HDMI Bringup issue in Costum board
aabhishekoct18
Hi  Team
We made  one custom board based  on iMX 6  solo , first  time we  are doing bring up , at the  time of boot up we are able  to see  NXP logo  but  after that we are continuously getting even of  HDMI plug in and  plug out every 1-2 sec  . Same Display and cable if  we are  using everything works  fine.
1) Please  check  schematic once if  any change is  required  ?
2) Please  explain me or provide  me some documents which can explain me flow  of events so that i can  probe  everything  and  try to  figure out where is  actual issue ?
Hi Abhishek
one can look at various hdmi detection issues described on
https://boundarydevices.com/configuring-i-mx6-machines-different-screens-nitrogen6x-sabre-lite/
https://boundarydevices.com/dvi-support-on-i-mx6-boards/
HDMI schematic example can be found in Sabre SD design files
Design files, including hardware schematics, Gerbers, and OrCAD files.
