Hi, I am trying to use CodeWarrior USB TAP with ONCE communication. FreeMASTER does not see any device. CodeWarrior IDE version 11.1 update 1 doesn't see the device. The TAP came with no documentation or downloads. Where do I get drivers from? I also somehow managed to wipe the chip, where can I find source code to make the wireless charging work again?
Hi, Wpsigma,
Have you solved your issue? If you can not communicate with USBTAP, have you tried to use the USB-SCI device?
XiangJun Rong
