We're designing a new product using the UCODE G2iM+ (SL3S1013), and there seems to be contradictive information regarding the minimum current consumption.
Table 36 in the datasheet (SL3S1003_1013, Rev. 3.8 — 5 February 2019) says 14 uA.
Section 3.2 in the application note (AN10940, Rev. 1.3 — 13 May 2014) says 7 uA.
What is the correct value?
Thanks in advance.
Hi ,
I believe there is a confusion here,you are comparing G2iL+ (7uA) values with G2iM+ (14uA) – the issue here is not necessarily the max. values.
Have a great day !
Jonathan
I have modified my answer due to some erros and got of data confirmation please check it above.
Have a great day !
Jonathan
