USB OTG power group conflict
vinythambi
As per imx6 solox refrence design, E18 pin is used as USB OTG2 OC signal. When this function is configured in iomux tool, power group conflict warning pops up. Is this warning ignorable or function change is required?
diegoadrian
Could you please tell me the Pins Tool version that you are using? And what is the complete name that you are using to configure the Chip? I cannot see the same warning that you have by my side.
Diego.
