Also threre is another solution that may help you. Try to implement timeout detection by hardware. The SHFT2 flag from register I2Cx_SMB , indicate that the SDA is held low more than clock × LoValue / 512 .After detection you could implement the recovery procedure of the nine clock cycles . Please take a look at the reference manual chapter 31.3.9 I2C SMBus Control and Status register.
Solved! Go to Solution.
Dear 梁 卓夫,
You are correct, part of the functionality provided by the I2Cx_SMB register is to detect when SCL and SDA lines are hang-up, using timeout flags and enabling related interrupts. The recovery of the bus still requires nine clock cycles, which is not a functionality provided by the register.
Diego
Dear 梁 卓夫,
Diego
Thanks!
