Pedro Palacios
XEP100 - Partition DFlash vs Full Partition DFlash
Discussion created by Pedro Palacios on Mar 23, 2009
Latest reply on Apr 2, 2009 by Pedro Palacios
Hi all,
I wonder if you could help me out with the following problem.
The flash loader I have needs to be capable of partitioning the D-Flash memory. The software will be running in Secured Normal Single Chip mode therefore it is not possible to execute a Full Partition D-Flash command.
I understand that even though parts are shipped in erase state, it is recommended to run a Full Partition command during production.
I'd like to know if the Full Partition command could be replaced with a sequence that erases the 32k D-Flash using FTM command 0x12 - Erase D-Flash sector, followed by a Partition D-Flash 0x20 command.
Is this something you would recommended?
Message Edited by Pedro_ on 2009-03-23 11:07 AM
