Spreadsheet for i.MX6ULL fusemap
ceggers
Contributor V
Similar as asked here https://community.nxp.com/message/1239425, I would like to ask for the spreadsheet for the i.MX6ULL fusemap. Even if most fuses should be identically, I already noticed some subtle differences which I need to clarify.
Could you please provide the spreadsheet here?
regards
Christian Eggers
Tags (3)
gusarambula
Hello Christian Eggers,
I’m inquiring about this file and I will let you know as soon as I have some information.
ceggers
Contributor V
Ping?
IMX6ULLRM.pdf contains many inconsistencies regarding the fuses. Clarification of these is necessary.
regards
Christian
gusarambula
Hello Christian,
My apologies for the delay, I checked and there is not a fuse map spreadsheet available for the i.MX6ULL. The only information regarding the fusemap is that of the Reference Manual. Is there anything we can help you with regarding that fusemap?
