How to debug in MPC5604P use CodeWarrior 10.5
byron_dai
I am new in CodeWarrior.
I got problems in CodeWarrior.
I buy a TRK-MPC5604P
The box have some software CodeWarrior 10.5, FreeMASTER, RAppID_Init_560xP, RAppIDBootloader, rsp2cw10.
I follow the document "FSK_TRK_MPC5604P_Training.pdf", install and creating LED example.
In the document, it use RAppID Bootloader utility to flash S-record file Training_LED_Example.mot using serial port.
And monitor variables using FreeMASTER is OK.
But i want to debug step by step or use breakpoint in CodeWarrior.
How can i flash and debug use CodeWarrior instead of use RAppID Bootloader?
When i press Debug in CodeWarriorpastedImage_4.png, it show pastedImage_5.png, i press OK, and next
pastedImage_6.png, it is show P&E Connection Assistant and pastedImage_7.png and pastedImage_8.png.
It seems not work.
MPC5604P connect to my NB by OSBDM/OSJTAG in mini USB.
Can anyone give me a favor?
Provide my CodeWarrior version
Am i need other tools or software?
Attachment is the document i followed.
Thanks.
Tags (2)
byron_dai
Hi Petr
It's no option with "OSBDM/OSJATG"
and I use USB to connect to my NB.
Thanks.
PetrS
if I connect TRK-MPC5604B using USB cable i see following in the PC device Manager
then within CW 10.5 target setting I can select OSBDM/OSJTAG and it is available in Port option
BR, Petr
PetrS
within P&E Connection Assistant select "OSBDM/OSJATG" option, if it is there, as you are not connecting through USB Multilink.
BR, Petr
