We started our new application design with I.MX6 dual lite.
And, we plan to use DAC(, or DAMP) as slave device by providing I2S(LRCK, SCK, DATA) with MCK from I.MX6.
I found explanation about I2S at page.5077 on reference manual(i.MX 6Solo/6DualLite Applications Processor Reference Manual).
But, i don't understand how I.MX6 can output MCK that is synchronized with I2S signals.
please give your strong support.
yuji
Hi Igor
OK, i create new thread.
br,
yuji
Hi, Igor
Thanks for your explanation.
so, i understand that oversampling clock can be obtained from SRCK when that is unused to set SCR register bit15,SYS_CLK_EN.
And, I get further questions as below
1) Each SSIx(x=1,2,3) is included STCK/STFS/SRCK/SRFS/STXD/SRXD signal lines?
2) Each SSIx(x=1,2,3) are connected to internal port 1/2/7 of AUDMUX. Is my understanding correct?
3) we can set port to port connection inside AUDMUX?(default configuration is below figure)
4) Each signals on external ports is connected SoC pad as Table 16-1?
yuji
Hi Yuji
for new questions please create new thread.
Hi Yuji
probably by "MCK" you means "oversampling clock", it is described in
sect.61.8.4 SSI Clocking i.MX 6Solo/6DualLite Applications Processor Reference Manual :
detailed clocking scheme can be found in Figure 61-22. SSI Transmit Clock Generator Block Diagram
