How to cross-compile to install OpenCV on iMX6UL ?
toanjunifer
Senior Contributor I
Hi NXPs,
My name is Toan. I installed opencv on python 2 successfully. I installed pt5-creator first and then I install opencv via source code. I successfully but it's take a long time. So how can I do cross-compile or anything else to reduce native-compile ? Use layer or recipe ?
Thank you again !
Toan
weidong_sun
Hi Toan,
    it is very easy if you have download Yocto BSP via repo sync, and compiled it successfully.
if not, you should setup environment for Yocto.
---downloading linux document from the link
Embedded Linux for i.MX Applications Processors | NXP
Supporting informtion
Select one version of linux bsp, and download it's document.
then download yocto BSP and compile it according to steps in "i.MX_Yocto_Project_User's_Guide.pdf",  opencv on python 2 have been included.
Have a nice day!
BR,
Weidong
weidong_sun
Hello Toan,
 NXP provides a way to compile it in yocto. Actually, it only takes a long time to compile for the first time, because it needs to download relevant software packages. After that, the compilation speed will be very fast.
Have a nice day!
BR,
Weidong
toanjunifer
Hi weidong.sun‌,
Thank you for your response. I think this way is better than I do, which take very long time to native-compile.
May you show me that way ? It's very meaningful.
Thank you so much,
Toan
weidong_sun
Hi Toan,
Have a nice day!
BR,
Weidong
toanjunifer
Hi weidong.sun
As my main question above, I'm finding other way to execute cross-compile instead of native-compile on iMX6ULEVK. Because It's take a long time. So I think writing a recipe by myself may solved this problem. But I don't exactly what I need to do and does it's possible ?
Toan
weidong_sun
Hello Toan,
    I just tested meta-python2 in yocto , below is steps:
# cd ~/imx-yocto-bsp-L4.14.98-2.2.0/sources/meta-openembedded
# git clone https://git.openembedded.org/meta-python2
# cd meta-python2
# git checkout -b sumo origin/sumo
# DISTRO=fsl-imx-fb MACHINE=imx6ulevk source fsl-setup-release.sh -b build-fb
(1) changing ./conf/bblayer.conf
#BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-python "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-python2 "
(2)changing networking's layer.conf
~/imx-yocto-bsp-L4.14.98-2.2.0/sources/meta-openembedded/meta-networking/conf/layer.conf
#LAYERDEPENDS_networking-layer += "meta-python"
LAYERDEPENDS_networking-layer += "meta-python2"
# bitbake python -c fetch
# bibake python -c compile
Have a nice day!
BR,
Weidong
toanjunifer
Hi weidong.sun‌,
Thank you for your response, but I think we have a mistake here. Maybe It's my wrong presentation.
Python is also can be added by modify "local.conf" file. It's easier than your way. Just adding "python" is enough. I mean I wanna install OpenCV on Python 2 by cross-compile. Using recipe, layer may be possible ?
Toan
weidong_sun
Hello Toan,
     I may have misunderstood the question you submitted before. Your goal is to call opencv Library in Python, so you want to achieve this goal when compiling in yocto.
    I looked up some materials, and did some tests in yocto. You can try it like this, which may help you.
Add these 2 lines to local.conf, please!
IMAGE_INSTALL_append = " opencv python python-pip zbar"
PACKAGECONFIG_append_pn-opencv = " python"
good luck!
Have a nice day!
BR,
Weidong
toanjunifer
Hi weidong.sun‌,
I found that NXP has release a new kernel 4.19.35 which cantains python3-pyqt5 package. So this problem may not need to solve anymore.
Thank you for your support.
Toan
weidong_sun
You are welcome!
toanjunifer
Hi weidong.sun‌,
I tried follow your guide. But It's seem like not working. While building have no error but then I can not import cv2 from python 2 environment. I search some material It's say that opencv 4.0.1 is working good on python 2.7.
Note: While build I found a warning:
WARNING: opencv-4.0.1.imx+gitAUTOINC+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0 do_configure: QA Issue: opencv: invalid PACKAGECONFIG: python [invalid-packageconfig]
Toan
toanjunifer
Hi weidong.sun‌,
Thank you for your response. It's very worth to try. I will response whenever I done this.
Toan
weidong_sun
Hi Toan,
   You mean Yocto BSP includes Python3, but you want to use Python2,  and you hope Python2 can be added to Yocto, right?
Have a nice day!
Weidong
toanjunifer
Hi weidong.sun‌,
Currently, I'm using BSP kernel v4.14.98_2.0.0 and I build a distro successfully. I install successfully OpenCV on Python 3 by adding "opencv" and other relevant packages on "local.conf" file. But I can not install OpenCV on Python 2 by this way. Did you mean "very easy way" is modify local.conf file ?
Toan
