Can't capture Video/image on i.MX 8QuadMax MEK With gstreamer and v4l2
Question asked by Saiful Bappi on Jan 14, 2020
Latest reply on Jan 14, 2020 by igorpadykov
For i.MX 8QuadMax MEK I am facing some issues while capturing videos and images.
I am using this image-
https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL4.14.78_1.0.0_MX8MQ%26appType%3Dlicense%26location%3Dnull
Problem-1: When I try to stream/dump h264 encoded data with v4lh264enc and gstreamer it stucks at PREROLLING state-
gst-launch-1.0 v4l2h264enc ! rtph264pay ! udpsink sync=false host=192.168.1.246 port=5000
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ..
gst-launch-1.0 v4l2h264enc ! rtph264pay ! autovideosink
Pipeline is PREROLLING ...
gst-launch-1.0 v4l2h264enc ! rtph264pay ! filesink location=test.h264
For all above v4l2h264enc commands corresponding dmesg log--
[ 158.930946] (null): mxc_isi_capture_open, No remote pad found!
[ 158.937326] (null): mxc_isi_capture_open, No remote pad found!
[ 158.943539] (null): mxc_isi_capture_open, No remote pad found!
[ 158.949821] (null): mxc_isi_capture_open, No remote pad found!
[ 159.187735] (null): mxc_isi_capture_open, No remote pad found!
[ 159.194115] (null): mxc_isi_capture_open, No remote pad found!
[ 159.200400] (null): mxc_isi_capture_open, No remote pad found!
[ 159.206710] (null): mxc_isi_capture_open, No remote pad found
Problem-2:
When i run v4l2-ctl --list-devices it gives--
vpu B0 (platform:):
/dev/video12
/dev/video13
mxc-isi (platform:58100000.isi.0):
/dev/video4
mxc-jpeg decoder (platform:58400000.jpegdec):
/dev/video5
mxc-jpeg decoder (platform:58450000.jpegenc):
/dev/video6
Logitech BRIO (usb-xhci-cdns3-1.3):
/dev/video7
/dev/video8
Failed to open /dev/video0: Invalid argument
Also -
v4l2-ctl --all
[ 88.289844] (null): mxc_isi_capture_open, No remote pad found!
Problem-3 :
When i try to capture a jpeg image with v462src and gstreamer it gives a memory allcoation error .
gst-launch-1.0 v4l2src device=/dev/video4 num-buffers=1 ! jpegenc ! filesink location=a.jpg
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
../../../git/sys/v4l2/gstv4l2src.c(650): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Execution ended after 0:00:00.040333191
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
[ 76.664041] (null): mxc_isi_capture_open, No remote pad found!
[ 76.669998] (null): mxc_isi_capture_open, No remote pad found!
[ 76.675952] (null): mxc_isi_capture_open, No remote pad found!
[ 76.681900] (null): mxc_isi_capture_open, No remote pad found!
[ 76.750236] mxc-isi 58100000.isi: mxc_isi_m2m_streamon Not support upscale
For video5 and video6 it say it is not a capture device
gst-launch-1.0 v4l2src device=/dev/video5 num-buffers=1 ! jpegenc ! filesink location=a.jpg
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/dev/video5' is not a capture device.
../../../git/sys/v4l2/v4l2_calls.c(676): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Capabilities: 0x4208000
[ 130.578240] (null): mxc_isi_capture_open, No remote pad found!
[ 130.584416] (null): mxc_isi_capture_open, No remote pad found!
[ 130.590708] (null): mxc_isi_capture_open, No remote pad found!
[ 130.596798] (null): mxc_isi_capture_open, No remote pad found!
Some additional info--
cat /etc/issue.net
NXP i.MX Release Distro 4.14-sumo %h
uname -a
Linux imx8qmmek 4.14.78-imx_4.14.78_1.0.0_ga+g66620c3 #1 SMP PREEMPT Tue Dec 4 03:16:42 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
df -H
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.9G 1.6G 214M 88% /
devtmpfs 2.6G 4.1k 2.6G 1% /dev
tmpfs 3.1G 0 3.1G 0% /dev/shm
tmpfs 3.1G 18M 3.0G 1% /run
tmpfs 3.1G 0 3.1G 0% /sys/fs/cgroup
tmpfs 3.1G 4.1k 3.1G 1% /tmp
tmpfs 3.1G 279k 3.1G 1% /var/volatile
/dev/mmcblk1p1 16G 2.9G 13G 19% /run/media/mmcblk1p1
/dev/mmcblk0p1 67M 26M 42M 38% /run/media/mmcblk0p1
tmpfs 604M 91k 604M 1% /run/user/0
free -h
total used free shared buff/cache available
Mem: 5.6G 413M 5.1G 16M 132M 5.1G
Swap: 0B 0B 0B
ls -l /dev/video*
crw-rw---- 1 root video 81, 0 Nov 25 2018 /dev/video0
crw-rw---- 1 root video 81, 1 Nov 25 2018 /dev/video1
crw-rw---- 1 root video 81, 7 Nov 25 2018 /dev/video12
crw-rw---- 1 root video 81, 8 Nov 25 2018 /dev/video13
crw-rw---- 1 root video 81, 2 Nov 25 2018 /dev/video2
crw-rw---- 1 root video 81, 3 Nov 25 2018 /dev/video3
crw-rw---- 1 root video 81, 4 Nov 25 2018 /dev/video4
crw-rw---- 1 root video 81, 5 Nov 25 2018 /dev/video5
crw-rw---- 1 root video 81, 6 Nov 25 2018 /dev/video6
