Reading out proprietary data from NXQ1TXH5
nagl
WPC spec allows receivers to send data to transmitters to control charging operations. There are also proprietary packets defined in the WPC specs. If a receiver sends such proprietary packages to a NXQ1TXH5 transmitter chip, is it possible to read out this data from the NXQ1TXH5 via its I2C interface?
TomasVaverka
Hello Matthias,
The I2C interface of the NXQ1TXH5 is primarily intended to be used in combination with the NXQ1TXH5DB1355 debugging board.
You can read the chip temperature, Qi messages etc. using the commands shown in the UM11152.
The datasheet does not show how to read the registers of the NXQ1TXH5 as we do not support it.
Tomas
