Building later Opencv versions in Yocto
davidvescovi
Contributor V
I am following the NXP eIQ direction to build some machine learning based platforms based on IMX8M.
The Linux 4.14.98_2.0.0 Yocto build just fine and works. My issues is it looks to build and include OpenCV 4.0.1.
I would like to use a later version (4.1.0 or 4.2) as I need an API not included with 4.0.1.
I tried just changing from:
PREFERRED_VERSION_opencv = "4.0.1%"
to:
PREFERRED_VERSION_opencv = "4.1.0%"
in the local.conf file but it still looks to be building 4.0.1 and it eventually fails.
Is it possible to include a later version of OpenCV?
Bio_TICFSL
Hello David,
You needed to take some dependencies. Don´t know what they are but I think you are looking for PACKAGECONFIG recipe variable, you can find more, info in here:
http://www.yoctoproject.org/docs/latest/ref-manual/ref-manual.html#var-PACKAGECONFIG A good recipe example would be ffmpeg.
