSfEventPhaseOffsetNs retrieved: 1000000 (default)
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasSyncFramework retrieved: 1
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::presentTimeOffsetFromVSyncNs retrieved: 0
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useHwcForRGBtoYUV retrieved: 0
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxVirtualDisplaySize retrieved: 0 (default)
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useVrFlinger retrieved: 0 (default)
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxFrameBufferAcquiredBuffers retrieved: 3
02-22 03:47:57.256 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:47:57.258 I/ConfigStore( 3250): android::hardware::configstore::V1_1::ISurfaceFlingerConfigs::primaryDisplayOrientation retrieved: ORIENTATION_0 (default)
02-22 03:47:57.258 I/SurfaceFlinger( 3250): Enabling HWC virtual displays
02-22 03:47:57.258 I/SurfaceFlinger( 3250): Disabling Triple Buffering
02-22 03:47:57.258 I/SurfaceFlinger( 3250): Treble testing override: 'false'
02-22 03:47:57.259 I/SurfaceFlinger( 3250): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
02-22 03:47:57.259 I/SurfaceFlinger( 3250): Phase offest NS: 1000000
02-22 03:47:57.275 E/libc    ( 3248): Access denied finding property "sys.usb.ffs.ready"
02-22 03:47:57.294 W/MediaCodecsXmlParser( 3270): unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
02-22 03:47:57.294 W/MediaCodecsXmlParser( 3270): parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
02-22 03:47:57.296 I/ServiceManagement( 3270): Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
02-22 03:47:57.297 D/libEGL  ( 3250): loaded /vendor/lib64/egl/libEGL_VIVANTE.so
02-22 03:47:57.298 I/android.hardware.usb.gadget@1.0-service.imx( 3248): setCurrentUsbFunctions Adb
02-22 03:47:57.298 I/android.hardware.usb.gadget@1.0-service.imx( 3248): Service started
02-22 03:47:57.299 I/android.hardware.usb.gadget@1.0-service.imx( 3248): Usb Gadget setcurrent functions called successfully
02-22 03:47:57.325 I/cameraserver( 3260): ServiceManager: 0xe8e9c100
02-22 03:47:57.325 I/CameraService( 3260): CameraService started (pid=3260)
02-22 03:47:57.325 I/CameraService( 3260): CameraService process starting
02-22 03:47:57.325 W/BatteryNotifier( 3260): batterystats service unavailable!
02-22 03:47:57.329 I/CameraProviderManager( 3260): Connecting to new camera provider: legacy/0, isRemote? 1
02-22 03:47:57.330 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/0
02-22 03:47:57.331 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/1
02-22 03:47:57.332 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/2
02-22 03:47:57.332 I/CameraProviderManager( 3260): Enumerating new camera device: device@3.4/legacy/3
02-22 03:47:57.332 I/CameraProviderManager( 3260): Camera provider legacy/0 ready with 4 camera devices
02-22 03:47:57.333 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.camera.provider@2.4::ICameraProvider/external/0 in either framework or device manifest.
02-22 03:47:57.334 W/CameraProviderManager( 3260): addProviderLocked: Camera provider HAL with name 'legacy/0' already registered
02-22 03:47:57.334 I/CameraHardwareInterface( 3260): Opening camera 0
02-22 03:47:57.334 E/CameraHardwareInterface( 3260): initialize: openSession failed! No such file or directory (-2)
02-22 03:47:57.334 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 0 failed
02-22 03:47:57.334 I/mediaserver( 3254): ServiceManager: 0xe9c1c1c0
02-22 03:47:57.334 I/CameraHardwareInterface( 3260): Destroying camera 0
02-22 03:47:57.334 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 0 has a flash unit. No such file or directory (-2)
02-22 03:47:57.335 I/CameraHardwareInterface( 3260): Opening camera 1
02-22 03:47:57.335 E/CameraHardwareInterface( 3260): initialize: openSession failed! No such file or directory (-2)
02-22 03:47:57.335 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 1 failed
02-22 03:47:57.335 I/CameraHardwareInterface( 3260): Destroying camera 1
02-22 03:47:57.335 W/BatteryNotifier( 3254): batterystats service unavailable!
02-22 03:47:57.335 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 1 has a flash unit. No such file or directory (-2)
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Opening camera 2
02-22 03:47:57.336 E/CameraHardwareInterface( 3260): initialize: openSession failed! No such file or directory (-2)
02-22 03:47:57.336 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 2 failed
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Destroying camera 2
02-22 03:47:57.336 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 2 has a flash unit. No such file or directory (-2)
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Opening camera 3
02-22 03:47:57.336 E/CameraFlashlight( 3260): connectCameraDevice: initializing camera 3 failed
02-22 03:47:57.336 I/CameraHardwareInterface( 3260): Destroying camera 3
02-22 03:47:57.336 E/CameraFlashlight( 3260): findFlashUnits: failed to check if camera 3 has a flash unit. No such file or directory (-2)
02-22 03:47:57.336 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=3, newStatus=1
02-22 03:47:57.336 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 3, a new camera is added
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=2, newStatus=1
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 2, a new camera is added
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=1, newStatus=1
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 1, a new camera is added
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
02-22 03:47:57.337 I/CameraService( 3260): onDeviceStatusChanged: Unknown camera ID 0, a new camera is added
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=3, newStatus=1
02-22 03:47:57.338 E/CameraService( 3260): onDeviceStatusChanged: State transition to the same status 0x1 not allowed
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=2, newStatus=1
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=1, newStatus=1
02-22 03:47:57.338 I/CameraService( 3260): onDeviceStatusChanged: Status changed for cameraId=0, newStatus=1
02-22 03:47:57.338 I/        ( 3260): Waiting for activity service
02-22 03:47:57.360 I/OMXPlayer( 3270): LEVEL: 1 FUNCTION: Open LINE: 39
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ac3
02-22 03:47:57.360 I/OMXPlayer( 3270): LEVEL: 1 FUNCTION: ComponentRegister LINE: 75
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ac3 fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ddp
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ddp fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ms
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ms fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_wmv9
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_wmv9 fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_ra
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_ra fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_rv
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_rv fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Can't open file: /vendor/etc/component_register_dsp_aacp
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_dsp_aacp fail.
02-22 03:47:57.360 I/OMXPlayer( 3270): Open component register file /vendor/etc/component_register_dsp fail.
02-22 03:47:57.375 D/libEGL  ( 3250): loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
02-22 03:47:57.378 W/MediaCodecsXmlParser( 3270): unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
02-22 03:47:57.378 W/MediaCodecsXmlParser( 3270): parseTopLevelXMLFile(/data/misc/media/media_codecs_profiling_results.xml) failed
02-22 03:47:57.378 I/ServiceManagement( 3270): Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
02-22 03:47:57.379 I/media.codec( 3270): IOmx HAL service created.
02-22 03:47:57.439 I/FastMixerState( 3252): sMaxFastTracks = 8
02-22 03:47:57.441 V/MediaUtils( 3252): physMem: 4294967295
02-22 03:47:57.441 V/MediaUtils( 3252): requested limit: 536870912
02-22 03:47:57.441 V/MediaUtils( 3252): actual limit: 536870912
02-22 03:47:57.441 V/MediaUtils( 3252): original limits: 4294967295/4294967295
02-22 03:47:57.441 V/MediaUtils( 3252): new limits: 536870912/4294967295
02-22 03:47:57.442 I/audioserver( 3252): ServiceManager: 0xf189c100
02-22 03:47:57.442 W/BatteryNotifier( 3252): batterystats service unavailable!
02-22 03:47:57.445 D/libEGL  ( 3250): loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
02-22 03:47:57.447 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.audio@4.0::IDevicesFactory/msd in either framework or device manifest.
02-22 03:47:57.451 I/AudioFlinger( 3252): Using default 3000 mSec as standby time.
02-22 03:47:57.454 E/APM::Serializer( 3252): deserialize: Could not parse /odm/etc/audio_policy_configuration.xml document.
02-22 03:47:57.494 D/AndroidRuntime( 3221): >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
02-22 03:47:57.504 I/zygote  ( 3221): option[0]=-Xzygote
02-22 03:47:57.504 I/zygote  ( 3221): option[1]=-Xusetombstonedtraces
02-22 03:47:57.504 I/zygote  ( 3221): option[2]=exit
02-22 03:47:57.504 I/zygote  ( 3221): option[3]=vfprintf
02-22 03:47:57.504 I/zygote  ( 3221): option[4]=sensitiveThread
02-22 03:47:57.504 I/zygote  ( 3221): option[5]=-verbose:gc
02-22 03:47:57.504 I/zygote  ( 3221): option[6]=-Xms16m
02-22 03:47:57.504 I/zygote  ( 3221): option[7]=-Xmx512m
02-22 03:47:57.504 I/zygote  ( 3221): option[8]=-XX:HeapGrowthLimit=192m
02-22 03:47:57.504 I/zygote  ( 3221): option[9]=-XX:HeapMinFree=512k
02-22 03:47:57.504 I/zygote  ( 3221): option[10]=-XX:HeapMaxFree=8m
02-22 03:47:57.504 I/zygote  ( 3221): option[11]=-XX:HeapTargetUtilization=0.75
02-22 03:47:57.504 I/zygote  ( 3221): option[12]=-Xusejit:true
02-22 03:47:57.504 I/zygote  ( 3221): option[13]=-Xjitsaveprofilinginfo
02-22 03:47:57.504 I/zygote  ( 3221): option[14]=-XjdwpOptions:suspend=n,server=y
02-22 03:47:57.504 I/zygote  ( 3221): option[15]=-XjdwpProvider:default
02-22 03:47:57.504 I/zygote  ( 3221): option[16]=-Xlockprofthreshold:500
02-22 03:47:57.504 I/zygote  ( 3221): option[17]=-Ximage-compiler-option
02-22 03:47:57.504 I/zygote  ( 3221): option[18]=--runtime-arg
02-22 03:47:57.504 I/zygote  ( 3221): option[19]=-Ximage-compiler-option
02-22 03:47:57.504 I/zygote  ( 3221): option[20]=-Xms64m
02-22 03:47:57.505 I/zygote  ( 3221): option[21]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[22]=--runtime-arg
02-22 03:47:57.505 I/zygote  ( 3221): option[23]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[24]=-Xmx64m
02-22 03:47:57.505 I/zygote  ( 3221): option[25]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[26]=--profile-file=/system/etc/boot-image.prof
02-22 03:47:57.505 I/zygote  ( 3221): option[27]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[28]=--compiler-filter=speed-profile
02-22 03:47:57.505 I/zygote  ( 3221): option[29]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[30]=--runtime-arg
02-22 03:47:57.505 I/zygote  ( 3221): option[31]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[32]=-Xms64m
02-22 03:47:57.505 I/zygote  ( 3221): option[33]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[34]=--runtime-arg
02-22 03:47:57.505 I/zygote  ( 3221): option[35]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[36]=-Xmx512m
02-22 03:47:57.505 I/zygote  ( 3221): option[37]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[38]=--instruction-set-variant=cortex-a9
02-22 03:47:57.505 I/zygote  ( 3221): option[39]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[40]=--instruction-set-variant=cortex-a9
02-22 03:47:57.505 I/zygote  ( 3221): option[41]=-Ximage-compiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[42]=--instruction-set-features=default
02-22 03:47:57.505 I/zygote  ( 3221): option[43]=-Xcompiler-option
02-22 03:47:57.505 I/zygote  ( 3221): option[44]=--instruction-set-features=default
02-22 03:47:57.505 I/zygote  ( 3221): option[45]=-Duser.locale=zh-Hans-CN
02-22 03:47:57.505 I/zygote  ( 3221): option[46]=--cpu-abilist=armeabi-v7a,armeabi
02-22 03:47:57.505 I/zygote  ( 3221): option[47]=-Xfingerprint:Android/mek_8q/mek_8q:9/2.0.1-ga-rc1/neolix01061131:userdebug/dev-keys
02-22 03:47:57.506 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:47:57.506 I/ConfigStore( 3250): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:47:57.507 W/SurfaceFlinger( 3250): no suitable EGLConfig found, trying a simpler query
02-22 03:47:57.507 I/SurfaceFlinger( 3250): EGL information:
02-22 03:47:57.507 I/SurfaceFlinger( 3250): vendor    : Android
02-22 03:47:57.507 I/SurfaceFlinger( 3250): version   : 1.4 Android META-EGL
02-22 03:47:57.507 I/SurfaceFlinger( 3250): extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_get_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_ANDROID_get_frame_timestamps EGL_EXT_surface_SMPTE2086_metadata EGL_EXT_surface_CTA861_3_metadata EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_KHR_partial_update EGL_EXT_buffer_age
02-22 03:47:57.507 I/SurfaceFlinger( 3250): Client API: OpenGL_ES
02-22 03:47:57.507 I/SurfaceFlinger( 3250): EGLSurface: 8-8-8-8, config=0x15
02-22 03:47:57.511 W/audio_hw_primary( 3231): card 0, id wm8960audio, driver wm8960-audio, name wm8960-audio
02-22 03:47:57.516 W/audio_hw_primary( 3231): out rate 44100
02-22 03:47:57.519 I/zygote  ( 3221): VerifyImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-directory=/data/dalvik-cache/arm --instruction-set=arm --verify
02-22 03:47:57.531 I/SurfaceFlinger( 3250): OpenGL ES informations:
02-22 03:47:57.531 I/SurfaceFlinger( 3250): vendor    : Vivante Corporation
02-22 03:47:57.531 I/SurfaceFlinger( 3250): renderer  : Vivante GC7000XSVX
02-22 03:47:57.531 I/SurfaceFlinger( 3250): version   : OpenGL ES 3.2 V6.2.4.p4.190076
02-22 03:47:57.531 I/SurfaceFlinger( 3250): extensions: GL_EXT_debug_marker GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_rgb8_rgba8 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32 GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_fragment_precision_high GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_texture_stencil8 GL_OES_shader_image_atomic GL_OES_sample_variables GL_OES_sample_shading GL_OES_texture_storage_multisample_2d_array GL_OES_shader_multisample_interpolation GL_OES_required_internalformat GL_OES_surfaceless_context GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_geometry_shader GL_OES_geometry_point_size GL_OES_gpu_shader5 GL_OES_shader_io_blocks GL_OES_texture_border_clamp GL_OES_texture_buffer GL_OES_tessellation
02-22 03:47:57.531 I/SurfaceFlinger( 3250): GL_MAX_TEXTURE_SIZE = 8192
02-22 03:47:57.531 I/SurfaceFlinger( 3250): GL_MAX_VIEWPORT_DIMS = 8192
02-22 03:47:57.532 W/audio_hw_primary( 3231): in rate 44100, channels 1 format 0
02-22 03:47:57.532 W/audio_hw_primary( 3231): card 1, id xtoraudio, driver xtor-audio, name xtor-audio
02-22 03:47:57.537 W/audio_hw_primary( 3231): out rate 48000
02-22 03:47:57.545 I/display ( 3242): HWC disabled!
02-22 03:47:57.545 I/display ( 3242): Opengl ES 3D composition enabled!
02-22 03:47:57.559 W/audio_hw_primary( 3231): in rate 48000, channels 1 format 0
02-22 03:47:57.559 W/audio_hw_primary( 3231): card 2, id amixaudiosai, driver amix-audio-sai, name amix-audio-sai
02-22 03:47:57.559 W/audio_hw_primary( 3231): unrecognized card found.
02-22 03:47:57.559 I/audio_hw_primary( 3231): Total 2 cards match
02-22 03:47:57.559 I/audio_hw_primary( 3231): card idx 0, name wm8960-audio
02-22 03:47:57.559 I/audio_hw_primary( 3231): card idx 1, name bt-sai-audio
02-22 03:47:57.562 I/audio_hw_primary( 3231): select_output_device(), headphone 0 ,headset 0 ,speaker 2, earpiece 0,
02-22 03:47:57.563 W/DeviceHAL( 3231): Error from HAL Device in function set_master_volume: Function not implemented
02-22 03:47:57.564 I/AudioFlinger( 3252): loadHwModule() Loaded primary audio interface, handle 10
02-22 03:47:57.564 I/AudioFlinger( 3252): openOutput() this 0xf18be000, module 10 Device 0x2, SamplingRate 48000, Format 0x000001, Channels 0x3, flags 0x2
02-22 03:47:57.564 I/audio_hw_primary( 3231): adev_open_output_stream: enter: sample_rate(48000) channel_mask(0x3) format(0x1) devices(0x2) flags(0x2), address()
02-22 03:47:57.564 I/audio_hw_primary( 3231): adev_open_output_stream: exit: output_type 1, output 0xee2d2000
02-22 03:47:57.565 I/AudioFlinger( 3252): HAL output buffer size 192 frames, normal sink buffer size 960 frames
02-22 03:47:57.591 I/display ( 3242): load /vendor/lib64/libg2d.so library!
02-22 03:47:57.592 I/display ( 3242): open gpu gralloc module!
02-22 03:47:57.623 I/display ( 3242): try dev:/dev/dri/card0
02-22 03:47:57.624 I/libedid ( 3242): Try to check fd 19 connector:82 edid info
02-22 03:47:57.639 I/BufferProvider( 3252): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
02-22 03:47:57.640 I/AudioFlinger( 3252): Using module 10 as the primary audio interface
02-22 03:47:57.640 I/audio_hw_primary( 3231): adev_set_mode mode 0
02-22 03:47:57.641 I/AudioFlinger( 3252): AudioFlinger's thread 0xf0e03c00 tid=3361 ready to run
02-22 03:47:57.641 W/AudioFlinger( 3252): no wake lock to update, system not ready yet
02-22 03:47:57.641 W/AudioFlinger( 3252): moveEffects() bad srcOutput 0
02-22 03:47:57.642 D/audio_hw_primary( 3231): out_set_parameters: enter: kvpairs: routing=2
02-22 03:47:57.642 D/audio_hw_primary( 3231): out_set_parameters: exit: code(0)
02-22 03:47:57.642 W/audio_hw_primary( 3231): In channels 2, rate 48000, devices 0x80000004
02-22 03:47:57.643 W/audio_hw_primary( 3231): get_input_buffer_size size = 512, channel_count = 2
02-22 03:47:57.644 I/AudioFlinger( 3252): AudioFlinger's thread 0xf0b03000 tid=3363 ready to run
02-22 03:47:57.644 E/FastThread( 3252): did not receive expected priority boost on time
02-22 03:47:57.664 I/bt_a2dp_hw( 3252): adev_open:  adev_open in A2dp_hw module
02-22 03:47:57.664 I/AudioFlinger( 3252): loadHwModule() Loaded a2dp audio interface, handle 18
02-22 03:47:57.670 I/AudioFlinger( 3252): loadHwModule() Loaded usb audio interface, handle 26
02-22 03:47:57.700 I/display ( 3242): readConnection: id:1, connection:1, count_modes:19, count_encoders:1
02-22 03:47:57.700 I/display ( 3242): Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
02-22 03:47:57.700 I/display ( 3242): Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
02-22 03:47:57.715 E/        ( 3247): retrying to open(FSL_SENS_HUB)
02-22 03:47:57.719 I/r_submix( 3231): adev_open(name=audio_hw_if)
02-22 03:47:57.719 I/r_submix( 3231): adev_init_check()
02-22 03:47:57.719 W/DeviceHAL( 3231): Error from HAL Device in function set_master_mute: Function not implemented
02-22 03:47:57.720 I/AudioFlinger( 3252): loadHwModule() Loaded r_submix audio interface, handle 34
02-22 03:47:57.720 D/r_submix( 3231): adev_open_input_stream(addr=0)
02-22 03:47:57.720 D/r_submix( 3231): submix_audio_device_create_pipe_l(addr=0, idx=9)
02-22 03:47:57.720 D/r_submix( 3231):   now using address 0 for route 9
02-22 03:47:57.721 I/AudioFlinger( 3252): AudioFlinger's thread 0xf0b03440 tid=3364 ready to run
02-22 03:47:57.722 D/r_submix( 3231): adev_close_input_stream()
02-22 03:47:57.722 I/        ( 3252): Waiting for activity service
02-22 03:47:57.722 D/r_submix( 3231): submix_audio_device_release_pipe_l(idx=9) addr=0
02-22 03:47:57.722 D/r_submix( 3231): submix_audio_device_destroy_pipe_l(): pipe destroyed
02-22 03:47:57.738 I/display ( 3242): Require mode:width:1920, height:1080, vrefresh 60, prefermode 1
02-22 03:47:57.738 I/display ( 3242): Find best mode w:1920, h:1080, vrefresh:60 at mode index 0
02-22 03:47:57.739 E/display ( 3242): can't find property ID for 'ANDROID_OUT_FENCE_PTR'.
02-22 03:47:57.739 E/display ( 3242): can't find property ID for 'alpha'.
02-22 03:47:57.740 E/display ( 3242): can't find property ID for 'dtrc_table_ofs'.
02-22 03:47:57.740 E/display ( 3242): can't find property ID for 'alpha'.
02-22 03:47:57.740 W/display ( 3242): xres         = 1920 px
02-22 03:47:57.740 W/display ( 3242): yres         = 1080 px
02-22 03:47:57.740 W/display ( 3242): format       = 1
02-22 03:47:57.740 W/display ( 3242): xdpi         = 69.67 ppi
02-22 03:47:57.740 W/display ( 3242): ydpi         = 70.34 ppi
02-22 03:47:57.740 W/display ( 3242): fps          = 60.00 Hz
02-22 03:47:57.740 W/display ( 3242): mode.width   = 1920 px
02-22 03:47:57.740 W/display ( 3242): mode.height  = 1080 px
02-22 03:47:57.740 E/ion     ( 3242): ioctl c0044901 failed with code -1: Not a typewriter
02-22 03:47:57.770 E/        ( 3247): couldn't find 'FSL_SENS_HUB' input device
02-22 03:47:57.791 I/display ( 3242): enumKmsDisplay set 1 as primary display
02-22 03:47:57.791 E/display ( 3242): failed to set DPMS mode:3
02-22 03:47:57.791 I/display ( 3242): try dev:/dev/dri/card1
02-22 03:47:57.791 E/display ( 3242): Failed to set atomic cap -1
02-22 03:47:57.793 E/HWComposer( 3250): getSupportedPerFrameMetadata: getSupportedPerFrameMetadata failed for display 0: Unsupported (8)
02-22 03:47:57.800 I/display ( 3241): open gpu gralloc module!
02-22 03:47:57.802 E/ion     ( 3241): ioctl c0044901 failed with code -1: Not a typewriter
02-22 03:47:57.804 I/android.hardware.usb.gadget@1.0-service.imx( 3248): GADGET pulled up
02-22 03:47:57.805 E/display ( 3242): threadLoop invalid uevent change@/devices/platform/5b110000.usb3/gadget-cdns3/udc/gadget-cdns3
02-22 03:47:57.807 I/display ( 3250): open gpu gralloc module!
02-22 03:47:57.808 E/gralloc ( 3250): gralloc1_device_open invalid name:fb0
02-22 03:47:57.808 I/v_egl   ( 3250): FramebufferSurface: bufferCount=3
02-22 03:47:57.877 I/ServiceManager( 3268): Waiting for service package_native...
02-22 03:47:58.026 D/SurfaceFlinger( 3250): shader cache generated - 24 shaders in 195.013870 ms
02-22 03:47:58.028 W/init    (    1): type=1400 audit(0.0:572): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:58.028 I/chatty  (    1): uid=0(root) /init identical 2 lines
02-22 03:47:58.028 W/init    (    1): type=1400 audit(0.0:575): avc: denied { dac_read_search } for capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
02-22 03:47:58.028 D/SurfaceFlinger( 3250): Set power mode=2, type=0 flinger=0xfa0244858000
02-22 03:47:58.028 D/SurfaceFlinger( 3250): Finished set power mode=2, type=0
02-22 03:47:58.082 E/display ( 3242): threadLoop invalid uevent change@/devices/virtual/android_usb/android0
02-22 03:47:58.107 E/display ( 3242): threadLoop invalid uevent change@/devices/virtual/android_usb/android0
02-22 03:47:58.120 D/Zygote  ( 3220): begin preload
02-22 03:47:58.120 I/Zygote  ( 3220): Installing ICU cache reference pinning...
02-22 03:47:58.120 I/Zygote  ( 3220): Preloading ICU data...
02-22 03:47:58.183 D/Zygote64Timing( 3220): BeginIcuCachePinning took to complete: 63ms
02-22 03:47:58.184 I/Zygote  ( 3220): Preloading classes...
02-22 03:47:58.203 I/Zygote  ( 3220): ...preloaded 0 classes in 20ms.
02-22 03:47:58.204 I/zygote64( 3220): VMRuntime.preloadDexCaches starting
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches strings total=339243 before=12303 after=12303
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches types total=31355 before=7818 after=7819
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
02-22 03:47:58.262 I/zygote64( 3220): VMRuntime.preloadDexCaches finished
02-22 03:47:58.262 D/Zygote64Timing( 3220): PreloadClasses took to complete: 79ms
02-22 03:47:58.298 I/zygote64( 3220): Thread[6,tid=3379,Native,Thread*=0xff8e17886800,peer=0x12cf9198,"Thread-1"] recursive attempt to load library "/system/lib64/libmedia_jni.so"
02-22 03:47:58.298 D/MtpDeviceJNI( 3220): register_android_mtp_MtpDevice
02-22 03:47:58.407 I/zygote  ( 3221): Explicit concurrent copying GC freed 179(9KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 83us total 9.038ms
02-22 03:47:58.417 I/zygote  ( 3221): Explicit concurrent copying GC freed 5(32KB) AllocSpace objects, 0(0B) LOS objects, 98% free, 22KB/1558KB, paused 59us total 8.650ms
02-22 03:47:58.417 D/Zygote32Timing( 3221): PostZygoteInitGC took to complete: 18ms
02-22 03:47:58.417 D/Zygote32Timing( 3221): ZygoteInit took to complete: 19ms
02-22 03:47:58.446 I/Zygote  ( 3221): Accepting command socket connections
02-22 03:47:58.465 D/libEGL  ( 3376): loaded /vendor/lib64/egl/libEGL_VIVANTE.so
02-22 03:47:58.476 D/libEGL  ( 3376): loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
02-22 03:47:58.524 I/Zygote  ( 3220): Preloading resources...
02-22 03:47:58.549 W/Resources( 3220): Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
02-22 03:47:58.562 D/libEGL  ( 3376): loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
02-22 03:47:58.574 I/Zygote  ( 3220): ...preloaded 64 resources in 50ms.
02-22 03:47:58.581 I/Zygote  ( 3220): ...preloaded 41 resources in 7ms.
02-22 03:47:58.581 D/Zygote64Timing( 3220): PreloadResources took to complete: 317ms
02-22 03:47:58.604 D/libEGL  ( 3220): loaded /vendor/lib64/egl/libEGL_VIVANTE.so
02-22 03:47:58.617 D/libEGL  ( 3220): loaded /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
02-22 03:47:58.630 I/ConfigStore( 3376): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:47:58.630 I/ConfigStore( 3376): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:47:58.637 I/display ( 3376): open gpu gralloc module!
02-22 03:47:58.662 D/BootAnimation( 3376): BootAnimationShownTiming start time: 14719ms
02-22 03:47:58.680 D/libEGL  ( 3220): loaded /vendor/lib64/egl/libGLESv2_VIVANTE.so
02-22 03:47:58.710 I/SurfaceFlinger( 3250): Enter boot animation
02-22 03:47:58.720 W/SurfaceFlinger( 3250): Unable to determine the display type for display 1
02-22 03:47:58.725 I/Zygote  ( 3220): Preloading shared libraries...
02-22 03:47:58.743 I/Zygote  ( 3220): Uninstalled ICU cache reference pinning...
02-22 03:47:58.744 I/Zygote  ( 3220): Installed AndroidKeyStoreProvider in 0ms.
02-22 03:47:58.750 I/Zygote  ( 3220): Warmed up JCA providers in 7ms.
02-22 03:47:58.750 D/Zygote  ( 3220): end preload
02-22 03:47:58.750 D/Zygote64Timing( 3220): ZygotePreload took to complete: 630ms
02-22 03:47:58.770 E/        ( 3247): retrying to open(FSL_SENS_HUB)
02-22 03:47:58.780 I/zygote64( 3220): Explicit concurrent copying GC freed 51536(5MB) AllocSpace objects, 165(3MB) LOS objects, 50% free, 2MB/4MB, paused 47us total 29.456ms
02-22 03:47:58.809 I/zygote64( 3220): Explicit concurrent copying GC freed 2801(136KB) AllocSpace objects, 0(0B) LOS objects, 49% free, 2MB/4MB, paused 22us total 18.994ms
02-22 03:47:58.809 D/Zygote64Timing( 3220): PostZygoteInitGC took to complete: 59ms
02-22 03:47:58.809 D/Zygote64Timing( 3220): ZygoteInit took to complete: 689ms
02-22 03:47:58.822 E/        ( 3247): couldn't find 'FSL_SENS_HUB' input device
02-22 03:47:58.885 I/ServiceManager( 3268): Waiting for service package_native...
02-22 03:47:59.142 I/Zygote  ( 3220): System server process 3407 has been created
02-22 03:47:59.145 I/Zygote  ( 3220): Accepting command socket connections
02-22 03:47:59.161 I/Zygote  ( 3407): Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
02-22 03:47:59.256 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:47:59.279 W/cmd     ( 3423): Can't find service package
02-22 03:47:59.282 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:47:59.302 I/SystemServer( 3407): InitBeforeStartServices
02-22 03:47:59.303 I/SystemServer( 3407): Entered the Android system server!
02-22 03:47:59.284 I/chatty  ( 3407): uid=1000 system_server identical 1 line
02-22 03:47:59.286 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:47:59.326 W/cmd     ( 3427): Can't find service package
02-22 03:47:59.508 E/UsbAlsaJackDetectorJNI( 3407): Can't register UsbAlsaJackDetector native methods
02-22 03:47:59.523 D/SystemServerTiming( 3407): InitBeforeStartServices took to complete: 221ms
02-22 03:47:59.523 I/SystemServer( 3407): StartServices
02-22 03:47:59.524 I/SystemServer( 3407): Reading configuration...
02-22 03:47:59.524 I/SystemServer( 3407): ReadingSystemConfig
02-22 03:47:59.524 D/SystemServerTiming( 3407): ReadingSystemConfig took to complete: 1ms
02-22 03:47:59.524 I/SystemServer( 3407): StartInstaller
02-22 03:47:59.524 I/SystemServiceManager( 3407): Starting com.android.server.pm.Installer
02-22 03:47:59.525 D/SystemServerInitThreadPool( 3407): Started executing ReadingSystemConfig
02-22 03:47:59.526 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:47:59.526 D/SystemServerTiming( 3407): StartInstaller took to complete: 2ms
02-22 03:47:59.526 I/SystemServer( 3407): DeviceIdentifiersPolicyService
02-22 03:47:59.526 I/SystemServiceManager( 3407): Starting com.android.server.os.DeviceIdentifiersPolicyService
02-22 03:47:59.527 D/SystemServerTiming( 3407): DeviceIdentifiersPolicyService took to complete: 0ms
02-22 03:47:59.527 I/SystemServer( 3407): StartActivityManager
02-22 03:47:59.527 I/SystemServiceManager( 3407): Starting com.android.server.am.ActivityManagerService$Lifecycle
02-22 03:47:59.537 I/ActivityManager( 3407): Memory class: 192
02-22 03:47:59.546 D/BatteryStatsImpl( 3407): Reading daily items from /data/system/batterystats-daily.xml
02-22 03:47:59.552 E/BluetoothAdapter( 3407): Bluetooth binder is null
02-22 03:47:59.553 E/BatteryExternalStatsWorker( 3407): no controller energy info supplied for telephony
02-22 03:47:59.554 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:47:59.560 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_active_time
02-22 03:47:59.560 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_policy_time
02-22 03:47:59.565 I/PowerManagerService-JNI( 3407): Loaded power HAL 1.0 service
02-22 03:47:59.565 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:47:59.581 D/SystemServerInitThreadPool( 3407): Finished executing ReadingSystemConfig
02-22 03:47:59.612 W/AppOps  ( 3407): Unknown attribute in 'op' tag: n
02-22 03:47:59.616 I/chatty  ( 3407): uid=1000 system_server identical 125 lines
02-22 03:47:59.616 W/AppOps  ( 3407): Unknown attribute in 'op' tag: n
02-22 03:47:59.619 I/IntentFirewall( 3407): Read new rules (A:0 B:0 S:0)
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1003/pid_3376: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1003: Permission denied
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1001/pid_3271: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1001: Permission denied
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1058/pid_3274: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1058: Permission denied
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1066/pid_3267: Device or resource busy
02-22 03:47:59.624 W/libprocessgroup( 3407): Failed to remove /acct/uid_1066: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1046/pid_3270: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1046: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1036/pid_3157: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1036: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_2000/pid_3258: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_2000: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1040/pid_3265: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1040: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1002/pid_3232: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1002: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1010/pid_3269: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1010/pid_3224: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1010: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1067/pid_3262: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1067: Permission denied
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3229: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3247: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3160: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3245: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3235: Device or resource busy
02-22 03:47:59.625 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3169: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3159: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3243: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3251: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3241: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3246: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3244: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3272: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3158: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3242: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3250: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000/pid_3240: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1000: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1019/pid_3255: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1019: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1047/pid_3233: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1047/pid_3260: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1047: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1017/pid_3264: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_1017: Permission denied
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3230: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3220: Device or resource busy
02-22 03:47:59.626 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3249: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3219: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3275: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3170: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3273: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3263: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3308: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_2540: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3221: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_2539: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3268: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3248: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3168: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0/pid_3148: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_0: Permission denied
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3237: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3253: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3266: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3254: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013/pid_3234: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1013: Permission denied
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1041/pid_3231: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1041/pid_3252: Device or resource busy
02-22 03:47:59.627 W/libprocessgroup( 3407): Failed to remove /acct/uid_1041: Permission denied
02-22 03:47:59.629 D/AppOps  ( 3407): AppOpsService published
02-22 03:47:59.629 D/SystemServerTiming( 3407): StartActivityManager took to complete: 103ms
02-22 03:47:59.629 I/SystemServer( 3407): StartPowerManager
02-22 03:47:59.629 I/SystemServiceManager( 3407): Starting com.android.server.power.PowerManagerService
02-22 03:47:59.632 D/SystemServerTiming( 3407): StartPowerManager took to complete: 3ms
02-22 03:47:59.632 I/SystemServer( 3407): InitPowerManagement
02-22 03:47:59.633 D/SystemServerTiming( 3407): InitPowerManagement took to complete: 1ms
02-22 03:47:59.633 I/SystemServer( 3407): StartRecoverySystemService
02-22 03:47:59.633 I/SystemServiceManager( 3407): Starting com.android.server.RecoverySystemService
02-22 03:47:59.634 D/SystemServerTiming( 3407): StartRecoverySystemService took to complete: 0ms
02-22 03:47:59.634 V/RescueParty( 3407): Disabled because of active USB connection
02-22 03:47:59.634 I/SystemServer( 3407): StartLightsService
02-22 03:47:59.634 I/SystemServiceManager( 3407): Starting com.android.server.lights.LightsService
02-22 03:47:59.635 D/SystemServerTiming( 3407): StartLightsService took to complete: 0ms
02-22 03:47:59.635 I/SystemServer( 3407): StartSidekickService
02-22 03:47:59.635 D/SystemServerTiming( 3407): StartSidekickService took to complete: 0ms
02-22 03:47:59.635 I/SystemServer( 3407): StartDisplayManager
02-22 03:47:59.635 I/SystemServiceManager( 3407): Starting com.android.server.display.DisplayManagerService
02-22 03:47:59.637 D/SystemServerTiming( 3407): StartDisplayManager took to complete: 3ms
02-22 03:47:59.637 I/SystemServer( 3407): WaitForDisplay
02-22 03:47:59.637 I/SystemServiceManager( 3407): Starting phase 100
02-22 03:47:59.650 I/DisplayManagerService( 3407): Display device added: DisplayDeviceInfo{"内置屏幕": uniqueId="local:0", 1920 x 1080, modeId 1, defaultModeId 1, supportedModes [{id=1, width=1920, height=1080, fps=60.000004}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@40f3c928, density 213, 320.0 x 320.0 dpi, appVsyncOff 1000000, presDeadline 16666666, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
02-22 03:47:59.651 D/SurfaceFlinger( 3250): Set power mode=2, type=0 flinger=0xfa0244858000
02-22 03:47:59.653 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:47:59.653 D/SystemServerTiming( 3407): WaitForDisplay took to complete: 16ms
02-22 03:47:59.653 I/SystemServer( 3407): StartPackageManagerService
02-22 03:47:59.653 I/DisplayManagerService( 3407): Display device changed state: "内置屏幕", ON
02-22 03:47:59.666 D/SELinuxMMAC( 3407): Using policy file /system/etc/selinux/plat_mac_permissions.xml
02-22 03:47:59.667 D/SELinuxMMAC( 3407): Using policy file /vendor/etc/selinux/vendor_mac_permissions.xml
02-22 03:47:59.670 D/FallbackCategoryProvider( 3407): Found 1 fallback categories
02-22 03:47:59.778 E/display ( 3242): threadLoop invalid uevent remove@/bus/pci/drivers/hif_pci
02-22 03:47:59.782 D/PackageManager( 3407): No files in app dir /product/overlay
02-22 03:47:59.785 W/PackageManager( 3407): Failed to parse /system/framework/oat: Missing base APK in /system/framework/oat
02-22 03:47:59.785 W/PackageManager( 3407): Failed to parse /system/framework/arm64: Missing base APK in /system/framework/arm64
02-22 03:47:59.786 W/PackageManager( 3407): Failed to parse /system/framework/arm: Missing base APK in /system/framework/arm
02-22 03:47:59.798 E/display ( 3242): threadLoop invalid uevent remove@/module/wlan
02-22 03:47:59.822 E/        ( 3247): retrying to open(FSL_SENS_HUB)
02-22 03:47:59.888 I/ServiceManager( 3268): Waiting for service package_native...
02-22 03:47:59.890 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:47:59.913 D/PackageManager( 3407): No files in app dir /vendor/priv-app
02-22 03:47:59.920 D/PackageManager( 3407): No files in app dir /odm/priv-app
02-22 03:47:59.920 D/PackageManager( 3407): No files in app dir /odm/app
02-22 03:47:59.920 D/PackageManager( 3407): No files in app dir /oem/app
02-22 03:47:59.921 D/PackageManager( 3407): No files in app dir /system/product/priv-app
02-22 03:47:59.921 D/PackageManager( 3407): No files in app dir /system/product/app
02-22 03:47:59.921 I/PackageManager( 3407): Finished scanning system apps. Time: 148 ms, packageCount: 88 , timePerPackage: 1 , cached: 88
02-22 03:47:59.941 W/PackageParser( 3407): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.MOUNT_UNMOUNT_FILESYSTEMS in package: com.neolix.videoRecorder at: Binary XML file line #14
02-22 03:47:59.942 I/PackageBackwardCompatibility( 3407): Loaded android.content.pm.OrgApacheHttpLegacyUpdater
02-22 03:47:59.942 I/PackageBackwardCompatibility( 3407): Could not find android.content.pm.AndroidTestBaseUpdater, ignoring
02-22 03:47:59.944 D/PackageManager( 3407): No files in app dir /data/app-private
02-22 03:47:59.944 I/PackageManager( 3407): Finished scanning non-system apps. Time: 23 ms, packageCount: 2 , timePerPackage: 11 , cached: 1
02-22 03:47:59.948 I/PackageManager( 3407): Time to scan packages: 0.174 seconds
02-22 03:47:59.952 V/PackageManager( 3407): reconcileAppsData for null u0 0x1 migrateAppData=true
02-22 03:47:59.948 W/Binder:3263_1( 3263): type=1400 audit(0.0:576): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:47:59.948 W/Binder:3263_1( 3263): type=1400 audit(0.0:577): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:47:59.955 I/SELinux ( 3263): SELinux: Loaded file_contexts
02-22 03:47:59.952 W/Binder:3263_1( 3263): type=1400 audit(0.0:578): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:48:00.001 V/PackageManager( 3407): reconcileAppsData finished 21 packages
02-22 03:48:00.003 D/SystemServerInitThreadPool( 3407): Started executing prepareAppData
02-22 03:47:59.952 I/chatty  ( 3263): uid=0(root) Binder:3263_2 identical 2 lines
02-22 03:47:59.952 W/Binder:3263_1( 3263): type=1400 audit(0.0:581): avc: denied { dac_read_search } for capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
02-22 03:48:00.067 E/PackageManager( 3407): There should probably be a verifier, but, none were found
02-22 03:48:00.071 D/PackageManager( 3407): Ephemeral resolver NOT found; no matching intent filters
02-22 03:48:00.071 D/PackageManager( 3407): Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
02-22 03:48:00.071 D/PackageManager( 3407): Clear ephemeral installer activity
02-22 03:48:00.077 W/installd( 3263): Ignoring /data/data/X3Spv81RIFil,BUIjwMwoKeHaoG/vhKpxfcYk38h9tv274NSbB with unexpected GID 0 instead of 10056
02-22 03:48:00.117 D/SystemServerTimingAsync( 3407): AppDataFixup took to complete: 114ms
02-22 03:48:00.164 I/system_server( 3407): Explicit concurrent copying GC freed 19932(1048KB) AllocSpace objects, 8(292KB) LOS objects, 42% free, 3MB/5MB, paused 88us total 86.356ms
02-22 03:48:00.166 D/SystemServerTiming( 3407): StartPackageManagerService took to complete: 513ms
02-22 03:48:00.167 I/SystemServer( 3407): StartOtaDexOptService
02-22 03:48:00.168 D/OTADexopt( 3407): No upgrade, skipping A/B artifacts check.
02-22 03:48:00.168 D/SystemServerTiming( 3407): StartOtaDexOptService took to complete: 0ms
02-22 03:48:00.168 I/SystemServer( 3407): StartUserManagerService
02-22 03:48:00.168 I/SystemServiceManager( 3407): Starting com.android.server.pm.UserManagerService$LifeCycle
02-22 03:48:00.169 D/SystemServerTiming( 3407): StartUserManagerService took to complete: 0ms
02-22 03:48:00.169 I/SystemServer( 3407): InitAttributerCache
02-22 03:48:00.169 D/SystemServerTiming( 3407): InitAttributerCache took to complete: 0ms
02-22 03:48:00.169 I/SystemServer( 3407): SetSystemProcess
02-22 03:48:00.175 I/lowmemorykiller( 3249): lmkd data connection established
02-22 03:48:00.176 D/SystemServerTiming( 3407): SetSystemProcess took to complete: 7ms
02-22 03:48:00.180 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.soundtrigger@2.0::ISoundTriggerHw/default in either framework or device manifest.
02-22 03:48:00.180 E/SoundTriggerHwService( 3252): could not read implementation properties
02-22 03:48:00.182 I/SystemServer( 3407): StartOverlayManagerService
02-22 03:48:00.183 D/SystemServerTiming( 3407): StartOverlayManagerService took to complete: 1ms
02-22 03:48:00.183 D/SystemServerInitThreadPool( 3407): Started executing Init OverlayManagerService
02-22 03:48:00.184 I/SystemServer( 3407): StartBatteryService
02-22 03:48:00.184 D/SystemServerInitThreadPool( 3407): Started executing StartSensorService
02-22 03:48:00.184 I/SystemServiceManager( 3407): Starting com.android.server.BatteryService
02-22 03:48:00.184 D/SensorService( 3407): nuSensorService starting...
02-22 03:48:00.188 I/ServiceManagement( 3407): getService: Trying again for android.hardware.sensors@1.0::ISensors/default...
02-22 03:48:00.188 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.health@2.0::IHealth
02-22 03:48:00.212 E/LightsService( 3407): Light requested not available on this device. 3
02-22 03:48:00.213 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:48:00.214 I/chatty  ( 3407): uid=1000(system) batterystats-wo identical 1 line
02-22 03:48:00.218 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:48:00.251 I/storaged( 3268): storaged: Start
02-22 03:48:00.252 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:00.253 I/HealthServiceWrapper( 3407): health: HealthServiceWrapper listening to instance default
02-22 03:48:00.253 I/BatteryService( 3407): health: Waited 1ms and received the update.
02-22 03:48:00.255 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.health@2.0::IHealth
02-22 03:48:00.255 W/SystemServiceManager( 3407): Service com.android.server.BatteryService took 71 ms in onStart
02-22 03:48:00.255 D/SystemServerTiming( 3407): StartBatteryService took to complete: 72ms
02-22 03:48:00.255 I/SystemServer( 3407): StartUsageService
02-22 03:48:00.255 I/SystemServiceManager( 3407): Starting com.android.server.usage.UsageStatsService
02-22 03:48:00.277 I/UsageStatsService( 3407): User[0] Rollover scheduled @ 2020-02-23 02:46:02(1582425962694)
02-22 03:48:00.278 D/SystemServerTiming( 3407): StartUsageService took to complete: 22ms
02-22 03:48:00.278 I/SystemServer( 3407): StartWebViewUpdateService
02-22 03:48:00.278 I/SystemServiceManager( 3407): Starting com.android.server.webkit.WebViewUpdateService
02-22 03:48:00.281 D/SystemServerTiming( 3407): StartWebViewUpdateService took to complete: 3ms
02-22 03:48:00.281 I/SystemServer( 3407): StartBinderCallsStatsService
02-22 03:48:00.281 D/SystemServerTiming( 3407): StartBinderCallsStatsService took to complete: 1ms
02-22 03:48:00.282 I/SystemServer( 3407): StartKeyAttestationApplicationIdProviderService
02-22 03:48:00.282 D/SystemServerInitThreadPool( 3407): Started executing SecondaryZygotePreload
02-22 03:48:00.282 I/SystemServer( 3407): SecondaryZygotePreload
02-22 03:48:00.283 D/SystemServerTiming( 3407): StartKeyAttestationApplicationIdProviderService took to complete: 1ms
02-22 03:48:00.283 I/SystemServer( 3407): StartKeyChainSystemService
02-22 03:48:00.283 I/SystemServiceManager( 3407): Starting com.android.server.security.KeyChainSystemService
02-22 03:48:00.283 I/Zygote  ( 3407): Process: zygote socket RESERVED/zygote opened, supported ABIS: arm64-v8a
02-22 03:48:00.283 D/SystemServerTiming( 3407): StartKeyChainSystemService took to complete: 1ms
02-22 03:48:00.283 I/SystemServer( 3407): StartSchedulingPolicyService
02-22 03:48:00.285 D/SystemServerTiming( 3407): StartSchedulingPolicyService took to complete: 1ms
02-22 03:48:00.285 I/SystemServer( 3407): StartTelecomLoaderService
02-22 03:48:00.285 I/SystemServiceManager( 3407): Starting com.android.server.telecom.TelecomLoaderService
02-22 03:48:00.285 D/SystemServerTiming( 3407): StartTelecomLoaderService took to complete: 0ms
02-22 03:48:00.285 I/SystemServer( 3407): StartTelephonyRegistry
02-22 03:48:00.287 D/SystemServerTiming( 3407): StartTelephonyRegistry took to complete: 2ms
02-22 03:48:00.287 I/SystemServer( 3407): StartEntropyMixer
02-22 03:48:00.291 W/EntropyMixer( 3407): Failed to add HW RNG output to entropy pool
02-22 03:48:00.291 W/EntropyMixer( 3407): java.io.IOException: read failed: ENODEV (No such device)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.IoBridge.read(IoBridge.java:511)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at java.io.FileInputStream.read(FileInputStream.java:307)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.RandomBlock.fromStream(RandomBlock.java:56)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.RandomBlock.fromFile(RandomBlock.java:46)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.EntropyMixer.addHwRandomEntropy(EntropyMixer.java:205)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.EntropyMixer.<init>(EntropyMixer.java:115)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.EntropyMixer.<init>(EntropyMixer.java:97)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.SystemServer.startOtherServices(SystemServer.java:829)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.SystemServer.run(SystemServer.java:447)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.server.SystemServer.main(SystemServer.java:300)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at java.lang.reflect.Method.invoke(Native Method)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:893)
02-22 03:48:00.291 W/EntropyMixer( 3407): Caused by: android.system.ErrnoException: read failed: ENODEV (No such device)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.Linux.readBytes(Native Method)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.Linux.read(Linux.java:184)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.BlockGuardOs.read(BlockGuardOs.java:254)
02-22 03:48:00.291 W/EntropyMixer( 3407):  at libcore.io.IoBridge.read(IoBridge.java:501)
02-22 03:48:00.291 W/EntropyMixer( 3407):  ... 12 more
02-22 03:48:00.291 I/EntropyMixer( 3407): Writing entropy...
02-22 03:48:00.297 D/SystemServerTiming( 3407): StartEntropyMixer took to complete: 9ms
02-22 03:48:00.297 I/SystemServer( 3407): StartAccountManagerService
02-22 03:48:00.297 I/SystemServiceManager( 3407): Starting com.android.server.accounts.AccountManagerService$Lifecycle
02-22 03:48:00.301 D/SystemServerTiming( 3407): StartAccountManagerService took to complete: 5ms
02-22 03:48:00.301 I/SystemServer( 3407): StartContentService
02-22 03:48:00.301 I/SystemServiceManager( 3407): Starting com.android.server.content.ContentService$Lifecycle
02-22 03:48:00.303 D/SystemServerTiming( 3407): StartContentService took to complete: 2ms
02-22 03:48:00.303 I/SystemServer( 3407): InstallSystemProviders
02-22 03:48:00.304 I/Zygote  ( 3407): Process: zygote socket RESERVED/zygote_secondary opened, supported ABIS: armeabi-v7a,armeabi
02-22 03:48:00.315 I/Zygote  ( 3221): Lazily preloading resources.
02-22 03:48:00.315 D/Zygote  ( 3221): begin preload
02-22 03:48:00.315 I/Zygote  ( 3221): Installing ICU cache reference pinning...
02-22 03:48:00.315 I/Zygote  ( 3221): Preloading ICU data...
02-22 03:48:00.327 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:00.331 D/ZygoteInitTiming_lazy( 3221): BeginIcuCachePinning took to complete: 15ms
02-22 03:48:00.331 I/Zygote  ( 3221): Preloading classes...
02-22 03:48:00.356 D/SystemServerTiming( 3407): InstallSystemProviders took to complete: 52ms
02-22 03:48:00.356 I/SystemServer( 3407): StartDropBoxManager
02-22 03:48:00.356 I/SystemServiceManager( 3407): Starting com.android.server.DropBoxManagerService
02-22 03:48:00.357 D/SystemServerTiming( 3407): StartDropBoxManager took to complete: 1ms
02-22 03:48:00.357 I/SystemServer( 3407): StartVibratorService
02-22 03:48:00.358 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
02-22 03:48:00.359 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
02-22 03:48:00.359 E/VibratorService( 3407): vibratorOff command failed (1).
02-22 03:48:00.362 D/SystemServerTiming( 3407): StartVibratorService took to complete: 4ms
02-22 03:48:00.362 I/SystemServer( 3407): StartConsumerIrService
02-22 03:48:00.363 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.ir@1.0::IConsumerIr/default in either framework or device manifest.
02-22 03:48:00.364 D/SystemServerTiming( 3407): StartConsumerIrService took to complete: 1ms
02-22 03:48:00.364 I/SystemServer( 3407): StartAlarmManagerService
02-22 03:48:00.364 I/SystemServiceManager( 3407): Starting com.android.server.AlarmManagerService
02-22 03:48:00.365 D/AlarmManagerService( 3407): Kernel timezone updated to 0 minutes west of GMT
02-22 03:48:00.370 D/SystemServerTiming( 3407): StartAlarmManagerService took to complete: 6ms
02-22 03:48:00.370 I/SystemServer( 3407): InitWatchdog
02-22 03:48:00.370 D/SystemServerTiming( 3407): InitWatchdog took to complete: 1ms
02-22 03:48:00.370 I/SystemServer( 3407): StartInputManagerService
02-22 03:48:00.371 I/InputManager( 3407): Initializing input manager, mUseDevInputEventForAudioJack=false
02-22 03:48:00.372 D/SystemServerTiming( 3407): StartInputManagerService took to complete: 1ms
02-22 03:48:00.372 I/SystemServer( 3407): StartWindowManagerService
02-22 03:48:00.404 I/Zygote  ( 3221): ...preloaded 0 classes in 73ms.
02-22 03:48:00.404 I/zygote  ( 3221): VMRuntime.preloadDexCaches starting
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches strings total=339243 before=12303 after=12303
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches types total=31355 before=7818 after=7820
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches fields total=140849 before=9174 after=9174
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches methods total=247792 before=12783 after=12783
02-22 03:48:00.480 I/zygote  ( 3221): VMRuntime.preloadDexCaches finished
02-22 03:48:00.480 D/ZygoteInitTiming_lazy( 3221): PreloadClasses took to complete: 149ms
02-22 03:48:00.514 I/zygote  ( 3221): Background concurrent copying GC freed 25398(3MB) AllocSpace objects, 160(2MB) LOS objects, 49% free, 2MB/4MB, paused 378us total 103.375ms
02-22 03:48:00.520 I/zygote  ( 3221): Thread[6,tid=3493,Native,Thread*=0xf3d68000,peer=0x13200088,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
02-22 03:48:00.521 D/MtpDeviceJNI( 3221): register_android_mtp_MtpDevice
02-22 03:48:00.521 I/zygote  ( 3221): Thread[6,tid=3493,Native,Thread*=0xf3d68000,peer=0x13200088,"Thread-1"] recursive attempt to load library "/system/lib/libmedia_jni.so"
02-22 03:48:00.588 I/Zygote  ( 3221): Preloading resources...
02-22 03:48:00.597 W/Resources( 3221): Preloaded drawable resource #0x1080265 (android:drawable/dialog_background_material) that varies with configuration!!
02-22 03:48:00.616 I/Zygote  ( 3221): ...preloaded 64 resources in 28ms.
02-22 03:48:00.621 I/Zygote  ( 3221): ...preloaded 41 resources in 5ms.
02-22 03:48:00.621 D/ZygoteInitTiming_lazy( 3221): PreloadResources took to complete: 140ms
02-22 03:48:00.636 D/SystemServerInitThreadPool( 3407): Finished executing Init OverlayManagerService
02-22 03:48:00.636 D/SystemServerInitThreadPool( 3407): Started executing SchedulingPolicyService.<init>
02-22 03:48:00.642 I/SchedulingPolicyService( 3407): Moving 3270 back to group default
02-22 03:48:00.643 D/SystemServerInitThreadPool( 3407): Finished executing SchedulingPolicyService.<init>
02-22 03:48:00.654 D/libEGL  ( 3221): loaded /vendor/lib/egl/libEGL_VIVANTE.so
02-22 03:48:00.660 D/SystemServerTimingAsync( 3407): AppDataPrepare took to complete: 543ms
02-22 03:48:00.661 I/PackageManager( 3407): Deferred reconcileAppsData finished 69 packages
02-22 03:48:00.661 D/SystemServerInitThreadPool( 3407): Finished executing prepareAppData
02-22 03:48:00.677 D/libEGL  ( 3221): loaded /vendor/lib/egl/libGLESv1_CM_VIVANTE.so
02-22 03:48:00.745 D/libEGL  ( 3221): loaded /vendor/lib/egl/libGLESv2_VIVANTE.so
02-22 03:48:00.798 I/Zygote  ( 3221): Preloading shared libraries...
02-22 03:48:00.809 I/Zygote  ( 3221): Uninstalled ICU cache reference pinning...
02-22 03:48:00.810 I/Zygote  ( 3221): Installed AndroidKeyStoreProvider in 1ms.
02-22 03:48:00.831 I/Zygote  ( 3221): Warmed up JCA providers in 21ms.
02-22 03:48:00.831 D/Zygote  ( 3221): end preload
02-22 03:48:00.831 D/SystemServerTimingAsync( 3407): SecondaryZygotePreload took to complete: 549ms
02-22 03:48:00.831 D/SystemServerInitThreadPool( 3407): Finished executing SecondaryZygotePreload
02-22 03:48:00.890 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:00.922 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:01.188 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:01.922 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:01.962 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:02.188 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:02.962 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:02.962 D/        ( 3247): sendrolon press sensor init
02-22 03:48:02.962 E/        ( 3247): Can`t find the press sensor!
02-22 03:48:03.010 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:03.188 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:04.010 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:04.074 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:04.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:05.074 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:05.142 E/        ( 3247): couldn't find 'mpl3115' input device
02-22 03:48:05.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:06.142 E/        ( 3247): retrying to open(mpl3115)
02-22 03:48:06.142 D/        ( 3247): sendrolon press sensor init
02-22 03:48:06.142 E/        ( 3247): Can`t find the press sensor!
02-22 03:48:06.182 E/        ( 3247): couldn't find 'isl29023 light sensor' input device
02-22 03:48:06.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:07.182 E/        ( 3247): retrying to open(isl29023 light sensor)
02-22 03:48:07.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:07.214 E/        ( 3247): couldn't find 'isl29023 light sensor' input device
02-22 03:48:08.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:08.214 E/        ( 3247): retrying to open(isl29023 light sensor)
02-22 03:48:08.254 E/        ( 3247): couldn't find 'isl29023 light sensor' input device
02-22 03:48:09.189 W/ServiceManagement( 3407): Waited one second for android.hardware.sensors@1.0::ISensors/default. Waiting another...
02-22 03:48:09.254 E/        ( 3247): retrying to open(isl29023 light sensor)
02-22 03:48:09.254 E//vendor/bin/hw/android.hardware.sensors@1.0-service( 3247): HAL specifies version 1.4, but does not implement inject_sensor_data()
02-22 03:48:09.254 E//vendor/bin/hw/android.hardware.sensors@1.0-service( 3247): HAL specifies version 1.4, but does not implement set_operation_mode()
02-22 03:48:09.255 I/ServiceManagement( 3247): Removing namespace from process name android.hardware.sensors@1.0-service to sensors@1.0-service.
02-22 03:48:09.255 I/android.hardware.sensors@1.0-service( 3247): Registration complete for android.hardware.sensors@1.0::ISensors/default.
02-22 03:48:09.256 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:09.256 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:09.256 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:09.256 D/        ( 3247): FSLSensorsHub sensor waht = 1 , enable = 0
02-22 03:48:09.256 D/        ( 3247): FSLSensorsHub sensor waht = 2 , enable = 0
02-22 03:48:09.257 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:09.257 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:09.257 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:09.257 D/        ( 3247): FSLSensorsHub sensor waht = 4 , enable = 0
02-22 03:48:09.258 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:09.258 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:09.258 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:09.258 D/        ( 3247): FSLSensorsHub sensor waht = 3 , enable = 0
02-22 03:48:09.258 D/        ( 3247): FSLSensorsHub sensor waht = 5 , enable = 0
02-22 03:48:09.258 D/        ( 3247): PressSensor mEnabled 0, Temperature mEnabled 0
02-22 03:48:09.259 D/        ( 3247): PressSensor mEnabled 0, Temperature mEnabled 0
02-22 03:48:09.266 D/SensorService( 3407): nuSensorService thread starting...
02-22 03:48:09.267 D/SensorService( 3407): new thread SensorEventAckReceiver
02-22 03:48:09.267 D/SystemServerTimingAsync( 3407): StartSensorService took to complete: 9084ms
02-22 03:48:09.267 D/SystemServerInitThreadPool( 3407): Finished executing StartSensorService
02-22 03:48:09.270 I/WindowManager( 3407): No existing display settings /data/system/display_settings.xml; starting empty
02-22 03:48:09.281 D/SystemServerTiming( 3407): StartWindowManagerService took to complete: 8909ms
02-22 03:48:09.281 I/SystemServer( 3407): SetWindowManagerService
02-22 03:48:09.299 D/SystemServerTiming( 3407): SetWindowManagerService took to complete: 19ms
02-22 03:48:09.299 I/SystemServer( 3407): WindowManagerServiceOnInitReady
02-22 03:48:09.315 D/SystemServerTiming( 3407): WindowManagerServiceOnInitReady took to complete: 16ms
02-22 03:48:09.315 D/SystemServerInitThreadPool( 3407): Started executing StartHidlServices
02-22 03:48:09.316 I/SystemServer( 3407): StartVrManagerService
02-22 03:48:09.316 I/SystemServiceManager( 3407): Starting com.android.server.vr.VrManagerService
02-22 03:48:09.317 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.vr@1.0::IVr/default in either framework or device manifest.
02-22 03:48:09.317 W/VrManagerService( 3407): init_native: Could not open IVr interface
02-22 03:48:09.317 D/SystemServerTimingAsync( 3407): StartHidlServices took to complete: 2ms
02-22 03:48:09.317 D/SystemServerInitThreadPool( 3407): Finished executing StartHidlServices
02-22 03:48:09.317 D/SystemServerTiming( 3407): StartVrManagerService took to complete: 2ms
02-22 03:48:09.317 I/SystemServer( 3407): StartInputManager
02-22 03:48:09.318 I/InputManager( 3407): Starting input manager
02-22 03:48:09.320 D/SystemServerTiming( 3407): StartInputManager took to complete: 2ms
02-22 03:48:09.320 I/SystemServer( 3407): DisplayManagerWindowManagerAndInputReady
02-22 03:48:09.320 D/SystemServerTiming( 3407): DisplayManagerWindowManagerAndInputReady took to complete: 0ms
02-22 03:48:09.320 I/SystemServer( 3407): StartBluetoothService
02-22 03:48:09.320 I/SystemServiceManager( 3407): Starting com.android.server.BluetoothService
02-22 03:48:09.321 D/BluetoothManagerService( 3407): Loading stored name and address
02-22 03:48:09.322 D/BluetoothManagerService( 3407): Stored bluetooth Name=iMX8,Address=null
02-22 03:48:09.322 D/BluetoothManagerService( 3407): Bluetooth persisted state: 0
02-22 03:48:09.322 D/BluetoothManagerService( 3407): Detected SystemUiUid: 10012
02-22 03:48:09.322 D/SystemServerTiming( 3407): StartBluetoothService took to complete: 2ms
02-22 03:48:09.322 I/SystemServer( 3407): IpConnectivityMetrics
02-22 03:48:09.322 I/SystemServiceManager( 3407): Starting com.android.server.connectivity.IpConnectivityMetrics
02-22 03:48:09.323 D/SystemServerTiming( 3407): IpConnectivityMetrics took to complete: 1ms
02-22 03:48:09.323 I/SystemServer( 3407): NetworkWatchlistService
02-22 03:48:09.323 I/SystemServiceManager( 3407): Starting com.android.server.net.watchlist.NetworkWatchlistService$Lifecycle
02-22 03:48:09.324 D/EventHub( 3407): No input device configuration file found for device 'sc-powerkey'.
02-22 03:48:09.327 I/WatchlistSettings( 3407): Reload watchlist settings done
02-22 03:48:09.328 I/WatchlistLoggingHandler( 3407): No need to aggregate record yet.
02-22 03:48:09.328 I/WatchlistLoggingHandler( 3407): Milliseconds spent on tryAggregateRecords(): 0
02-22 03:48:09.328 D/SystemServerTiming( 3407): NetworkWatchlistService took to complete: 5ms
02-22 03:48:09.328 I/SystemServer( 3407): PinnerService
02-22 03:48:09.328 I/SystemServiceManager( 3407): Starting com.android.server.PinnerService
02-22 03:48:09.332 W/EventHub( 3407): Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
02-22 03:48:09.332 I/EventHub( 3407): wakeMechanism=EPOLLWAKEUP, usingClockIoctl=true
02-22 03:48:09.332 I/EventHub( 3407): New device: id=1, fd=114, path='/dev/input/event0', name='sc-powerkey', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false,
02-22 03:48:09.332 D/SystemServerTiming( 3407): PinnerService took to complete: 4ms
02-22 03:48:09.332 I/SystemServer( 3407): StartInputMethodManagerLifecycle
02-22 03:48:09.332 I/SystemServiceManager( 3407): Starting com.android.server.InputMethodManagerService$Lifecycle
02-22 03:48:09.337 I/InputReader( 3407): Device added: id=-1, name='Virtual', sources=0x00000301
02-22 03:48:09.337 I/InputReader( 3407): Device added: id=1, name='sc-powerkey', sources=0x00000101
02-22 03:48:09.338 D/SystemServerTiming( 3407): StartInputMethodManagerLifecycle took to complete: 6ms
02-22 03:48:09.338 I/SystemServer( 3407): StartAccessibilityManagerService
02-22 03:48:09.342 D/SystemServerTiming( 3407): StartAccessibilityManagerService took to complete: 4ms
02-22 03:48:09.342 I/SystemServer( 3407): MakeDisplayReady
02-22 03:48:09.344 I/ActivityManager( 3407): Config changes=20005df8 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2}
02-22 03:48:09.350 I/ActivityManager( 3407): Override config changes=60007dfc {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h811dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1080) mWindowingMode=fullscreen mActivityType=undefined} s.2} for displayId=0
02-22 03:48:09.358 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:09.358 I/ActivityManager( 3407): Config changes=20000400 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3}
02-22 03:48:09.363 I/ActivityManager( 3407): Override config changes=20000400 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land ?uimode ?night -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.3} for displayId=0
02-22 03:48:09.372 D/SystemServerTiming( 3407): MakeDisplayReady took to complete: 29ms
02-22 03:48:09.373 I/SystemServer( 3407): StartStorageManagerService
02-22 03:48:09.373 I/SystemServiceManager( 3407): Starting com.android.server.StorageManagerService$Lifecycle
02-22 03:48:09.379 D/SystemServerTiming( 3407): StartStorageManagerService took to complete: 6ms
02-22 03:48:09.379 I/SystemServer( 3407): StartStorageStatsService
02-22 03:48:09.379 I/SystemServiceManager( 3407): Starting com.android.server.usage.StorageStatsService$Lifecycle
02-22 03:48:09.380 D/StorageManagerService( 3407): Thinking about init, mSystemReady=false, mDaemonConnected=true
02-22 03:48:09.380 D/StorageManagerService( 3407): Thinking about reset, mSystemReady=false, mDaemonConnected=true
02-22 03:48:09.358 I/chatty  ( 3407): uid=1000(system) InputReader identical 1 line
02-22 03:48:09.373 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:09.381 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:48:09.384 D/SystemServerTiming( 3407): StartStorageStatsService took to complete: 5ms
02-22 03:48:09.384 I/SystemServer( 3407): StartUiModeManager
02-22 03:48:09.384 I/SystemServiceManager( 3407): Starting com.android.server.UiModeManagerService
02-22 03:48:09.386 D/SystemServerInitThreadPool( 3407): Started executing UiModeManager.onStart
02-22 03:48:09.386 I/ActivityManager( 3407): Config changes=200 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4}
02-22 03:48:09.389 D/SystemServerTiming( 3407): StartUiModeManager took to complete: 5ms
02-22 03:48:09.389 I/SystemServer( 3407): UpdatePackagesIfNeeded
02-22 03:48:09.389 D/SystemServerTiming( 3407): UpdatePackagesIfNeeded took to complete: 0ms
02-22 03:48:09.389 I/SystemServer( 3407): PerformFstrimIfNeeded
02-22 03:48:09.390 D/SystemServerTiming( 3407): PerformFstrimIfNeeded took to complete: 1ms
02-22 03:48:09.390 I/SystemServer( 3407): StartLockSettingsService
02-22 03:48:09.390 I/SystemServiceManager( 3407): Starting com.android.server.locksettings.LockSettingsService$Lifecycle
02-22 03:48:09.400 I/ActivityManager( 3407): Override config changes=200 {1.0 ?mcc?mnc [zh_CN_#Hans] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.4} for displayId=0
02-22 03:48:09.404 D/SystemServerInitThreadPool( 3407): Finished executing UiModeManager.onStart
02-22 03:48:09.407 D/SystemServerTiming( 3407): StartLockSettingsService took to complete: 17ms
02-22 03:48:09.407 I/SystemServer( 3407): StartPersistentDataBlock
02-22 03:48:09.407 I/SystemServiceManager( 3407): Starting com.android.server.PersistentDataBlockService
02-22 03:48:09.408 D/SystemServerTiming( 3407): StartPersistentDataBlock took to complete: 0ms
02-22 03:48:09.408 I/SystemServer( 3407): StartOemLockService
02-22 03:48:09.408 D/SystemServerInitThreadPool( 3407): Started executing PersistentDataBlockService.onStart
02-22 03:48:09.408 I/SystemServiceManager( 3407): Starting com.android.server.oemlock.OemLockService
02-22 03:48:09.382 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:48:09.408 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.oemlock@1.0::IOemLock/default in either framework or device manifest.
02-22 03:48:09.409 E/PersistentDataBlockService( 3407): not able to find package
02-22 03:48:09.409 E/PersistentDataBlockService( 3407): android.content.pm.PackageManager$NameNotFoundException:
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at android.app.ApplicationPackageManager.getPackageUidAsUser(ApplicationPackageManager.java:299)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.PersistentDataBlockService.getAllowedUid(PersistentDataBlockService.java:113)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.PersistentDataBlockService.lambda$onStart$0(PersistentDataBlockService.java:126)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.-$$Lambda$PersistentDataBlockService$EZl9OYaT2eNL7kfSr2nKUBjxidk.run(Unknown Source:2)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.SystemServerInitThreadPool.lambda$submit$0(SystemServerInitThreadPool.java:64)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.server.-$$Lambda$SystemServerInitThreadPool$7wfLGkZF7FvYZv7xj3ghvuiJJGk.run(Unknown Source:4)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:458)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
02-22 03:48:09.409 E/PersistentDataBlockService( 3407):  at com.android.internal.util.ConcurrentUtils$1$1.run(ConcurrentUtils.java:62)
02-22 03:48:09.409 I/OemLock ( 3407): OemLock HAL not present on device
02-22 03:48:09.409 I/OemLock ( 3407): Using persistent data block based lock
02-22 03:48:09.410 D/SystemServerTiming( 3407): StartOemLockService took to complete: 3ms
02-22 03:48:09.410 I/SystemServer( 3407): StartDeviceIdleController
02-22 03:48:09.410 I/SystemServiceManager( 3407): Starting com.android.server.DeviceIdleController
02-22 03:48:09.413 D/SystemServerTiming( 3407): StartDeviceIdleController took to complete: 3ms
02-22 03:48:09.413 I/SystemServer( 3407): StartDevicePolicyManager
02-22 03:48:09.413 I/SystemServiceManager( 3407): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
02-22 03:48:09.418 D/SystemServerTiming( 3407): StartDevicePolicyManager took to complete: 5ms
02-22 03:48:09.418 I/SystemServer( 3407): StartStatusBarManagerService
02-22 03:48:09.419 D/SystemServerTiming( 3407): StartStatusBarManagerService took to complete: 1ms
02-22 03:48:09.419 I/SystemServer( 3407): StartClipboardService
02-22 03:48:09.419 I/SystemServiceManager( 3407): Starting com.android.server.clipboard.ClipboardService
02-22 03:48:09.420 D/SystemServerTiming( 3407): StartClipboardService took to complete: 1ms
02-22 03:48:09.420 I/SystemServer( 3407): StartNetworkManagementService
02-22 03:48:09.422 I/NetworkManagement( 3407): onDaemonConnected()
02-22 03:48:09.423 D/SystemServerTiming( 3407): StartNetworkManagementService took to complete: 3ms
02-22 03:48:09.423 I/SystemServer( 3407): StartIpSecService
02-22 03:48:09.425 D/SystemServerTiming( 3407): StartIpSecService took to complete: 2ms
02-22 03:48:09.425 I/SystemServer( 3407): StartTextServicesManager
02-22 03:48:09.425 I/SystemServiceManager( 3407): Starting com.android.server.TextServicesManagerService$Lifecycle
02-22 03:48:09.427 D/SystemServerTiming( 3407): StartTextServicesManager took to complete: 1ms
02-22 03:48:09.427 I/SystemServer( 3407): StartTextClassificationManagerService
02-22 03:48:09.427 I/SystemServiceManager( 3407): Starting com.android.server.textclassifier.TextClassificationManagerService$Lifecycle
02-22 03:48:09.428 D/SystemServerTiming( 3407): StartTextClassificationManagerService took to complete: 1ms
02-22 03:48:09.428 I/SystemServer( 3407): StartNetworkScoreService
02-22 03:48:09.428 I/SystemServiceManager( 3407): Starting com.android.server.NetworkScoreService$Lifecycle
02-22 03:48:09.429 I/NetworkScoreService( 3407): Registering network_score
02-22 03:48:09.430 D/SystemServerInitThreadPool( 3407): Finished executing PersistentDataBlockService.onStart
02-22 03:48:09.430 D/SystemServerTiming( 3407): StartNetworkScoreService took to complete: 3ms
02-22 03:48:09.430 I/SystemServer( 3407): StartNetworkStatsService
02-22 03:48:09.433 D/SystemServerTiming( 3407): StartNetworkStatsService took to complete: 2ms
02-22 03:48:09.433 I/SystemServer( 3407): StartNetworkPolicyManagerService
02-22 03:48:09.436 D/SystemServerTiming( 3407): StartNetworkPolicyManagerService took to complete: 4ms
02-22 03:48:09.436 I/SystemServer( 3407): StartWifi
02-22 03:48:09.439 I/SystemServiceManager( 3407): Starting com.android.server.wifi.WifiService
02-22 03:48:09.512 D/WifiApConfigStore( 3407): 2G band allowed channels are:1,6,11
02-22 03:48:09.519 I/WifiScoringParams( 3407): rssi2=-85:-85:-73:-60,rssi5=-82:-82:-70:-57,pps=0:1:100,horizon=15,nud=8,expid=0
02-22 03:48:09.545 D/WifiStateMachine( 3407): EnableConnectedMacRandomization Setting changed to false
02-22 03:48:09.545 E/WifiStateMachine( 3407): getWifiLinkLayerStats called without an interface
02-22 03:48:09.546 D/WifiStateMachinePrime( 3407): Starting Wifi in WifiDisabledState
02-22 03:48:09.546 D/WifiStateMachinePrime( 3407): Entering WifiDisabledState
02-22 03:48:09.546 D/ActiveModeManager( 3407): sending scan available broadcast: false
02-22 03:48:09.547 D/WifiOpenNetworkNotifier( 3407): Settings toggle enabled=true
02-22 03:48:09.547 D/WifiCarrierNetworkNotifier( 3407): Settings toggle enabled=true
02-22 03:48:09.548 D/WakeupController( 3407): WifiWake enabled
02-22 03:48:09.549 D/WifiController( 3407): isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false, isLocationModeActive = true
02-22 03:48:09.551 E/SupplicantStaIfaceHal( 3407): Can't call setDebugParams, ISupplicant is null
02-22 03:48:09.551 W/WifiDiags( 3407): no ring buffers found
02-22 03:48:09.551 W/WifiDiags( 3407): Failed to start packet fate monitoring
02-22 03:48:09.552 I/WifiService( 3407): Registering wifi
02-22 03:48:09.552 D/SystemServerTiming( 3407): StartWifi took to complete: 116ms
02-22 03:48:09.552 I/SystemServer( 3407): StartWifiScanning
02-22 03:48:09.553 I/SystemServiceManager( 3407): Starting com.android.server.wifi.scanner.WifiScanningService
02-22 03:48:09.553 I/WifiScanningService( 3407): Creating wifiscanner
02-22 03:48:09.554 I/WifiScanningService( 3407): Publishing wifiscanner
02-22 03:48:09.555 D/SystemServerTiming( 3407): StartWifiScanning took to complete: 3ms
02-22 03:48:09.555 I/SystemServer( 3407): StartWifiP2P
02-22 03:48:09.555 I/SystemServiceManager( 3407): Starting com.android.server.wifi.p2p.WifiP2pService
02-22 03:48:09.561 W/HalDevMgr( 3407): isWifiStarted called but mWifi is null!?
02-22 03:48:09.561 I/WifiP2pService( 3407): Registering wifip2p
02-22 03:48:09.562 D/SystemServerTiming( 3407): StartWifiP2P took to complete: 7ms
02-22 03:48:09.562 I/SystemServer( 3407): StartEthernet
02-22 03:48:09.563 I/SystemServiceManager( 3407): Starting com.android.server.ethernet.EthernetService
02-22 03:48:09.563 I/EthernetService( 3407): Registering service ethernet
02-22 03:48:09.564 D/SystemServerTiming( 3407): StartEthernet took to complete: 1ms
02-22 03:48:09.564 I/SystemServer( 3407): StartConnectivityService
02-22 03:48:09.565 D/ConnectivityService( 3407): ConnectivityService starting up
02-22 03:48:09.567 D/ConnectivityService( 3407): wifiOnly=true
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 10
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 11
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 12
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 14
02-22 03:48:09.567 E/ConnectivityService( 3407): Ignoring protectedNetwork 15
02-22 03:48:09.575 D/SystemServerTiming( 3407): StartConnectivityService took to complete: 12ms
02-22 03:48:09.575 I/SystemServer( 3407): StartNsdService
02-22 03:48:09.576 D/NsdService( 3407): Network service discovery is enabled
02-22 03:48:09.577 D/SystemServerTiming( 3407): StartNsdService took to complete: 2ms
02-22 03:48:09.578 I/SystemServer( 3407): StartSystemUpdateManagerService
02-22 03:48:09.578 I/SystemUpdateManagerService( 3407): No existing info file /data/system/system-update-info.xml
02-22 03:48:09.578 D/SystemServerTiming( 3407): StartSystemUpdateManagerService took to complete: 1ms
02-22 03:48:09.578 I/SystemServer( 3407): StartUpdateLockService
02-22 03:48:09.579 D/SystemServerTiming( 3407): StartUpdateLockService took to complete: 1ms
02-22 03:48:09.580 I/SystemServer( 3407): StartNotificationManager
02-22 03:48:09.580 I/SystemServiceManager( 3407): Starting com.android.server.notification.NotificationManagerService
02-22 03:48:09.584 D/ConditionProviders.SCP( 3407): new ScheduleConditionProvider()
02-22 03:48:09.594 I/NotificationListeners( 3407): Read notification listener permissions from xml
02-22 03:48:09.595 I/NotificationAssistants( 3407): Read notification assistant permissions from xml
02-22 03:48:09.595 I/ConditionProviders( 3407): Read condition provider permissions from xml
02-22 03:48:09.598 D/SystemServerTiming( 3407): StartNotificationManager took to complete: 19ms
02-22 03:48:09.598 I/SystemServer( 3407): StartDeviceMonitor
02-22 03:48:09.598 I/SystemServiceManager( 3407): Starting com.android.server.storage.DeviceStorageMonitorService
02-22 03:48:09.600 D/SystemServerTiming( 3407): StartDeviceMonitor took to complete: 2ms
02-22 03:48:09.600 I/SystemServer( 3407): StartLocationManagerService
02-22 03:48:09.601 D/SystemServerTiming( 3407): StartLocationManagerService took to complete: 0ms
02-22 03:48:09.601 I/SystemServer( 3407): StartCountryDetectorService
02-22 03:48:09.601 D/SystemServerTiming( 3407): StartCountryDetectorService took to complete: 1ms
02-22 03:48:09.601 I/SystemServer( 3407): StartSearchManagerService
02-22 03:48:09.601 I/SystemServiceManager( 3407): Starting com.android.server.search.SearchManagerService$Lifecycle
02-22 03:48:09.602 D/SystemServerTiming( 3407): StartSearchManagerService took to complete: 1ms
02-22 03:48:09.603 I/SystemServer( 3407): StartWallpaperManagerService
02-22 03:48:09.603 I/SystemServiceManager( 3407): Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle
02-22 03:48:09.604 D/SystemServerTiming( 3407): StartWallpaperManagerService took to complete: 1ms
02-22 03:48:09.604 I/SystemServer( 3407): StartAudioService
02-22 03:48:09.604 I/SystemServiceManager( 3407): Starting com.android.server.audio.AudioService$Lifecycle
02-22 03:48:09.606 W/TelecomManager( 3407): Telecom Service not found.
02-22 03:48:09.608 D/PermissionCache( 3252): checking android.permission.MODIFY_AUDIO_ROUTING for uid=1000 => granted (704 us)
02-22 03:48:09.608 D/PermissionCache( 3252): checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (754 us)
02-22 03:48:09.609 W/AudioFlinger( 3252): no wake lock to update, system not ready yet
02-22 03:48:09.610 W/DeviceHAL( 3231): Error from HAL Device in function set_mic_mute: Function not implemented
02-22 03:48:09.620 D/AudioFlinger( 3252): isLowRamDevice:false totalMemory:5996650496 mClientSharedHeapSize:33554432
02-22 03:48:09.621 D/SystemServerTiming( 3407): StartAudioService took to complete: 18ms
02-22 03:48:09.621 I/SystemServer( 3407): StartDockObserver
02-22 03:48:09.621 I/SystemServiceManager( 3407): Starting com.android.server.DockObserver
02-22 03:48:09.622 W/DockObserver( 3407): This kernel does not have dock station support
02-22 03:48:09.623 D/SystemServerTiming( 3407): StartDockObserver took to complete: 2ms
02-22 03:48:09.623 I/SystemServer( 3407): StartWiredAccessoryManager
02-22 03:48:09.624 W/WiredAccessoryManager( 3407): This kernel does not have wired headset support
02-22 03:48:09.624 W/WiredAccessoryManager( 3407): This kernel does not have usb audio support
02-22 03:48:09.624 W/WiredAccessoryManager( 3407): This kernel does not have HDMI audio support
02-22 03:48:09.624 D/SystemServerTiming( 3407): StartWiredAccessoryManager took to complete: 1ms
02-22 03:48:09.624 I/SystemServer( 3407): StartUsbService
02-22 03:48:09.624 I/SystemServiceManager( 3407): Starting com.android.server.usb.UsbService$Lifecycle
02-22 03:48:09.625 E/UsbDeviceManager( 3407): failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr
02-22 03:48:09.628 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb.gadget@1.0::IUsbGadget
02-22 03:48:09.649 W/StorageManagerService( 3407): No primary storage defined yet; hacking together a stub
02-22 03:48:09.650 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:09.651 I/UsbDeviceManager( 3407): Usb gadget hal service started android.hardware.usb.gadget@1.0::IUsbGadget default
02-22 03:48:09.651 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb.gadget@1.0::IUsbGadget
02-22 03:48:09.653 E/UsbDeviceManager( 3407): prcessing MSG_GET_CURRENT_USB_FUNCTIONS
02-22 03:48:09.653 E/UsbDeviceManager( 3407): updating mCurrentFunctions
02-22 03:48:09.653 E/UsbDeviceManager( 3407): mCurrentFunctions:0applied:1
02-22 03:48:09.653 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb.gadget@1.0::IUsbGadget
02-22 03:48:09.659 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:09.660 I/UsbPortManager( 3407): Usb hal service started android.hardware.usb@1.0::IUsb default
02-22 03:48:09.660 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.usb@1.0::IUsb
02-22 03:48:09.661 I/android.hardware.usb@1.1-service.imx( 3248): registering callback
02-22 03:48:09.662 E/android.hardware.usb@1.1-service.imx( 3248): creating thread
02-22 03:48:09.662 I/android.hardware.usb@1.1-service.imx( 3248): port0
02-22 03:48:09.662 I/android.hardware.usb@1.1-service.imx( 3248): connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
02-22 03:48:09.663 D/SystemServerTiming( 3407): StartUsbService took to complete: 38ms
02-22 03:48:09.663 I/SystemServer( 3407): StartSerialService
02-22 03:48:09.663 D/SystemServerTiming( 3407): StartSerialService took to complete: 1ms
02-22 03:48:09.663 I/SystemServer( 3407): StartHardwarePropertiesManagerService
02-22 03:48:09.664 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.thermal@1.0::IThermal/default in either framework or device manifest.
02-22 03:48:09.664 E/HardwarePropertiesManagerService-JNI( 3407): Unable to get Thermal service.
02-22 03:48:09.664 D/SystemServerTiming( 3407): StartHardwarePropertiesManagerService took to complete: 1ms
02-22 03:48:09.664 I/SystemServer( 3407): StartTwilightService
02-22 03:48:09.664 I/SystemServiceManager( 3407): Starting com.android.server.twilight.TwilightService
02-22 03:48:09.665 D/SystemServerTiming( 3407): StartTwilightService took to complete: 0ms
02-22 03:48:09.665 I/SystemServer( 3407): StartJobScheduler
02-22 03:48:09.665 I/SystemServiceManager( 3407): Starting com.android.server.job.JobSchedulerService
02-22 03:48:09.672 D/JobStore( 3407): Start tag: job-info
02-22 03:48:09.674 I/JobStore( 3407): Read 2 jobs
02-22 03:48:09.679 D/SystemServerTiming( 3407): StartJobScheduler took to complete: 15ms
02-22 03:48:09.680 I/SystemServer( 3407): StartSoundTrigger
02-22 03:48:09.680 I/SystemServiceManager( 3407): Starting com.android.server.soundtrigger.SoundTriggerService
02-22 03:48:09.680 D/SystemServerTiming( 3407): StartSoundTrigger took to complete: 1ms
02-22 03:48:09.680 I/SystemServer( 3407): StartTrustManager
02-22 03:48:09.680 I/SystemServiceManager( 3407): Starting com.android.server.trust.TrustManagerService
02-22 03:48:09.681 D/SystemServerTiming( 3407): StartTrustManager took to complete: 1ms
02-22 03:48:09.681 I/SystemServer( 3407): StartBackupManager
02-22 03:48:09.681 I/SystemServiceManager( 3407): Starting com.android.server.backup.BackupManagerService$Lifecycle
02-22 03:48:09.682 D/SystemServerTiming( 3407): StartBackupManager took to complete: 1ms
02-22 03:48:09.682 I/SystemServer( 3407): StartAppWidgerService
02-22 03:48:09.682 I/SystemServiceManager( 3407): Starting com.android.server.appwidget.AppWidgetService
02-22 03:48:09.683 D/OpenGLRenderer( 3407): Skia GL Pipeline
02-22 03:48:09.684 D/SystemServerTiming( 3407): StartAppWidgerService took to complete: 2ms
02-22 03:48:09.685 I/SystemServer( 3407): StartVoiceRecognitionManager
02-22 03:48:09.685 I/SystemServiceManager( 3407): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
02-22 03:48:09.685 D/SystemServerTiming( 3407): StartVoiceRecognitionManager took to complete: 1ms
02-22 03:48:09.685 I/SystemServer( 3407): StartGestureLauncher
02-22 03:48:09.685 I/SystemServiceManager( 3407): Starting com.android.server.GestureLauncherService
02-22 03:48:09.685 D/SystemServerTiming( 3407): StartGestureLauncher took to complete: 0ms
02-22 03:48:09.686 I/SystemServer( 3407): StartSensorNotification
02-22 03:48:09.686 I/SystemServiceManager( 3407): Starting com.android.server.SensorNotificationService
02-22 03:48:09.686 D/SystemServerTiming( 3407): StartSensorNotification took to complete: 0ms
02-22 03:48:09.686 I/SystemServer( 3407): StartContextHubSystemService
02-22 03:48:09.686 I/SystemServiceManager( 3407): Starting com.android.server.ContextHubSystemService
02-22 03:48:09.686 D/SystemServerTiming( 3407): StartContextHubSystemService took to complete: 1ms
02-22 03:48:09.686 D/SystemServerInitThreadPool( 3407): Started executing Init ContextHubSystemService
02-22 03:48:09.686 I/SystemServer( 3407): StartDiskStatsService
02-22 03:48:09.687 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.contexthub@1.0::IContexthub/default in either framework or device manifest.
02-22 03:48:09.687 I/ContextHubService( 3407): Context Hub HAL service not found
02-22 03:48:09.687 D/SystemServerInitThreadPool( 3407): Finished executing Init ContextHubSystemService
02-22 03:48:09.688 D/SystemServerTiming( 3407): StartDiskStatsService took to complete: 2ms
02-22 03:48:09.688 I/SystemServer( 3407): StartNetworkTimeUpdateService
02-22 03:48:09.689 D/SystemServerTiming( 3407): StartNetworkTimeUpdateService took to complete: 1ms
02-22 03:48:09.689 I/SystemServer( 3407): StartCommonTimeManagementService
02-22 03:48:09.690 D/SystemServerTiming( 3407): StartCommonTimeManagementService took to complete: 0ms
02-22 03:48:09.690 I/SystemServer( 3407): CertBlacklister
02-22 03:48:09.691 D/SystemServerTiming( 3407): CertBlacklister took to complete: 0ms
02-22 03:48:09.691 I/SystemServer( 3407): StartEmergencyAffordanceService
02-22 03:48:09.691 I/SystemServiceManager( 3407): Starting com.android.server.emergency.EmergencyAffordanceService
02-22 03:48:09.691 D/SystemServerTiming( 3407): StartEmergencyAffordanceService took to complete: 1ms
02-22 03:48:09.691 I/SystemServer( 3407): StartDreamManager
02-22 03:48:09.691 I/SystemServiceManager( 3407): Starting com.android.server.dreams.DreamManagerService
02-22 03:48:09.692 D/SystemServerTiming( 3407): StartDreamManager took to complete: 1ms
02-22 03:48:09.692 I/SystemServer( 3407): AddGraphicsStatsService
02-22 03:48:09.694 D/SystemServerTiming( 3407): AddGraphicsStatsService took to complete: 1ms
02-22 03:48:09.695 I/SystemServer( 3407): StartPrintManager
02-22 03:48:09.695 I/SystemServiceManager( 3407): Starting com.android.server.print.PrintManagerService
02-22 03:48:09.696 D/SystemServerTiming( 3407): StartPrintManager took to complete: 2ms
02-22 03:48:09.697 I/SystemServer( 3407): StartCompanionDeviceManager
02-22 03:48:09.697 I/SystemServiceManager( 3407): Starting com.android.server.companion.CompanionDeviceManagerService
02-22 03:48:09.698 D/SystemServerTiming( 3407): StartCompanionDeviceManager took to complete: 2ms
02-22 03:48:09.698 I/SystemServer( 3407): StartRestrictionManager
02-22 03:48:09.698 I/SystemServiceManager( 3407): Starting com.android.server.restrictions.RestrictionsManagerService
02-22 03:48:09.699 D/SystemServerTiming( 3407): StartRestrictionManager took to complete: 0ms
02-22 03:48:09.699 I/SystemServer( 3407): StartMediaSessionService
02-22 03:48:09.699 I/SystemServiceManager( 3407): Starting com.android.server.media.MediaSessionService
02-22 03:48:09.701 D/SystemServerTiming( 3407): StartMediaSessionService took to complete: 2ms
02-22 03:48:09.701 I/SystemServer( 3407): StartMediaUpdateService
02-22 03:48:09.701 I/SystemServiceManager( 3407): Starting com.android.server.media.MediaUpdateService
02-22 03:48:09.702 D/SystemServerTiming( 3407): StartMediaUpdateService took to complete: 1ms
02-22 03:48:09.702 I/SystemServer( 3407): StartMediaResourceMonitor
02-22 03:48:09.703 I/SystemServiceManager( 3407): Starting com.android.server.media.MediaResourceMonitorService
02-22 03:48:09.703 D/SystemServerTiming( 3407): StartMediaResourceMonitor took to complete: 1ms
02-22 03:48:09.703 I/SystemServer( 3407): StartMediaRouterService
02-22 03:48:09.704 D/SystemServerTiming( 3407): StartMediaRouterService took to complete: 1ms
02-22 03:48:09.704 I/SystemServer( 3407): StartBackgroundDexOptService
02-22 03:48:09.704 W/BackgroundDexOptService( 3407): SysProp pm.dexopt.downgrade_after_inactive_days not set
02-22 03:48:09.705 D/SystemServerTiming( 3407): StartBackgroundDexOptService took to complete: 1ms
02-22 03:48:09.705 I/SystemServer( 3407): StartPruneInstantAppsJobService
02-22 03:48:09.705 D/SystemServerTiming( 3407): StartPruneInstantAppsJobService took to complete: 0ms
02-22 03:48:09.705 I/SystemServer( 3407): StartShortcutServiceLifecycle
02-22 03:48:09.706 I/SystemServiceManager( 3407): Starting com.android.server.pm.ShortcutService$Lifecycle
02-22 03:48:09.708 D/SystemServerTiming( 3407): StartShortcutServiceLifecycle took to complete: 3ms
02-22 03:48:09.708 I/SystemServer( 3407): StartLauncherAppsService
02-22 03:48:09.708 I/SystemServiceManager( 3407): Starting com.android.server.pm.LauncherAppsService
02-22 03:48:09.708 D/SystemServerTiming( 3407): StartLauncherAppsService took to complete: 0ms
02-22 03:48:09.709 I/SystemServer( 3407): StartCrossProfileAppsService
02-22 03:48:09.709 I/SystemServiceManager( 3407): Starting com.android.server.pm.CrossProfileAppsService
02-22 03:48:09.709 D/SystemServerTiming( 3407): StartCrossProfileAppsService took to complete: 1ms
02-22 03:48:09.709 I/SystemServer( 3407): StartMediaProjectionManager
02-22 03:48:09.709 I/SystemServiceManager( 3407): Starting com.android.server.media.projection.MediaProjectionManagerService
02-22 03:48:09.710 V/MediaRouter( 3407): Adding route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:09.711 V/MediaRouter( 3407): Selecting route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:09.712 D/SystemServerTiming( 3407): StartMediaProjectionManager took to complete: 2ms
02-22 03:48:09.712 I/SystemServer( 3407): StartSliceManagerService
02-22 03:48:09.712 I/SystemServiceManager( 3407): Starting com.android.server.slice.SliceManagerService$Lifecycle
02-22 03:48:09.714 D/SystemServerTiming( 3407): StartSliceManagerService took to complete: 2ms
02-22 03:48:09.714 I/SystemServer( 3407): StartCameraServiceProxy
02-22 03:48:09.714 I/SystemServiceManager( 3407): Starting com.android.server.camera.CameraServiceProxy
02-22 03:48:09.716 D/SystemServerTiming( 3407): StartCameraServiceProxy took to complete: 2ms
02-22 03:48:09.717 I/SystemServer( 3407): StartStatsCompanionService
02-22 03:48:09.717 I/SystemServiceManager( 3407): Starting com.android.server.stats.StatsCompanionService$Lifecycle
02-22 03:48:09.718 E/KernelUidCpuFreqTimeReader( 3407): Failed to read /proc/uid_time_in_state: java.io.FileNotFoundException: /proc/uid_time_in_state (No such file or directory)
02-22 03:48:09.718 D/SystemServerTiming( 3407): StartStatsCompanionService took to complete: 2ms
02-22 03:48:09.719 I/WindowManager( 3407): SAFE MODE not enabled
02-22 03:48:09.719 I/SystemServer( 3407): StartJitCompilation
02-22 03:48:09.719 D/SystemServerTiming( 3407): StartJitCompilation took to complete: 0ms
02-22 03:48:09.719 I/SystemServer( 3407): StartMmsService
02-22 03:48:09.719 I/SystemServiceManager( 3407): Starting com.android.server.MmsServiceBroker
02-22 03:48:09.720 D/SystemServerTiming( 3407): StartMmsService took to complete: 1ms
02-22 03:48:09.720 I/SystemServer( 3407): StartAutoFillService
02-22 03:48:09.720 I/SystemServiceManager( 3407): Starting com.android.server.autofill.AutofillManagerService
02-22 03:48:09.721 I/AutofillManagerService( 3407): Setting debug to true
02-22 03:48:09.722 D/SystemServerTiming( 3407): StartAutoFillService took to complete: 2ms
02-22 03:48:09.722 I/SystemServer( 3407): MakeVibratorServiceReady
02-22 03:48:09.724 D/SystemServerTiming( 3407): MakeVibratorServiceReady took to complete: 1ms
02-22 03:48:09.724 I/SystemServer( 3407): MakeLockSettingsServiceReady
02-22 03:48:09.748 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.weaver@1.0::IWeaver/default in either framework or device manifest.
02-22 03:48:09.748 I/SyntheticPasswordManager( 3407): Device does not support weaver
02-22 03:48:09.748 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.authsecret@1.0::IAuthSecret/default in either framework or device manifest.
02-22 03:48:09.748 I/LockSettingsService( 3407): Device doesn't implement AuthSecret HAL
02-22 03:48:09.752 E/LockSettingsStorage( 3407): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
02-22 03:48:09.752 E/LockSettingsStorage( 3407): Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory)
02-22 03:48:09.753 E/LockSettingsStorage( 3407): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
02-22 03:48:09.753 D/SystemServerTiming( 3407): MakeLockSettingsServiceReady took to complete: 29ms
02-22 03:48:09.753 I/SystemServer( 3407): StartBootPhaseLockSettingsReady
02-22 03:48:09.753 I/SystemServiceManager( 3407): Starting phase 480
02-22 03:48:09.757 I/DevicePolicyManager( 3407): Set ro.device_owner property to false
02-22 03:48:09.759 D/SystemServerInitThreadPool( 3407): Started executing DevicePolicyManager
02-22 03:48:09.759 D/SystemServerInitThreadPool( 3407): Finished executing DevicePolicyManager
02-22 03:48:09.761 D/SystemServerTiming( 3407): StartBootPhaseLockSettingsReady took to complete: 8ms
02-22 03:48:09.762 I/SystemServer( 3407): StartBootPhaseSystemServicesReady
02-22 03:48:09.762 I/SystemServiceManager( 3407): Starting phase 500
02-22 03:48:09.764 D/AppStandbyController( 3407): Setting app idle enabled state
02-22 03:48:09.768 I/VrManagerService( 3407): No default vr listener service found.
02-22 03:48:09.773 I/WifiService( 3407): WifiService starting up with Wi-Fi disabled
02-22 03:48:09.776 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hidl.manager@1.0::IServiceManager
02-22 03:48:09.776 D/HalDevMgr( 3407): IWifi registration notification: fqName=android.hardware.wifi@1.0::IWifi, name=default, preexisting=true
02-22 03:48:09.778 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.wifi@1.0::IWifi
02-22 03:48:09.780 D/WificondControl( 3407): tearing down interfaces in wificond
02-22 03:48:09.782 I/WifiScanningService( 3407): Starting wifiscanner
02-22 03:48:09.787 I/EthernetServiceImpl( 3407): Starting Ethernet service
02-22 03:48:09.792 D/Ethernet( 3407): Registering NetworkFactory
02-22 03:48:09.792 D/ConnectivityService( 3407): Got NetworkFactory Messenger for Ethernet
02-22 03:48:09.793 D/Ethernet( 3407): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:09.793 E/IpConfigStore( 3407): Error opening configuration file: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt (No such file or directory)
02-22 03:48:09.796 I/EthernetTracker( 3407): maybeTrackInterface eth0
02-22 03:48:09.799 D/CommandListener( 3219): Setting iface cfg
02-22 03:48:09.799 D/CommandListener( 3219): Trying to bring up eth0
02-22 03:48:09.800 D/PermissionCache( 3252): checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (100 us)
02-22 03:48:09.800 W/SoundTriggerHelper( 3407): listModules status=0, # of modules=0
02-22 03:48:09.801 D/ContextHubSystemService( 3407): onBootPhase: PHASE_SYSTEM_SERVICES_READY
02-22 03:48:09.802 D/SystemServerTiming( 3407): StartBootPhaseSystemServicesReady took to complete: 41ms
02-22 03:48:09.802 I/SystemServer( 3407): MakeWindowManagerServiceReady
02-22 03:48:09.806 I/android_os_HwBinder( 3407): HwBinder: Starting thread pool for default::android.hardware.configstore@1.0::ISurfaceFlingerConfigs
02-22 03:48:09.806 D/SystemServerTiming( 3407): MakeWindowManagerServiceReady took to complete: 4ms
02-22 03:48:09.807 I/SystemServer( 3407): MakePowerManagerServiceReady
02-22 03:48:09.816 W/KeyguardServiceDelegate( 3407): onScreenTurningOn(): no keyguard service!
02-22 03:48:09.816 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_active_time
02-22 03:48:09.816 W/KernelCpuProcReader( 3407): File not exist: /proc/uid_cpupower/concurrent_policy_time
02-22 03:48:09.819 D/SystemServerTiming( 3407): MakePowerManagerServiceReady took to complete: 11ms
02-22 03:48:09.819 I/SystemServer( 3407): MakePackageManagerServiceReady
02-22 03:48:09.824 D/WifiStateMachinePrime( 3407): received a message in WifiDisabledState: { when=0 what=3 target=com.android.internal.util.StateMachine$SmHandler }
02-22 03:48:09.824 D/WifiStateMachinePrime( 3407): Switching from WifiDisabledState to WifiDisabled
02-22 03:48:09.824 D/WifiStateMachinePrime( 3407): Entering WifiDisabledState
02-22 03:48:09.824 D/ActiveModeManager( 3407): sending scan available broadcast: false
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/user_de/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/user/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/system_de/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/system_ce/0 with serial number 0
02-22 03:48:09.835 V/UserDataPreparer( 3407): Found /data/misc_ce/0 with serial number 0
02-22 03:48:09.837 D/SystemServerTiming( 3407): MakePackageManagerServiceReady took to complete: 18ms
02-22 03:48:09.837 I/SystemServer( 3407): MakeDisplayManagerServiceReady
02-22 03:48:09.837 D/SystemServerTiming( 3407): MakeDisplayManagerServiceReady took to complete: 0ms
02-22 03:48:09.837 I/SystemServer( 3407): StartDeviceSpecificServices
02-22 03:48:09.838 D/SystemServerTiming( 3407): StartDeviceSpecificServices took to complete: 0ms
02-22 03:48:09.838 I/SystemServer( 3407): StartBootPhaseDeviceSpecificServicesReady
02-22 03:48:09.838 I/SystemServiceManager( 3407): Starting phase 520
02-22 03:48:09.839 D/SystemServerTiming( 3407): StartBootPhaseDeviceSpecificServicesReady took to complete: 1ms
02-22 03:48:09.840 W/UsageStatsService( 3407): Event reported without a package name
02-22 03:48:09.843 I/AppOps  ( 3407): Pruning old package system/com.android.server.AppOpsService$UidState@75a4c8d: new uid=-1
02-22 03:48:09.844 I/ActivityManager( 3407): System now ready
02-22 03:48:09.847 I/ActivityManager( 3407): Config changes=104 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.5}
02-22 03:48:09.885 W/JHwRemoteBinder( 3407): BinderProxy is being destroyed but the application did not call unlinkToDeath to unlink all of its death recipients beforehand.  Releasing leaked death recipient: com.android.server.usb.UsbDeviceManager$UsbHandlerHal$UsbGadgetDeathRecipient
02-22 03:48:09.886 I/ActivityManager( 3407): Override config changes=104 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.5} for displayId=0
02-22 03:48:09.886 W/System  ( 3407): A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
02-22 03:48:09.887 W/System  ( 3407): java.lang.Throwable: Explicit termination method 'close' not called
02-22 03:48:09.887 W/System  ( 3407):  at dalvik.system.CloseGuard.open(CloseGuard.java:221)
02-22 03:48:09.887 W/System  ( 3407):  at java.io.FileInputStream.<init>(FileInputStream.java:168)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.internal.os.AtomicFile.openRead(AtomicFile.java:147)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.server.storage.CacheQuotaStrategy.setupQuotasFromFile(CacheQuotaStrategy.java:301)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.server.usage.StorageStatsService$H.handleMessage(StorageStatsService.java:508)
02-22 03:48:09.887 W/System  ( 3407):  at android.os.Handler.dispatchMessage(Handler.java:106)
02-22 03:48:09.887 W/System  ( 3407):  at android.os.Looper.loop(Looper.java:193)
02-22 03:48:09.887 W/System  ( 3407):  at android.os.HandlerThread.run(HandlerThread.java:65)
02-22 03:48:09.887 W/System  ( 3407):  at com.android.server.ServiceThread.run(ServiceThread.java:44)
02-22 03:48:09.890 I/EthernetTracker( 3407): interfaceLinkStateChanged, iface: eth0, up: false
02-22 03:48:09.897 D/EthernetTracker( 3407): Started tracking interface eth0
02-22 03:48:09.897 D/EthernetNetworkFactory( 3407): addInterface, iface: eth0, capabilities: [ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&NOT_CONGESTED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]
02-22 03:48:09.899 D/EthernetNetworkFactory( 3407): starting IpClient(eth0): mNetworkInfo=[type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false]
02-22 03:48:09.903 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:09.903 D/EthernetNetworkFactory( 3407): updateCapabilityFilter: [ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&NOT_CONGESTED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]
02-22 03:48:09.903 I/EthernetTracker( 3407): maybeTrackInterface ip6_vti0
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface ip6tnl0
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface ip_vti0
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface lo
02-22 03:48:09.904 I/EthernetTracker( 3407): maybeTrackInterface sit0
02-22 03:48:09.904 D/EthernetNetworkFactory( 3407): updateInterfaceLinkState, iface: eth0, up: false
02-22 03:48:09.913 I/ActivityManager( 3407): Config changes=100 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 0, 0) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.6}
02-22 03:48:09.914 I/ActivityManager( 3407): Override config changes=100 {1.0 ?mcc?mnc [zh_CN_#Hans,en_US] ldltr sw811dp w1442dp h739dp 213dpi xlrg long hdr land -touch -keyb/v/h -nav/h winConfig={ mBounds=Rect(0, 0 - 1920, 1080) mAppBounds=Rect(0, 0 - 1920, 1016) mWindowingMode=fullscreen mActivityType=undefined} s.6} for displayId=0
02-22 03:48:09.916 I/SystemServer( 3407): Making services ready
02-22 03:48:09.916 I/SystemServer( 3407): StartActivityManagerReadyPhase
02-22 03:48:09.917 I/SystemServiceManager( 3407): Starting phase 550
02-22 03:48:09.919 D/DhcpClient( 3407): doQuit
02-22 03:48:09.920 W/ActivityManager( 3407): Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
02-22 03:48:09.921 W/ActivityManager( 3407): Too early to start/bind service in system_server: Phase=550 ComponentInfo{com.android.server.telecom/com.android.server.telecom.components.TelecomService}
02-22 03:48:09.949 D/BluetoothManagerService( 3407): Bluetooth boot completed
02-22 03:48:09.949 D/BluetoothManagerService( 3407): Getting adapter name and address
02-22 03:48:09.949 D/BluetoothManagerService( 3407): MESSAGE_GET_NAME_AND_ADDRESS
02-22 03:48:09.949 D/BluetoothManagerService( 3407): Binding to service to get name and address
02-22 03:48:09.952 D/DhcpClient( 3407): Receive thread started
02-22 03:48:09.952 D/DhcpClient( 3407): Receive thread stopped
02-22 03:48:09.967 I/ActivityManager( 3407): Start proc 3546:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
02-22 03:48:10.006 D/DhcpClient( 3407): onQuitting
02-22 03:48:09.960 W/main    ( 3546): type=1400 audit(0.0:2359): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:09.964 I/chatty  ( 3546): uid=1002(bluetooth) com.android.bluetooth identical 2 lines
02-22 03:48:09.964 W/main    ( 3546): type=1400 audit(0.0:2362): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:10.009 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:10.011 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], score: 0
02-22 03:48:10.012 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], network: NetworkInterfaceState{ iface: eth0, up: false, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false], networkAgent: null, ipClient: null,linkProperties: {LinkAddresses: []  Routes: [] DnsAddresses: [] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}
02-22 03:48:10.012 D/EthernetNetworkFactory( 3407): starting IpClient(eth0): mNetworkInfo=[type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false]
02-22 03:48:10.017 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:10.040 I/droid.bluetoot( 3546): The ClassLoaderContext is a special shared library.
02-22 03:48:10.069 W/SystemServiceManager( 3407): Service com.android.server.InputMethodManagerService$Lifecycle took 117 ms in onBootPhase
02-22 03:48:10.069 D/StorageManagerService( 3407): Thinking about init, mSystemReady=true, mDaemonConnected=true
02-22 03:48:10.069 D/StorageManagerService( 3407): Thinking about reset, mSystemReady=true, mDaemonConnected=true
02-22 03:48:10.070 I/ActivityManager( 3407): Force stopping com.android.providers.media appid=10006 user=-1: vold reset
02-22 03:48:10.072 I/WallpaperManagerService( 3407): No static wallpaper imagery; defaults will be shown
02-22 03:48:10.074 V/StorageManagerService( 3407): Found primary storage at VolumeInfo{emulated}:
02-22 03:48:10.074 V/StorageManagerService( 3407):     type=EMULATED diskId=null partGuid= mountFlags=0 mountUserId=-1
02-22 03:48:10.074 V/StorageManagerService( 3407):     state=UNMOUNTED
02-22 03:48:10.074 V/StorageManagerService( 3407):     fsType=null fsUuid=null fsLabel=null
02-22 03:48:10.074 V/StorageManagerService( 3407):     path=null internalPath=null
02-22 03:48:10.075 I/droid.bluetoot( 3546): The ClassLoaderContext is a special shared library.
02-22 03:48:10.079 E/BitmapFactory( 3407): Unable to decode stream: java.io.FileNotFoundException: /data/system/users/0/wallpaper_orig (No such file or directory)
02-22 03:48:10.079 W/WallpaperManagerService( 3407): Invalid wallpaper data
02-22 03:48:10.079 E/WallpaperManagerService( 3407): Unable to apply new wallpaper
02-22 03:48:10.080 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:10.080 V/vold    ( 3170): Waiting for FUSE to spin up...
02-22 03:48:10.081 D/DhcpClient( 3407): Receive thread started
02-22 03:48:10.082 D/audio_hw_primary( 3231): adev_set_parameters: enter: A2dpSuspended=false
02-22 03:48:10.082 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:10.083 I/AudioService( 3407): setBluetoothScoOnInt: false resetBluetoothSco
02-22 03:48:10.083 D/audio_hw_primary( 3231): adev_set_parameters: enter: BT_SCO=off
02-22 03:48:10.083 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:10.084 D/SystemServerTiming( 3407): StartActivityManagerReadyPhase took to complete: 168ms
02-22 03:48:10.084 I/SystemServer( 3407): StartObservingNativeCrashes
02-22 03:48:10.084 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:10.084 I/android.hardware.usb@1.1-service.imx( 3248): port0
02-22 03:48:10.085 D/SystemServerTiming( 3407): StartObservingNativeCrashes took to complete: 0ms
02-22 03:48:10.085 I/android.hardware.usb@1.1-service.imx( 3248): connected:1 canChangeMode:1 canChagedata:0 canChangePower:0
02-22 03:48:10.085 I/SystemServer( 3407): StartSystemUI
02-22 03:48:10.085 D/SystemServerInitThreadPool( 3407): Started executing WebViewFactoryPreparation
02-22 03:48:10.085 I/SystemServer( 3407): WebViewFactoryPreparation
02-22 03:48:10.086 I/UsbPortManager( 3407): ClientCallback: port0
02-22 03:48:10.086 I/UsbPortManager( 3407): USB port added: port=UsbPort{id=port0, supportedModes=dual}, status=UsbPortStatus{connected=true, currentMode=ufp, currentPowerRole=sink, currentDataRole=device, supportedRoleCombinations=[source:host, sink:device]}, canChangeMode=true, canChangePowerRole=false, canChangeDataRole=false
02-22 03:48:10.086 E/BluetoothHearingAid( 3407): Could not bind to Bluetooth Hearing Aid Service with Intent { act=android.bluetooth.IBluetoothHearingAid }
02-22 03:48:10.088 I/AudioFlinger( 3252): systemReady
02-22 03:48:10.094 D/SystemServerTiming( 3407): StartSystemUI took to complete: 9ms
02-22 03:48:10.094 I/SystemServer( 3407): MakeNetworkManagementServiceReady
02-22 03:48:10.095 I/ActivityManager( 3407): Start proc 3573:com.android.inputmethod.latin/u0a63 for service com.android.inputmethod.latin/.LatinIME
02-22 03:48:10.096 D/NetworkManagement( 3407): enabling bandwidth control
02-22 03:48:10.101 W/sdcard  ( 3571): Device explicitly enabled sdcardfs
02-22 03:48:10.110 D/WebViewLibraryLoader( 3407): Setting new address space to 147551200
02-22 03:48:10.119 D/SystemServerTimingAsync( 3407): WebViewFactoryPreparation took to complete: 33ms
02-22 03:48:10.119 D/SystemServerInitThreadPool( 3407): Finished executing WebViewFactoryPreparation
02-22 03:48:10.121 E/linker  ( 3265): library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:10.122 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/..) Permission denied
02-22 03:48:10.124 I/ActivityManager( 3407): Start proc 3583:com.android.systemui/u0a12 for service com.android.systemui/.SystemUIService
02-22 03:48:10.137 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/.) Is a directory
02-22 03:48:10.153 E/MediaExtractorFactory( 3265): couldn't opendir(/vendor/lib64/extractors)
02-22 03:48:10.167 D/StagefrightPluginLoader( 3254): Failed to load library: libstagefright_ccodec.so (dlopen failed: library "libstagefright_ccodec.so" not found)
02-22 03:48:10.167 D/StagefrightPluginLoader( 3254): Handle or CreateInputSurface symbol is null
02-22 03:48:10.167 D/StagefrightPluginLoader( 3254): Handle or CreateBuilder symbol is null
02-22 03:48:10.169 V/AdapterServiceConfig( 3546): Adding HeadsetService
02-22 03:48:10.169 V/AdapterServiceConfig( 3546): Adding A2dpService
02-22 03:48:10.169 V/AdapterServiceConfig( 3546): Adding HidHostService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding HealthService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding PanService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding GattService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding BluetoothMapService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding AvrcpTargetService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding HidDeviceService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding BluetoothOppService
02-22 03:48:10.170 V/AdapterServiceConfig( 3546): Adding BluetoothPbapService
02-22 03:48:10.177 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.178 I/OMXMaster( 3270): makeComponentInstance(OMX.google.aac.decoder) in omx@1.0-service process
02-22 03:48:10.200 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.200 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.aac.sw-based) in omx@1.0-service process
02-22 03:48:10.088 W/main    ( 3573): type=1400 audit(0.0:2363): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:10.208 I/OMXPlayer( 3270): Can't open library: lib_aacplusd_wrap_arm12_elinux_android.so
02-22 03:48:10.208 I/OMXPlayer( 3270): dlopen failed: library "lib_aacplusd_wrap_arm12_elinux_android.so" not found
02-22 03:48:10.210 I/        ( 3546): [0222/034810.210154:INFO:com_android_bluetooth_btservice_AdapterService.cpp(630)] hal_util_load_bt_library loaded HAL: btinterface=0xff8dfec49430, handle=0x6fce011393bb7ac5
02-22 03:48:10.211 D/BluetoothAdapterService( 3546): onCreate()
02-22 03:48:10.217 D/AdapterState( 3546): make() - Creating AdapterState
02-22 03:48:10.219 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.219 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.amrnb.sw-based) in omx@1.0-service process
02-22 03:48:10.220 I/bt_btif ( 3546): init
02-22 03:48:10.220 I/AdapterState( 3546): OFF : entered
02-22 03:48:10.220 D/AdapterProperties( 3546): Setting state to OFF
02-22 03:48:10.220 D/bt_osi_allocation_tracker( 3546): canary initialized
02-22 03:48:10.220 I/bt_osi_thread( 3546): run_thread: thread id 3620, thread name stack_manager started
02-22 03:48:10.221 I/bt_stack_manager( 3546): event_init_stack is initializing the stack
02-22 03:48:10.222 E/bt_btif_config( 3546): Config is missing adapter section
02-22 03:48:10.222 W/bt_btif_config( 3546): init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
02-22 03:48:10.223 E/bt_btif_config( 3546): Config is missing adapter section
02-22 03:48:10.223 W/bt_btif_config( 3546): init unable to load backup; attempting to transcode legacy file.
02-22 03:48:10.223 E/bt_btif_config_transcode( 3546): btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
02-22 03:48:10.223 E/bt_btif_config( 3546): init unable to transcode legacy file; creating empty config.
02-22 03:48:10.224 I/bt_osi_thread( 3546): run_thread: thread id 3623, thread name alarm_default_ca started
02-22 03:48:10.224 I/bt_osi_thread( 3546): run_thread: thread id 3624, thread name alarm_dispatcher started
02-22 03:48:10.226 I/bt_btif_core( 3546): btif_init_bluetooth entered
02-22 03:48:10.227 I/bt_stack_config( 3546): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
02-22 03:48:10.229 I/bt_osi_thread( 3546): run_thread: thread id 3626, thread name bt_jni_workqueue started
02-22 03:48:10.229 I/bt_btif_core( 3546): btif_init_bluetooth finished
02-22 03:48:10.229 I/bt_stack_manager( 3546): event_init_stack finished
02-22 03:48:10.229 I/bt_osi_wakelock( 3546): wakelock_set_os_callouts set to non-native
02-22 03:48:10.229 I/bt_btif ( 3546): get_profile_interface: id = socket
02-22 03:48:10.229 W/bt_btif ( 3546): do_in_jni_thread: Dropped message, message_loop not initialized yet!
02-22 03:48:10.229 I/chatty  ( 3546): uid=1002(bluetooth) com.android.bluetooth identical 1 line
02-22 03:48:10.229 I/bt_btif_core( 3546): run_message_loop entered
02-22 03:48:10.231 I/bt_btif ( 3546): get_profile_interface: id = sdp
02-22 03:48:10.233 I/BluetoothAdapterService( 3546): Phone policy enabled
02-22 03:48:10.234 I/OMXPlayer( 3270): SetRoleFormat AMR NB mode.
02-22 03:48:10.237 D/BluetoothActiveDeviceManager( 3546): start()
02-22 03:48:10.238 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.238 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrnb.decoder) in omx@1.0-service process
02-22 03:48:10.247 D/BluetoothAdapterService( 3546): setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@657a85e
02-22 03:48:10.247 D/BluetoothActiveDeviceManager( 3546): onAudioDevicesAdded
02-22 03:48:10.247 D/BluetoothActiveDeviceManager( 3546): Audio device added: MEK-MX8Q type: 2
02-22 03:48:10.247 D/BluetoothActiveDeviceManager( 3546): Audio device added: MEK-MX8Q type: 15
02-22 03:48:10.249 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.250 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.amrwb.sw-based) in omx@1.0-service process
02-22 03:48:10.251 D/BluetoothAdapterService( 3546): onBind()
02-22 03:48:10.256 I/OMXPlayer( 3270): SetRoleFormat AMR WB mode.
02-22 03:48:10.259 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.260 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrwb.decoder) in omx@1.0-service process
02-22 03:48:10.264 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.265 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.flac.sw-based) in omx@1.0-service process
02-22 03:48:10.274 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.275 I/OMXMaster( 3270): makeComponentInstance(OMX.google.g711.alaw.decoder) in omx@1.0-service process
02-22 03:48:10.282 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.282 I/OMXMaster( 3270): makeComponentInstance(OMX.google.g711.mlaw.decoder) in omx@1.0-service process
02-22 03:48:10.284 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.284 I/OMXMaster( 3270): makeComponentInstance(OMX.google.gsm.decoder) in omx@1.0-service process
02-22 03:48:10.286 W/ZygoteProcess( 3407): Got error connecting to zygote, retrying. msg= Connection refused
02-22 03:48:10.290 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.290 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.audio_decoder.mp3.sw-based) in omx@1.0-service process
02-22 03:48:10.296 I/WebViewZygoteInit( 3651): Starting WebViewZygoteInit
02-22 03:48:10.296 I/WebViewZygoteInit( 3651): --zygote-socket=com.android.internal.os.WebViewZygoteInit/f0642249-e0a6-4656-94b7-17a7125c2826
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: returned from zygote!
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: done updating battery stats
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 184ms so far, now at startProcess: building log message
02-22 03:48:10.301 I/ActivityManager( 3407): Start proc 3666:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 184ms so far, now at startProcess: starting to update pids map
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 184ms so far, now at startProcess: done updating pids map
02-22 03:48:10.301 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: asking zygote to start proc
02-22 03:48:10.304 W/WebViewLoader-( 3666): Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
02-22 03:48:10.304 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.304 I/OMXMaster( 3270): makeComponentInstance(OMX.google.mp3.decoder) in omx@1.0-service process
02-22 03:48:10.313 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.313 I/OMXMaster( 3270): makeComponentInstance(OMX.google.opus.decoder) in omx@1.0-service process
02-22 03:48:10.316 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: returned from zygote!
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: done updating battery stats
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: building log message
02-22 03:48:10.317 I/ActivityManager( 3407): Start proc 3681:WebViewLoader-arm64-v8a/1037 [android.webkit.WebViewLibraryLoader$RelroFileCreator] for
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: starting to update pids map
02-22 03:48:10.317 W/ActivityManager( 3407): Slow operation: 198ms so far, now at startProcess: done updating pids map
02-22 03:48:10.321 V/WebViewLibraryLoader( 3666): RelroFileCreator (64bit = false), lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so
02-22 03:48:10.326 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.326 I/OMXMaster( 3270): makeComponentInstance(OMX.google.raw.decoder) in omx@1.0-service process
02-22 03:48:10.344 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.345 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.359 V/WebViewLibraryLoader( 3681): RelroFileCreator (64bit = true), lib: /system/app/webview/webview.apk!/lib/arm64-v8a/libwebviewchromium.so
02-22 03:48:10.362 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.363 I/OMXMaster( 3270): makeComponentInstance(OMX.google.aac.encoder) in omx@1.0-service process
02-22 03:48:10.376 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.376 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrnb.encoder) in omx@1.0-service process
02-22 03:48:10.435 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.435 I/OMXMaster( 3270): makeComponentInstance(OMX.google.amrwb.encoder) in omx@1.0-service process
02-22 03:48:10.438 I/WebViewLoader-( 3666): System.exit called, status: 0
02-22 03:48:10.438 I/AndroidRuntime( 3666): VM exiting with result code 0, cleanup skipped.
02-22 03:48:10.448 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.448 I/OMXMaster( 3270): makeComponentInstance(OMX.google.flac.encoder) in omx@1.0-service process
02-22 03:48:10.454 I/ActivityManager( 3407): Process WebViewLoader-armeabi-v7a (pid 3666) has died: psvc PER
02-22 03:48:10.455 W/libprocessgroup( 3407): kill(-3666, 9) failed: No such process
02-22 03:48:10.459 I/Zygote  ( 3221): Process 3666 exited cleanly (0)
02-22 03:48:10.468 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.468 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based) in omx@1.0-service process
02-22 03:48:10.501 W/libprocessgroup( 3407): kill(-3666, 9) failed: No such process
02-22 03:48:10.501 I/libprocessgroup( 3407): Successfully killed process cgroup uid 1037 pid 3666 in 46ms
02-22 03:48:10.533 I/WebViewLoader-( 3681): System.exit called, status: 0
02-22 03:48:10.533 I/AndroidRuntime( 3681): VM exiting with result code 0, cleanup skipped.
02-22 03:48:10.540 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.540 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.541 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.541 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.541 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.avc.v3.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.543 I/ActivityManager( 3407): Process WebViewLoader-arm64-v8a (pid 3681) has died: psvc PER
02-22 03:48:10.543 I/Zygote  ( 3220): Process 3681 exited cleanly (0)
02-22 03:48:10.543 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.544 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h264.decoder) in omx@1.0-service process
02-22 03:48:10.544 W/libprocessgroup( 3407): kill(-3681, 9) failed: No such process
02-22 03:48:10.544 I/libprocessgroup( 3407): Successfully killed process cgroup uid 1037 pid 3681 in 0ms
02-22 03:48:10.549 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c600:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.549 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c600:google.h264.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.551 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.551 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.h263.hw-based) in omx@1.0-service process
02-22 03:48:10.553 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.553 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.554 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.554 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.554 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.h263.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.556 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.556 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h263.decoder) in omx@1.0-service process
02-22 03:48:10.560 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c720:google.h263.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.560 E/OMXNodeInstance( 3270): getExtensionIndex(0xef92c720:google.h263.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.562 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.562 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.hevc.hw-based) in omx@1.0-service process
02-22 03:48:10.564 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.564 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.565 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.565 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.hevc.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.565 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.hevc.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.567 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.567 I/OMXMaster( 3270): makeComponentInstance(OMX.google.hevc.decoder) in omx@1.0-service process
02-22 03:48:10.575 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27d80:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.575 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27d80:google.hevc.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.579 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.579 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.mjpeg.hw-based) in omx@1.0-service process
02-22 03:48:10.582 E/OMXNodeInstance( 3270): getParameter(0xef947f04:Freescale.std._decoder.mjpeg.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.582 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.583 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.583 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.583 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.583 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.mjpeg.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.586 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.586 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg2.hw-based) in omx@1.0-service process
02-22 03:48:10.588 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.588 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.588 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.589 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.589 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.mpeg2.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.592 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.592 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg4.hw-based) in omx@1.0-service process
02-22 03:48:10.593 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.594 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.594 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.594 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.594 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.mpeg4.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.597 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.597 I/OMXMaster( 3270): makeComponentInstance(OMX.google.mpeg4.decoder) in omx@1.0-service process
02-22 03:48:10.598 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27e40:google.mpeg4.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.599 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27e40:google.mpeg4.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.599 W/NetworkManagement( 3407): setDataSaverMode(): already false
02-22 03:48:10.600 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.601 D/SystemServerTiming( 3407): MakeNetworkManagementServiceReady took to complete: 506ms
02-22 03:48:10.601 I/SystemServer( 3407): MakeIpSecServiceReady
02-22 03:48:10.601 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.sorenson.sw-based) in omx@1.0-service process
02-22 03:48:10.602 D/IpSecService( 3407): IpSecService is ready
02-22 03:48:10.602 D/SystemServerTiming( 3407): MakeIpSecServiceReady took to complete: 2ms
02-22 03:48:10.602 I/SystemServer( 3407): MakeNetworkStatsServiceReady
02-22 03:48:10.603 E/BatteryExternalStatsWorker( 3407): no controller energy info supplied for wifi
02-22 03:48:10.603 E/BatteryExternalStatsWorker( 3407): no controller energy info supplied for telephony
02-22 03:48:10.610 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.612 E/OMXNodeInstance( 3270): getParameter(0xef947f04:Freescale.std._decoder.sorenson.sw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.614 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.614 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.614 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.sorenson.sw-based] component does not support metadata mode; using fallback
02-22 03:48:10.614 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.prepareForAdaptivePlayback(0x7f00003d): Output:1 en=1 max=1280x720) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.616 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.616 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_decoder.vp8.hw-based) in omx@1.0-service process
02-22 03:48:10.616 W/NetworkPolicy( 3407): setRestrictBackgroundUL: already false
02-22 03:48:10.619 I/putmethod.lati( 3573): The ClassLoaderContext is a special shared library.
02-22 03:48:10.621 D/SystemServerTiming( 3407): MakeNetworkStatsServiceReady took to complete: 19ms
02-22 03:48:10.622 I/SystemServer( 3407): MakeConnectivityServiceReady
02-22 03:48:10.622 E/OMXNodeInstance( 3270): getParameter(0xef947f04:Freescale.std._decoder.vp8.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.622 W/OMXUtils( 3254): do not know color format 0x19 = 25
02-22 03:48:10.622 W/OMXUtils( 3254): do not know color format 0x7f000002 = 2130706434
02-22 03:48:10.622 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.623 E/OMXFSLPlugin( 3270): Failed to make GMDecoder Wrapper.
02-22 03:48:10.623 E/OMXNodeInstance( 3270): setParameter(0xef947f04:Freescale.std._decoder.vp8.hw-based, OMX.google.android.index.configureVideoTunnelMode(0x7f000049): Output:1 tun=1 sync=0) ERROR: BadParameter(0x80001005)
02-22 03:48:10.623 W/OMXNodeInstance( 3270): [0xef947f04:Freescale.std._decoder.vp8.hw-based] component does not support metadata mode; using fallback
02-22 03:48:10.625 D/Ethernet( 3407): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:10.626 D/PermissionMonitor( 3407): Monitoring
02-22 03:48:10.627 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.627 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vp8.decoder) in omx@1.0-service process
02-22 03:48:10.632 I/ndroid.systemu( 3583): The ClassLoaderContext is a special shared library.
02-22 03:48:10.635 D/PermissionMonitor( 3407): Users: 1, Apps: 72
02-22 03:48:10.640 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.640 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp8.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.641 D/SystemServerTiming( 3407): MakeConnectivityServiceReady took to complete: 20ms
02-22 03:48:10.641 I/SystemServer( 3407): MakeNetworkPolicyServiceReady
02-22 03:48:10.642 D/SystemServerTiming( 3407): MakeNetworkPolicyServiceReady took to complete: 0ms
02-22 03:48:10.642 I/SystemServer( 3407): StartWatchdog
02-22 03:48:10.642 D/SystemServerTiming( 3407): StartWatchdog took to complete: 1ms
02-22 03:48:10.642 I/SystemServer( 3407): PhaseThirdPartyAppsCanStart
02-22 03:48:10.642 I/SystemServiceManager( 3407): Starting phase 600
02-22 03:48:10.643 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.643 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vp9.decoder) in omx@1.0-service process
02-22 03:48:10.645 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.645 E/OMXNodeInstance( 3270): getExtensionIndex(0xefd27ea0:google.vp9.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
02-22 03:48:10.645 E/LightsService( 3407): Light requested not available on this device. 4
02-22 03:48:10.647 V/WallpaperManagerService( 3407): bindWallpaperComponentLocked: componentName=ComponentInfo{com.android.systemui/com.android.systemui.ImageWallpaper}
02-22 03:48:10.651 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.651 I/OMXMaster( 3270): makeComponentInstance(OMX.Freescale.std.video_encoder.avc.hw-based) in omx@1.0-service process
02-22 03:48:10.656 I/putmethod.lati( 3573): The ClassLoaderContext is a special shared library.
02-22 03:48:10.660 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.666 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.668 W/OMXUtils( 3254): do not know color format 0x6 = 6
02-22 03:48:10.668 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:10.669 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.674 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.674 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h264.encoder) in omx@1.0-service process
02-22 03:48:10.680 I/StatsCompanionService( 3407): Told statsd that StatsCompanionService is alive.
02-22 03:48:10.680 D/SystemServerTiming( 3407): PhaseThirdPartyAppsCanStart took to complete: 38ms
02-22 03:48:10.680 I/SystemServer( 3407): MakeLocationServiceReady
02-22 03:48:10.683 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.gnss@1.1::IGnss/default in either framework or device manifest.
02-22 03:48:10.683 D/GnssLocationProvider( 3407): gnssHal 1.1 was null, trying 1.0
02-22 03:48:10.684 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.684 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.gnss@1.0::IGnss/default in either framework or device manifest.
02-22 03:48:10.685 W/LocationManagerService( 3407): no network location provider found
02-22 03:48:10.687 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.687 I/OMXMaster( 3270): makeComponentInstance(OMX.google.h263.encoder) in omx@1.0-service process
02-22 03:48:10.691 E/LocationManagerService( 3407): no geocoder provider found
02-22 03:48:10.691 I/SoftMPEG4Encoder( 3270): Construct SoftMPEG4Encoder
02-22 03:48:10.693 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.693 E/OMXNodeInstance( 3270): getConfig(0xefd27ea0:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
02-22 03:48:10.695 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.695 I/OMXMaster( 3270): makeComponentInstance(OMX.google.mpeg4.encoder) in omx@1.0-service process
02-22 03:48:10.695 I/SoftMPEG4Encoder( 3270): Construct SoftMPEG4Encoder
02-22 03:48:10.696 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.697 E/OMXNodeInstance( 3270): getConfig(0xefd27ea0:google.mpeg4.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
02-22 03:48:10.699 D/LocationManagerService( 3407): Unable to bind FLP Geofence proxy.
02-22 03:48:10.699 I/OMXClient( 3254): IOmx service obtained
02-22 03:48:10.699 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vp8.encoder) in omx@1.0-service process
02-22 03:48:10.700 E/ActivityRecognitionHardware( 3407): activity_recognition HAL is deprecated. class_init is effectively a no-op
02-22 03:48:10.700 E/ActivityRecognitionHardware( 3407): activity_recognition HAL is deprecated. is_supported is effectively a no-op
02-22 03:48:10.700 D/LocationManagerService( 3407): Hardware Activity-Recognition not supported.
02-22 03:48:10.701 E/ActivityRecognitionProxy( 3407): ServiceWatcher could not start.
02-22 03:48:10.701 D/LocationManagerService( 3407): Unable to bind ActivityRecognitionProxy.
02-22 03:48:10.704 D/SystemServerTiming( 3407): MakeLocationServiceReady took to complete: 24ms
02-22 03:48:10.704 I/SystemServer( 3407): MakeCountryDetectionServiceReady
02-22 03:48:10.704 D/SystemServerTiming( 3407): MakeCountryDetectionServiceReady took to complete: 0ms
02-22 03:48:10.704 I/SystemServer( 3407): MakeNetworkTimeUpdateReady
02-22 03:48:10.707 D/ConnectivityService( 3407): requestNetwork for uid/pid:1000/3407 NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ]
02-22 03:48:10.707 D/SystemServerTiming( 3407): MakeNetworkTimeUpdateReady took to complete: 3ms
02-22 03:48:10.707 I/SystemServer( 3407): MakeCommonTimeManagementServiceReady
02-22 03:48:10.708 I/CommonTimeManagementService( 3407): No common time service detected on this platform.  Common time services will be unavailable.
02-22 03:48:10.708 D/SystemServerTiming( 3407): MakeCommonTimeManagementServiceReady took to complete: 0ms
02-22 03:48:10.708 I/SystemServer( 3407): MakeInputManagerServiceReady
02-22 03:48:10.709 D/Ethernet( 3407): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:10.709 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], score: 0
02-22 03:48:10.709 D/SystemServerTiming( 3407): MakeInputManagerServiceReady took to complete: 2ms
02-22 03:48:10.710 I/SystemServer( 3407): MakeTelephonyRegistryReady
02-22 03:48:10.710 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], network: NetworkInterfaceState{ iface: eth0, up: false, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTING/OBTAINING_IPADDR, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: false, roaming: false], networkAgent: null, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {LinkAddresses: []  Routes: [] DnsAddresses: [] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}
02-22 03:48:10.710 W/OMXUtils( 3254): do not know color format 0x7f000789 = 2130708361
02-22 03:48:10.710 D/SystemServerTiming( 3407): MakeTelephonyRegistryReady took to complete: 1ms
02-22 03:48:10.710 I/SystemServer( 3407): MakeMediaRouterServiceReady
02-22 03:48:10.710 E/OMXNodeInstance( 3270): getConfig(0xefd27ea0:google.vp8.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
02-22 03:48:10.711 D/SystemServerTiming( 3407): MakeMediaRouterServiceReady took to complete: 1ms
02-22 03:48:10.711 I/SystemServer( 3407): MakeMmsServiceReady
02-22 03:48:10.711 I/MmsServiceBroker( 3407): Delay connecting to MmsService until an API is called
02-22 03:48:10.711 D/SystemServerTiming( 3407): MakeMmsServiceReady took to complete: 0ms
02-22 03:48:10.711 I/SystemServer( 3407): IncidentDaemonReady
02-22 03:48:10.713 D/SystemServerTiming( 3407): IncidentDaemonReady took to complete: 1ms
02-22 03:48:10.713 I/SystemServiceManager( 3407): Calling onStartUser u0
02-22 03:48:10.715 W/VoiceInteractionManagerService( 3407): no available voice interaction services found for user 0
02-22 03:48:10.715 W/VoiceInteractionManagerService( 3407): no available voice recognition services found for user 0
02-22 03:48:10.715 D/MediaCodecList( 3254): ignored a null builder
02-22 03:48:10.716 W/AlarmManager( 3583): Unrecognized alarm listener com.android.systemui.keyguard.-$$Lambda$KeyguardSliceProvider$IhzByd8TsqFuOrSyuGurVskyPLo@48b149d
02-22 03:48:10.719 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.719 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.720 I/ActivityManager( 3407): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0
02-22 03:48:10.721 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.723 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.725 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000020
02-22 03:48:10.733 I/LatinIME( 3573): Hardware accelerated drawing: true
02-22 03:48:10.738 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.754 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 9 lines
02-22 03:48:10.754 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.779 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.779 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.780 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.782 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.787 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 5 lines
02-22 03:48:10.790 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.790 I/system_server( 3407): Background concurrent copying GC freed 44817(2MB) AllocSpace objects, 26(680KB) LOS objects, 42% free, 5MB/9MB, paused 116us total 142.767ms
02-22 03:48:10.791 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.817 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.818 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.819 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.821 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.822 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 1 line
02-22 03:48:10.822 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.823 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000010
02-22 03:48:10.823 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.825 I/ActivityManager( 3407): Loaded persisted task ids for user 0
02-22 03:48:10.826 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 3 lines
02-22 03:48:10.827 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.853 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.853 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.855 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.858 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.862 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:10.862 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.886 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.886 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.888 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.890 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.893 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:10.893 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.915 W/system_server( 3407): Framework Matrix: Ignore file /system/etc/vintf/manifest.xml:
02-22 03:48:10.918 I/OMXClient( 3407): IOmx service obtained
02-22 03:48:10.918 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:10.920 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:10.922 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.962 D/SystemServerTiming( 3407): ActivityManagerStartApps took to complete: 250ms
02-22 03:48:10.962 D/SystemServerTiming( 3407): PhaseActivityManagerReady took to complete: 1123ms
02-22 03:48:10.933 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 10 lines
02-22 03:48:10.934 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:10.963 W/system_server( 3407): Long monitor contention with owner main (3407) at void com.android.server.am.ActivityManagerService.systemReady(java.lang.Runnable, android.util.TimingsTraceLog)(ActivityManagerService.java:15319) waiters=0 in java.lang.String com.android.server.am.ActivityManagerService.checkContentProviderAccess(java.lang.String, int) for 246ms
02-22 03:48:10.963 D/SystemServerInitThreadPool( 3407): Shutdown successful
02-22 03:48:10.964 D/SystemServerTiming( 3407): StartServices took to complete: 11440ms
02-22 03:48:10.964 W/ActivityManager( 3407): Slow operation: 247ms so far, now at startProcess: asking zygote to start proc
02-22 03:48:10.965 W/Looper  ( 3407): Slow delivery took 10752ms main h=android.os.Handler c=com.android.server.-$$Lambda$BatteryService$2x73lvpB0jctMSVP4qb9sHAqRPw@d0c6531 m=0
02-22 03:48:10.967 W/Looper  ( 3407): Slow dispatch took 250ms android.ui h=com.android.server.am.ActivityManagerService$UiHandler c=null m=53
02-22 03:48:10.975 W/InputAttributes( 3573): No editor info for this field. Bug?
02-22 03:48:10.977 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: returned from zygote!
02-22 03:48:10.977 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: done updating battery stats
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: building log message
02-22 03:48:10.978 I/ActivityManager( 3407): Start proc 3826:com.android.phone/1001 for added application com.android.phone
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: starting to update pids map
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 260ms so far, now at startProcess: done updating pids map
02-22 03:48:10.978 W/ActivityManager( 3407): Slow operation: 136ms so far, now at startProcess: asking zygote to start proc
02-22 03:48:11.002 W/ActivityManager( 3407): Slow operation: 160ms so far, now at startProcess: returned from zygote!
02-22 03:48:11.006 I/LatinIME:LogUtils( 3573): Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 1582254574 ; date = 1582803303
02-22 03:48:11.007 I/LatinIME:LogUtils( 3573): Dictionary info: dictionary = userunigram.en_US ; version = 1582343291 ; date = ?
02-22 03:48:10.976 W/main    ( 3826): type=1400 audit(0.0:2383): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: done updating battery stats
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: building log message
02-22 03:48:11.025 I/ActivityManager( 3407): Start proc 3841:com.android.settings/1000 for activity com.android.settings/.FallbackHome
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: starting to update pids map
02-22 03:48:11.025 W/ActivityManager( 3407): Slow operation: 183ms so far, now at startProcess: done updating pids map
02-22 03:48:11.026 E/ActivityThread( 3573): Failed to find provider info for user_dictionary
02-22 03:48:11.036 D/ConditionProviders.SCP( 3407): onConnected
02-22 03:48:11.037 D/ConditionProviders( 3407): Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider}
02-22 03:48:11.037 D/ConditionProviders( 3407): Subscribing to condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
02-22 03:48:10.976 I/chatty  ( 3826): uid=1001(radio) com.android.phone identical 2 lines
02-22 03:48:10.976 W/main    ( 3826): type=1400 audit(0.0:2386): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:11.047 V/SystemUIService( 3583): Starting SystemUI services for user 0.
02-22 03:48:11.047 V/MediaExtractorUpdateService( 3265): loadPlugins /vendor/app/ExtractorPkg/ExtractorPkg.apk
02-22 03:48:11.049 E/linker  ( 3265): library "/system/lib64/extractors/.." ("/system/lib64") needed or dlopened by "/system/lib64/libstagefright.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib64", permitted_paths="/system/lib64/drm:/system/lib64/extractors:/system/lib64/hw:/system/product/lib64:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:11.049 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/..) Success
02-22 03:48:11.050 W/MediaExtractorFactory( 3265): couldn't dlopen(/system/lib64/extractors/.) Is a directory
02-22 03:48:11.054 I/m.android.phon( 3826): The ClassLoaderContext is a special shared library.
02-22 03:48:11.053 E/MediaExtractorFactory( 3265): couldn't opendir(/vendor/lib64/extractors)
02-22 03:48:11.063 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.Dependency took to complete: 15ms
02-22 03:48:11.070 I/ndroid.setting( 3841): The ClassLoaderContext is a special shared library.
02-22 03:48:10.996 W/main    ( 3841): type=1400 audit(0.0:2387): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:11.082 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.util.NotificationChannels took to complete: 19ms
02-22 03:48:11.084 I/WifiScanningService( 3407): wifi driver unloaded
02-22 03:48:11.086 V/SettingsProvider( 3407): Notifying for 0: content://settings/secure/location_providers_allowed
02-22 03:48:11.086 V/SettingsProvider( 3407): Notifying for 0: content://settings/global/location_global_kill_switch
02-22 03:48:11.088 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.statusbar.CommandQueue$CommandQueueStart took to complete: 6ms
02-22 03:48:11.093 D/UsbDeviceManager( 3407): push notification:正在通过 USB 为此设备充电
02-22 03:48:11.087 I/WifiScanningService( 3407): wifi driver unloaded
02-22 03:48:11.095 V/MediaRouter( 3583): Adding route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:11.098 V/MediaRouter( 3583): Selecting route: RouteInfo{ name=平板电脑, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:11.107 I/ndroid.setting( 3841): The ClassLoaderContext is a special shared library.
02-22 03:48:11.109 I/LatinIME:LogUtils( 3573): Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
02-22 03:48:11.123 I/m.android.phon( 3826): The ClassLoaderContext is a special shared library.
02-22 03:48:11.134 W/SoundPool( 3583): Use of stream types is deprecated for operations other than volume control
02-22 03:48:11.134 W/SoundPool( 3583): See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
02-22 03:48:11.139 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.keyguard.KeyguardViewMediator took to complete: 50ms
02-22 03:48:11.148 D/OpenGLRenderer( 3583): Skia GL Pipeline
02-22 03:48:11.153 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:11.170 I/OMXClient( 3583): IOmx service obtained
02-22 03:48:11.170 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:11.173 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:11.176 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.191 W/ActivityManager( 3407): Unable to start service Intent { act=android.intent.action.QUICKSTEP_SERVICE pkg=com.android.launcher3 } U=0: not found
02-22 03:48:11.183 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:11.184 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.192 W/OverviewProxyService( 3583): Failed to connect on attempt 1 will try again in 5000ms
02-22 03:48:11.192 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.193 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 2 lines
02-22 03:48:11.193 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.199 I/m.android.phon( 3826): The ClassLoaderContext is a special shared library.
02-22 03:48:11.203 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:11.227 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:11.228 W/Looper  ( 3407): Slow dispatch took 135ms main h=android.app.ActivityThread$H c=null m=114
02-22 03:48:11.235 I/OMXClient( 3583): IOmx service obtained
02-22 03:48:11.236 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:11.237 E/OMXNodeInstance( 3270): getConfig(0xef92c0c0:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:11.239 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.241 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:11.245 I/Telecom ( 3407): BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
02-22 03:48:11.248 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.recents.Recents took to complete: 108ms
02-22 03:48:11.249 I/Telecom ( 3407): SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@48e0917: TS.init@AAA
02-22 03:48:11.243 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:11.243 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.251 D/OpenGLRenderer( 3841): Skia GL Pipeline
02-22 03:48:11.251 I/vol.Events( 3583): writeEvent collection_started
02-22 03:48:11.257 D/TelephonyProvider( 3826): dbh.onOpen: ok, queried table=siminfo
02-22 03:48:11.258 D/TelephonyProvider( 3826): dbh.onOpen: ok, queried table=carriers
02-22 03:48:11.258 I/Telecom ( 3407): Logging.Events: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentSpeakerRoute
02-22 03:48:11.259 I/Telecom ( 3407): BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
02-22 03:48:11.260 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.262 I/vol.Events( 3583): writeEvent external_ringer_mode_changed normal
02-22 03:48:11.262 I/vol.Events( 3583): writeEvent internal_ringer_mode_changed normal
02-22 03:48:11.265 I/Telecom ( 3407): CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA
02-22 03:48:11.269 I/Telecom ( 3407): MissedCallNotifierImpl: reloadFromDatabase: Boot not yet complete -- call log db may not be available. Deferring loading until boot complete for user 0: TS.init@AAA
02-22 03:48:11.271 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:11.275 I/Telecom ( 3407): Class: TelecomSystem.INSTANCE being set
02-22 03:48:11.275 W/ContextImpl( 3407): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 android.content.ContextWrapper.startService:664 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:197 com.android.server.telecom.components.TelecomService.onBind:67 android.app.ActivityThread.handleBindService:3597
02-22 03:48:11.277 W/ContextImpl( 3407): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1531 com.android.server.content.SyncManager$14.run:756 android.os.Handler.handleCallback:873 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:193
02-22 03:48:11.277 D/CarrierIdProvider( 3826): onCreate
02-22 03:48:11.279 D/installd( 3263): Found quota mount /dev/block/by-name/userdata at /data
02-22 03:48:11.280 D/installd( 3263): Found storage mount /data/media at /mnt/runtime/default/emulated
02-22 03:48:11.280 D/BluetoothManagerService( 3407): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
02-22 03:48:11.281 V/SettingsProvider( 3407): Notifying for 0: content://settings/global/boot_count
02-22 03:48:11.282 D/BluetoothManagerService( 3407): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
02-22 03:48:11.282 D/BluetoothManagerService( 3407): MESSAGE_GET_NAME_AND_ADDRESS
02-22 03:48:11.286 D/CarrierIdProvider( 3826): update database from pb file
02-22 03:48:11.286 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.288 D/BluetoothManagerService( 3407): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@8d1f71d mBinding = false mUnbinding = false
02-22 03:48:11.287 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.290 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:11.290 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.294 D/BluetoothAdapterService( 3546): onUnbind() - calling cleanup
02-22 03:48:11.294 D/BluetoothAdapterService( 3546): cleanup()
02-22 03:48:11.297 W/BluetoothSdpJni( 3546): Cleaning up Bluetooth SDP Interface...
02-22 03:48:11.298 W/BluetoothSdpJni( 3546): Cleaning up Bluetooth SDP object
02-22 03:48:11.298 D/BluetoothAdapterService( 3546): cleanup() - Cleaning up adapter native
02-22 03:48:11.298 I/bt_stack_manager( 3546): event_clean_up_stack is cleaning up the stack
02-22 03:48:11.298 I/bt_btif_core( 3546): btif_cleanup_bluetooth entered
02-22 03:48:11.298 E/bt_btif ( 3546): do_in_bta_thread: MessageLooper not initialized
02-22 03:48:11.298 E/BluetoothServiceJni( 3546): Callback: 'callback_thread_event' is not called on the correct thread
02-22 03:48:11.298 I/bt_btif_queue( 3546): btif_queue_release
02-22 03:48:11.298 I/bt_btif_core( 3546): run_message_loop finished
02-22 03:48:11.298 W/bt_osi_thread( 3546): run_thread: thread id 3626, thread name bt_jni_workqueue exited
02-22 03:48:11.298 I/Zygote  ( 3407): Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/f0642249-e0a6-4656-94b7-17a7125c2826 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
02-22 03:48:11.298 D/WebViewZygote( 3407): Preloading package /system/app/webview/webview.apk /system/app/webview/lib/arm:/system/app/webview/webview.apk!/lib/armeabi-v7a
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleaning up module "stack_config_module"
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleanup of module "stack_config_module" completed
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleaning up module "interop_module"
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleanup of module "interop_module" completed
02-22 03:48:11.299 I/bt_btif_core( 3546): btif_cleanup_bluetooth finished
02-22 03:48:11.299 I/bt_core_module( 3546): module_clean_up Cleaning up module "btif_config_module"
02-22 03:48:11.299 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:48:11.313 I/Zygote  ( 3407): Process: zygote socket ABSTRACT/com.android.internal.os.WebViewZygoteInit/f0642249-e0a6-4656-94b7-17a7125c2826 opened, supported ABIS: arm64-v8a,armeabi-v7a,armeabi
02-22 03:48:11.315 E/CarrierIdProvider( 3826): read carrier list from ota pb failure: java.io.FileNotFoundException: /data/misc/carrierid/carrier_list.pb (No such file or directory)
02-22 03:48:11.315 D/CarrierIdProvider( 3826): latest version: 4 need update: false
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleanup of module "btif_config_module" completed
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleaning up module "bt_utils_module"
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleanup of module "bt_utils_module" completed
02-22 03:48:11.318 I/bt_core_module( 3546): module_clean_up Cleaning up module "osi_module"
02-22 03:48:11.318 D/CarrierProvider( 3826): onCreate
02-22 03:48:11.318 D/bt_osi_alarm( 3546): callback_dispatch Callback thread exited
02-22 03:48:11.318 W/bt_osi_thread( 3546): run_thread: thread id 3624, thread name alarm_dispatcher exited
02-22 03:48:11.319 W/bt_osi_thread( 3546): run_thread: thread id 3623, thread name alarm_default_ca exited
02-22 03:48:11.320 I/bt_core_module( 3546): module_clean_up Cleanup of module "osi_module" completed
02-22 03:48:11.320 I/bt_stack_manager( 3546): event_clean_up_stack finished
02-22 03:48:11.320 I/BluetoothServiceJni( 3546): cleanupNative: return from cleanup
02-22 03:48:11.321 D/BluetoothActiveDeviceManager( 3546): cleanup()
02-22 03:48:11.324 D/BluetoothAdapterService( 3546): onDestroy()
02-22 03:48:11.325 I/WebViewZygoteInit( 3651): Beginning package preload
02-22 03:48:11.326 I/BluetoothAdapterService( 3546): Force exit to cleanup internal state in Bluetooth stack
02-22 03:48:11.327 I/ConfigStore( 3841): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:11.327 I/ConfigStore( 3841): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:11.327 I/OpenGLRenderer( 3841): Initialized EGL, version 1.4
02-22 03:48:11.327 D/OpenGLRenderer( 3841): Swap behavior 2
02-22 03:48:11.332 I/droid.bluetoot( 3546): System.exit called, status: 0
02-22 03:48:11.332 I/AndroidRuntime( 3546): VM exiting with result code 0, cleanup skipped.
02-22 03:48:11.335 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:11.339 I/ImsResolver( 3826): ImsResolver initialized with static binding.
02-22 03:48:11.343 I/ImsResolver( 3826): Initializing cache and binding.
02-22 03:48:11.345 V/WiredAccessoryManager( 3407): init()
02-22 03:48:11.346 V/WiredAccessoryManager( 3407): state_cable  16
02-22 03:48:11.347 V/WiredAccessoryManager( 3407): newName=extcon0 newState=16 headsetState=16 prev headsetState=0
02-22 03:48:11.347 I/OMXClient( 3583): IOmx service obtained
02-22 03:48:11.347 I/WiredAccessoryManager( 3407): MSG_NEW_DEVICE_STATE
02-22 03:48:11.347 I/OMXMaster( 3270): makeComponentInstance(OMX.google.vorbis.decoder) in omx@1.0-service process
02-22 03:48:11.349 E/OMXNodeInstance( 3270): getConfig(0xefd28080:google.vorbis.decoder, ConfigAndroidVendorExtension(0x6f100004)) ERROR: Undefined(0x80001001)
02-22 03:48:11.355 I/webview_zygote( 3651): The ClassLoaderContext is a special shared library.
02-22 03:48:11.357 I/display ( 3841): open gpu gralloc module!
02-22 03:48:11.360 W/WiredAccessoryManager( 3407): /sys/class/extcon/extcon1/state not found while attempting to determine initial switch state
02-22 03:48:11.360 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.361 V/WiredAccessoryManager( 3407): state_cable  16
02-22 03:48:11.362 V/WiredAccessoryManager( 3407): newName=extcon2 newState=16 headsetState=16 prev headsetState=16
02-22 03:48:11.361 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 2 lines
02-22 03:48:11.362 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.362 E/WiredAccessoryManager( 3407): No state change.
02-22 03:48:11.363 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.385 D/AccessibilityManagerService( 3407): Ignoring non-encryption-aware service ComponentInfo{com.sigma_rt.totalcontrol/com.sigma_rt.totalcontrol.ap.service.TCAccessibilityService}
02-22 03:48:11.387 V/NotificationListeners( 3407): enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
02-22 03:48:11.387 V/NotificationListeners( 3407): binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
02-22 03:48:11.387 W/ActivityManager( 3407): Unable to start service Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener } U=0: not found
02-22 03:48:11.387 W/NotificationListeners( 3407): Unable to bind notification listener service: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
02-22 03:48:11.387 V/NotificationAssistants( 3407): enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:11.388 V/NotificationAssistants( 3407): binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
02-22 03:48:11.374 I/chatty  ( 3229): uid=1000(system) allocator@1.0-s identical 6 lines
02-22 03:48:11.375 W/AshmemAllocator( 3229): ashmem_create_region(32768) returning hidl_memory(0xea37f442c100, 32768)
02-22 03:48:11.399 W/DeviceHAL( 3231): Error from HAL Device in function set_mic_mute: Function not implemented
02-22 03:48:11.407 I/ActivityManager( 3407): Start proc 3917:android.ext.services/u0a28 for service android.ext.services/.notification.Assistant
02-22 03:48:11.414 D/ConditionProviders.SCP( 3407): onSubscribe condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true
02-22 03:48:11.415 D/ConditionProviders.SCP( 3407): setRegistered true
02-22 03:48:11.420 D/ConditionProviders.SCP( 3407): evaluateSubscriptionLocked cal=ScheduleCalendar[mDays={1, 2, 3, 4, 5, 6, 7}, mSchedule=ScheduleInfo{days=[1, 2, 3, 4, 5, 6, 7], startHour=22, startMinute=0, endHour=7, endMinute=0, exitAtAlarm=true, nextAlarm=Thu Jan 01 00:00:00 GMT 1970 (0)}], now=Sat Feb 22 03:48:11 GMT 2020 (1582343291415), nextUserAlarmTime=Thu Jan 01 00:00:00 GMT 1970 (0)
02-22 03:48:11.421 D/ConditionProviders.SCP( 3407): notifyCondition condition://android/schedule?days=1.2.3.4.5.6.7&start=22.0&end=7.0&exitAtAlarm=true STATE_TRUE reason=meetsSchedule
02-22 03:48:11.424 D/ConditionProviders.SCP( 3407): Scheduling evaluate for Sat Feb 22 07:00:00 GMT 2020 (1582354800000), in +3h11m48s585ms, now=Sat Feb 22 03:48:11 GMT 2020 (1582343291415)
02-22 03:48:11.427 I/ActivityManager( 3407): Displayed com.android.settings/.FallbackHome: +574ms
02-22 03:48:11.427 W/KeyguardServiceDelegate( 3407): onScreenTurningOn(): no keyguard service!
02-22 03:48:11.427 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:11.432 E/ActivityThread( 3407): Failed to find provider info for com.android.calendar
02-22 03:48:11.435 I/Telecom ( 3407): WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE
02-22 03:48:11.436 I/WebViewZygoteInit( 3651): Package preload done
02-22 03:48:11.443 D/MediaSessionService( 3407): Global priority session is changed from null to com.android.server.telecom/HeadsetMediaButton (userId=0)
02-22 03:48:11.447 I/system_server( 3407): Background concurrent copying GC freed 53242(3MB) AllocSpace objects, 16(440KB) LOS objects, 42% free, 5MB/10MB, paused 337us total 172.379ms
02-22 03:48:11.449 I/SyncManager( 3407): Got SyncJobService instance.
02-22 03:48:11.450 V/WiredAccessoryManager( 3407): headsetName:  connected
02-22 03:48:11.452 D/AutofillManagerService( 3407): Autofill restriction did not change for user 0
02-22 03:48:11.453 D/audio_hw_primary( 3231): adev_set_parameters: enter: connect=1024
02-22 03:48:11.453 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:11.454 D/audio_hw_primary( 3231): out_set_parameters: enter: kvpairs: routing=0
02-22 03:48:11.454 D/audio_hw_primary( 3231): out_set_parameters: exit: code(0)
02-22 03:48:11.462 I/FusedLocation( 3407): engine started (com.android.location.fused)
02-22 03:48:11.462 W/Looper  ( 3407): Drained
02-22 03:48:11.462 V/MediaRouter( 3407): Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
02-22 03:48:11.463 V/MediaRouter( 3407): Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:11.471 I/Telecom ( 3407): WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAI
02-22 03:48:11.482 I/vol.Events( 3583): writeEvent level_changed STREAM_VOICE_CALL 4
02-22 03:48:11.483 I/vol.Events( 3583): writeEvent level_changed STREAM_SYSTEM 5
02-22 03:48:11.485 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.volume.VolumeUI took to complete: 236ms
02-22 03:48:11.487 I/ActivityManager( 3407): Process com.android.bluetooth (pid 3546) has died: fore SVC
02-22 03:48:11.488 W/libprocessgroup( 3407): kill(-3546, 9) failed: No such process
02-22 03:48:11.488 I/libprocessgroup( 3407): Successfully killed process cgroup uid 1002 pid 3546 in 0ms
02-22 03:48:11.488 I/Zygote  ( 3220): Process 3546 exited cleanly (0)
02-22 03:48:11.488 I/vol.Events( 3583): writeEvent level_changed STREAM_MUSIC 5
02-22 03:48:11.492 D/NotificationSQLiteLog( 3407): Pruned event entries: 0
02-22 03:48:11.494 I/vol.Events( 3583): writeEvent level_changed STREAM_RING 5
02-22 03:48:11.497 I/vol.Events( 3583): writeEvent level_changed STREAM_ALARM 6
02-22 03:48:11.500 I/vol.Events( 3583): writeEvent level_changed STREAM_BLUETOOTH_SCO 7
02-22 03:48:11.501 I/DefaultPermGrantPolicy( 3407): Revoking permissions from disabled data services for user:0
02-22 03:48:11.502 I/DefaultPermGrantPolicy( 3407): Granting permissions to enabled data services for user:0
02-22 03:48:11.506 I/vol.Events( 3583): writeEvent zen_mode_config_changed [disallowAlarms=false disallowMedia=false disallowSystem=true disallowRinger=false]
02-22 03:48:11.509 I/id.ext.service( 3917): The ClassLoaderContext is a special shared library.
02-22 03:48:11.531 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.stackdivider.Divider took to complete: 46ms
02-22 03:48:11.535 D/ExtAssistant( 3917): File doesn't exist or isn't readable yet
02-22 03:48:11.556 I/WifiService( 3407): getWifiServiceMessenger uid=10012
02-22 03:48:11.560 D/ConnectivityService( 3407): requestNetwork for uid/pid:10012/3583 NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ]
02-22 03:48:11.561 D/Ethernet( 3407): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:11.561 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], score: 0
02-22 03:48:11.561 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], network: NetworkInterfaceState{ iface: eth0, up: false, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTING/OBTAINING_IPADDR, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: false, roaming: false], networkAgent: null, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {LinkAddresses: []  Routes: [] DnsAddresses: [] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}
02-22 03:48:11.579 D/PhoneSwitcherNetworkRequstListener( 3826): Registering NetworkFactory
02-22 03:48:11.579 D/ConnectivityService( 3407): Got NetworkFactory Messenger for PhoneSwitcherNetworkRequstListener
02-22 03:48:11.586 D/ConnectivityService( 3407): Got NetworkFactory Messenger for TelephonyNetworkFactory[0]
02-22 03:48:11.597 E/ActivityThread( 3826): Failed to find provider info for com.android.contacts
02-22 03:48:11.597 W/CallerInfoCache( 3826): cursor is null
02-22 03:48:11.611 D/CarrierConfigLoader( 3826): CarrierConfigLoader has started
02-22 03:48:11.615 D/BluetoothManagerService( 3407): Trying to bind to profile: 1, while Bluetooth was disabled
02-22 03:48:11.626 W/WallpaperManagerService( 3407): Cannot extract colors because wallpaper could not be read.
02-22 03:48:11.626 W/WallpaperManagerService( 3407): Cannot get theme colors because WallpaperColors is null.
02-22 03:48:11.627 W/WallpaperManagerService( 3407): Cannot extract colors because wallpaper could not be read.
02-22 03:48:11.627 W/WallpaperManagerService( 3407): Cannot get theme colors because WallpaperColors is null.
02-22 03:48:11.630 I/TelecomFramework( 3826): TtyManager: updateUiTtyMode -1 -> 0
02-22 03:48:11.635 D/StatusBar( 3583): disable<e i a s b h r c s > disable2<q i n >
02-22 03:48:11.636 D/ImsResolver( 3826): maybeAddedImsService, packageName: null
02-22 03:48:11.636 I/ImsResolver( 3826): Adding newly added ImsService to cache: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
02-22 03:48:11.636 I/StatusBarManagerService( 3407): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@a9aec5d
02-22 03:48:11.638 I/ImsResolver( 3826): Binding ImsService: ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver} with features: [{s=0, f=0}, {s=0, f=1}]
02-22 03:48:11.638 I/ImsServiceController( 3826): Granting Runtime permissions to:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
02-22 03:48:11.638 I/DefaultPermGrantPolicy( 3407): Granting permissions to enabled ImsServices for user:0
02-22 03:48:11.638 I/ImsServiceController( 3826): Binding ImsService:ComponentInfo{com.android.phone/com.android.internal.telephony.ims.ImsResolver}
02-22 03:48:11.650 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:11.651 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:11.651 D/ServiceStateProvider( 3826): subId=-2
02-22 03:48:11.656 I/WifiService( 3407): WifiService trying to set country code to
02-22 03:48:11.656 I/WifiService( 3407): setCountryCode uid=1001
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:11.661 D/PhoneSwitcherNetworkRequstListener( 3826): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:11.662 D/TelephonyDebugService( 3826): TelephonyDebugService()
02-22 03:48:11.664 D/CarrierConfigLoader( 3826): mHandler: 12 phoneId: 0
02-22 03:48:11.669 E/PhoneInterfaceManager( 3826): [PhoneIntfMgr] getIccId: No UICC
02-22 03:48:11.676 D/OpenGLRenderer( 3826): Skia GL Pipeline
02-22 03:48:11.680 W/Telecom ( 3407): : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAY
02-22 03:48:11.680 I/TelecomFramework( 3826): AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0} Capabilities: CallProvider MultiUser PlaceEmerg SimSub  Audio Routes: BESW Schemes: tel voicemail  Extras: Bundle[{android.telecom.extra.SUPPORTS_VIDEO_CALLING_FALLBACK=true}] GroupId: ***] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, ***, UserHandle{0}
02-22 03:48:11.681 I/TelecomFramework( 3826): PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.GsmCdmaPhone) {d1d24d0}
02-22 03:48:11.687 I/TelecomFramework( 3826): PstnPhoneCapabilitiesNotifier: handleVideoCapabilitesChanged. Video capability - false
02-22 03:48:11.689 E/PhoneInterfaceManager( 3826): [PhoneIntfMgr] getIccId: No UICC
02-22 03:48:11.697 W/Telecom ( 3407): : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAk
02-22 03:48:11.714 D/incidentd( 3262): Start uploading backlogs in /data/misc/incidents/
02-22 03:48:11.720 D/incidentd( 3262): Successfully uploaded 0 files to Dropbox.
02-22 03:48:11.793 I/CameraManagerGlobal( 3583): Connecting to camera service
02-22 03:48:11.921 D/NotificationEntryMgr( 3583): heads up is enabled
02-22 03:48:12.001 D/BluetoothHidDevice( 3583): Bound to HID Device Service
02-22 03:48:12.001 D/LocalBluetoothProfileManager( 3583): Adding local MAP profile
02-22 03:48:12.002 D/BluetoothMap( 3583): Create BluetoothMap proxy object
02-22 03:48:12.003 D/LocalBluetoothProfileManager( 3583): Adding local PBAP profile
02-22 03:48:12.006 D/LocalBluetoothProfileManager( 3583): LocalBluetoothProfileManager construction complete
02-22 03:48:12.021 V/WifiManager( 3583): registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@bc141b5, handler=Handler (android.os.Handler) {a4c504a}
02-22 03:48:12.023 V/WifiManager( 3583): SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
02-22 03:48:12.023 V/WifiManager( 3583): SoftApCallbackProxy: onNumClientsChanged: numClients=0
02-22 03:48:12.031 D/OpenGLRenderer( 3583): profile bars disabled
02-22 03:48:12.032 D/OpenGLRenderer( 3583): ambientRatio = 1.50
02-22 03:48:12.045 D/StatusBar( 3583): disable<e i a s b h r c s > disable2<q i n >
02-22 03:48:12.063 V/WifiManager( 3583): registerSoftApCallback: callback=com.android.systemui.statusbar.policy.HotspotControllerImpl@bc141b5, handler=Handler (android.os.Handler) {a4c504a}
02-22 03:48:12.064 V/WifiManager( 3583): SoftApCallbackProxy: onStateChanged: state=11, failureReason=0
02-22 03:48:12.064 V/WifiManager( 3583): SoftApCallbackProxy: onNumClientsChanged: numClients=0
02-22 03:48:12.073 I/SecurityController( 3583): could not bind to KeyChainService
02-22 03:48:12.120 E/ActivityThread( 3583): Failed to find provider info for com.android.contacts
02-22 03:48:12.128 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.SystemBars took to complete: 597ms
02-22 03:48:12.134 D/StorageNotification( 3583): Notifying about private volume: VolumeInfo{private}:
02-22 03:48:12.134 D/StorageNotification( 3583):     type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
02-22 03:48:12.134 D/StorageNotification( 3583):     state=MOUNTED
02-22 03:48:12.134 D/StorageNotification( 3583):     fsType=null fsUuid=null fsLabel=null
02-22 03:48:12.134 D/StorageNotification( 3583):     path=/data internalPath=null
02-22 03:48:12.137 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.usb.StorageNotification took to complete: 8ms
02-22 03:48:12.147 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.power.PowerUI took to complete: 10ms
02-22 03:48:12.149 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.media.RingtonePlayer took to complete: 3ms
02-22 03:48:12.150 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.keyboard.KeyboardUI took to complete: 1ms
02-22 03:48:12.167 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.pip.PipUI took to complete: 17ms
02-22 03:48:12.169 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.shortcut.ShortcutKeyDispatcher took to complete: 2ms
02-22 03:48:12.169 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.VendorServices took to complete: 0ms
02-22 03:48:12.171 V/GarbageMonitor( 3583): Now tracking processes: 3583
02-22 03:48:12.171 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.util.leak.GarbageMonitor$Service took to complete: 2ms
02-22 03:48:12.173 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.LatencyTester took to complete: 1ms
02-22 03:48:12.176 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.globalactions.GlobalActionsComponent took to complete: 3ms
02-22 03:48:12.183 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.ScreenDecorations took to complete: 7ms
02-22 03:48:12.185 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.fingerprint.FingerprintDialogImpl took to complete: 1ms
02-22 03:48:12.187 D/SystemUIBootTiming( 3583): StartServicescom.android.systemui.SliceBroadcastRelayHandler took to complete: 1ms
02-22 03:48:12.187 D/SystemUIBootTiming( 3583): StartServices took to complete: 1138ms
02-22 03:48:12.199 W/AlarmManager( 3583): Unrecognized alarm listener com.android.systemui.keyguard.-$$Lambda$KeyguardSliceProvider$IhzByd8TsqFuOrSyuGurVskyPLo@48b149d
02-22 03:48:12.203 V/MediaRouter( 3583): Audio routes updated: AudioRoutesInfo{ type=HDMI }, a2dp=false
02-22 03:48:12.203 V/MediaRouter( 3583): Selecting route: RouteInfo{ name=HDMI, description=null, status=null, category=RouteCategory{ name=系统 types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
02-22 03:48:12.205 E/ndroid.systemu( 3583): Invalid ID 0x00000000.
02-22 03:48:12.205 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@5aaae80
02-22 03:48:12.208 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@5aaae80
02-22 03:48:12.210 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@557885f
02-22 03:48:12.211 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@557885f
02-22 03:48:12.213 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c70570a
02-22 03:48:12.214 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c70570a
02-22 03:48:12.214 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@2164b7b
02-22 03:48:12.215 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@2164b7b
02-22 03:48:12.216 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@a9fcd98
02-22 03:48:12.216 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@23f09f1
02-22 03:48:12.217 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@23f09f1
02-22 03:48:12.217 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@b44d9d6
02-22 03:48:12.219 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@b44d9d6
02-22 03:48:12.220 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c29542d
02-22 03:48:12.221 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c29542d
02-22 03:48:12.221 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@d0cbd62
02-22 03:48:12.222 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@becaef3
02-22 03:48:12.223 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@becaef3
02-22 03:48:12.224 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@406b7b0
02-22 03:48:12.225 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@4f40629
02-22 03:48:12.226 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@4f40629
02-22 03:48:12.228 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@e179edc
02-22 03:48:12.229 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@c9ddbe5
02-22 03:48:12.230 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@4f40629
02-22 03:48:12.231 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@5496ba
02-22 03:48:12.232 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@7cd096b
02-22 03:48:12.233 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@eedccc8
02-22 03:48:12.235 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@eedccc8
02-22 03:48:12.237 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@a555161
02-22 03:48:12.238 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@7cd096b
02-22 03:48:12.239 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@7256486
02-22 03:48:12.240 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@530d147
02-22 03:48:12.241 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@976ed74
02-22 03:48:12.242 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@fb4a29d
02-22 03:48:12.243 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@530d147
02-22 03:48:12.243 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@be34312
02-22 03:48:12.243 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@1f3ae3
02-22 03:48:12.244 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@1f3ae3
02-22 03:48:12.244 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@fcf6ce0
02-22 03:48:12.245 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@3bdcb99
02-22 03:48:12.245 E/vol.VolumeDialogImpl( 3583): Can't find translation for stream com.android.systemui.plugins.VolumeDialogController$StreamState@1f3ae3
02-22 03:48:12.245 I/chatty  ( 3583): uid=10012(com.android.systemui) identical 54 lines
02-22 03:48:12.245 E/ndroid.systemu( 3583): Invalid ID 0x00000000.
02-22 03:48:12.256 I/Choreographer( 3583): Skipped 43 frames!  The application may be doing too much work on its main thread.
02-22 03:48:12.269 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.272 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:12.289 D/ViewRootImpl[StatusBar]( 3583): changeCanvasOpacity: opaque=true
02-22 03:48:12.303 I/ConfigStore( 3583): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:12.303 I/ConfigStore( 3583): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:12.304 I/OpenGLRenderer( 3583): Initialized EGL, version 1.4
02-22 03:48:12.304 D/OpenGLRenderer( 3583): Swap behavior 2
02-22 03:48:12.317 E/ActivityThread( 3583): Failed to find provider info for com.android.contacts
02-22 03:48:12.322 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.328 I/display ( 3583): open gpu gralloc module!
02-22 03:48:12.351 E/ActivityThread( 3583): Failed to find provider info for com.android.contacts
02-22 03:48:12.435 D/WifiService( 3407): New client listening to asynchronous messages
02-22 03:48:12.809 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.816 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:12.980 I/EthernetTracker( 3407): interfaceLinkStateChanged, iface: eth0, up: true
02-22 03:48:12.981 D/EthernetNetworkFactory( 3407): updateInterfaceLinkState, iface: eth0, up: true
02-22 03:48:12.982 D/DhcpClient( 3407): doQuit
02-22 03:48:13.007 D/DhcpClient( 3407): onQuitting
02-22 03:48:13.009 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:13.011 D/EthernetNetworkFactory( 3407): starting IpClient(eth0): mNetworkInfo=[type: Ethernet[], state: DISCONNECTED/IDLE, reason: (unspecified), extra: (none), failover: false, available: false, roaming: false]
02-22 03:48:13.016 D/CommandListener( 3219): Clearing all IP addresses on eth0
02-22 03:48:13.028 W/WindowManager( 3407): App freeze timeout expired.
02-22 03:48:13.030 D/DhcpClient( 3407): Receive thread stopped
02-22 03:48:13.055 D/DhcpClient( 3407): Receive thread started
02-22 03:48:13.057 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:13.086 D/audio_hw_primary( 3231): adev_set_parameters: enter: A2dpSuspended=false
02-22 03:48:13.086 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:13.087 I/AudioService( 3407): setBluetoothScoOnInt: false resetBluetoothSco
02-22 03:48:13.087 D/audio_hw_primary( 3231): adev_set_parameters: enter: BT_SCO=off
02-22 03:48:13.087 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:13.162 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.204 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:13.218 I/Choreographer( 3583): Skipped 56 frames!  The application may be doing too much work on its main thread.
02-22 03:48:13.231 I/InputReader( 3407): Reconfiguring input devices.  changes=0x00000004
02-22 03:48:13.273 I/OpenGLRenderer( 3583): Davey! duration=1000ms; Flags=0, IntendedVsync=28328968658, Vsync=29262301954, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=29275853750, AnimationStart=29275879375, PerformTraversalsStart=29276725875, DrawStart=29298806500, SyncQueued=29316589625, SyncStart=29318134750, IssueDrawCommandsStart=29318255750, SwapBuffers=29328866875, FrameCompleted=29331460000, DequeueBufferDuration=733000, QueueBufferDuration=220000,
02-22 03:48:13.387 I/OpenGLRenderer( 3583): Davey! duration=1113ms; Flags=0, IntendedVsync=28328968658, Vsync=29262301954, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=29275853750, AnimationStart=29275879375, PerformTraversalsStart=29276725875, DrawStart=29408859000, SyncQueued=29411503750, SyncStart=29413656750, IssueDrawCommandsStart=29413806125, SwapBuffers=29443649875, FrameCompleted=29445108250, DequeueBufferDuration=449000, QueueBufferDuration=167000,
02-22 03:48:13.394 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/poll_delay" (No such file or directory).
02-22 03:48:13.395 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleAccelerometer/enable" (No such file or directory).
02-22 03:48:13.395 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleMagnetometer/enable" (No such file or directory).
02-22 03:48:13.395 E/        ( 3247): Could not open (write-only) SysFs attribute "/sys/class/misc/FreescaleGyroscope/enable" (No such file or directory).
02-22 03:48:13.395 D/        ( 3247): FSLSensorsHub sensor waht = 1 , enable = 1
02-22 03:48:13.493 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.533 I/chatty  ( 3583): uid=10012(com.android.systemui) identical 3 lines
02-22 03:48:13.548 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.561 W/StatusBar/NavBarView( 3583): *** Invalid layout in navigation bar (sizeChanged this=1920x64 cur=1898x64)
02-22 03:48:13.630 I/WindowManager( 3407): ******* TELLING SURFACE FLINGER WE ARE BOOTED!
02-22 03:48:13.630 I/SurfaceFlinger( 3250): Boot is finished (16377 ms)
02-22 03:48:13.632 I/ImageWallpaper( 3583): Redrawing in rect: RectF(0.0, 0.0, 1920.0001, 1536.0) with surface size: 1920x1280
02-22 03:48:13.639 I/SystemServiceManager( 3407): Starting phase 1000
02-22 03:48:13.656 D/ActivityManager( 3407): Finishing user boot 0
02-22 03:48:13.657 I/ActivityManager( 3407): User 0 state changed from BOOTING to RUNNING_LOCKED
02-22 03:48:13.659 D/vold    ( 3170): e4crypt_unlock_user_key 0 serial=0 token_present=0
02-22 03:48:13.666 D/vold    ( 3170): Skipping non-key ..
02-22 03:48:13.666 D/vold    ( 3170): Trying user CE key /data/misc/vold/user_keys/ce/0/current
02-22 03:48:13.672 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.keymaster@4.0::IKeymasterDevice/default in either framework or device manifest.
02-22 03:48:13.685 I/vold    ( 3170): List of Keymaster HALs found:
02-22 03:48:13.686 I/vold    ( 3170): Keymaster HAL #1: SoftwareKeymasterDevice from Google SecurityLevel: SOFTWARE HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:48:13.687 I/vold    ( 3170): Using SoftwareKeymasterDevice from Google for encryption.  Security level: SOFTWARE, HAL: android.hardware.keymaster@3.0::IKeymasterDevice/default
02-22 03:48:13.690 D/vold    ( 3170): Successfully retrieved key
02-22 03:48:13.691 D/vold    ( 3170): Added key 980530730 (ext4:d0b2240490369ad2) to keyring 625017044 in process 3170
02-22 03:48:13.691 D/vold    ( 3170): Added key 177620527 (f2fs:d0b2240490369ad2) to keyring 625017044 in process 3170
02-22 03:48:13.691 D/vold    ( 3170): Added key 1027625186 (fscrypt:d0b2240490369ad2) to keyring 625017044 in process 3170
02-22 03:48:13.692 D/vold    ( 3170): Installed ce key for user 0
02-22 03:48:13.692 D/ActivityManager( 3407): Started unlocking user 0
02-22 03:48:13.692 D/ActivityManager( 3407): Unlocking user 0 progress 0
02-22 03:48:13.692 D/ActivityManager( 3407): Unlocking user 0 progress 5
02-22 03:48:13.695 D/vold    ( 3170): e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 2
02-22 03:48:13.695 D/vold    ( 3170): Preparing: /data/system_ce/0
02-22 03:48:13.695 D/vold    ( 3170): Preparing: /data/misc_ce/0
02-22 03:48:13.695 D/vold    ( 3170): Preparing: /data/vendor_ce/0
02-22 03:48:13.699 D/vold    ( 3170): Preparing: /data/media/0
02-22 03:48:13.699 D/vold    ( 3170): Preparing: /data/data
02-22 03:48:13.701 D/WifiConfigStore( 3407): Reading from stores completed in 2 ms.
02-22 03:48:13.709 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/system_ce/0 which matches expected value
02-22 03:48:13.710 W/WifiConfigManager( 3407): No stored networks found.
02-22 03:48:13.712 D/WIFI    ( 3407): Registering NetworkFactory
02-22 03:48:13.712 D/WIFI_UT ( 3407): Registering NetworkFactory
02-22 03:48:13.714 D/ConnectivityService( 3407): Got NetworkFactory Messenger for WIFI
02-22 03:48:13.714 D/ConnectivityService( 3407): Got NetworkFactory Messenger for WIFI_UT
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.714 D/WIFI    ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ] with score 0
02-22 03:48:13.715 D/WIFI_UT ( 3407): got request NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ] with score 0
02-22 03:48:13.721 I/ActivityManager( 3407): Start proc 4010:com.android.deskclock/u0a45 for broadcast com.android.deskclock/.AlarmInitReceiver
02-22 03:48:13.743 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/misc_ce/0 which matches expected value
02-22 03:48:13.759 I/vold    ( 3170): Policy for /data/vendor_ce/0 set to d0b2240490369ad2 modes 1/4
02-22 03:48:13.760 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/media/0 which matches expected value
02-22 03:48:13.760 I/vold    ( 3170): Found policy d0b2240490369ad2 at /data/data which matches expected value
02-22 03:48:13.760 V/vold    ( 3170): Starting restorecon of /data/system_ce/0
02-22 03:48:13.760 I/bootstat( 4009): Service started: /system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l
02-22 03:48:13.692 W/Binder:3170_3( 3170): type=1400 audit(0.0:2396): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
02-22 03:48:13.696 I/chatty  ( 3170): uid=0(root) Binder:3170_2 identical 3 lines
02-22 03:48:13.696 W/Binder:3170_3( 3170): type=1400 audit(0.0:2400): avc: denied { dac_read_search } for capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
02-22 03:48:13.804 E/droid.deskcloc( 4010): Failed to send DDMS packet REAQ to debugger (-1 of 20): Broken pipe
02-22 03:48:13.823 I/bootstat( 4009): Battery level at startup 85%
02-22 03:48:13.823 I/bootstat( 4009): Canonical boot reason: reboot
02-22 03:48:13.833 E/bootstat( 4009): Failed to read /data/misc/bootstat/post_decrypt_time_elapsed: No such file or directory
02-22 03:48:13.833 E/bootstat( 4009): Failed to parse boot time record: /data/misc/bootstat/post_decrypt_time_elapsed
02-22 03:48:13.834 V/vold    ( 3170): Finished restorecon of /data/system_ce/0
02-22 03:48:13.834 V/vold    ( 3170): Starting restorecon of /data/misc_ce/0
02-22 03:48:13.851 I/droid.deskcloc( 4010): The ClassLoaderContext is a special shared library.
02-22 03:48:13.879 V/vold    ( 3170): Finished restorecon of /data/misc_ce/0
02-22 03:48:13.879 V/vold    ( 3170): /system/bin/vold_prepare_subdirs
02-22 03:48:13.879 V/vold    ( 3170):     prepare
02-22 03:48:13.879 V/vold    ( 3170):     0
02-22 03:48:13.879 V/vold    ( 3170):     2
02-22 03:48:13.897 I/droid.deskcloc( 4010): The ClassLoaderContext is a special shared library.
02-22 03:48:13.915 I/vold_prepare_subdirs( 3170): SELinux: Loaded file_contexts
02-22 03:48:13.920 D/vold_prepare_subdirs( 4034): Setting up mode 700 uid 0 gid 0 context u:object_r:vold_data_file:s0 on path: /data/misc_ce/0/vold
02-22 03:48:13.926 D/vold_prepare_subdirs( 4034): Setting up mode 700 uid 0 gid 0 context u:object_r:storaged_data_file:s0 on path: /data/misc_ce/0/storaged
02-22 03:48:13.929 V/UserDataPreparer( 3407): Found /data/user/0 with serial number 0
02-22 03:48:13.929 V/UserDataPreparer( 3407): Found /data/system_ce/0 with serial number 0
02-22 03:48:13.930 D/UserDataPreparer( 3407): Setting property: sys.user.0.ce_available=true
02-22 03:48:13.931 V/PackageManager( 3407): reconcileAppsData for null u0 0x2 migrateAppData=false
02-22 03:48:13.968 W/cutils  ( 3263): Expected path /data/data/com.sigma_rt.totalcontrol with mode 751 but found 777
02-22 03:48:13.979 I/AlarmClock( 4010): AlarmInitReceiver android.intent.action.LOCKED_BOOT_COMPLETED
02-22 03:48:13.988 I/AlarmClock( 4010): Fixing alarm instances
02-22 03:48:14.063 V/AlarmClock( 4010): AlarmInitReceiver finished
02-22 03:48:14.091 I/android.os.Debug( 3407): using rollup pss collection
02-22 03:48:14.133 V/PackageManager( 3407): reconcileAppsData finished 90 packages
02-22 03:48:14.133 I/ActivityManager( 3407): User 0 state changed from RUNNING_LOCKED to RUNNING_UNLOCKING
02-22 03:48:14.133 D/ActivityManager( 3407): Unlocking user 0 progress 20
02-22 03:48:14.133 W/Looper  ( 3407): Slow dispatch took 439ms android.fg h=android.os.Handler c=com.android.server.am.-$$Lambda$UserController$o6oQFjGYYIfx-I94cSakTLPLt6s@68e80e6 m=0
02-22 03:48:14.133 W/Looper  ( 3407): Slow delivery took 435ms android.fg h=com.android.server.AppStateTracker$MyHandler c=null m=14
02-22 03:48:14.133 I/SystemServiceManager( 3407): Calling onUnlockUser u0
02-22 03:48:14.134 D/BluetoothManagerService( 3407): User 0 unlocked
02-22 03:48:14.134 D/BluetoothManagerService( 3407): MESSAGE_USER_UNLOCKED
02-22 03:48:14.134 D/StorageManagerService( 3407): onUnlockUser 0
02-22 03:48:14.135 D/vold    ( 3170): Linking /storage/emulated/0 to /mnt/user/0/primary
02-22 03:48:14.150 W/Looper  ( 3407): Drained
02-22 03:48:14.150 D/StorageManagerService( 3407): Volume emulated broadcasting mounted to UserHandle{0}
02-22 03:48:14.163 D/WifiConfigStore( 3407): Reading from user store completed in 1 ms.
02-22 03:48:14.163 W/VoiceInteractionManagerService( 3407): no available voice interaction services found for user 0
02-22 03:48:14.164 W/VoiceInteractionManagerService( 3407): no available voice recognition services found for user 0
02-22 03:48:14.164 V/BackupManagerService( 3407): Starting with transport android/com.android.internal.backup.LocalTransport
02-22 03:48:14.164 D/WakeupConfigStoreData( 3407): WifiWake user data has been read
02-22 03:48:14.165 D/AutofillManagerServiceImpl( 3407): Reset component for user 0 ()
02-22 03:48:14.166 D/AutofillManagerServiceImpl( 3407): Reset component for user 0 ()
02-22 03:48:14.166 D/AutofillUI( 3407): destroySaveUiUiThread(): already destroyed
02-22 03:48:14.166 D/FieldClassificationStrategy( 3407): reset(): service is not bound. Do nothing.
02-22 03:48:14.166 I/ActivityManager( 3407): User 0 state changed from RUNNING_UNLOCKING to RUNNING_UNLOCKED
02-22 03:48:14.166 I/ActivityManager( 3407): Loading recents for user 0 into memory.
02-22 03:48:14.166 D/SystemServerTiming( 3407): SystemUserUnlock took to complete: 474ms
02-22 03:48:14.187 I/SELinux ( 3407): SELinux: Loaded file_contexts
02-22 03:48:14.190 E/BackupPasswordManager( 3407): Unable to read backup pw version
02-22 03:48:14.190 E/BackupPasswordManager( 3407): Unable to read saved backup pw hash
02-22 03:48:14.193 I/InputAttributes( 3573): InputType.TYPE_NULL is specified
02-22 03:48:14.198 D/WifiConfigStore( 3407): Writing to stores completed in 33 ms.
02-22 03:48:14.199 V/BackupManagerService( 3407): No ancestral data
02-22 03:48:14.205 I/ActivityManager( 3407): Start proc 4047:com.android.se/1068 for added application com.android.se
02-22 03:48:14.214 I/BackupManagerService( 3407): Package com.neolix.nexlioflowpdu not installed; dropping from full backup
02-22 03:48:14.220 I/BackupManagerService( 3407): Unlocking system user; mService=com.android.server.backup.BackupManagerService@8e89704
02-22 03:48:14.222 I/BackupManagerService( 3407): Backup enabled => false
02-22 03:48:14.233 V/BackupManagerConstants( 3407): getKeyValueBackupIntervalMilliseconds(...) returns 14400000
02-22 03:48:14.233 V/BackupManagerConstants( 3407): getKeyValueBackupFuzzMilliseconds(...) returns 600000
02-22 03:48:14.233 V/BackupManagerConstants( 3407): getKeyValueBackupRequiredNetworkType(...) returns 1
02-22 03:48:14.234 V/BackupManagerConstants( 3407): getKeyValueBackupRequireCharging(...) returns true
02-22 03:48:14.234 V/KeyValueBackupJob( 3407): Scheduling k/v pass in 247 minutes
02-22 03:48:14.286 I/com.android.se( 4047): The ClassLoaderContext is a special shared library.
02-22 03:48:14.317 I/SecureElementService( 4047): main onCreate
02-22 03:48:14.323 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.secure_element@1.0::ISecureElement/eSE1 in either framework or device manifest.
02-22 03:48:14.324 I/SecureElementService( 4047): No HAL implementation for eSE1
02-22 03:48:14.325 W/hwservicemanager( 3159): getTransport: Cannot find entry android.hardware.secure_element@1.0::ISecureElement/SIM1 in either framework or device manifest.
02-22 03:48:14.327 I/SecureElementService( 4047): No HAL implementation for SIM1
02-22 03:48:14.351 I/AppWidgetServiceImpl( 3407): Processing of handleUserUnlocked u0 took 168 ms
02-22 03:48:14.351 I/ActivityManager( 3407): Sending BOOT_COMPLETE user #0
02-22 03:48:14.352 I/system_server( 3407): Background concurrent copying GC freed 58775(3MB) AllocSpace objects, 45(1284KB) LOS objects, 42% free, 6MB/10MB, paused 273us total 117.268ms
02-22 03:48:14.364 D/FallbackHome( 3841): User unlocked and real home found; let's go!
02-22 03:48:14.365 D/CarrierSvcBindHelper( 3826): Received android.intent.action.USER_UNLOCKED
02-22 03:48:14.366 E/PhoneInterfaceManager( 3826): [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
02-22 03:48:14.366 D/CarrierSvcBindHelper( 3826): No carrier app for: 0
02-22 03:48:14.374 V/NotificationListeners( 3407): enabling notification listener for 0: ComponentInfo{com.android.launcher3/com.android.launcher3.notification.NotificationListener}
02-22 03:48:14.385 I/ActivityManager( 3407): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.launcher3/.Launcher} from uid 0
02-22 03:48:14.450 V/NotificationListeners( 3407): binding: Intent { act=android.service.notification.NotificationListenerService cmp=com.android.launcher3/.notification.NotificationListener (has extras) }
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: done updating battery stats
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: building log message
02-22 03:48:14.451 I/ActivityManager( 3407): Start proc 4070:android.process.media/u0a6 for broadcast com.android.providers.downloads/.DownloadReceiver
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: starting to update pids map
02-22 03:48:14.451 W/ActivityManager( 3407): Slow operation: 94ms so far, now at startProcess: done updating pids map
02-22 03:48:14.465 V/NotificationAssistants( 3407): disabling notification assistant for user 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:14.465 D/NotificationListeners( 3407): Removing active service ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:14.467 V/NotificationAssistants( 3407): enabling notification assistant for 0: ComponentInfo{android.ext.services/android.ext.services.notification.Assistant}
02-22 03:48:14.467 V/NotificationAssistants( 3407): binding: Intent { act=android.service.notification.NotificationAssistantService cmp=android.ext.services/.notification.Assistant (has extras) }
02-22 03:48:14.473 I/ActivityManager( 3407): Start proc 4086:com.android.launcher3/u0a27 for activity com.android.launcher3/.Launcher
02-22 03:48:14.486 I/AccountManagerService( 3407): User 0 is unlocked - opening CE database
02-22 03:48:14.513 I/d.process.medi( 4070): The ClassLoaderContext is a special shared library.
02-22 03:48:14.539 I/SyncManager( 3407): Loaded persisted syncs: 0 periodic syncs, 0 oneshot syncs, 10 total system server jobs, JobStats: FirstLoad: 2/2/0 LastSave: -1/-1/-1
02-22 03:48:14.550 I/droid.launcher( 4086): The ClassLoaderContext is a special shared library.
02-22 03:48:14.563 I/ActivityManager( 3407): Start proc 4106:com.android.printspooler/u0a53 for service com.android.printspooler/.model.PrintSpoolerService
02-22 03:48:14.564 I/d.process.medi( 4070): The ClassLoaderContext is a special shared library.
02-22 03:48:14.630 I/id.printspoole( 4106): The ClassLoaderContext is a special shared library.
02-22 03:48:14.682 D/MediaScannerReceiver( 4070): action: android.intent.action.MEDIA_MOUNTED path: /storage/emulated/0
02-22 03:48:14.696 W/WallpaperManagerService( 3407): Cannot extract colors because wallpaper could not be read.
02-22 03:48:14.696 W/WallpaperManagerService( 3407): Cannot get theme colors because WallpaperColors is null.
02-22 03:48:14.697 V/Launcher( 4086): LauncherAppState initiated
02-22 03:48:14.701 I/ActivityManager( 3407): Start proc 4130:com.android.quicksearchbox/u0a41 for broadcast com.android.quicksearchbox/.SearchWidgetProvider
02-22 03:48:14.704 W/main    ( 4130): type=1400 audit(0.0:3637): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:14.719 I/ActivityManager( 3407): Start proc 4135:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
02-22 03:48:14.708 I/chatty  ( 4130): uid=0(root) .quicksearchbo identical 2 lines
02-22 03:48:14.708 W/main    ( 4130): type=1400 audit(0.0:3640): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:14.716 W/main    ( 4135): type=1400 audit(0.0:3641): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:14.727 D/OpenGLRenderer( 4086): Skia GL Pipeline
02-22 03:48:14.782 I/.quicksearchbo( 4130): The ClassLoaderContext is a special shared library.
02-22 03:48:14.787 I/ndroid.keychai( 4135): The ClassLoaderContext is a special shared library.
02-22 03:48:14.798 I/.quicksearchbo( 4130): The ClassLoaderContext is a special shared library.
02-22 03:48:14.904 I/RecoverySystem( 3407): No recovery log file
02-22 03:48:14.917 I/BootReceiver( 3407): Copying audit failures to DropBox
02-22 03:48:14.917 I/BootReceiver( 3407): Checking for fsck errors
02-22 03:48:14.918 I/BootReceiver( 3407): fs_stat, partition:userdata stat:0xb
02-22 03:48:14.942 I/ActivityManager( 3407): Start proc 4180:com.android.dialer/u0a31 for broadcast com.android.dialer/.app.calllog.CallLogReceiver
02-22 03:48:15.008 I/.android.diale( 4180): The ClassLoaderContext is a special shared library.
02-22 03:48:15.031 D/DhcpClient( 3407): Broadcasting DHCPDISCOVER
02-22 03:48:15.130 I/.android.diale( 4180): The ClassLoaderContext is a special shared library.
02-22 03:48:15.141 D/LoaderTask( 4086): loadWorkspace: loading default favorites
02-22 03:48:15.207 I/vol.Events( 3583): writeEvent dismiss_dialog timeout
02-22 03:48:15.221 I/ConfigStore( 4086): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:15.222 I/ConfigStore( 4086): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:15.222 I/OpenGLRenderer( 4086): Initialized EGL, version 1.4
02-22 03:48:15.223 D/OpenGLRenderer( 4086): Swap behavior 2
02-22 03:48:15.238 I/Dialer  ( 4180): DialerExecutorModule.newThread - creating low priority thread
02-22 03:48:15.250 I/display ( 4086): open gpu gralloc module!
02-22 03:48:15.253 I/Dialer  ( 4180): CallLogFramework.registerContentObservers - enter
02-22 03:48:15.258 I/Dialer  ( 4180): CallLogFramework.registerContentObservers - not registering content observers
02-22 03:48:15.264 I/Dialer  ( 4180): DialerExecutorModule.newThread - creating low priority thread
02-22 03:48:15.279 D/TouchInteractionService( 4086): Touch service connected
02-22 03:48:15.312 I/Dialer  ( 4180): DialerExecutorModule.newThread - creating low priority thread
02-22 03:48:15.315 I/Dialer  ( 4180): VisualVoicemailUpdateTask.updateNotification - enter
02-22 03:48:15.349 I/ActivityManager( 3407): Start proc 4228:android.process.acore/u0a15 for content provider com.android.providers.contacts/.CallLogProvider
02-22 03:48:15.430 I/ActivityManager( 3407): Displayed com.android.launcher3/.Launcher: +975ms
02-22 03:48:15.437 I/d.process.acor( 4228): The ClassLoaderContext is a special shared library.
02-22 03:48:15.457 E/SchedPolicy( 4086): set_timerslack_ns write failed: Operation not permitted
02-22 03:48:15.588 I/ContactsPerf( 4228): VoicemailContentProvider.onCreate start
02-22 03:48:15.604 I/ContactsPerf( 4228): VoicemailContentProvider.onCreate finish
02-22 03:48:15.667 I/d.process.acor( 4228): The ClassLoaderContext is a special shared library.
02-22 03:48:15.708 W/SurfaceFlinger( 3250): Attempting to set client state on removed layer: com.android.settings/com.android.settings.FallbackHome#0
02-22 03:48:15.708 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: com.android.settings/com.android.settings.FallbackHome#0
02-22 03:48:15.713 D/ContactsDatabaseHelper( 4228): WAL enabled for contacts2.db: true
02-22 03:48:15.716 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: AppWindowToken{5c08d4a token=Token{99c52b5 ActivityRecord{1dd6eec u0 com.android.settings/.FallbackHome t1}}}#0
02-22 03:48:15.731 I/d.process.acor( 4228): The ClassLoaderContext is a special shared library.
02-22 03:48:15.841 I/ContactLocale( 4228): AddressBook Labels [[zh_CN_#Hans,en_US]]: […, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, …, А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, …, א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, …, ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, …, ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, …, ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, …, あ, か, さ, た, な, は, ま, や, ら, わ, #, …]
02-22 03:48:15.859 D/DhcpClient( 3407): Received packet: 1e:ec:5a:75:1b:94 OFFER, ip /172.16.0.118, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:48:15.859 D/DhcpClient( 3407): Got pending lease: IP address 172.16.0.118/24 Gateway 172.16.0.1  DNS servers: [ 172.16.0.1 ] Domains lan DHCP server /172.16.0.1 Vendor info null lease 1800 seconds
02-22 03:48:15.860 D/DhcpClient( 3407): Broadcasting DHCPREQUEST ciaddr=0.0.0.0 request=172.16.0.118 serverid=172.16.0.1
02-22 03:48:15.866 D/DhcpClient( 3407): Received packet: 1e:ec:5a:75:1b:94 ACK: your new IP /172.16.0.118, netmask /255.255.255.0, gateways [/172.16.0.1] DNS servers: /172.16.0.1 , lease time 1800
02-22 03:48:15.866 D/DhcpClient( 3407): Confirmed lease: IP address 172.16.0.118/24 Gateway 172.16.0.1  DNS servers: [ 172.16.0.1 ] Domains lan DHCP server /172.16.0.1 Vendor info null lease 1800 seconds
02-22 03:48:15.867 D/CommandListener( 3219): Setting iface cfg
02-22 03:48:15.871 D/DhcpClient( 3407): Scheduling renewal in 899s
02-22 03:48:15.871 D/DhcpClient( 3407): Scheduling rebind in 1574s
02-22 03:48:15.871 D/DhcpClient( 3407): Scheduling expiry in 1799s
02-22 03:48:15.874 I/Dialer  ( 4180): VisualVoicemailUpdateTask.updateNotification - no voicemails to notify about
02-22 03:48:15.875 I/Dialer  ( 4180): VisualVoicemailNotifier.cancelAllVoicemailNotifications - enter
02-22 03:48:15.784 E/SchedPolicy( 4086): set_timerslack_ns write failed: Operation not permitted
02-22 03:48:15.880 D/ConnectivityService( 3407): registerNetworkAgent NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false]}  network{100}  nethandle{432902426637}  lp{{InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}  nc{[ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]}  Score{70}  everValidated{false}  lastValidated{false}  created{false} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} clat{null} }
02-22 03:48:15.880 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] EVENT_NETWORK_INFO_CHANGED, going from null to CONNECTED
02-22 03:48:15.881 D/TcpSocketMonitor( 3219): resuming tcpinfo polling (interval=30000ms)
02-22 03:48:15.882 W/DnsManager( 3407): updatePrivateDns(100, PrivateDnsConfig{true:/[]})
02-22 03:48:15.883 D/ConnectivityService( 3407): Setting DNS servers for network 100 to [/172.16.0.1]
02-22 03:48:15.884 D/DnsManager( 3407): setDnsConfigurationForNetwork(100, [172.16.0.1], [lan], [1800, 25, 8, 64], , [172.16.0.1])
02-22 03:48:15.888 D/ConnectivityService( 3407): Adding iface eth0 to network 100
02-22 03:48:15.900 D/ContactsDatabaseHelper( 4228): WAL enabled for profile.db: false
02-22 03:48:15.902 I/Dialer  ( 4180): VoicemailNotificationJobService.scheduleJob - job canceled
02-22 03:48:15.914 I/Dialer  ( 4180): VisualVoicemailUpdateTask.scheduleTask - update successful
02-22 03:48:15.925 D/ConnectivityService( 3407): Setting DNS servers for network 100 to [/172.16.0.1]
02-22 03:48:15.925 D/DnsManager( 3407): setDnsConfigurationForNetwork(100, [172.16.0.1], [lan], [1800, 25, 8, 64], , [172.16.0.1])
02-22 03:48:15.930 W/DnsTlsSocket( 3219): SSL_connect error 5, errno=111
02-22 03:48:15.931 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.937 E/SchedPolicy( 4086): set_timerslack_ns write failed: Operation not permitted
02-22 03:48:15.943 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.944 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.946 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.953 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.954 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.956 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], score: 70
02-22 03:48:15.958 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=8, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 10012] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {135afab}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
02-22 03:48:15.958 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], score: 70
02-22 03:48:15.958 D/ConnectivityService( 3407): Switching to new default network: NetworkAgentInfo{ ni{[type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false]}  network{100}  nethandle{432902426637}  lp{{InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}  nc{[ Transports: ETHERNET Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED Unwanted:  LinkUpBandwidth>=100000Kbps LinkDnBandwidth>=100000Kbps]}  Score{70}  everValidated{false}  lastValidated{false}  created{true} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} clat{null} }
02-22 03:48:15.958 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN Unwanted: ] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {135afab}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
02-22 03:48:15.958 D/EthernetNetworkFactory( 3407): acceptRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], score: 70
02-22 03:48:15.959 I/EthernetNetworkFactory( 3407): networkForRequest, request: NetworkRequest [ TRACK_DEFAULT id=6, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Unwanted:  Uid: 1000] ], network: NetworkInterfaceState{ iface: eth0, up: true, hwAddress: 1e:ec:5a:75:1b:94, networkInfo: [type: Ethernet[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: 1e:ec:5a:75:1b:94, failover: false, available: true, roaming: false], networkAgent: Handler (com.android.server.ethernet.EthernetNetworkFactory$NetworkInterfaceState$2) {135afab}, ipClient: name=IpClient.eth0 state=RunningState,linkProperties: {InterfaceName: eth0 LinkAddresses: [fe80::a021:d30e:d58:e446/64,172.16.0.118/24,]  Routes: [fe80::/64 -> :: eth0,172.16.0.0/24 -> 0.0.0.0 eth0,0.0.0.0/0 -> 172.16.0.1 eth0,] DnsAddresses: [172.16.0.1,] UsePrivateDns: false PrivateDnsServerName: null Domains: lan MTU: 0 TcpBufferSizes: 524288,1048576,3145728,524288,1048576,2097152}}
02-22 03:48:15.964 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 6ms OK 69.63.180.173
02-22 03:48:15.966 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 7ms OK 203.208.39.247
02-22 03:48:15.974 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.980 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=12ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:06:45 GMT], X-Android-Received-Millis=[1582343295979], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343295975]}
02-22 03:48:15.984 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.985 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.988 D/NetworkTimeUpdateService( 3407): New default network 100; checking time.
02-22 03:48:15.989 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:15.989 D/ConnectivityService( 3407): Sending CONNECTED broadcast for type 9 NetworkAgentInfo [Ethernet () - 100] isDefaultNetwork=true
02-22 03:48:15.994 I/chatty  ( 3407): uid=1000(system) NetworkPolicy identical 1 line
02-22 03:48:15.995 W/BestClock( 3407): java.time.DateTimeException: Missing NTP fix
02-22 03:48:16.054 V/MediaProvider( 4070): pruneThumbnails
02-22 03:48:16.063 V/MediaProvider( 4070): /pruneDeadThumbnailFiles...
02-22 03:48:16.242 I/LatinIME( 3573): Timeout waiting for dictionary load
02-22 03:48:20.916 D/WifiService( 3407): boot completed do start wifi
02-22 03:48:20.916 W/Looper  ( 3407): Slow dispatch took 5001ms main h=android.app.ActivityThread$H c=android.app.-$$Lambda$LoadedApk$ReceiverDispatcher$Args$_BumDX2UKsnxLVrE6UJsJZkotuA@d01b175 m=0
02-22 03:48:20.916 W/Looper  ( 3407): Slow delivery took 5001ms main h=com.android.server.job.JobSchedulerService$JobHandler c=null m=4
02-22 03:48:20.932 I/Telecom ( 3407): DefaultDialerCache: Refreshing default dialer for user 0: now com.android.dialer: DDC.oR@AA8
02-22 03:48:20.934 I/TransportClient( 3407): LocalTransportService#0: Notifying [TransportManager.registerTransport()] transport = IBackupTransport
02-22 03:48:20.934 W/Looper  ( 3407): Drained
02-22 03:48:20.935 I/Telecom ( 3407): MissedCallNotifierImpl: reloadAfterBootComplete: user=0: TSBCR.oR@ABA
02-22 03:48:20.938 D/CarrierConfigLoader( 3826): mHandler: 13 phoneId: 0
02-22 03:48:20.942 D/BackupTransportManager( 3407): Transport android/com.android.internal.backup.LocalTransportService registered
02-22 03:48:20.942 D/BackupManagerService( 3407): Transport android/com.android.internal.backup.LocalTransport registered 6723ms after first request (delay = 3000ms)
02-22 03:48:20.948 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:20.958 D/SIP     ( 3826): [SipPreferences] isReceivingCallsEnabled, option not set; use default value, exception: android.provider.Settings$SettingNotFoundException: sip_receive_calls
02-22 03:48:20.973 I/chatty  ( 3407): uid=1000(system) backup identical 163 lines
02-22 03:48:20.973 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:20.973 I/ActivityManager( 3407): Start proc 4327:com.android.calendar/u0a62 for broadcast com.android.calendar/.alerts.AlertReceiver
02-22 03:48:20.974 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:21.006 D/SntpClient( 3407): request time failed: java.net.SocketTimeoutException: Poll timed out
02-22 03:48:20.968 W/main    ( 4327): type=1400 audit(0.0:3653): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:21.027 I/ndroid.calenda( 4327): The ClassLoaderContext is a special shared library.
02-22 03:48:21.043 I/ndroid.calenda( 4327): The ClassLoaderContext is a special shared library.
02-22 03:48:21.073 D/ExtensionsFactory( 4327): No custom extensions.
02-22 03:48:21.077 D/AlertReceiver( 4327): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
02-22 03:48:20.987 I/chatty  ( 3407): uid=1000(system) backup identical 130 lines
02-22 03:48:20.987 I/BackupManagerService( 3407): Found stale backup journal, scheduling
02-22 03:48:21.096 I/ActivityManager( 3407): Start proc 4357:com.android.cellbroadcastreceiver/u0a24 for broadcast com.android.cellbroadcastreceiver/.CellBroadcastReceiver
02-22 03:48:21.108 D/AlertService( 4327): 0 Action = android.intent.action.BOOT_COMPLETED
02-22 03:48:21.112 D/AlertService( 4327): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
02-22 03:48:21.140 I/ActivityManager( 3407): Start proc 4368:com.android.providers.calendar/u0a4 for content provider com.android.providers.calendar/.CalendarProvider2
02-22 03:48:21.092 W/main    ( 4357): type=1400 audit(0.0:3657): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:21.239 I/oadcastreceive( 4357): The ClassLoaderContext is a special shared library.
02-22 03:48:21.252 I/viders.calenda( 4368): The ClassLoaderContext is a special shared library.
02-22 03:48:21.298 D/CellBroadcastReceiver( 4357): onReceive Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.cellbroadcastreceiver/.CellBroadcastReceiver (has extras) }
02-22 03:48:21.298 D/CellBroadcastReceiver( 4357): Start Cell Broadcast configuration.
02-22 03:48:21.309 D/CellBroadcastReceiver( 4357): Default interval 0 did not change.
02-22 03:48:21.324 I/ActivityManager( 3407): Start proc 4406:com.android.contacts/u0a26 for broadcast com.android.contacts/.interactions.OnBootOrUpgradeReceiver
02-22 03:48:21.328 I/CalendarProvider2( 4368): Created com.android.providers.calendar.CalendarAlarmManager@12606e0(com.android.providers.calendar.CalendarProvider2@4895d99)
02-22 03:48:21.332 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.333 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4370 to 4370 from client com.android.cellbroadcastreceiver
02-22 03:48:21.337 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.338 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4096 to 4096 from client com.android.cellbroadcastreceiver
02-22 03:48:21.340 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.341 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4383 to 4383 from client com.android.cellbroadcastreceiver
02-22 03:48:21.344 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.344 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4371 to 4372 from client com.android.cellbroadcastreceiver
02-22 03:48:21.349 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.350 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4097 to 4097 from client com.android.cellbroadcastreceiver
02-22 03:48:21.353 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.353 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4384 to 4385 from client com.android.cellbroadcastreceiver
02-22 03:48:21.358 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.358 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4373 to 4378 from client com.android.cellbroadcastreceiver
02-22 03:48:21.361 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.361 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4098 to 4098 from client com.android.cellbroadcastreceiver
02-22 03:48:21.365 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.365 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4386 to 4391 from client com.android.cellbroadcastreceiver
02-22 03:48:21.374 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.375 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4379 to 4379 from client com.android.cellbroadcastreceiver
02-22 03:48:21.380 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setCdmaBroadcastConfig with 1 configurations
02-22 03:48:21.381 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add cdma broadcast subscription for MID range 4099 to 4099 from client com.android.cellbroadcastreceiver
02-22 03:48:21.384 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.384 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4392 to 4392 from client com.android.cellbroadcastreceiver
02-22 03:48:21.388 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4380 to 4380 from client com.android.cellbroadcastreceiver
02-22 03:48:21.391 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove cdma broadcast subscription for MID range 4100 to 4100 from client com.android.cellbroadcastreceiver
02-22 03:48:21.393 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4393 to 4393 from client com.android.cellbroadcastreceiver
02-22 03:48:21.399 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4381 to 4381 from client com.android.cellbroadcastreceiver
02-22 03:48:21.401 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4394 to 4394 from client com.android.cellbroadcastreceiver
02-22 03:48:21.404 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4382 to 4382 from client com.android.cellbroadcastreceiver
02-22 03:48:21.407 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4395 to 4395 from client com.android.cellbroadcastreceiver
02-22 03:48:21.411 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.412 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4352 to 4354 from client com.android.cellbroadcastreceiver
02-22 03:48:21.415 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Calling setGsmBroadcastConfig with 1 configurations
02-22 03:48:21.415 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to add GSM cell broadcast subscription for MID range 4356 to 4356 from client com.android.cellbroadcastreceiver
02-22 03:48:21.418 D/IccSmsInterfaceManager( 3826): [IccSmsInterfaceManager] Failed to remove GSM cell broadcast subscription for MID range 4355 to 4355 from client com.android.cellbroadcastreceiver
02-22 03:48:21.435 I/ndroid.contact( 4406): The ClassLoaderContext is a special shared library.
02-22 03:48:21.448 D/AlarmScheduler( 4327): No events found starting within 1 week.
02-22 03:48:21.483 I/AlarmClock( 4010): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
02-22 03:48:21.491 D/ActivityManager( 3407): Raise procstate to external provider: ProcessRecord{ee30ac8 4228:android.process.acore/u0a15}
02-22 03:48:21.494 W/Binder  ( 3407): Outgoing transactions from this process must be FLAG_ONEWAY
02-22 03:48:21.494 W/Binder  ( 3407): java.lang.Throwable
02-22 03:48:21.494 W/Binder  ( 3407):  at android.os.BinderProxy.transact(Binder.java:1114)
02-22 03:48:21.494 W/Binder  ( 3407):  at android.content.ContentProviderProxy.getType(ContentProviderNative.java:451)
02-22 03:48:21.494 W/Binder  ( 3407):  at com.android.server.am.ActivityManagerService.getProviderMimeType(ActivityManagerService.java:13064)
02-22 03:48:21.494 W/Binder  ( 3407):  at android.app.IActivityManager$Stub.onTransact(IActivityManager.java:1416)
02-22 03:48:21.494 W/Binder  ( 3407):  at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:3291)
02-22 03:48:21.494 W/Binder  ( 3407):  at android.os.Binder.execTransact(Binder.java:731)
02-22 03:48:21.504 I/AlarmClock( 4010): Fixing alarm instances
02-22 03:48:21.513 V/AlarmClock( 4010): AlarmInitReceiver finished
02-22 03:48:21.522 I/Dialer  ( 4180): VoicemailModule.provideVoicemailClient - providing VoicemailClientImpl
02-22 03:48:21.524 I/Dialer  ( 4180): VvmOmtpService - onBoot
02-22 03:48:21.543 I/ActivityManager( 3407): Start proc 4442:com.android.email/u0a37 for broadcast com.android.email/.service.EmailBroadcastReceiver
02-22 03:48:21.600 I/m.android.emai( 4442): The ClassLoaderContext is a special shared library.
02-22 03:48:21.672 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.619 I/m.android.emai( 4442): The ClassLoaderContext is a special shared library.
02-22 03:48:21.683 D/DhcpClient( 3407): Received packet: 80:05:88:b7:35:48 OFFER, ip /172.16.0.43, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:48:21.688 D/ActivityThread( 4442): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
02-22 03:48:21.690 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.765 I/SystemBroadcastReceiver( 3573): Boot has been completed
02-22 03:48:21.765 I/SystemBroadcastReceiver( 3573): toggleAppIcon() : FLAG_SYSTEM = true
02-22 03:48:21.789 I/ActivityManager( 3407): Start proc 4483:com.android.managedprovisioning/u0a9 for broadcast com.android.managedprovisioning/.preprovisioning.BootReminder
02-22 03:48:21.793 W/ActivityManager( 3407): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
02-22 03:48:21.795 W/ActivityManager( 3407): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
02-22 03:48:21.799 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.818 E/gedprovisionin( 4483): Failed to send DDMS packet REAQ to debugger (-1 of 20): Broken pipe
02-22 03:48:21.820 I/chatty  ( 3407): uid=1000(system) Binder:3407_1 identical 1 line
02-22 03:48:21.822 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.824 E/ActivityThread( 4442): Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@a2c753c that was originally bound here
02-22 03:48:21.824 E/ActivityThread( 4442): android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@a2c753c that was originally bound here
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1610)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1502)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1659)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.ContextImpl.bindService(ContextImpl.java:1612)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.content.ContextWrapper.bindService(ContextWrapper.java:698)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
02-22 03:48:21.824 E/ActivityThread( 4442):  at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:76)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.os.Handler.dispatchMessage(Handler.java:106)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.os.Looper.loop(Looper.java:193)
02-22 03:48:21.824 E/ActivityThread( 4442):  at android.os.HandlerThread.run(HandlerThread.java:65)
02-22 03:48:21.824 W/ActivityManager( 3407): Unbind failed: could not find connection for android.os.BinderProxy@c30ac5e
02-22 03:48:21.839 I/Email   ( 4442): Observing account changes for notifications
02-22 03:48:21.854 W/ActivityManager( 3407): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
02-22 03:48:21.881 I/gedprovisionin( 4483): The ClassLoaderContext is a special shared library.
02-22 03:48:21.932 I/ActivityManager( 3407): Start proc 4510:com.android.onetimeinitializer/u0a19 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
02-22 03:48:21.986 I/timeinitialize( 4510): The ClassLoaderContext is a special shared library.
02-22 03:48:22.007 V/OneTimeInitializerReceiver( 4510): OneTimeInitializerReceiver.onReceive
02-22 03:48:22.028 I/ActivityManager( 3407): Start proc 4529:com.android.packageinstaller/u0a32 for broadcast com.android.packageinstaller/.TemporaryFileManager
02-22 03:48:22.024 W/main    ( 4529): type=1400 audit(0.0:3681): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:22.130 I/ackageinstalle( 4529): The ClassLoaderContext is a special shared library.
02-22 03:48:22.169 I/VvmSimStateTracker( 3826): android.intent.action.BOOT_COMPLETED
02-22 03:48:22.358 I/ActivityManager( 3407): Start proc 4547:com.android.traceur/u0a58 for broadcast com.android.traceur/.Receiver
02-22 03:48:22.352 W/main    ( 4547): type=1400 audit(0.0:3685): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:22.420 I/android.traceu( 4547): The ClassLoaderContext is a special shared library.
02-22 03:48:22.517 I/ActivityManager( 3407): Start proc 4564:com.sigma_rt.totalcontrol/u0a66 for broadcast com.sigma_rt.totalcontrol/.activity.bc.BroadcastBootReceiver
02-22 03:48:22.438 I/android.traceu( 4547): The ClassLoaderContext is a special shared library.
02-22 03:48:22.579 I/rt.totalcontro( 4564): The ClassLoaderContext is a special shared library.
02-22 03:48:22.622 D/===MaApplication===( 4564): ApApplication run onCreate()
02-22 03:48:22.624 I/===MaApplication===( 4564): Will write content:ANDROID-MEK-MX8Q
02-22 03:48:22.628 I/===MaApplication===( 4564): Will write content:appcation package name /data/data/com.sigma_rt.totalcontrol
02-22 03:48:22.630 I/===MaApplication===( 4564): init UDP socket success.
02-22 03:48:22.646 I/===MaApplication===( 4564): Will write content:Version:7.6.1.31780 Version:in XML 7.6.1.31780 Version in ma.conf:7.6.1.31780
02-22 03:48:22.646 I/===MaApplication===( 4564): Chenking hasRootPermission ....
02-22 03:48:22.647 I/===MaApplication===( 4564): Chenking hasRootPermission over.
02-22 03:48:22.652 I/===CheckRootPermission===( 4564): su error :
02-22 03:48:22.652 I/===CheckRootPermission===( 4564): java.io.IOException: Cannot run program "su": error=13, Permission denied
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.ProcessBuilder.start(ProcessBuilder.java:1050)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.Runtime.exec(Runtime.java:695)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.Runtime.exec(Runtime.java:560)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.sigma_rt.totalcontrol.h.s.c(Unknown Source:14)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.sigma_rt.totalcontrol.root.MaApplication.onCreate(Unknown Source:454)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1154)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread.handleBindApplication(ActivityThread.java:5920)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread.access$1100(ActivityThread.java:200)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1656)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.os.Handler.dispatchMessage(Handler.java:106)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.os.Looper.loop(Looper.java:193)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at android.app.ActivityThread.main(ActivityThread.java:6718)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.reflect.Method.invoke(Native Method)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564): Caused by: java.io.IOException: error=13, Permission denied
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.UNIXProcess.forkAndExec(Native Method)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.UNIXProcess.<init>(UNIXProcess.java:133)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.ProcessImpl.start(ProcessImpl.java:132)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
02-22 03:48:22.652 I/===CheckRootPermission===( 4564):  ... 14 more
02-22 03:48:22.653 I/===MaApplication===( 4564): Chenking hasRootPermission excute[su]over.
02-22 03:48:22.653 I/===MaApplication===( 4564): hasRootPermission = false
02-22 03:48:22.653 I/===MaApplication===( 4564): version:76131780
02-22 03:48:22.659 I/===MaApplication===( 4564): Will write content:ApApplication onCreate() Version:7.6.1.31780  SDK:28 Run TC:true
02-22 03:48:22.661 I/BroadcastBootReceiver( 4564): android.intent.action.BOOT_COMPLETED
02-22 03:48:22.661 I/BroadcastBootReceiver( 4564): Will write content:----------Device reboot---------
02-22 03:48:22.669 W/Notification( 4564): Use of stream types is deprecated for operations other than volume control
02-22 03:48:22.669 W/Notification( 4564): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
02-22 03:48:22.674 D/OpenGLRenderer( 4564): Skia GL Pipeline
02-22 03:48:22.683 I/ActivityManager( 3407): Finished processing BOOT_COMPLETED for u0
02-22 03:48:22.684 I/===DaemonService===( 4564): onCreate()
02-22 03:48:22.685 W/Notification( 4564): Use of stream types is deprecated for operations other than volume control
02-22 03:48:22.685 W/Notification( 4564): See the documentation of setSound() for what to use instead with android.media.AudioAttributes to qualify your playback use case
02-22 03:48:22.694 I/ControlSockrtOnJava( 4564): start creating socket[11010].
02-22 03:48:22.696 I/ControlSockrtOnJava( 4564):  Begin to send msg to mobile.
02-22 03:48:22.700 I/===DaemonService===( 4564): Will write content:register[true] sms&content&phone info: smsObserver=null|| mobileagent state =0
02-22 03:48:22.700 I/===DaemonService===( 4564): Will write content:cannot regist isNotificationCheckboxSelected=  mobileagent state:0
02-22 03:48:22.704 W/audio_hw_primary( 3231): get_input_buffer_size size = 512, channel_count = 2
02-22 03:48:22.705 I/===AudioRecorderThread===( 4564): min buffer size:4096
02-22 03:48:22.709 E/System  ( 4564): Ignoring attempt to set property "java.net.preferIPv6Addresses" to value "false".
02-22 03:48:22.709 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:22.709 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:22.709 D/USBService( 4564): ===USBService onCreate()===
02-22 03:48:22.709 I/USBService( 4564): Will write content:USBService onCreate().
02-22 03:48:22.711 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:22.712 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:22.712 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:22.713 E/===APKProtocolTransmit===( 4564): send sb-cmd:275 error, the socket is null
02-22 03:48:22.713 I/===APKProtocolTransmit===( 4564): Will write content:send sb-cmd:275 error, the socket is null
02-22 03:48:22.716 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:22.716 I/===DaemonService===( 4564): public receiver :[android.intent.action.BATTERY_CHANGED]
02-22 03:48:22.716 D/===DaemonService===( 4564): publicReceiver receive action: android.intent.action.BATTERY_CHANGED
02-22 03:48:22.716 I/===DaemonService===( 4564): device dumpenergy 85
02-22 03:48:22.716 I/===BoradcastDynamic===( 4564): Receive action:android.intent.action.BATTERY_CHANGED
02-22 03:48:22.716 I/===BoradcastDynamic===( 4564): plugged:1, status:2
02-22 03:48:22.718 I/===APKProtocolTransmit===( 4564): Start send su-cmd:302 length[0]
02-22 03:48:22.718 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[302]
02-22 03:48:22.719 I/===APKProtocolTransmit===( 4564): End send sb-cmd [302]
02-22 03:48:22.719 I/===Mrcp===( 4564): sending cmd:105
02-22 03:48:22.726 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:22.793 W/System  ( 3583): ClassLoader referenced unknown path:
02-22 03:48:23.129 W/MediaScanner( 4070): Error opening directory '/oem/media/', skipping: No such file or directory.
02-22 03:48:23.129 W/MediaScanner( 4070): Error opening directory '/product/media/', skipping: No such file or directory.
02-22 03:48:23.151 V/MediaProvider( 4070): pruneThumbnails
02-22 03:48:23.161 V/MediaProvider( 4070): /pruneDeadThumbnailFiles...
02-22 03:48:24.718 I/USBService( 4564): get mobileagent state 0
02-22 03:48:25.699 I/===DaemonService===( 4564): handleMessage 0
02-22 03:48:25.712 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:25.713 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:25.713 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:25.713 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:25.713 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:25.715 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:25.716 I/USBService( 4564): handle message 13
02-22 03:48:25.716 I/USBService( 4564): Will write content:USBService start, Mobile Agnet state 0.
02-22 03:48:25.977 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 443) from /172.16.0.118 (port 46608) after 10000ms
02-22 03:48:27.719 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:27.720 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:27.760 W/System  ( 4564): A resource failed to call close.
02-22 03:48:28.715 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:28.715 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:28.716 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:28.716 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:28.716 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:28.717 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:28.972 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 80) from /172.16.0.118 (port 45670) after 10000ms
02-22 03:48:28.973 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:48:29.719 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:29.977 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 3ms OK 69.63.180.173
02-22 03:48:29.977 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 2ms OK 203.208.39.247
02-22 03:48:29.983 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:06:59 GMT], X-Android-Received-Millis=[1582343309982], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343309978]}
02-22 03:48:31.716 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:31.717 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:31.717 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:31.717 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:31.717 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:31.719 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:32.018 D/DhcpClient( 3407): Received packet: 80:05:88:9e:bc:c4 OFFER, ip /172.16.0.65, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:48:32.720 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:32.721 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:34.718 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:34.719 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:34.719 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:34.719 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:34.719 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:34.721 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:34.721 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:36.119 I/ActivityManager( 3407): Waited long enough for: ServiceRecord{9188b62 u0 com.android.calendar/.alerts.InitAlarmsService}
02-22 03:48:37.660 I/ActivityManager( 3407): Waited long enough for: ServiceRecord{cf93ad1 u0 com.sigma_rt.totalcontrol/.USBService}
02-22 03:48:37.720 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:37.721 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:37.721 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:37.721 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:37.721 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:37.722 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:37.723 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:37.723 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:39.722 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:39.991 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 443) from /172.16.0.118 (port 46612) after 10000ms
02-22 03:48:40.722 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:40.723 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:40.723 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:40.723 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:40.723 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:40.725 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:42.150 I/system_server( 3407): Background concurrent copying GC freed 49853(2MB) AllocSpace objects, 33(1040KB) LOS objects, 42% free, 5MB/9MB, paused 167us total 132.407ms
02-22 03:48:42.723 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:42.724 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:42.989 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /69.63.180.173 (port 80) from /172.16.0.118 (port 45674) after 10000ms
02-22 03:48:42.990 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:48:43.724 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:43.724 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:43.725 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:43.725 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:43.725 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:43.727 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:44.723 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:45.001 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 6ms OK 203.208.43.95
02-22 03:48:45.001 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 7ms OK 31.13.84.1
02-22 03:48:45.007 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:07:14 GMT], X-Android-Received-Millis=[1582343325007], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343325002]}
02-22 03:48:46.726 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:46.726 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:46.727 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:46.727 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:46.727 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:46.729 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:47.723 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:47.724 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:47.967 I/ActivityManager( 3407): START u0 {flg=0x10000000 cmp=com.neolix.videoRecorder/.MainActivity} from uid 0
02-22 03:48:47.994 W/System  ( 3407): ClassLoader referenced unknown path:
02-22 03:48:48.017 I/ActivityManager( 3407): Start proc 4679:com.neolix.videoRecorder/u0a76 for activity com.neolix.videoRecorder/.MainActivity
02-22 03:48:48.020 I/x.videoRecorde( 4679): Late-enabling -Xcheck:jni
02-22 03:48:48.012 W/main    ( 4679): type=1400 audit(0.0:3693): avc: denied { dac_read_search } for capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
02-22 03:48:48.075 I/display ( 3407): open gpu gralloc module!
02-22 03:48:48.181 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:48.182 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:48.182 I/OpenGLRenderer( 3407): Initialized EGL, version 1.4
02-22 03:48:48.182 D/OpenGLRenderer( 3407): Swap behavior 2
02-22 03:48:48.568 W/x.videoRecorde( 4679): Accessing hidden method Landroid/view/View;->computeFitSystemWindows(Landroid/graphics/Rect;Landroid/graphics/Rect;)Z (light greylist, reflection)
02-22 03:48:48.571 W/x.videoRecorde( 4679): Accessing hidden method Landroid/view/ViewGroup;->makeOptionalFitsSystemWindows()V (light greylist, reflection)
02-22 03:48:48.613 D/OpenGLRenderer( 4679): Skia GL Pipeline
02-22 03:48:48.785 D/ygl     ( 4679): getUserInfo recordTimeInterval:60000,recordVideoNumber:10
02-22 03:48:48.961 I/ConfigStore( 4679): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:48:48.961 I/ConfigStore( 4679): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:48:48.961 I/OpenGLRenderer( 4679): Initialized EGL, version 1.4
02-22 03:48:48.961 D/OpenGLRenderer( 4679): Swap behavior 2
02-22 03:48:48.978 I/display ( 4679): open gpu gralloc module!
02-22 03:48:48.986 W/ServiceManager( 3250): Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10076 pid=4679
02-22 03:48:48.986 D/PermissionCache( 3250): checking android.permission.ACCESS_SURFACE_FLINGER for uid=10076 => denied (1485 us)
02-22 03:48:48.989 I/SurfaceHolder( 4679): main
02-22 03:48:48.992 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 0) for HAL version default and Camera API version 1
02-22 03:48:48.997 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1100) created, clientPid(3260)
02-22 03:48:49.001 E/FileSource( 3254): Failed to open file '/product/media/audio/ui/camera_click.ogg'. (No such file or directory)
02-22 03:48:49.001 E/GenericSource( 3254): Failed to create data source!
02-22 03:48:49.001 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1100), (100, 1, -2147483648, -1), loop setting(0, 0)
02-22 03:48:49.001 E/MediaPlayerNative( 3260): error (1, -2147483648)
02-22 03:48:49.001 E/CameraService( 3260): Failed to load CameraService sounds: /product/media/audio/ui/camera_click.ogg
02-22 03:48:49.001 D/NuPlayerDriver( 3254): reset(0xe82a1100) at state 2
02-22 03:48:49.003 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1100), (8, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.003 D/NuPlayerDriver( 3254): notifyResetComplete(0xe82a1100)
02-22 03:48:49.005 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1180) created, clientPid(3260)
02-22 03:48:49.017 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:49.023 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1180), (1, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.025 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1400) created, clientPid(3260)
02-22 03:48:49.027 E/FileSource( 3254): Failed to open file '/product/media/audio/ui/VideoRecord.ogg'. (No such file or directory)
02-22 03:48:49.027 E/GenericSource( 3254): Failed to create data source!
02-22 03:48:49.027 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1400), (100, 1, -2147483648, -1), loop setting(0, 0)
02-22 03:48:49.027 E/MediaPlayerNative( 3260): error (1, -2147483648)
02-22 03:48:49.027 E/CameraService( 3260): Failed to load CameraService sounds: /product/media/audio/ui/VideoRecord.ogg
02-22 03:48:49.028 D/NuPlayerDriver( 3254): reset(0xe82a1400) at state 2
02-22 03:48:49.028 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1400), (8, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.028 D/NuPlayerDriver( 3254): notifyResetComplete(0xe82a1400)
02-22 03:48:49.029 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1500) created, clientPid(3260)
02-22 03:48:49.034 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:49.040 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1500), (1, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.042 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1600) created, clientPid(3260)
02-22 03:48:49.045 E/FileSource( 3254): Failed to open file '/product/media/audio/ui/VideoStop.ogg'. (No such file or directory)
02-22 03:48:49.045 E/GenericSource( 3254): Failed to create data source!
02-22 03:48:49.045 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1600), (100, 1, -2147483648, -1), loop setting(0, 0)
02-22 03:48:49.045 E/MediaPlayerNative( 3260): error (1, -2147483648)
02-22 03:48:49.045 E/CameraService( 3260): Failed to load CameraService sounds: /product/media/audio/ui/VideoStop.ogg
02-22 03:48:49.046 D/NuPlayerDriver( 3254): reset(0xe82a1600) at state 2
02-22 03:48:49.046 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1600), (8, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.046 D/NuPlayerDriver( 3254): notifyResetComplete(0xe82a1600)
02-22 03:48:49.047 D/NuPlayerDriver( 3254): NuPlayerDriver(0xe82a1680) created, clientPid(3260)
02-22 03:48:49.051 I/FslExtractor( 3265): FslExtractor Sniff
02-22 03:48:49.057 D/NuPlayerDriver( 3254): notifyListener_l(0xe82a1680), (1, 0, 0, -1), loop setting(0, 0)
02-22 03:48:49.058 I/Camera2ClientBase( 3260): Camera 0: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.062 I/FslCameraHAL( 3233): openDev:0: Opening camera device
02-22 03:48:49.062 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=back
02-22 03:48:49.063 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.067 I/FslCameraHAL( 3233): constructDefaultRequestSettings:0: type=1
02-22 03:48:49.068 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.068 I/Camera2-Parameters( 3260): Camera 0: Disabling ZSL mode
02-22 03:48:49.068 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.068 I/FslCameraHAL( 3233): constructDefaultRequestSettings:0: type=2
02-22 03:48:49.069 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.069 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.077 I/FslCameraHAL( 3233): configureStreams:0: stream_config 0xeacfd500, num 2, streams 0xec817180, mode 0
02-22 03:48:49.077 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.077 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.077 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.077 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.077 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.077 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.077 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.080 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4734)
02-22 03:48:49.080 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.081 D/SurfaceFlinger( 3250): duplicate layer name: changing SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#1
02-22 03:48:49.082 D/SurfaceFlinger( 3250): duplicate layer name: changing Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#1
02-22 03:48:49.088 I/SurfaceHolder( 4679): main
02-22 03:48:49.089 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 1) for HAL version default and Camera API version 1
02-22 03:48:49.090 I/Camera2ClientBase( 3260): Camera 1: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.093 I/FslCameraHAL( 3233): openDev:1: Opening camera device
02-22 03:48:49.093 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=front
02-22 03:48:49.093 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.097 I/FslCameraHAL( 3233): constructDefaultRequestSettings:1: type=1
02-22 03:48:49.098 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.098 I/Camera2-Parameters( 3260): Camera 1: Disabling ZSL mode
02-22 03:48:49.098 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.098 I/FslCameraHAL( 3233): constructDefaultRequestSettings:1: type=2
02-22 03:48:49.099 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.107 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.114 I/FslCameraHAL( 3233): configureStreams:1: stream_config 0xeabff500, num 2, streams 0xeaf0d020, mode 0
02-22 03:48:49.114 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.114 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.114 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.114 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.114 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.114 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.114 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.115 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4741)
02-22 03:48:49.116 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.118 D/SurfaceFlinger( 3250): duplicate layer name: changing SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#2
02-22 03:48:49.120 D/SurfaceFlinger( 3250): duplicate layer name: changing Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#2
02-22 03:48:49.132 I/display ( 3260): open gpu gralloc module!
02-22 03:48:49.139 I/SurfaceHolder( 4679): main
02-22 03:48:49.140 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 2) for HAL version default and Camera API version 1
02-22 03:48:49.142 I/Camera2ClientBase( 3260): Camera 2: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.144 I/FslCameraHAL( 3233): openDev:2: Opening camera device
02-22 03:48:49.144 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=front
02-22 03:48:49.144 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.147 I/display ( 3233): open gpu gralloc module!
02-22 03:48:49.147 I/FslCameraHAL( 3233): constructDefaultRequestSettings:2: type=1
02-22 03:48:49.148 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.148 I/Camera2-Parameters( 3260): Camera 2: Disabling ZSL mode
02-22 03:48:49.148 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.148 I/FslCameraHAL( 3233): constructDefaultRequestSettings:2: type=2
02-22 03:48:49.149 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.149 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.149 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.149 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.149 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.150 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.150 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.150 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.150 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.150 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.156 I/FslCameraHAL( 3233): configureStreams:2: stream_config 0xffc10fa0, num 2, streams 0xec8171a0, mode 0
02-22 03:48:49.156 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.156 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.156 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.156 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.156 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.156 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.156 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.159 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4750)
02-22 03:48:49.159 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.161 D/SurfaceFlinger( 3250): duplicate layer name: changing SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#3
02-22 03:48:49.173 D/SurfaceFlinger( 3250): duplicate layer name: changing Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity to Background for -SurfaceView - com.neolix.videoRecorder/com.neolix.videoRecorder.MainActivity#3
02-22 03:48:49.188 I/SurfaceHolder( 4679): main
02-22 03:48:49.189 I/CameraService( 3260): CameraService::connect call (PID -1 "com.neolix.videoRecorder", camera ID 3) for HAL version default and Camera API version 1
02-22 03:48:49.191 I/Camera2ClientBase( 3260): Camera 3: Opened. Client: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:48:49.193 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.193 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.193 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.193 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.194 I/FslCameraHAL( 3233): openDev:3: Opening camera device
02-22 03:48:49.194 D/audio_hw_primary( 3231): adev_set_parameters: enter: cameraFacing=front
02-22 03:48:49.194 D/audio_hw_primary( 3231): adev_set_parameters: exit with code(0)
02-22 03:48:49.197 I/FslCameraHAL( 3233): constructDefaultRequestSettings:3: type=1
02-22 03:48:49.198 E/Camera2-Parameters( 3260): Error finding static metadata entry 'android.distortionCorrection.availableModes' (1b0001)
02-22 03:48:49.198 I/Camera2-Parameters( 3260): Camera 3: Disabling ZSL mode
02-22 03:48:49.198 I/Camera2-Parameters( 3260): initialize: allowZslMode: 0 slowJpegMode 0
02-22 03:48:49.199 I/FslCameraHAL( 3233): constructDefaultRequestSettings:3: type=2
02-22 03:48:49.199 I/Camera2-CallbackProcessor( 3260): libopencl-2d.so is existed!
02-22 03:48:49.200 E/linker  ( 3260): library "/vendor/lib/libopencl-2d.so" ("/vendor/lib/libopencl-2d.so") needed or dlopened by "/system/lib/libcameraservice.so" is not accessible for the namespace: [name="(default)", ld_library_paths="", default_library_paths="/system/lib", permitted_paths="/system/lib/drm:/system/lib/extractors:/system/lib/hw:/system/product/lib:/system/framework:/system/app:/system/priv-app:/vendor/framework:/vendor/app:/vendor/priv-app:/odm/framework:/odm/app:/odm/priv-app:/oem/app:/system/product/framework:/system/product/app:/system/product/priv-app:/data:/mnt/expand"]
02-22 03:48:49.208 I/FslCameraHAL( 3233): configureStreams:3: stream_config 0xeb07f500, num 2, streams 0xeaf0d010, mode 0
02-22 03:48:49.208 I/FslCameraHAL( 3233): config 0, type 0, res 1280x720, fmt 0x22, usage 0x900, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.208 I/FslCameraHAL( 3233): config 1, type 0, res 1280x720, fmt 0x21, usage 0x3, maxbufs 0, priv 0x0, rotation 0
02-22 03:48:49.208 I/FslCameraHAL( 3233): Stream create preview stream
02-22 03:48:49.208 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp getPreviewPixelFormat
02-22 03:48:49.208 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x103, usage:0x20b02, buffers:3
02-22 03:48:49.208 I/FslCameraHAL( 3233): Stream create capture stream
02-22 03:48:49.208 I/FslCameraHAL( 3233): stream: w:1280, h:720, format:0x21, usage:0x20303, buffers:2
02-22 03:48:49.210 D/Camera3-Device( 3260): Set real time priority for request queue thread (tid 4758)
02-22 03:48:49.210 I/SurfaceHolder( 4679): surfaceChanged()
02-22 03:48:49.228 I/FslCameraHAL( 3233): configure: w:1280, h:720, sensor format:0x14, stream format:0x103, fps:30, num:3
02-22 03:48:49.228 I/FslCameraHAL( 3233): ---- Camera Test vendor/nxp-opensource/imx/libcamera3/Max9286Mipi.cpp onDeviceConfigureLocked
02-22 03:48:49.228 I/FslCameraHAL( 3233): Width * Height 1280 x 720 format YUYV, fps: 30
02-22 03:48:49.228 I/FslCameraHAL( 3233): onDeviceStartLocked
02-22 03:48:49.380 I/ActivityManager( 3407): Displayed com.neolix.videoRecorder/.MainActivity: +1s382ms
02-22 03:48:49.542 W/SurfaceFlinger( 3250): Attempting to set client state on removed layer: Splash Screen com.neolix.videoRecorder#0
02-22 03:48:49.542 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: Splash Screen com.neolix.videoRecorder#0
02-22 03:48:49.724 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:49.728 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:49.729 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:49.729 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:49.729 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:49.729 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:49.730 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:49.976 W/FslCameraHAL( 3233): opencl g2d device is used!
02-22 03:48:49.982 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:49.998 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.014 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.033 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.091 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.192 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.357 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.426 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:50.827 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.025 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.092 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.154 D/InitAlarmsService( 4327): Clearing and rescheduling alarms.
02-22 03:48:51.259 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.292 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:51.328 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.391 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.459 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.491 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.522 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:51.624 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:51.926 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.024 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.060 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.090 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.124 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.357 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.425 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.494 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.522 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.557 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.691 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.724 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:52.725 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:52.730 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:52.730 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:52.731 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:52.731 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:52.731 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:52.733 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:52.792 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:52.858 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.057 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.125 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.191 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:48:53.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.292 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.424 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.491 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.591 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.826 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.858 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:53.924 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.027 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.089 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.124 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.192 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.259 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:54.291 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.693 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.725 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:54.758 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:54.928 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.015 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 443) from /172.16.0.118 (port 58272) after 10000ms
02-22 03:48:55.062 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.391 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.489 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.526 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.624 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.692 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.732 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:55.732 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:55.733 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:55.733 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:55.733 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:55.734 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:55.893 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.923 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:55.957 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:56.057 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.123 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.424 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.453 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.557 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.890 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:56.956 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:57.056 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.288 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.725 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:48:57.726 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.726 I/===Mrcp===( 4564): sending cmd:276
02-22 03:48:57.856 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.890 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:57.923 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:57.991 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.007 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 80) from /172.16.0.118 (port 34058) after 10000ms
02-22 03:48:58.007 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:48:58.024 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.089 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:48:58.361 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.423 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.457 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.490 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.523 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.592 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:48:58.658 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:58.734 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:48:58.734 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:48:58.734 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:48:58.734 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:48:58.734 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:48:58.736 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:48:58.856 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.355 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 7 lines
02-22 03:48:59.390 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.523 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.723 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.725 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:48:59.957 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:48:59.989 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.064 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.088 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.160 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.256 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.353 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.426 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.489 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:00.522 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.589 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:00.955 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:01.053 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.057 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.189 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.224 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.323 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.393 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.525 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:01.555 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.736 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:01.736 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:01.737 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:01.737 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:01.737 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:01.739 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:01.757 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:01.864 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:01.989 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.014 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 2ms OK 31.13.84.1
02-22 03:49:02.014 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 2ms OK 203.208.43.95
02-22 03:49:02.020 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:07:31 GMT], X-Android-Received-Millis=[1582343342019], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343342015]}
02-22 03:49:02.026 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.158 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.330 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.655 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.726 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:02.727 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:02.755 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.821 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.888 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.922 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:02.963 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.022 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.055 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.163 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:03.224 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.288 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.319 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.384 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:03.421 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.551 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.595 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.754 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.786 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:03.821 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.055 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.088 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.123 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.154 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.221 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.356 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.389 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.517 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:04.552 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.587 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.621 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.653 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:04.687 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.727 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:04.737 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:04.737 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:04.739 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:04.739 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:04.742 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:04.745 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:04.753 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.854 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.887 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:04.987 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.094 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.254 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:05.319 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.386 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.453 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:05.619 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.656 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.885 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:05.923 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:05.953 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.087 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.119 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.154 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.421 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:06.686 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:06.723 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.022 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:07.186 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.218 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.251 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.285 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:07.322 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.389 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.405 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.420 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.422 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.505 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 5 lines
02-22 03:49:07.522 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.529 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.538 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.689 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 9 lines
02-22 03:49:07.705 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.720 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:07.722 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.727 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:07.728 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:07.738 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.740 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:07.740 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:07.741 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:07.741 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:07.741 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:07.743 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:07.756 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.905 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 9 lines
02-22 03:49:07.925 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:07.983 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.054 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.225 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.252 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.386 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.419 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.457 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.495 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.655 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:08.718 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.020 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.053 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.119 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.185 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.384 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.487 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.650 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:09.727 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:09.854 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.221 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.320 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:10.386 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.744 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:10.744 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:10.745 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:10.745 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:10.745 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:10.746 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:10.752 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:10.854 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:10.984 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.285 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.452 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.652 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:11.787 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.917 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:11.988 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.028 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 443) from /172.16.0.118 (port 58276) after 10000ms
02-22 03:49:12.084 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.284 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.451 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.485 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.517 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.685 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 3 lines
02-22 03:49:12.720 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.728 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:12.729 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:12.786 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:12.951 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.017 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.083 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.119 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.518 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.683 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.745 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:13.745 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:13.746 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:13.746 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:13.746 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:13.748 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:13.754 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:13.917 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:14.018 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.083 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.149 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:14.250 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.284 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.318 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.616 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:14.654 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.685 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.728 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:14.850 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:14.883 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.016 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.025 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 80) from /172.16.0.118 (port 34062) after 10000ms
02-22 03:49:15.054 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.083 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.116 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.149 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.316 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.353 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.416 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.684 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.717 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.919 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:16.183 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.252 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.316 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:16.419 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.618 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.649 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:16.747 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:16.747 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:16.747 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:16.747 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:16.747 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:16.749 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:16.886 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.050 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.216 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.283 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.317 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.350 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:17.419 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.728 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:17.729 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:17.851 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.883 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.949 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:17.983 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.217 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.349 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.385 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.420 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.483 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.749 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.751 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.783 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.819 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.850 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.884 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.948 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:18.986 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.018 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.048 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.216 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.250 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.350 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.516 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.649 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:19.719 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.729 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:19.748 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:19.748 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:19.748 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:19.748 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:19.748 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:19.750 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:19.882 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:19.983 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.085 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.215 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:20.252 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.416 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.452 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:20.513 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.551 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.583 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.650 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.915 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:20.951 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:15.025 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:49:21.010 I/ActivityManager( 3407): Killing 4130:com.android.quicksearchbox/u0a41 (adj 906): empty #17
02-22 03:49:21.011 W/libprocessgroup( 3407): kill(-4130, 9) failed: No such process
02-22 03:49:21.033 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.047 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 3 lines
02-22 03:49:21.052 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.057 W/libprocessgroup( 3407): kill(-4130, 9) failed: No such process
02-22 03:49:21.057 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.069 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 2 lines
02-22 03:49:21.071 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.076 I/Zygote  ( 3220): Process 4130 exited due to signal (9)
02-22 03:49:21.079 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.095 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 2 lines
02-22 03:49:21.099 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.102 W/libprocessgroup( 3407): kill(-4130, 9) failed: No such process
02-22 03:49:21.102 I/libprocessgroup( 3407): Successfully killed process cgroup uid 10041 pid 4130 in 91ms
02-22 03:49:21.103 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.133 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 5 lines
02-22 03:49:21.147 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.149 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.168 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.181 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.182 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.186 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.273 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 11 lines
02-22 03:49:21.276 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.279 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.281 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.540 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 31 lines
02-22 03:49:21.546 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.549 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.570 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.576 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 2 lines
02-22 03:49:21.582 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.584 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.586 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.593 I/chatty  ( 3407): uid=1000(system) BackgroundDexOp identical 3 lines
02-22 03:49:21.604 I/system_server( 3407): The ClassLoaderContext is a special shared library.
02-22 03:49:21.605 I/BackgroundDexOptService( 3407): Pinning optimized code {}
02-22 03:49:21.649 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.681 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.718 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.815 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.848 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.915 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:21.948 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.082 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.216 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.249 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.549 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 5 lines
02-22 03:49:22.582 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.681 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.683 D/DhcpClient( 3407): Received packet: 80:05:88:b7:35:48 OFFER, ip /172.16.0.43, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:49:22.714 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.729 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:22.730 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:22.749 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:22.749 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:22.750 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:22.750 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:22.750 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:22.752 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:22.817 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.880 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.918 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:22.984 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.033 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 1ms OK 31.13.84.1
02-22 03:49:23.033 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 1ms OK 203.208.43.95
02-22 03:49:23.039 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:07:52 GMT], X-Android-Received-Millis=[1582343363039], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343363034]}
02-22 03:49:23.047 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.682 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 6 lines
02-22 03:49:23.718 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.813 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:23.950 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.048 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.215 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.519 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.681 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:24.729 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:24.881 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.052 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.114 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.415 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 6 lines
02-22 03:49:25.481 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.578 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.584 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.614 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.684 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.715 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.750 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:25.751 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:25.751 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:25.751 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:25.751 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:25.753 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:25.814 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.914 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:25.982 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.023 D/SntpClient( 3407): request time failed: java.net.SocketTimeoutException: Poll timed out
02-22 03:49:26.084 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.214 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.348 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.384 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.549 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:26.581 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.713 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.749 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.781 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.818 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.882 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:26.980 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.015 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.082 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.115 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.149 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.215 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.248 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.282 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 1 line
02-22 03:49:27.317 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.482 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:27.730 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:27.730 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:27.948 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.248 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.348 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.414 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.481 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.715 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 5 lines
02-22 03:49:28.750 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.752 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:28.752 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:28.752 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:28.753 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:28.753 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:28.762 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:28.815 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.850 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.883 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.912 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:28.980 I/chatty  ( 3233): uid=1047(cameraserver) MessageThread identical 2 lines
02-22 03:49:29.047 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.114 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.148 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.214 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.281 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.312 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.346 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.377 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.481 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.515 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.647 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.717 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.730 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:29.847 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:29.913 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.082 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.146 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.248 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.278 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.333 D/AndroidRuntime( 4787): >>>>>> START com.android.internal.os.RuntimeInit uid 0 <<<<<<
02-22 03:49:30.561 I/app_process( 4787): The ClassLoaderContext is a special shared library.
02-22 03:49:30.615 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.636 D/AndroidRuntime( 4787): Calling main entry com.android.commands.input.Input
02-22 03:49:30.637 I/Input   ( 4787): injectKeyEvent: KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=0, metaState=0, flags=0x0, repeatCount=0, eventTime=106695, downTime=106695, deviceId=-1, source=0x101 }
02-22 03:49:30.646 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.651 I/Input   ( 4787): injectKeyEvent: KeyEvent { action=ACTION_UP, keyCode=KEYCODE_BACK, scanCode=0, metaState=0, flags=0x0, repeatCount=0, eventTime=106695, downTime=106695, deviceId=-1, source=0x101 }
02-22 03:49:30.651 D/AutofillManagerService( 3407): onBackKeyPressed()
02-22 03:49:30.658 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.666 D/ygl     ( 4679): onPause camera1android.hardware.Camera@9fd9423
02-22 03:49:30.666 D/AndroidRuntime( 4787): Shutting down VM
02-22 03:49:30.666 I/FslCameraHAL( 3233): flushDev:0: Flushing camera device
02-22 03:49:30.672 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.685 I/FslCameraHAL( 3233): onFlushLocked, v4l2 memory type 1, mV4l2BufType 9
02-22 03:49:30.689 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.788 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 6 lines
02-22 03:49:30.805 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.813 I/opencl-2d( 3233): cl_g2d_blit: invalid kernel index 0
02-22 03:49:30.817 I/FslCameraHAL( 3233): flushDev:0: Flushing camera device
02-22 03:49:30.817 I/FslCameraHAL( 3233): onFlushLocked, v4l2 memory type 1, mV4l2BufType 9
02-22 03:49:30.822 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.889 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 4 lines
02-22 03:49:30.905 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260): Stream 0 dequeueBuffer latency histogram (1223) samples:
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):         5     10     15     20     25     30     35     40     45    inf (max ms)
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):      1.14   31.81   34.51   23.79   8.59   0.00   0.08   0.00   0.00   0.08 (%)
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260): Stream 0 latency histogram for wait on max_buffers (1220) samples:
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):        33     66     99    132    165    198    231    264    297    inf (max ms)
02-22 03:49:30.918 I/CameraLatencyHistogram( 3260):      99.92   0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.08 (%)
02-22 03:49:30.919 I/Camera3-Device( 3260): disconnect: E
02-22 03:49:30.919 I/CameraLatencyHistogram( 3260): ProcessCaptureRequest latency histogram (1223) samples:
02-22 03:49:30.919 I/CameraLatencyHistogram( 3260):        40     80    120    160    200    240    280    320    360    inf (max ms)
02-22 03:49:30.919 I/CameraLatencyHistogram( 3260):      99.84   0.08   0.00   0.00   0.00   0.00   0.00   0.00   0.08   0.00 (%)
02-22 03:49:30.919 I/FslCameraHAL( 3233): closeDev:0: Closing camera device
02-22 03:49:30.919 I/FslCameraHAL( 3233): onDeviceStopLocked
02-22 03:49:30.919 I/Camera3-Device( 3260): disconnect: X
02-22 03:49:30.920 I/Camera3-Device( 3260): disconnect: E
02-22 03:49:30.924 I/CameraService( 3260): disconnect: Disconnected client for camera 0 for PID 4679
02-22 03:49:30.925 I/Camera2Client( 3260): Camera 0: Closed
02-22 03:49:30.925 D/ygl     ( 4679): camera1 stopPreview() release()
02-22 03:49:30.925 D/ygl     ( 4679): onPause camera2android.hardware.Camera@a2ced20
02-22 03:49:30.925 I/FslCameraHAL( 3233): flushDev:1: Flushing camera device
02-22 03:49:30.926 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:30.926 I/Camera2ClientBase( 3260): Closed Camera 0. Client was: com.neolix.videoRecorder (PID 4679, UID 10076)
02-22 03:49:30.938 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:31.163 W/ActivityManager( 3407): Activity pause timeout for ActivityRecord{4051270 u0 com.neolix.videoRecorder/.MainActivity t61 f}
02-22 03:49:31.172 I/chatty  ( 3407): uid=1000(system) PhotonicModulat identical 14 lines
02-22 03:49:31.188 E/LightsService( 3407): Light requested not available on this device. 0
02-22 03:49:31.262 D/PermissionCache( 3250): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (215 us)
02-22 03:49:31.332 W/ServiceManager( 3250): Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10027 pid=4086
02-22 03:49:31.332 D/PermissionCache( 3250): checking android.permission.ACCESS_SURFACE_FLINGER for uid=10027 => denied (489 us)
02-22 03:49:31.753 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:31.753 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:31.753 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:31.753 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:31.753 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:31.754 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:31.776 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
02-22 03:49:31.776 I/ConfigStore( 3407): android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasHDRDisplay retrieved: 0
02-22 03:49:31.776 I/OpenGLRenderer( 3407): Initialized EGL, version 1.4
02-22 03:49:31.776 D/OpenGLRenderer( 3407): Swap behavior 2
02-22 03:49:32.730 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:32.731 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:33.018 D/DhcpClient( 3407): Received packet: 80:05:88:9e:bc:c4 OFFER, ip /172.16.0.65, mask /255.255.255.0, DNS servers: /172.16.0.1 , gateways [/172.16.0.1] lease time 1800, domain lan
02-22 03:49:33.045 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTPS https://www.google.com/generate_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 443) from /172.16.0.118 (port 58280) after 10000ms
02-22 03:49:34.730 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:34.754 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:34.754 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:34.754 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:34.754 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:34.754 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:34.756 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:36.046 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://www.google.com/gen_204 Probe failed with exception java.net.SocketTimeoutException: failed to connect to /31.13.84.1 (port 80) from /172.16.0.118 (port 34066) after 10000ms
02-22 03:49:36.046 D/ConnectivityService( 3407): NetworkAgentInfo [Ethernet () - 100] validation failed
02-22 03:49:37.731 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:37.732 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:37.755 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:37.755 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:37.756 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:37.756 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:37.756 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:37.757 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:39.731 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:40.756 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:40.756 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:40.757 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:40.757 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:40.757 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:40.758 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:41.755 W/ActivityManager( 3407): Activity destroy timeout for ActivityRecord{4051270 u0 com.neolix.videoRecorder/.MainActivity t61 f}
02-22 03:49:41.766 W/SurfaceFlinger( 3250): Attempting to destroy on removed layer: AppWindowToken{1e8066e token=Token{46729e9 ActivityRecord{4051270 u0 com.neolix.videoRecorder/.MainActivity t61}}}#0
02-22 03:49:42.731 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:42.732 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:43.757 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:43.758 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:43.758 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:43.758 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:43.758 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:43.760 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:44.732 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:46.759 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:46.759 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:46.760 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:46.760 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:46.760 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:46.761 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:47.732 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:47.733 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:49.733 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:49.761 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:49.761 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:49.761 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:49.761 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:49.761 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:49.763 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:52.066 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS connectivitycheck.gstatic.com 2ms OK 203.208.43.95
02-22 03:49:52.066 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_DNS www.google.com 3ms OK 31.13.84.1
02-22 03:49:52.073 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_HTTP http://connectivitycheck.gstatic.com/generate_204 time=5ms ret=204 request={User-Agent=[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.32 Safari/537.36]} headers={null=[HTTP/1.1 204 No Content], Content-Length=[0], Date=[Thu, 27 Feb 2020 05:08:21 GMT], X-Android-Received-Millis=[1582343392072], X-Android-Response-Source=[NETWORK 204], X-Android-Selected-Protocol=[http/1.1], X-Android-Sent-Millis=[1582343392068]}
02-22 03:49:52.733 I/USBService( 4564): send udp to check mobileagent state.
02-22 03:49:52.733 I/===Mrcp===( 4564): sending cmd:276
02-22 03:49:52.762 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:52.762 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:52.762 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:52.762 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:52.762 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:52.763 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
02-22 03:49:54.734 I/USBService( 4564): get mobileagent state 0 and current mobileagent state 0 and usb state of connection false
02-22 03:49:55.177 D/NetworkMonitor/NetworkAgentInfo [Ethernet () - 100]( 3407): PROBE_FALLBACK http://play.googleapis.com/generate_204 Probe failed with exception java.net.SocketException: Connection reset
02-22 03:49:55.763 I/===DaemonService===( 4564): ############## Rotation : 0
02-22 03:49:55.763 I/===DaemonService===( 4564): ScreenOrientationThread:0 screentOrientation:0
02-22 03:49:55.763 I/===APKProtocolTransmit===( 4564): Ready send su-cmd:275
02-22 03:49:55.763 I/===APKProtocolTransmit===( 4564): Start send su-cmd:275 length[14]
02-22 03:49:55.763 I/===APKProtocolTransmit===( 4564): Will write content:the C socket has not been connected,so dicard the send command:[275]
02-22 03:49:55.764 I/===APKProtocolTransmit===( 4564): End send sb-cmd:275
