errors in the .xml files "Register details" in CW DSC56800E v 8.2.3
Dekabrist
Xml files in the CW DSC56800E v 8.2.3 has errors:
1. Bits order in the xml files for Register details is reversing. Examle:
<REGISTER NAME="TMRA0_CTRL" BITRANGE="0:15" RESETVALUE="0"....
Must be:
<REGISTER NAME="TMRA0_CTRL" BITRANGE="15" RESETVALUE="0"
2. Format in the description field rong (it give response "Other" when value bit field > = 0x10):
<BFVALUE VALUE="000" DESCRIPTION="Asserted while counter is active" />
 Must be:
<BFVALUE VALUE="0b000" DESCRIPTION="Asserted while counter is active" />
3. In the element definition write - "ELEMENT REGDISASM", but element has name "REGISTER"
trytohelp
Thanks for the request.
This seems to be an issue.
I suggest you to log your request to the Freescale CRM system.
Can I suggest you to have a look to your request via the web access ?
Please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request to create a new one or Manage Existing Service Request.
  - You will come to a login page.
  - You can submit your request through the web from there or view the activities of a SR.
Else send an email to support@freescale.com.
Pascal
Dekabrist
OK,
I send request to TechSupport
