Recompile Uboot did not take effect ls1021a
jiye
Contributor V
I am using
flexbuild_lsdk1906/packages/firmware/u-boot/configs/ls1021atwr_sdcard_ifc_defconfig
I changed the settings in the deconfig file and then use
 flex-builder -c uboot -m ls1021atwr -b sd
the new uboot bin file then generate under
flexbuild_lsdk1906/build/firmware/u-boot/ls1021atwr/uboot_ls1021atwr_sdcard_ifc.bin
Then I dd this file into my SD card, I tried to verify from the uboot prompt window for example I set the bootdelay to 5,
and when I checked from the uboot prompt window it still shows me default bootdelay=3
Can anyone help me with this?
Labels (2)
yipingwang
Hello Elias Bitbaker,
Please remove the build folder, then build u-boot from the scratch.
1. rm -rf build/firmware/u-boot/ls1021atwr/output/ls1021atwr_sdcard_ifc_defconfig/
2. Please modify packages/firmware/u-boot/configs/ls1021atwr_sdcard_ifc_defconfig according to your requirement.
3. flex-builder -c uboot -m ls1021atwr -b sd
4. Get the latest image in build/firmware/u-boot/ls1021atwr/uboot_ls1021atwr_sdcard_ifc.bin
Yiping
