Hi.
If I set the glitch filter of KBI on a pin that has both KBI and GPIO functions, is the GPIO glitch filter setting invalid for that pin?
For example, if you set a glitch filter for PORTA and want to use only one of the PORTAs as a KBI. For example, PTA6 / KBI0_P6.
Thank you.
jun
Solved! Go to Solution.
Hi jun,
If you set the glitch filter of KBI on a pin that has both KBI and GPIO functions, only KBI glitch filter function has effect. GPIO filter setting has no effect.
Jing
Thank you very much.
Have a good day.
jun
Hi jun,
Jing
