S32K148 - SAI bitclock slave and polarity
Question asked by Jakub Mielczarek on Feb 13, 2020
Latest reply on Feb 26, 2020 by Jakub Mielczarek
In my application I need to use SAI0 in bitclock slave mode (bitclock externally generated).
Attached is the relation between external bitclock and external frame sync.
When I configure SAI0 transmitter with bitclock active LOW, it works fine. SAI0 transmits data on falling edge of bitclock (is this right?).
When I configure SAI0 transmitter with bitclock active HIGH, it does not start to transmit at all. Should it work with the attached signals? If not, what should be changed?
Jakub
