MX8M :weston-simple-egl failed on debain
flyalfie
when I process weston-simple-egl.   the message is  "init_egl: Assertion `display->egl.dpy' failed". I saw the code is initEGL faild. it is work on the Yocto. but debain is failed.  please help me. thanks.
Bio_TICFSL
Hello Chen,
You should download the latest BSP where weston compositor not failed however you can check with our third party if debian work with it:
https://developer.solid-run.com/knowledge-base/i-mx8m-debian/
https://boundarydevices.com/wiki/debian-for-nitrogen8/
flyalfie
I found out If I run the weston-simple-egl on the debian Stretch,  it is work.  I do not way.  it is impossible run on the debian Buster?
Bio_TICFSL
You should ask to our third party since debian its not supported by nxp.
flyalfie
Hello Bio_TICFSL
        thanks  for your answer.   I try to downland debian-buster-sdhc img.  bug it can not boot from MMC
 U-Boot SPL 2018.11-08002-g8e521a3525 (Nov 20 2019 - 16:49:56 +0000)
PMIC: PFUZE100 ID=0x10
Training FAILED
Training FAILED
Training FAILED
Normal Boot
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device 1. error: -19
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ##
flyalfie
I am try to boot loader for SD card. but it is no work
