S32K144EVB-Q100 cannot flash S32K144 chip
Question asked by Denis Kotov on Jan 28, 2020
Latest reply on Jan 29, 2020 by Daniel Martynek
Hello all,
For test purpose I have changed manually io_table.c pin configuration (g_pin_mux_InitConfigArrand configured most of pins as PORT_PIN_DISABLED ...
But after this small modification microcontroller stooped response back to OpenSDA embedded on board ...
As result I cannot debug or flash firmware to chip anymore ...
The error is following:
Error in services launch sequence
PEmicro GDB Launch Failure : The GDB Server was not able to establish a connection to the target processor. Please check your connections and power. Verify that the launch settings in the Debug Configuration are accurate.
How to restore the board ? Have anybody faced with the same issue ?
