NAND boot on i.MX6ULL EVK board
Question asked by Daniel Perez on Feb 21, 2020
Latest reply on Feb 27, 2020 by Aldo Gutierrez
I'm trying to follow the instructions on this post https://community.nxp.com/docs/DOC-236994 to boot the evaluation board from a NAND flash.
I'm able to build u-boot with the mx6ul_14x14_evk_defconfig configuration, but when I try to build mx6ul_14x14_evk_nand_defconfig, It get stuck:
Looks like "CONFIG_SYS_TEXT_BASE=0x87800000" option is lacking on the downloaded "mx6ul_14x14_evk_nand_defconfig". Actually this attached file looks really small compared with other defconfig files.
If I add the "sys_text" option manually, the build proccess continues with many warning and finally it fails with the following error:
Any idead on what is going wrong?
