Dears,
Customer bought MIMXRT1050-EVK and running the 'sd_jpeg' example, find it stuck at the postion as below, can you help to advice?
BRs,
Ray
Hello Ray,
I made several tests on my side using the latest version of the SDK (v2.7) and I wasn't able to reproduce the behavior that you mentioned. What version of the SDK are you using? If you are using a different version, could you please try to reproduce the issue with the example from SDK version 2.7?
Victor
