如何打包单独编译的uboot和kernel到.sdcard文件
road_wang
在SDK下单独编译出uboot和kernel后,如果将它们重新打包到.sdcard文件?
road_wang
I.MX6ULL EVT,
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.1.0.xml
Rita_Wang
Here do you want to download the build images to your board?  If yes, you can use the uuu tool to download, but you need to do some modify toward your board and build images. Details you can see the samples under demo images.
The steps download uboot, kernel ,dts and rootfs you can see.
About how to make all these images to  .sdcard file, we also do not know how to.
road_wang
do we have another way make all images to single file for factory production?
Rita_Wang
Yes, but not build in Standalone build. The build step you have to follow our use guide.
Rita_Wang
Which board and BSP are you using?
