How regulator voltages are set
ioteng
We are currently trying to set the  PMIC(pfuze3000 A3) output voltage to 1.375V.  We tried setting the registers in u-boot but it gets overridden by the kernel during bootup. Currently, the only other method we know is by setting the operating-points tuple in the device tree. Is this correct method?
Leonardo
Labels (4)
Tags (4)
Hi Leonardo
for linux regulator usage one can look at sect.2.5.2 PMIC PF Regulator
attached Linux Manual.
