[i.MX8 QXP] yocto run bitbake toolchain error(Fatal error: can't create Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nssinit.o: Input/output error)
jianwei_lan
vmuser@ubuntu:/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp$ MACHINE=imx8qxpmek DISTRO=fsl-imx-xwayland source ./fsl-setup-release.sh -b jianwei-build-xwayland
Build directory is jianwei-build-xwayland
Welcome to Freescale Community BSP
The Yocto Project has extensive documentation about OE including a
reference manual which can be found at:
http://yoctoproject.org/documentation
For more information about OpenEmbedded see their website:
http://www.openembedded.org/
You can now run 'bitbake <target>'
Common targets are:
core-image-minimal
meta-toolchain
meta-toolchain-sdk
adt-installer
meta-ide-support
Your configuration files at jianwei-build-xwayland have not been touched.
BSPDIR=
BUILD_DIR=.
meta-freescale directory found
vmuser@ubuntu:/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland$ bitbake meta-toolchain
NOTE: Your conf/bblayers.conf has been automatically updated.
WARNING: Host distribution "ubuntu-14.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |################################################################################################################| Time: 0:00:03
Loaded 3483 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.38.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-14.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8qxpmek"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "4.14-sumo"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta
meta-poky = "HEAD:c9bd4984f8f471ca2c43052714f4413ba99cf171"
meta-oe
meta-multimedia = "HEAD:8760facba1bceb299b3613b8955621ddaa3d4c3f"
meta-freescale = "HEAD:27ca94f8a4336790ba117b4298566f6820e7e74c"
meta-freescale-3rdparty = "HEAD:82037216280a39957fb4272581637abec734ad50"
meta-freescale-distro = "HEAD:f7e2216e93aff14ac32728a13637a48df436b7f4"
meta-bsp
meta-sdk = "HEAD:8eeb420fad668b733ab95b460895e1c337c66b25"
meta-browser = "HEAD:75640e14e325479c076b6272b646be7a239c18aa"
meta-gnome
meta-networking
meta-python
meta-filesystems = "HEAD:8760facba1bceb299b3613b8955621ddaa3d4c3f"
meta-qt5 = "HEAD:d4e7f73d04e8448d326b6f89908701e304e37d65"
Initialising tasks: 100% |###########################################################################################################| Time: 0:00:04
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: nss-native-3.35-r0 do_compile: Function failed: do_compile (log file is located at /hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/temp/log.do_compile.5070)
ERROR: Logfile of failure stored in: /hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/temp/log.do_compile.5070
Log data follows:
| DEBUG: Executing shell function do_compile
| make: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss'
| cd coreconf; make export
| make[1]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/coreconf'
| cd nsinstall; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/coreconf/nsinstall'
| make[2]: Nothing to be done for `export'.
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/coreconf/nsinstall'
| cd nsinstall; make libs
| true -m 775 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/bin
| make[1]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/coreconf'
| cd lib; make export
| make[1]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib'
| cd util; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/util'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 base64.h ciferfam.h eccutil.h hasht.h nssb64.h nssb64t.h nsslocks.h nssilock.h nssilckt.h nssrwlk.h nssrwlkt.h nssutil.h pkcs11.h pkcs11f.h pkcs11p.h pkcs11t.h pkcs11n.h pkcs11u.h pkcs1sig.h portreg.h secasn1.h secasn1t.h seccomon.h secder.h secdert.h secdig.h secdigt.h secitem.h secoid.h secoidt.h secport.h secerr.h utilmodt.h utilrename.h utilpars.h utilparst.h pkcs11uri.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 verref.h templates.c ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/util'
| cd freebl; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/freebl'
| Makefile:648: warning: overriding commands for target `Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/Linux_SINGLE_SHLIB'
| Makefile:635: warning: ignoring old commands for target `Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/Linux_SINGLE_SHLIB'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 blapit.h shsign.h ecl/ecl-exp.h nsslowhash.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 alghmac.h blake2b.h blapi.h chacha20poly1305.h hmacct.h secmpi.h secrng.h ec.h ecl/ecl.h ecl/ecl-curve.h ecl/eclt.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/freebl'
| cd dbm; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dbm'
| cd include; make export
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dbm/include'
| ../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 mcom_db.h ncompat.h winfile.h ../../../../dist/public/dbm
| ../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 hsearch.h page.h extern.h queue.h hash.h search.h ../../../../dist/private/dbm
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dbm/include'
| cd src; make export
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dbm/src'
| make[3]: Nothing to be done for `export'.
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dbm/src'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dbm'
| cd softoken; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/softoken'
| cd legacydb; make export
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/softoken/legacydb'
| There are no private exports.
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/softoken/legacydb'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 lowkeyi.h lowkeyti.h ../../../dist/public/nss
| cd legacydb; make private_export
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 lgglue.h pkcs11ni.h softoken.h softoknt.h softkver.h sdb.h sftkdbt.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/softoken'
| cd base; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/base'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 nssbaset.h nssbase.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 baset.h base.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/base'
| cd dev; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dev'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 ckhelper.h devm.h devtm.h devt.h dev.h nssdevt.h nssdev.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/dev'
| cd pki; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pki'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pki.h pkit.h nsspkit.h nsspki.h pkistore.h pki3hack.h pkitm.h pkim.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pki'
| cd libpkix; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix'
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/include'
| ../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix.h pkix_crlsel.h pkix_errorstrings.h pkix_results.h pkixt.h pkix_certsel.h pkix_params.h pkix_revchecker.h pkix_certstore.h pkix_pl_pki.h pkix_sample_modules.h pkix_checker.h pkix_pl_system.h pkix_util.h ../../../../dist/private/nss
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/include'
| cd pkix; make export
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix'
| cd certsel; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/certsel'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_certselector.h pkix_comcertselparams.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/certsel'
| cd crlsel; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/crlsel'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_comcrlselparams.h pkix_crlselector.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/crlsel'
| cd checker; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/checker'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_basicconstraintschecker.h pkix_certchainchecker.h pkix_crlchecker.h pkix_ekuchecker.h pkix_expirationchecker.h pkix_namechainingchecker.h pkix_nameconstraintschecker.h pkix_ocspchecker.h pkix_policychecker.h pkix_revocationmethod.h pkix_revocationchecker.h pkix_signaturechecker.h pkix_targetcertchecker.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/checker'
| cd params; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/params'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_procparams.h pkix_trustanchor.h pkix_valparams.h pkix_resourcelimits.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/params'
| cd results; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/results'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_buildresult.h pkix_policynode.h pkix_valresult.h pkix_verifynode.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/results'
| cd store; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/store'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_store.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/store'
| cd top; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/top'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_build.h pkix_lifecycle.h pkix_validate.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/top'
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/util'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_tools.h pkix_error.h pkix_logger.h pkix_list.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix/util'
| cd certsel; make private_export
| cd crlsel; make private_export
| cd checker; make private_export
| cd params; make private_export
| cd results; make private_export
| cd store; make private_export
| cd top; make private_export
| cd util; make private_export
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix'
| cd pkix_pl_nss; make export
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss'
| cd pki; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss/pki'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_pl_basicconstraints.h pkix_pl_cert.h pkix_pl_certpolicyinfo.h pkix_pl_certpolicymap.h pkix_pl_certpolicyqualifier.h pkix_pl_crl.h pkix_pl_crldp.h pkix_pl_crlentry.h pkix_pl_date.h pkix_pl_generalname.h pkix_pl_infoaccess.h pkix_pl_nameconstraints.h pkix_pl_ocsprequest.h pkix_pl_ocspresponse.h pkix_pl_publickey.h pkix_pl_x500name.h pkix_pl_ocspcertid.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss/pki'
| cd system; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss/system'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_pl_common.h pkix_pl_mem.h pkix_pl_object.h pkix_pl_string.h pkix_pl_primhash.h pkix_pl_bigint.h pkix_pl_mutex.h pkix_pl_bytearray.h pkix_pl_lifecycle.h pkix_pl_oid.h pkix_pl_hashtable.h pkix_pl_rwlock.h pkix_pl_monitorlock.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss/system'
| cd module; make export
| make[4]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss/module'
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkix_pl_aiamgr.h pkix_pl_colcertstore.h pkix_pl_httpcertstore.h pkix_pl_httpdefaultclient.h pkix_pl_ldapt.h pkix_pl_ldapcertstore.h pkix_pl_ldapresponse.h pkix_pl_ldaprequest.h pkix_pl_ldapdefaultclient.h pkix_pl_nsscontext.h pkix_pl_pk11certstore.h pkix_pl_socket.h ../../../../../dist/private/nss
| make[4]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss/module'
| cd pki; make private_export
| cd system; make private_export
| cd module; make private_export
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix/pkix_pl_nss'
| cd include; make private_export
| cd pkix; make private_export
| cd pkix_pl_nss; make private_export
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/libpkix'
| cd certdb; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/certdb'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 cert.h certt.h certdb.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 genname.h xconst.h certxutl.h certi.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/certdb'
| cd certhigh; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/certhigh'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 ocsp.h ocspt.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 ocspti.h ocspi.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/certhigh'
| cd pk11wrap; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pk11wrap'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 secmod.h secmodt.h secpkcs5.h pk11func.h pk11pub.h pk11priv.h pk11sdr.h pk11pqg.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 secmodi.h dev3hack.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pk11wrap'
| cd cryptohi; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/cryptohi'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 cryptohi.h cryptoht.h key.h keyhi.h keyt.h keythi.h sechash.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 keyi.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/cryptohi'
| cd nss; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/nss'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 nss.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 nssrenam.h nssoptions.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/nss'
| cd ssl; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/ssl'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 ssl.h sslt.h sslerr.h sslexp.h sslproto.h preenc.h ../../../dist/public/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/ssl'
| cd pkcs7; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pkcs7'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 secmime.h secpkcs7.h pkcs7t.h ../../../dist/public/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pkcs7'
| cd pkcs12; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pkcs12'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 pkcs12t.h pkcs12.h p12plcy.h p12.h p12t.h ../../../dist/public/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/pkcs12'
| cd smime; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/smime'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 cms.h cmst.h smime.h cmsreclist.h ../../../dist/public/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/smime'
| cd crmf; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/crmf'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 crmf.h crmft.h cmmf.h cmmft.h ../../../dist/public/nss
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 crmfi.h crmfit.h cmmfi.h cmmfit.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/crmf'
| cd jar; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/jar'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 jar.h jar-ds.h jarfile.h ../../../dist/public/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/jar'
| cd ckfw; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/ckfw'
| cd builtins; make export
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/ckfw/builtins'
| ../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 nssckbi.h ../../../../dist/public/nss
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/ckfw/builtins'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 nssck.api nssckepv.h nssckft.h nssckfw.h nssckfwc.h nssckfwt.h nssckg.h nssckmdt.h nssckt.h ../../../dist/public/nss
| cd builtins; make private_export
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 ck.h ckfw.h ckfwm.h ckfwtm.h ckmd.h ckt.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/ckfw'
| make[1]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib'
| cd cmd; make export
| make[1]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd'
| cd lib; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/lib'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 444 basicutil.h secutil.h pk11table.h ../../../dist/private/nss
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/lib'
| cd bltest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/bltest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/bltest'
| cd ecperf; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ecperf'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ecperf'
| cd fbectest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/fbectest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/fbectest'
| cd fipstest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/fipstest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/fipstest'
| cd lowhashtest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/lowhashtest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/lowhashtest'
| cd shlibsign; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/shlibsign'
| cd mangle; make export
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/shlibsign/mangle'
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/shlibsign/mangle'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/shlibsign'
| cd addbuiltin; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/addbuiltin'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/addbuiltin'
| cd atob; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/atob'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/atob'
| cd btoa; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/btoa'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/btoa'
| cd certcgi; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/certcgi'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/certcgi'
| cd certutil; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/certutil'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/certutil'
| cd chktest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/chktest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/chktest'
| cd crlutil; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/crlutil'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/crlutil'
| cd crmftest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/crmftest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/crmftest'
| cd dbtest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/dbtest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/dbtest'
| cd derdump; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/derdump'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/derdump'
| cd digest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/digest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/digest'
| cd httpserv; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/httpserv'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/httpserv'
| cd listsuites; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/listsuites'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/listsuites'
| cd makepqg; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/makepqg'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/makepqg'
| cd multinit; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/multinit'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/multinit'
| cd ocspclnt; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ocspclnt'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ocspclnt'
| cd ocspresp; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ocspresp'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ocspresp'
| cd oidcalc; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/oidcalc'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/oidcalc'
| cd p7content; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7content'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7content'
| cd p7env; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7env'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7env'
| cd p7sign; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7sign'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7sign'
| cd p7verify; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7verify'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/p7verify'
| cd pk12util; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk12util'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk12util'
| cd pk11ectest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk11ectest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk11ectest'
| cd pk11gcmtest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk11gcmtest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk11gcmtest'
| cd pk11mode; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk11mode'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk11mode'
| cd pk1sign; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk1sign'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pk1sign'
| cd pp; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pp'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pp'
| cd pwdecrypt; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pwdecrypt'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pwdecrypt'
| cd rsaperf; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/rsaperf'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/rsaperf'
| cd rsapoptst; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/rsapoptst'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/rsapoptst'
| cd sdrtest; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/sdrtest'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/sdrtest'
| cd selfserv; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/selfserv'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/selfserv'
| cd signtool; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/signtool'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/signtool'
| cd signver; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/signver'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/signver'
| cd smimetools; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/smimetools'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/smimetools'
| cd ssltap; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ssltap'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/ssltap'
| cd strsclnt; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/strsclnt'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/strsclnt'
| cd symkeyutil; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/symkeyutil'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/symkeyutil'
| cd tests; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/tests'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/tests'
| cd tstclnt; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/tstclnt'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/tstclnt'
| cd vfychain; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/vfychain'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/vfychain'
| cd vfyserv; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/vfyserv'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/vfyserv'
| cd modutil; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/modutil'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/modutil'
| cd pkix-errcodes; make export
| make[2]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pkix-errcodes'
| make[2]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd/pkix-errcodes'
| make[1]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/cmd'
| cd coreconf; make libs
| cd lib; make libs
| cd util; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libnssutil.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 775 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libnssutil3.so ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd freebl; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libfreebl.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| make FREEBL_CHILD_BUILD=1 \
| OBJDIR=Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/Linux_SINGLE_SHLIB libs
| make[3]: Entering directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/freebl'
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 775 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/Linux_SINGLE_SHLIB/libfreeblpriv3.so ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| make[3]: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss/lib/freebl'
| make FREEBL_CHILD_BUILD=1 USE_STUB_BUILD=1 \
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 775 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/Linux_SINGLE_SHLIB/libfreebl3.so ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd dbm; make libs
| cd include; make libs
| make[3]: Nothing to be done for `libs'.
| cd src; make libs
| ../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libdbm.a ../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd softoken; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libsoftokn.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 775 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libsoftokn3.so ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd legacydb; make libs
| ../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libnssdbm.a ../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| ../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 775 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libnssdbm3.so ../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd base; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libnssb.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd dev; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libnssdev.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd pki; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libnsspki.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd libpkix; make libs
| cd pkix; make libs
| cd certsel; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixcertsel.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd crlsel; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixcrlsel.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd checker; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixchecker.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd params; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixparams.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd results; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixresults.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd store; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixstore.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd top; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixtop.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd util; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixutil.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd pkix_pl_nss; make libs
| cd pki; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixpki.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd system; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixsystem.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd module; make libs
| ../../../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpkixmodule.a ../../../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd certdb; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libcertdb.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd certhigh; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libcerthi.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd pk11wrap; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libpk11wrap.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd cryptohi; make libs
| ../../coreconf/nsinstall/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nsinstall -R -m 664 Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/libcryptohi.a ../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/lib
| cd nss; make libs
| gcc -isystem/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/recipe-sysroot-native/usr/include -O2 -pipe -o Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nssinit.o -c -O2 -fPIC -m64 -pipe -ffunction-sections -fdata-sections -DHAVE_STRERROR -DLINUX -Dlinux -Wall -DNSS_NO_GCC48 -DXP_UNIX -UDEBUG -DNDEBUG -D_REENTRANT -DNSS_NO_INIT_SUPPORT -DUSE_UTIL_DIRECTLY -DNO_NSPR_10_SUPPORT -DSSL_DISABLE_DEPRECATED_CIPHER_SUITE_NAMES -I/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/recipe-sysroot-native/usr/include -I../../../dist/Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/include -I../../../dist/public/nss -I../../../dist/private/nss nssinit.c
| Assembler messages:
| make[2]: *** [Linux3.4_x86_64_glibc_PTH_64_OPT.OBJ/nssinit.o] Error 2
| make[1]: *** [libs] Error 2
| make: *** [libs] Error 2
| make: Leaving directory `/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/nss-3.35/nss'
| WARNING: exit code 2 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/jianwei-build-xwayland/tmp/work/x86_64-linux/nss-native/3.35-r0/temp/log.do_compile.5070)
ERROR: Task (virtual:native:/hdd-1/L4-14-98_2-0-0/imx-yocto-bsp/sources/poky/meta/recipes-support/nss/nss_3.35.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 436 tasks of which 435 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Tags (2)
weidong_sun
Hi Jianwei,
   我们文档中推荐了14.04和16.04,说明test team和design team都做过严格的测试,不会有问题。但是,我这里没有14.04的环境,我在18.04 LTS编译了几个不同的开发板,可以在这里和你分享一下配置的步骤:
1. Install 18.04 on vmplayer
After installation is done, root user should be set at first.
# sudo passwd root
Then follow these steps to configuration ubuntu 18.04 for environment of compiliation
(1)Change sources of ubuntu 18.04 mirror
# sudo cp /etc/apt/sources.list /etc/apt/sources.list.bak
# sudo geit /etc/apt/source.list
[Comment]
I.MX customers outside China do not need to modify Ubuntu source list, or can modify it to local mirror site of Ubuntu 18.04, which can improve the speed of software upgrade
Delet all sources and copy following lines here, Then save it and exit
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic main restricted universe multiverse
# deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic main restricted universe multiverse
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-updates main restricted universe multiverse
# deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-updates main restricted universe multiverse
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-backports main restricted universe multiverse
# deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-backports main restricted universe multiverse
deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-security main restricted universe multiverse
# deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-security main restricted universe multiverse
# deb https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-proposed main restricted universe multiverse
# deb-src https://mirrors.tuna.tsinghua.edu.cn/ubuntu/ bionic-proposed main restricted universe multiverse
(2)Run these 2 commands to update sources and package
# sudo apt-get update
# sudo apt-get upgrade
  1. Installing packages for compiliation
         After installing the following packages, android9.0.0-2.3.1 and Linux BSP 4.19.35-1.1.0 can both compilied without errors. For other lower versions of android and linux BSP, even I didn’t test them, customer can also install these packages before compiliation, probably these packages can help customer solve  some of problems during compiling BSP.
# sudo apt-get install flex bison gperf build-essential zlib1g-dev lib32ncurses5-dev x11proto-core-dev libx11-dev lib32z1-dev libgl1-mesa-dev tofrodos python-markdown libxml2-utils xsltproc
# sudo apt-get install uuid-dev:i386 liblzo2-dev:i386 gcc-multilib g++-multilib subversion openssh-server openssh-client uuid uuid-dev zlib1g-dev liblz-dev lzop  liblzo2-2 liblzo2-dev git-core curl
# sudo apt-get install u-boot-tools mtd-utils android-tools-fsutils openjdk-8-jdk device-tree-compiler aptitude libcurl4-openssl-dev nss-updatedb
# sudo apt-get install chrpath texinfo gawk cpio diffstat
上面的这配置完成之后,就可以用你的命令进行编译了。这个版本我编译了好几个板子的BSP,都没啥问题。
[注] 可能你在编译到tensorflow的时候,会遇到编译出错的问题,这是因为在编译的时候,它需要下载软件包,网络环境不好造成的软件包下载不完整,从而解压出错的原因。如果网络环境好,不会遇到这个问题。
Have a nice day!
BR,
Weidong
weidong_sun
Hi Jianwei,
# sudo passwd root
[Comment]
Have a nice day!
BR,
Weidong
