Hello
I am not an expert in FuzzyTech, but it looks like you are missing a library file FTC16.lib.
This is probably delivered by FuzzyTech.
On a side note I would not recommend linking an library file generated by GNU compiler with object files generated by CodeWarrior compiler.
Here I would recommend you to build the whole application (including library) with one set of compiler/assembler/linker (either GNU or CodeWarrior).
You should be able to debug code generated by GNU compiler/linker in CodeWarrior (provided GNU tool generate ELF DWARF executable file).
If you wish to build everything with CodeWarrior, I would suggest you to ask People at FuzzyTech what is their recommendations.
I hope this helps.
CrasyCat
