Flash eMMC of ls1021a error CodeWarrior
jiye
Contributor V
When I use CodeWarrior to flash my stand alone ls1021a which has external eMMC
I encountered this error below:
Anyone knows what is going on ?
yipingwang
Hello Elias Bitbaker,
For MMC programming, please refer to the procedure described in document https://community.nxp.com/docs/DOC-332382.
First, please create a bareboard project and try whether you can connect to the target board and debug the bareboard project, please refer to the section "Creating and building bareboard project" and "Debugging bareboard project" in C:\Freescale\CW4NET_v2017.03rmv7\CW_ARMv7\ARMv7\CW_ARMv7_Getting_Started_Guide.pdf.
In addition, please create the bareboard project in a new workspace folder to do verification.
Yiping
jiye
Contributor V
first of all that document is exactly what I followed. I used these step to create a emmc-clone.bin and emmc-clone.img
(1) can you tell me what is the right value for this I suppose to put
(2)I am doing via OCRAM my image size is 1.2 GB. Should I still put the 0x10000000 and size 00020000?
(3)Third, what is the offset I need to put here
Please help to clarify all of this.
(4)Also what does this even mean:
yipingwang
If the problem remains in the bareboard project bugging, please refer to the following procedure to capture the low level CCS log to me to do more investigation.
Please enable CCS log from "Run->Debug Configurations-><project>-core0_RAM_<processor>-Connect(Download)->Edit...->Advanced->Advanced CCS setting->Enable logging", and connect to the target from "Run->Debug Configurations-><project>-core0_RAM_<processor>-Connect(Download)->Debug”, the CCS log will be displayed in the console panel in CodeWarrior IDE.
If the CCS log in the console is truncated, please enlarge the console buffer from Window->Preferences->Run/Debug->Console->uncheck "Limit console output".
(Please open the console panel from Window->Show View->Console, and if nothing displayed, please choose the correct session on the right top icon in the panel.)
Yiping
jiye
Contributor V
(1) I will send you the log please see attached below, in the log I did notice these below specifically: please also help to answer my second question after this one as well thanks.
!ENTRY org.eclipse.ui 4 4 2020-01-02 15:24:30.284
!MESSAGE An internal error has occurred.
!STACK 0
java.lang.OutOfMemoryError: Java heap space
    at org.eclipse.jface.text.GapTextStore.allocate(GapTextStore.java:339)
    at org.eclipse.jface.text.GapTextStore.reallocate(GapTextStore.java:290)
    at org.eclipse.jface.text.GapTextStore.adjustGap(GapTextStore.java:223)
    at org.eclipse.jface.text.GapTextStore.replace(GapTextStore.java:196)
    at org.eclipse.jface.text.CopyOnWriteTextStore.replace(CopyOnWriteTextStore.java:158)
    at org.eclipse.jface.text.AbstractDocument.replace(AbstractDocument.java:1184)
    at org.eclipse.jface.text.AbstractDocument.replace(AbstractDocument.java:1210)
    at org.eclipse.ui.internal.console.ConsoleDocument.replace(ConsoleDocument.java:82)
    at org.eclipse.ui.internal.console.IOConsolePartitioner.processQueue(IOConsolePartitioner.java:572)
    at org.eclipse.ui.internal.console.IOConsolePartitioner$QueueProcessingJob.runInUIThread(IOConsolePartitioner.java:520)
    at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:96)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:155)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4155)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3768)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3750)
    at com.freescale.flashprogrammer.editor.DumpFlashDialog.open(DumpFlashDialog.java:322)
    at com.freescale.flashprogrammer.editor.listeners.FlashPageListeners.widgetSelected(FlashPageListeners.java:213)
    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3765)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2803)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2767)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2601)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:680)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
!ENTRY org.eclipse.ui 4 4 2020-01-02 15:24:46.953
!STACK 0
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
    at org.eclipse.jface.window.Window.open(Window.java:801)
    at org.eclipse.jface.dialogs.MessageDialog.open(MessageDialog.java:334)
    at org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open(InternalErrorDialog.java:80)
    at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.openQuestionDialog(IDEWorkbenchErrorHandler.java:234)
    at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handleException(IDEWorkbenchErrorHandler.java:188)
    at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.access$3(IDEWorkbenchErrorHandler.java:180)
    at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler$1.runInUIThread(IDEWorkbenchErrorHandler.java:167)
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:36.645
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:42.819
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:44.521
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:45.513
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:46.643
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:47.630
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:52.182
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:54.163
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:56.138
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:58.064
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:56:59.735
!STACK 0
!ENTRY org.eclipse.ui 4 4 2019-12-31 11:57:05.828
!STACK 0
(2) can you answer me this question please? what is the base address i need to define when I am trying to flash a whole image (contains uboot, device treesm kernel, rootfs)
This is important !
In other words, 1. base address =?
                         2. Apply Address Offset = ?
yipingwang
1. Please create a bareboard project in a new workspace.
2. Please refer to page 3 in document https://community.nxp.com/docs/DOC-332382, the firmware image should be programmed at block 8. In this case, the address offset will be 8*512=4096, which means 0x1000 in hexadecimal.
Yiping
jiye
Contributor V
1. I did create new project in a different work space. I am able to get into debug mode
2.I did change the offset into 0x1000
then
It's always starting at 0x10000dc0 says Core not in debug mode. It seems like something try to make the core to quit debug mode.
3. what about the device name?
I have a 8GB eMMC sbut I am testing to flash into a 16 GB Sandisk SD card on eva board right now if that works I will start flash into eMMC
do I need to change anything here ?
jiye
Contributor V
now I am trying to use RAM method to flash the eMMC
Then i do not see any memory mapping on the right window
and this is the log:
    ccs_write_memory; ccs_error = 0; duration=3 ms
cmdwin::reg SPI1_MCR = 0x00000001
ccs_write_memory
    coreh = [serverh:0;cc_index:0;chain_pos:9]
    addr = [space:0x1;size:4;address_hi:0x00000000;address_lo:0x02100000]
    data: (size = 4)
         00000001
cmdwin::reg SPI2_MCR = 0x00000001
ccs_write_memory
    addr = [space:0x1;size:4;address_hi:0x00000000;address_lo:0x02110000]
    data: (size = 4)
         00000001
    ccs_write_memory; ccs_error = 0; duration=2 ms
cmdwin::mem 01550000 = 0x000f4000
ccs_read_register
    index = 2031872
    count = 1
    size = 4
    value: (size = 4)
         00C50878
    ccs_read_register; ccs_error = 0; duration=4 ms
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01550000]
    data: (size = 4)
         000F4000
    ccs_write_memory; ccs_error = 0; duration=4 ms
cmdwin::mem 01550108 = 0x00000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01550108]
    data: (size = 4)
         00000000
    ccs_write_memory; ccs_error = 0; duration=6 ms
cmdwin::mem 01550000 = 0x000f0000
ccs_write_memory
    data: (size = 4)
         000F0000
cmdwin::mem 01550180 = 0x41000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01550180]
    data: (size = 4)
         41000000
    ccs_write_memory; ccs_error = 0; duration=5 ms
cmdwin::mem 01550184 = 0x41000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01550184]
    data: (size = 4)
         41000000
cmdwin::mem 01550188 = 0x42000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01550188]
    data: (size = 4)
         42000000
cmdwin::mem 0155018C = 0x42000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x0155018c]
    data: (size = 4)
         42000000
cmdwin::mem 01550020 = 0x00000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01550020]
    data: (size = 4)
         00000000
cmdwin::mem p:0x01570200
ccs_read_memory
    addr = [space:0x1;size:4;address_hi:0x00000000;address_lo:0x01570200]
    data: (size = 4)
         00000000
    ccs_read_memory; ccs_error = 0; duration=3 ms
     1570200  0x00000000   ....
cmdwin::mem 0157015C = 0x00000803
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x0157015c]
    data: (size = 4)
         00000803
cmdwin::mem 01530018 = 0x00000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01530018]
    data: (size = 4)
         00000000
cmdwin::mem 0153001C = 0x7fb00085
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x0153001c]
    data: (size = 4)
         7FB00085
cmdwin::mem 015300AC = 0xffff0000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015300ac]
    data: (size = 4)
         FFFF0000
cmdwin::mem 0153013C = 0x0000800c
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x0153013c]
    data: (size = 4)
         0000800C
cmdwin::mem 015301F0 = 0xf00f000f
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301f0]
    data: (size = 4)
         F00F000F
cmdwin::mem 015301F4 = 0xff003f00
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301f4]
    data: (size = 4)
         FF003F00
cmdwin::mem 015301F8 = 0x0f3c00ff
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301f8]
    data: (size = 4)
         0F3C00FF
cmdwin::mem 015301FC = 0x00000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301fc]
    data: (size = 4)
         00000000
cmdwin::mem 0153000C = 0x00000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x0153000c]
    data: (size = 4)
         00000000
cmdwin::mem 01530010 = 0x60000101
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01530010]
    data: (size = 4)
         60000101
cmdwin::mem 015300A0 = 0xF8000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015300a0]
    data: (size = 4)
         F8000000
cmdwin::mem 01530130 = 0x0000800c
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x01530130]
    data: (size = 4)
         0000800C
cmdwin::mem 015301C0 = 0x40050005
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301c0]
    data: (size = 4)
         40050005
cmdwin::mem 015301C4 = 0x35001a13
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301c4]
    data: (size = 4)
         35001A13
cmdwin::mem 015301C8 = 0x0410381c
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301c8]
    data: (size = 4)
         0410381C
cmdwin::mem 015301CC = 0x00000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x015301cc]
    data: (size = 4)
         00000000
ccs_write_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x80000000]
    data: (size = 32768)
         04000000 14000000 03000000 474E5500
         6280432F 4325F275 C821D1B6 8A372762
         B475B492 00000000 00000000 00000000
         00000000 00000000 00000000 00000000
         00482DE9 04B08DE2 08D04DE2 08000BE5
         08301BE5 000053E3 010000CA 0030A0E3
         060000EA 08301BE5 013043E2 0300A0E1
         F2FFFFEB 0020A0E1 08301BE5 033082E0
         0300A0E1 04D04BE2 0088BDE8 00482DE9
         04B08DE2 10D04DE2 10000BE5 0030A0E3
         08300BE5 10301BE5 013003E2 000053E3
         0200000A 0130A0E3 08300BE5 0C0000EA
         10301BE5 672606E3 662646E3 9302C1E0
         C111A0E1 C32FA0E1 012062E0 1410A0E3
         910202E0 032062E0 0200A0E1 D3FFFFEB
         08000BE5 08301BE5 0300A0E1 04D04BE2
         0088BDE8 00482DE9 04B08DE2 08D04DE2
         0030A0E3 08300BE5 08001BE5 DAFFFFEB
         08301BE5 013083E2 08300BE5 F9FFFFEA
         CA0000EB 1600B0E3 471F8FE2 563412EF
         14019FE5 001090E5 000051E3 0100001A
         20119FE5 001080E5 081090E5 0C2090E5
         000051E3 0000000A 01D0A0E1 000052E3
         0000000A 01AC82E2 0010B0E3 01B0A0E1
         0170A0E1 D4009FE5 D4209FE5 002052E0
         B50000EB 1B0100EB 1500B0E3 CC108FE2
         563412EF C4109FE5 0000B0E3 01002DE9
         0130D1E4 000053E3 1100000A 200053E3
         FAFFFF0A 220053E3 27005313 0320A001
         2020A013 01104112 02002DE9 010090E2
         0130D1E4 000053E3 0500000A 030052E1
         FAFFFF1A 0020B0E3 013051E2 0020C3E5
         EAFFFFEA 0D10A0E1 00218DE0 0D30A0E1
         030052E1 04401285 00509385 04502285
         04408384 F9FFFF8A 07D0CDE3 0040B0E1
         0150B0E1 2C009FE5 000050E3 0100000A
         24009FE5 00F020E3 00F020E3 0400B0E1
         0510B0E1 AAFFFFEB 00F020E3 08250080
         00800080 E8800080 00000000 00000000
         18250080 FF000000 E8800080 00000000
         0EC0A0E1 110000EB 1C0000EB 230000EB
         0000A0E3 170F08EE D50F07EE 100F13EE
         0000E0E3 100F03EE 100F11EE 0102C0E3
         100F01EE 1E0000EB 490000EB 3D0000EB
         4D0000EB 240000EB 3F0000EB 1CFF2FE1
         0E80A0E1 304F11EE 404084E3 304F01EE
         6FF07FF5 18FF2FE1 0E80A0E1 304F11EE
         4040C4E3 304F01EE 6FF07FF5 18FF2FE1
         0E80A0E1 100F11EE 010AC0E3 0400C0E3
         0100C0E3 020BC0E3 100F01EE 18FF2FE1
         0E80A0E1 100F11EE 0200C0E3 100F01EE
         18FF2FE1 0E80A0E1 0040A0E3 504F02EE
         434F8FE2 004094E5 014084E2 084084E3
         404084E3 104F02EE 18FF2FE1 0E80A0E1
         100F11EE 010080E3 100F01EE 18FF2FE1
         0E80A0E1 300F1FEE 100080E3 300F0FEE
         300F1FEE 010A80E3 010580E3 300F0FEE
         300F1FEE 400080E3 300F0FEE 300F1FEE
         020B80E3 300F0FEE 300F1FEE 020680E3
         300F0FEE 18FF2FE1 0E80A0E1 100F11EE
         010A80E3 100F01EE 18FF2FE1 0E80A0E1
         100F11EE 040080E3 020B80E3 100F01EE
         18FF2FE1 0E80A0E1 300F30EE 030010E3
         0000A0E3 150F071E 18FF2FE1 0E80A0E1
         100F50EE 0010A0E3 010000E0 100F50EE
         100F30EE 3C309FE5 A00603E0 0010A0E3
         0030A0E3 012FA0E1 832282E1 562F07EE
         013083E2 030050E1 F9FFFFCA 011081E2
         040051E3 F5FFFF1A 0000A0E3 D50F07EE
         18FF2FE1 00400080 FF010000 00F020E3
         0EB0A0E1 85FFFFEB 1BFF2FE1 030010E3
         10402DE9 3700000A 000052E3 012042E2
         1080BD08 71E0EFE6 0030A0E1 020000EA
         000052E3 0C20A0E1 1080BD08 01E0C3E4
         030013E3 01C042E2 F8FFFF1A 030052E3
         2000009A 71E0EFE6 0F0052E3 0EE48EE1
         0EE88EE1 1000009A 10C083E2 0240A0E1
         104044E2 10E00CE5 0F0054E3 0CE00CE5
         08E00CE5 10C08CE2 14E00CE5 F7FFFF8A
         10C042E2 0F2002E2 0FC0CCE3 030052E3
         10C08CE2 0C3083E0 0A00009A 0340A0E1
         02C0A0E1 04C04CE2 04E084E4 03005CE3
         FBFFFF8A 04C042E2 032002E2 03C0CCE3
         04C08CE2 0C3083E0 000052E3 1080BD08
         7110EFE6 022083E0 0110C3E4 020053E1
         FCFFFF1A 1080BDE8 0030A0E1 D2FFFFEA
         183602E3 10402DE9 003048E3 0040A0E1
         000093E5 000050E3 0200000A 383090E5
         000053E3 0D00000A 000054E3 0700000A
         010054E3 0B00000A 020054E3 00300803
         00304803 08009305 20004412 1080BDE8
         003008E3 003048E3 000093E5 1080BDE8
         F40200EB EFFFFFEA 003008E3 003048E3
         040093E5 1080BDE8 70402DE9 1340A0E3
         390200EB 0060A0E3 0050A0E1 0400A0E1
         0610A0E1 563412EF 0040A0E1 0000E0E3
         004085E5 7080BDE8 F0472DE9 F86402E3
         10D04DE2 0390A0E3 006048E3 0040A0E3
         04608DE5 0150A0E3 0C908DE5 04808DE2
         08408DE5 0500A0E1 0810A0E1 563412EF
         00A0A0E1 007008E3 0430A0E3 007048E3
         04608DE5 00A087E5 0C908DE5 08308DE5
         0500A0E1 0810A0E1 563412EF 0050A0E1
         0000E0E3 0430A0E1 0C1087E2 085087E5
         045087E5 830181E7 013083E2 140053E3
         002008E3 002048E3 F9FFFF1A 001092E5
         0030A0E3 145082E5 103082E5 0C1082E5
         183082E5 10D08DE2 F087BDE8 70402DE9
         0140A0E1 0260A0E1 10D04DE2 A3FFFFEB
         08408DE5 04508DE2 0640A0E3 04008DE5
         0C608DE5 0400A0E1 0510A0E1 563412EF
         0040A0E1 0400A0E1 10D08DE2 7080BDE8
         F0402DE9 14D04DE2 0250A0E1 0160A0E1
         0070A0E1 0040A0E3 90FFFFEB A0209FE5
         843192E7 030050E1 0200000A 014084E2
         140054E3 F9FFFF1A 0700A0E1 87FFFFEB
         08608DE5 04708DE2 0660A0E3 04008DE5
         0C508DE5 0600A0E1 0710A0E1 563412EF
         0060A0E1 000056E3 0A0000BA 140054E3
         00300813 05006610 00304813 05006600
         84418310 10309415 00308310 10308415
         14D08DE2 F080BDE8 CB0100EB 1340A0E3
         0050A0E1 0060A0E3 0400A0E1 0610A0E1
         563412EF 0040A0E1 0000E0E3 004085E5
         F2FFFFEA 0C800080 F0472DE9 006008E3
         08D04DE2 006048E3 0150A0E1 0280A0E1
         0070A0E1 0040A0E3 5CFFFFEB 0CC086E2
         84119CE7 003008E3 003048E3 84E1A0E1
         010050E1 2900000A 014084E2 140054E3
         F6FFFF1A 010058E3 0090A013 1700000A
         020058E3 0D80A011 1700000A 0700A0E1
         0A70A0E3 49FFFFEB 04508DE5 00008DE5
         0700A0E1 0810A0E1 563412EF 0070A0E1
         173F6FE1 A332A0E1 090013E1 0400000A
         844186E0 0500A0E1 105084E5 08D08DE2
         F087BDE8 000053E3 0500A011 FAFFFF1A
         0000E0E3 08D08DE2 F087BDE8 08808DE2
         0CA0A0E3 080028E5 0A00A0E1 0810A0E1
         563412EF 00A0A0E1 0A5085E0 DEFFFFEA
         010058E3 0190A013 D8FFFF1A 0E3083E0
         0890A0E1 103093E5 0D80A0E1 035085E0
         D5FFFFEA 10402DE9 BAFFFFEB 010070E3
         1080BD18 1040BDE8 3AFFFFEA 70402DE9
         0140A0E1 0260A0E1 10D04DE2 17FFFFEB
         08408DE5 04508DE2 0540A0E3 04008DE5
         0070A0E1 0040A0E3 04FFFFEB A4209FE5
         140054E3 F9FFFF1A 0700A0E1 FBFEFFEB
         08608DE5 04708DE2 0560A0E3 04008DE5
         0060A0E1 010076E3 06005511 0A00000A
         140054E3 00300813 05006610 00304813
         05006600 84418310 10309415 00308310
         10308415 14D08DE2 F080BDE8 3E0100EB
         1340A0E3 0050A0E1 0060A0E3 0400A0E1
         004085E5 F2FFFFEA 0C800080 E0C09FE5
         0030A0E3 F0402DE9 14D04DE2 83219CE7
         8341A0E1 013083E2 010072E3 0400000A
         140053E3 F8FFFF1A 0000E0E3 14D08DE2
         F080BDE8 5158E0E7 020011E3 02508513
         020C11E3 04508513 010B11E3 04508513
         080011E3 0450C513 0030A0E1 08508513
         04308DE5 450400FA 08508DE5 04608DE2
         0150A0E3 0C008DE5 0500A0E1 0610A0E1
         563412EF 0050A0E1 000055E3 080000BA
         003008E3 0020A0E3 003048E3 200085E2
         044083E0 0C5084E5 102084E5 14D08DE2
         F080BDE8 040100EB 1340A0E3 0060A0E1
         0070A0E3 0400A0E1 0710A0E1 563412EF
         0040A0E1 0500A0E1 004086E5 14D08DE2
         F080BDE8 0C800080 0E002DE9 04E02DE5
         04109DE5 C0FFFFEB 010070E3 0200000A
         04E09DE4 0CD08DE2 1EFF2FE1 B1FEFFEB
         04E09DE4 0CD08DE2 1EFF2FE1 30402DE9
         0CD04DE2 8DFEFFEB 0030A0E3 58C09FE5
         04008DE5 83119CE7 002008E3 83E1A0E1
         002048E3 013083E2 010050E1 0A00000A
         140053E3 F6FFFF1A 0240A0E3 04508DE2
         0400A0E1 0510A0E1 563412EF 0040A0E1
         0400A0E1 0CD08DE2 3080BDE8 0E2082E0
         0030E0E3 0C3082E5 F2FFFFEA 0C800080
         10402DE9 E0FFFFEB 010070E3 1080BD18
         1040BDE8 8BFEFFEA 060051E3 30402DE9
         2350A003 2650A013 1840A0E3 025040E3
         0400A0E1 3080BDE8 0010E0E3 F1FFFFEA
         0100A0E3 1EFF2FE1 003008E3 10402DE9
         003048E3 AC2093E5 000052E3 E8100803
         00104803 0120A001 AC108305 000082E0
         0D10A0E1 010050E1 AC008395 0100008A
         0200A0E1 1080BDE8 A70000EB 0C30A0E3
         0020E0E3 003080E5 0200A0E1 1080BDE8
         10402DE9 0100A0E1 0140A0E1 3C20A0E3
         0010A0E3 04FEFFEB 022AA0E3 013BA0E3
         042084E5 0000A0E3 2C3084E5 1080BDE8
         70402DE9 0140A0E1 0010A0E3 99FFFFEB
         005050E2 0B0000BA 0010A0E3 0400A0E1
         3C20A0E3 F4FDFFEB 812CA0E3 013BA0E3
         0500A0E1 042084E5 2C3084E5 9AFFFFEB
         0000A0E3 7080BDE8 0000E0E3 7080BDE8
         0000E0E3 1EFF2FE1 30402DE9 0CD04DE2
         00008DE5 0E40A0E3 A80300FA 04008DE5
         0D50A0E1 0400A0E1 0510A0E1 563412EF
         0040A0E1 010074E3 0400A011 0400000A
         000090E2 0100A013 000060E2 0CD08DE2
         3080BDE8 2FFEFFEB F8FFFFEA 1EFF2FE1
         F0402DE9 006050E2 0140A0E1 0600000A
         1150A0E3 0070A0E3 0500A0E1 0710A0E1
         563412EF 0050A0E1 A00086E8 000054E3
         0000A0E3 0030A013 00308415 04308415
         F080BDE8 70402DE9 0040A0E1 1050A0E3
         0060A0E3 0500A0E1 0610A0E1 563412EF
         0050A0E1 060054E1 0500A0E1 60008418
         08608415 0C608415 7080BDE8 30402DE9
         0CD04DE2 EDFDFFEB 08508DE2 0940A0E3
         040025E5 0400A0E1 0510A0E1 563412EF
         0040A0E1 010074E3 0400A011 0100000A
         0CD08DE2 3080BDE8 FEFDFFEB 0CD08DE2
         3080BDE8 003050E2 1800000A 30402DE9
         0CD04DE2 00308DE5 1240A0E3 5F0300FA
         04008DE5 0D50A0E1 0400A0E1 0510A0E1
         563412EF 0040A0E1 010074E3 0D00000A
         FF0054E3 0400A0E1 0600008A 000054E3
         0400000A 8000B0E1 5034E7E7 0100000A
         040053E1 FAFFFF1A 0CD08DE2 3080BDE8
         0100A0E3 1EFF2FE1 DEFDFFEB 0040A0E1
         EEFFFFEA 30402DE9 0140A0E1 14D04DE2
         00008DE5 410300FA 04008DE5 0400A0E1
         08408DE5 0F40A0E3 3C0300FA 0C008DE5
         000090E2 0100A013 000060E2 14D08DE2
         3080BDE8 C3FDFFEB F8FFFFEA 183602E3
         003048E3 000093E5 1EFF2FE1 0000A0E3
         1EFF2FE1 0000A0E3 1EFF2FE1 FC1C01E3
         001048E3 D90000EA F84F2DE9 EC3E00E3
         045090E5 0040A0E3 0070A0E1 003048E3
         BB2F80E2 04C0A0E3 0310A0E3 3C3080E5
         E41287E5 5C0085E2 E82287E5 0410A0E1
         E04287E5 0820A0E3 BCC0C5E1 ACBA01E3
         004085E5 E4AA01E3 044085E5 389B01E3
         084085E5 648B01E3 644085E5 00B048E3
         BE40C5E1 00A048E3 104085E5 009048E3
         144085E5 008048E3 184085E5 3AFDFFEB
         086097E5 0130A0E3 09C0A0E3 1C5085E5
         20B085E5 0410A0E1 24A085E5 0820A0E3
         289085E5 5C0086E2 2C8085E5 BE30C6E1
         BCC0C6E1 004086E5 044086E5 084086E5
         644086E5 104086E5 144086E5 184086E5
         25FDFFEB 0C5097E5 12E0A0E3 02C0A0E3
         1C6086E5 20B086E5 0410A0E1 24A086E5
         5C0085E2 289086E5 0820A0E3 2C8086E5
         004085E5 044085E5 084085E5 644085E5
         104085E5 144085E5 184085E5 BCE0C5E1
         BEC0C5E1 10FDFFEB 0130A0E3 1C5085E5
         20B085E5 24A085E5 289085E5 2C8085E5
         383087E5 F88FBDE8 012041E2 70402DE9
         0242A0E1 0160A0E1 024144E0 024084E0
         8441A0E1 741084E2 9C0000EB 005050E2
         0600000A 0010A0E3 0C0085E2 046085E5
         682084E2 001085E5 080085E5 F6FCFFEB
         0500A0E1 7080BDE8 F43402E3 70402DE9
         003048E3 0060A0E1 005093E5 383095E5
         000053E3 0100001A 0500A0E1 8DFFFFEB
         2E5E85E2 180095E9 013053E2 0400005A
         1C0000EA 013043E2 684084E2 010073E3
         1800000A FC20D4E1 000052E3 F8FFFF1A
         0050A0E3 0130A0E3 0020E0E3 BC30C4E1
         BE20C4E1 0510A0E1 645084E5 0820A0E3
         005084E5 5C0084E2 085084E5 045084E5
         105084E5 145084E5 185084E5 CEFCFFEB
         0400A0E1 305084E5 345084E5 445084E5
         485084E5 7080BDE8 003095E5 000053E3
         0350A011 DAFFFF1A 0410A0E3 0600A0E1
         B8FFFFEB 000050E3 000085E5 0050A011
         D3FFFF1A 0C30A0E3 003086E5 7080BDE8
         F43402E3 FC1C01E3 003048E3 001048E3
         000093E5 310000EA 383090E5 000053E3
         1EFF2F11 53FFFFEA 1EFF2FE1 1EFF2FE1
         1EFF2FE1 1EFF2FE1 183602E3 DC1E00E3
         003048E3 001048E3 000093E5 050000EA
         183602E3 E41E00E3 003048E3 001048E3
         000093E5 FFFFFFEA F0412DE9 2E7E90E2
         1700000A 0180A0E1 0060A0E3 045097E5
         084097E5 015055E2 0C00004A BC30D4E1
         015045E2 010053E3 0500009A FE30D4E1
         0400A0E1 010073E3 0100000A 38FF2FE1
         006086E1 010075E3 684084E2 F2FFFF1A
         007097E5 000057E3 EBFFFF1A 0600A0E1
         F081BDE8 0760A0E1 0600A0E1 F081BDE8
         F0472DE9 2E6E90E2 1900000A 0180A0E1
         0070A0E1 0090A0E3 045096E5 084096E5
         015055E2 0D00004A BC30D4E1 015045E2
         010053E3 0600009A FE30D4E1 0410A0E1
         0700A0E1 010073E3 0100000A 38FF2FE1
         009089E1 010075E3 684084E2 F1FFFF1A
         006096E5 000056E3 EAFFFF1A 0900A0E1
         F087BDE8 0690A0E1 0900A0E1 F087BDE8
         F04F2DE9 0B4081E2 160054E3 0CD04DE2
         0050A0E1 1F00009A 0740C4E3 040051E1
         0010A093 0110A083 A43F91E1 8600001A
         D50100EB 7E0F54E3 1B00002A 486A02E3
         A411A0E1 006048E3 813186E0 0C2093E5
         030052E1 1E01000A 043092E5 088082E2
         0C1092E5 0500A0E1 08C092E5 0330C3E3
         032082E0 043092E5 0C108CE5 08C081E5
         013083E3 043082E5 C00100EB 0800A0E1
         0CD08DE2 F08FBDE8 100051E3 6A00008A
         B90100EB 1040A0E3 E3FFFFEA A414B0E1
         7E00A003 3FC0A003 6900001A 486A02E3
         006048E3 000186E0 0C3090E5 030050E1
         0500001A 0A0000EA 000051E3 A60000AA
         0C3093E5 030050E1 0500000A 042093E5
         0320C2E3 021064E0 0F0051E3 F5FFFFDA
         01C04CE2 01108CE2 48EA02E3 103096E5
         00E048E3 08708EE2 070053E1 04209E05
         1600000A 042093E5 0320C2E3 02C064E0
         0F005CE3 D40000CA 00005CE3 14708EE5
         10708EE5 4C0000AA 020C52E3 AE00002A
         A2C1A0E1 04009EE5 0190A0E3 8C818EE0
         4C21A0E1 08C098E5 192280E1 0C8083E5
         04208EE5 08C083E5 083088E5 0C308CE5
         4131A0E1 0100A0E3 1003A0E1 020050E1
         4300008A 000012E1 0800001A 8000A0E1
         0310C1E3 041081E2 000012E1 0300001A
         8000A0E1 041081E2 000012E1 FBFFFF0A
         818186E0 0190A0E1 08C0A0E1 0CE09CE5
         0E005CE1 0500001A B80000EA 000052E3
         C10000AA 0CE09EE5 0E005CE1 B300000A
         04309EE5 0330C3E3 032064E0 0F0052E3
         F5FFFFDA 0E80A0E1 0C309EE5 0810B8E5
         01C084E3 04C08EE5 04408EE0 01C082E3
         0500A0E1 0C3081E5 081083E5 144086E5
         104086E5 0C7084E5 087084E5 04C084E5
         022084E7 510100EB 8FFFFFEA 0C30A0E3
         0080A0E3 0800A0E1 003085E5 0CD08DE2
         F08FBDE8 040051E3 5D00008A 2413A0E1
         38C081E2 8C00A0E1 8FFFFFEA 022083E0
         088083E2 041092E5 0500A0E1 013081E3
         043082E5 3D0100EB 0800A0E1 0CD08DE2
         F08FBDE8 088096E5 481A02E3 001048E3
         047098E5 0370C7E3 040057E1 072064E0
         0030A023 0130A033 0F0052E3 013083D3
         000053E3 3600000A B09008E3 083491E5
         009048E3 0500A0E1 002099E5 010073E3
         022084E0 012A8212 10A08202 0F208212
         FFAEC213 0FA0CA13 0A10A0E1 200100EB
         010070E3 00B0A0E1 FB00000A 062058E0
         073088E0 0120A013 060058E1 00005311
         480A02E3 00208DE5 000048E3 9400009A
         088090E5 043098E5 0330C3E3 030054E1
         032064E0 0030A093 0130A083 0F0052E3
         013083D3 000053E3 1100000A 0500A0E1
         0080A0E3 050100EB 43FFFFEA 022083E0
         0CC093E5 041092E5 088083E2 08E093E5
         0500A0E1 013081E3 0CC08EE5 08E08CE5
         043082E5 F90000EB 0800A0E1 0CD08DE2
         F08FBDE8 013084E3 012082E3 044088E0
         043088E5 0500A0E1 084086E5 088088E2
         042084E5 ED0000EB 0800A0E1 0CD08DE2
         F08FBDE8 140051E3 5BC08192 8C00A091
         31FFFF9A 540051E3 AE00008A 2416A0E1
         6EC081E2 8C00A0E1 2BFFFFEA A204A0E1
         040050E3 4000009A 140050E3 5BE08092
         8E00A091 0400009A 540050E3 C700008A
         2206A0E1 6EE080E2 8E00A0E1 000186E0
         488A02E3 008048E3 08C090E5 00005CE1
         9E00000A 04E09CE5 03E0CEE3 0E0052E1
         0200002A 08C09CE5 0C0050E1 F8FFFF1A
         0C909CE5 042096E5 0C9083E5 08C083E5
         083089E5 0C308CE5 3CFFFFEA 011084E3
         01208CE3 044083E0 041083E5 0500A0E1
         14408EE5 10408EE5 088083E2 0C7084E5
         840084E9 0CC084E7 B40000EB F2FEFFEA
         019089E2 08C08CE2 030019E3 3EFFFF1A
         180000EA 083082E2 142092E5 020053E1
         02108102 07FFFF0A DAFEFFEA 03208EE0
         0E80A0E1 043092E5 0500A0E1 0C109EE5
         08C0B8E5 013083E3 043082E5 0C108CE5
         08C081E5 9D0000EB DBFEFFEA 2203A0E1
         38E080E2 8E00A0E1 C3FFFFEA 008098E5
         030058E1 9200001A 030011E3 083048E2
         011041E2 F8FFFF1A 043096E5 0030C3E1
         043086E5 8000A0E1 030050E1 0020A083
         0120A093 000050E3 0020A003 000052E3
         4BFFFF0A 000013E1 0910A0E1 0FFFFF1A
         8000A0E1 041081E2 000013E1 FBFFFF0A
         0AFFFFEA 041099E5 0B0053E1 01108AE0
         041089E5 5C00000A 08C496E5 480A02E3
         000048E3 01007CE3 0B306310 08B48005
         03108110 04108915 07301BE2 08006312
         011A6312 00B08B10 08108112 0A308BE0
         011AA003 5330EBE7 0500A0E1 013063E0
         B0A008E3 0310A0E1 04308DE5 640000EB
         010070E3 041099E5 04309D15 00206B10
         00009DE5 0120A003 0030A003 08B086E5
         02208310 011083E0 01208213 000050E3
         00A048E3 04208BE5 041089E5 0F00000A
         0F0057E3 0130A093 04308B95 46FFFF9A
         042098E5 0C3047E2 0730C3E3 05C0A0E3
         0F0053E3 030088E0 012002E2 023083E1
         043088E5 04C080E5 08C080E5 2E00008A
         2C2099E5 B03008E3 003048E3 088096E5
         020051E1 302099E5 2C108385 B03008E3
         003048E3 020051E1 30108385 043098E5
         0330C3E3 24FFFFEA 550F51E3 0A00008A
         A417A0E1 77C081E2 8C00A0E1 7AFEFFEA
         042098E5 4E01A0E1 01E0A0E3 0C90A0E1
         1E2082E1 042088E5 62FFFFEA 543500E3
         030051E1 2419A091 FC00A083 7EC0A083
         7CC08192 8C00A091 6BFEFFEA 088096E5
         043098E5 0330C3E3 0BFFFFEA 53C0EBE7
         00005CE3 9FFFFF1A 080090E5 07208AE0
         013082E3 043080E5 D0FFFFEA 081088E2
         0500A0E1 E40100EB 04109AE5 CBFFFFEA
         550F50E3 A207A091 77E08092 8E00A091
         35FFFF9A 54C500E3 0C0050E1 2209A091
         FC00A083 7EE0A083 7CE08092 8E00A091
         2DFFFFEA 043096E5 71FFFFEA 1EFF2FE1
         1EFF2FE1 70402DE9 E44008E3 0030A0E3
         0050A0E1 004048E3 0100A0E1 003084E5
         54FCFFEB 010070E3 7080BD18 003094E5
         000053E3 00308515 7080BDE8 10402DE9
         0140A0E1 FE10D1E1 7C0200EB 000050E3
         503094A5 BC30D4B1 003083A0 013AC3B3
         503084A5 BC30C4B1 1080BDE8 0000A0E3
         1EFF2FE1 F0412DE9 0260A0E1 BC20D1E1
         0140A0E1 0370A0E1 0050A0E1 010C12E3
         0400000A 0020A0E3 0230A0E3 FE10D1E1
         550200EB BC20D4E1 012AC2E3 0730A0E1
         BC20C4E1 0500A0E1 0620A0E1 FE10D4E1
         F041BDE8 510000EA 10402DE9 0140A0E1
         FE10D1E1 480200EB BC30D4E1 010070E3
         50008415 013AC303 013A8313 BC30C4E1
         1080BDE8 FE10D1E1 550000EA 00000000
         90F800F0 6DE90245 20F00701 6FF0000C
         10F00704 91F820F0 40F04980 4FF00004
         6FF00700 D1E90023 91F840F0 00F10800
         82FA4CF2 A4FA8CF2 83FA4CF3 A2FA8CF3
         4BBBD1E9 022382FA 4CF200F1 0800A4FA
         8CF283FA 4CF3A2FA 8CF3E3B9 D1E90423
         82FA4CF2 00F10800 A4FA8CF2 83FA4CF3
         A2FA8CF3 7BB9D1E9 062301F1 200182FA
         4CF200F1 0800A4FA 8CF283FA 4CF3A2FA
         8CF3002B C6D0002A 04BF0430 1A4612BA
         B2FA82F2 FDE80245 00EBD200 7047D1E9
         002304F0 0305C4F1 00004FEA C50514F0
         040F91F8 40F00CFA 05F562EA 05021CBF
         63EA0503 62464FF0 0004A9E7 AFF30080
         AFF30080 AFF30080 AFF30080 AFF30080
         70402DE9 01C0A0E1 E44008E3 0210A0E1
         0050A0E1 0320A0E1 0C00A0E1 0030A0E3
         004048E3 003084E5 20FBFFEB 010070E3
         7080BD18 003094E5 000053E3 00308515
         7080BDE8 70402DE9 E44008E3 0030A0E3
         AAFBFFEB 010070E3 7080BD18 003094E5
         000053E3 00308515 7080BDE8 000051E3
         3800000A 000050E3 70402DE9 0060A0E1
         0140A0E1 0200000A 383090E5 000053E3
         2A00000A FC30D4E1 000053E3 0100001A
         0000A0E3 7080BDE8 0410A0E1 0600A0E1
         2F0000EB 2C3094E5 0050A0E1 000053E3
         0400000A 1C1094E5 0600A0E1 33FF2FE1
         000050E3 0050E0B3 BC30D4E1 800013E3
         1800001A 301094E5 000051E3 0600000A
         403084E2 030051E1 0100000A 0600A0E1
         090100EB 0030A0E3 303084E5 441094E5
         000051E3 0300000A 0600A0E1 020100EB
         0030A0E3 443084E5 FAFCFFEB 0030A0E3
         BC30C4E1 F8FCFFEB 0500A0E1 7080BDE8
         F0FCFFEB D2FFFFEA 101094E5 0600A0E1
         F50000EB E2FFFFEA 0000A0E3 1EFF2FE1
         183602E3 0010A0E1 003048E3 000093E5
         BDFFFFEA BC30D1E1 F0412DE9 0150A0E1
         0080A0E1 7320FFE6 080012E3 3400001A
         042091E5 023B83E3 BC30C1E1 000052E3
         4D0000DA 286095E5 000056E3 4D00000A
         7330FFE6 0020A0E3 007098E5 010A03E2
         002088E5 7040FFE6 020054E1 5F00000A
         502095E5 040013E3 0500000A 301095E5
         043095E5 000051E3 022063E0 3C309515
         02206310 0030A0E3 1C1095E5 0800A0E1
         36FF2FE1 010070E3 3800000A BC10D5E1
         FF370FE3 102095E5 00C0A0E3 04C085E5
         013003E0 010A13E3 BC30C5E1 002085E5
         4400001A 301095E5 007088E5 000051E3
         2800000A 403085E2 030051E1 0100000A
         0800A0E1 B40000EB 0000A0E3 300085E5
         F081BDE8 106091E5 000056E3 1D00000A
         004091E5 030012E3 14309105 0030A013
         006081E5 044066E0 000054E3 083081E5
         020000CA 130000EA 000054E3 110000DA
         0430A0E1 0620A0E1 247095E5 0800A0E1
         1C1095E5 37FF2FE1 000050E3 044060E0
         006086E0 F3FFFFCA BC30D5E1 0000E0E3
         403083E3 BC30C5E1 F081BDE8 3C2091E5
         000052E3 AEFFFFCA 0000A0E3 F081BDE8
         001098E5 112F6FE1 A222A0E1 1D0051E3
         0230A011 01308203 160051E3 01308303
         000053E3 2100000A BCC0D5E1 FF370FE3
         101095E5 00E0A0E3 04E085E5 0C3003E0
         010A13E3 BC30C5E1 001085E5 BCFFFF0A
         000052E3 BAFFFF0A 500085E5 B8FFFFEA
         0420A0E1 0130A0E3 1C1095E5 0800A0E1
         36FF2FE1 010070E3 0020A0E1 0200000A
         BC30D5E1 286095E5 95FFFFEA 003098E5
         000053E3 F9FFFF0A 1D0053E3 16005313
         CCFFFF1A 007088E5 0400A0E1 F081BDE8
         BC30D5E1 403083E3 BC30C5E1 F081BDE8
         10402DE9 004050E2 08D04DE2 0200000A
         383094E5 000053E3 0800000A FC00D1E1
         000050E3 0100001A 08D08DE2 1080BDE8
         0400A0E1 08D08DE2 1040BDE8 60FFFFEA
         04108DE5 43FCFFEB 04109DE5 F2FFFFEA
         001050E2 0300000A 183602E3 003048E3
         000093E5 E5FFFFEA F43402E3 401002E3
         003048E3 001048E3 000093E5 67FCFFEA
         F0412DE9 487A02E3 007048E3 0140A0E1
         0060A0E1 64FEFFEB 083097E5 045093E5
         0350C5E3 051064E0 FE1E81E2 0F1081E2
         FF1EC1E3 0F10C1E3 014A41E2 010A54E3
         060000BA 0010A0E3 0600A0E1 58FEFFEB
         083097E5 053083E0 030050E1 0300000A
         0600A0E1 51FEFFEB 0000A0E3 F081BDE8
         001064E2 0600A0E1 4DFEFFEB 010070E3
         0C00000A B43008E3 082097E5 003048E3
         055064E0 001093E5 015085E3 0600A0E1
         045082E5 011064E0 001083E5 3FFEFFEB
         0100A0E3 F081BDE8 0010A0E3 0600A0E1
         3BFEFFEB 082097E5 003062E0 0F0053E3
         E2FFFFDA 50CE02E3 B41008E3 00C048E3
         013083E3 00C09CE5 001048E3 043082E5
         00006CE0 000081E5 D8FFFFEA 000051E3
         1EFF2F01 70402DE9 0140A0E1 0050A0E1
         25FEFFEB 040014E5 483A02E3 003048E3
         08C044E2 086093E5 0120C0E3 02E08CE0
         04109EE5 0E0056E1 0310C1E3 4B00000A
         010010E3 04108EE5 0900001A 080014E5
         084083E2 0CC060E0 002082E0 08009CE5
         040050E1 5900000A 0C409CE5 0C4080E5
         080084E5 01008EE0 040090E5 010010E3
         0B00001A 1C029FE5 012082E0 08109EE5
         000051E1 6F00000A 0CE09EE5 010082E3
         0CE081E5 08108EE5 04008CE5 02208CE7
         020000EA 011082E3 04108CE5 02208CE7
         020C52E3 0E00002A A221A0E1 040093E5
         0140A0E3 821183E0 4221A0E1 08E091E5
         142280E1 0C108CE5 042083E5 08E08CE5
         08C081E5 0CC08EE5 0500A0E1 7040BDE8
         EAFDFFEA A214A0E1 040051E3 4000008A
         2213A0E1 381081E2 8100A0E1 000183E0
         48EA02E3 00E048E3 083090E5 000053E1
         4100000A 041093E5 0310C1E3 020051E1
         0200009A 083093E5 030050E1 F8FFFF1A
         0C2093E5 0C208CE5 0500A0E1 08308CE5
         7040BDE8 08C082E5 0CC083E5 CFFDFFEA
         010010E3 022081E0 0600001A 081014E5
         0CC061E0 012082E0 08009CE5 0C109CE5
         0C1080E5 080081E5 540E02E3 011082E3
         000048E3 04108CE5 001090E5 08C083E5
         010052E1 CFFFFF3A B03008E3 0500A0E1
         003048E3 001093E5 4CFFFFEB C9FFFFEA
         01308EE0 043093E5 010013E3 0800001A
         0C309EE5 012082E0 08109EE5 010082E3
         0C3081E5 081083E5 04008CE5 02208CE7
         BCFFFFEA 013082E3 04308CE5 02208CE7
         B8FFFFEA 140051E3 5B108192 8100A091
         BDFFFF9A 540051E3 1100008A 2216A0E1
         6E1081E2 8100A0E1 B7FFFFEA 04009EE5
         4111A0E1 0140A0E3 0320A0E1 141180E1
         04108EE5 BEFFFFEA 010082E3 14C083E5
         10C083E5 0C108CE5 03008CE9 02208CE7
         A0FFFFEA 550F51E3 A217A091 77108192
         8100A091 A4FFFF9A 540500E3 000051E1
         2219A091 FC00A083 7E10A083 7C108192
         8100A091 9CFFFFEA 502A0080 70402DE9
         01C0A0E1 E44008E3 0210A0E1 0050A0E1
         0320A0E1 0C00A0E1 0030A0E3 004048E3
         003084E5 0EF9FFEB 010070E3 7080BD18
         003094E5 000053E3 00308515 7080BDE8
         004048E3 003084E5 88F8FFEB 010070E3
         7080BDE8 20260080 3A747400 43000000
         30DCFF7F 01000000 00000000 00000000
         00000000 00000000 20260080 00000000
         00000000 0C290080 74290080 DC290080
         00000000 FC240080 00000000 00000000
         00000000 00000000 01000000 00000000
         0E33CDAB 34126DE6 ECDE0500 0B000000
         482A0080 482A0080 502A0080 502A0080
         582A0080 582A0080 602A0080 602A0080
         682A0080 682A0080 702A0080 702A0080
         782A0080 782A0080 802A0080 802A0080
         882A0080 882A0080 902A0080 902A0080
         982A0080 982A0080 A02A0080 A02A0080
         A82A0080 A82A0080 B02A0080 B02A0080
         B82A0080 B82A0080 C02A0080 C02A0080
         C82A0080 C82A0080 D02A0080 D02A0080
         D82A0080 D82A0080 E02A0080 E02A0080
         E82A0080 E82A0080 F02A0080 F02A0080
         F82A0080 F82A0080 002B0080 002B0080
         082B0080 082B0080 102B0080 102B0080
         182B0080 182B0080 202B0080 202B0080
         282B0080 282B0080 302B0080 302B0080
         382B0080 382B0080 402B0080 402B0080
         482B0080 482B0080 502B0080 502B0080
         582B0080 582B0080 602B0080 602B0080
         682B0080 682B0080 702B0080 702B0080
         782B0080 782B0080 802B0080 802B0080
         882B0080 882B0080 902B0080 902B0080
         982B0080 982B0080 A02B0080 A02B0080
         A82B0080 A82B0080 B02B0080 B02B0080
         B82B0080 B82B0080 C02B0080 C02B0080
         C82B0080 C82B0080 D02B0080 D02B0080
         D82B0080 D82B0080 E02B0080 E02B0080
         E82B0080 E82B0080 F02B0080 F02B0080
         F82B0080 F82B0080 002C0080 002C0080
         082C0080 082C0080 102C0080 102C0080
         182C0080 182C0080 202C0080 202C0080
         282C0080 282C0080 302C0080 302C0080
         382C0080 382C0080 402C0080 402C0080
         482C0080 482C0080 502C0080 502C0080
         582C0080 582C0080 602C0080 602C0080
         682C0080 682C0080 702C0080 702C0080
         782C0080 782C0080 802C0080 802C0080
         882C0080 882C0080 902C0080 902C0080
         982C0080 982C0080 A02C0080 A02C0080
         A82C0080 A82C0080 B02C0080 B02C0080
         B82C0080 B82C0080 C02C0080 C02C0080
         C82C0080 C82C0080 D02C0080 D02C0080
         D82C0080 D82C0080 E02C0080 E02C0080
         E82C0080 E82C0080 F02C0080 F02C0080
         F82C0080 F82C0080 002D0080 002D0080
         082D0080 082D0080 102D0080 102D0080
         182D0080 182D0080 202D0080 202D0080
         282D0080 282D0080 302D0080 302D0080
         382D0080 382D0080 402D0080 402D0080
         482D0080 482D0080 502D0080 502D0080
         582D0080 582D0080 602D0080 602D0080
         682D0080 682D0080 702D0080 702D0080
         782D0080 782D0080 802D0080 802D0080
         882D0080 882D0080 902D0080 902D0080
         982D0080 982D0080 A02D0080 A02D0080
         A82D0080 A82D0080 B02D0080 B02D0080
         B82D0080 B82D0080 C02D0080 C02D0080
         C82D0080 C82D0080 D02D0080 D02D0080
         D82D0080 D82D0080 E02D0080 E02D0080
         E82D0080 E82D0080 F02D0080 F02D0080
         F82D0080 F82D0080 002E0080 002E0080
         082E0080 082E0080 102E0080 102E0080
         182E0080 182E0080 202E0080 202E0080
         282E0080 282E0080 302E0080 302E0080
         382E0080 382E0080 402E0080 402E0080
         FFFFFFFF 00000200 00000000 00000000
         0E1C0100 0E1C1100 0E1C2100 0E1C3100
         0E1C4100 0E1C5100 0E1C6100 0E1C7100
         0E1C8100 0E1C9100 0E1CA100 0E1CB100
         0E1CC100 0E1CD100 0E1CE100 0E1CF100
         022C0001 022C1001 022C2001 022C3001
         022C4001 022C5001 022C6001 022C7001
         022C8001 022C9001 022CA001 022CB001
         022CC001 022CD001 022CE001 022CF001
         022C0002 022C1002 022C2002 022C3002
         022C4002 022C5002 022C6002 022C7002
         022C8002 022C9002 022CA002 022CB002
         022CC002 022CD002 022CE002 022CF002
         022C0003 022C1003 022C2003 022C3003
         022C4003 022C5003 022C6003 022C7003
         022C8003 022C9003 022CA003 022CB003
         022CC003 022CD003 022CE003 022CF003
         022C0004 022C1004 022C2004 022C3004
         022C4004 022C5004 022C6004 022C7004
         022C8004 022C9004 022CA004 022CB004
         022CC004 022CD004 022CE004 022CF004
         022C0005 022C1005 022C2005 022C3005
         022C4005 022C5005 022C6005 022C7005
         022C8005 022C9005 022CA005 022CB005
         022CC005 022CD005 022CE005 022CF005
         022C0006 022C1006 022C2006 022C3006
         022C4006 022C5006 022C6006 022C7006
         022C8006 022C9006 022CA006 022CB006
         022CC006 022CD006 022CE006 022CF006
         022C0007 022C1007 022C2007 022C3007
         022C4007 022C5007 022C6007 022C7007
         022C8007 022C9007 022CA007 022CB007
         022CC007 022CD007 022CE007 022CF007
         022C0008 022C1008 022C2008 022C3008
         022C4008 022C5008 022C6008 022C7008
         022C8008 022C9008 022CA008 022CB008
         022CC008 022CD008 022CE008 022CF008
         022C0009 022C1009 022C2009 022C3009
         022C4009 022C5009 022C6009 022C7009
         022C8009 022C9009 022CA009 022CB009
         022CC009 022CD009 022CE009 022CF009
         022C000A 022C100A 022C200A 022C300A
         022C400A 022C500A 022C600A 022C700A
         022C800A 022C900A 022CA00A 022CB00A
         022CC00A 022CD00A 022CE00A 022CF00A
         022C000B 022C100B 022C200B 022C300B
         022C400B 022C500B 022C600B 022C700B
         022C800B 022C900B 022CA00B 022CB00B
         022CC00B 022CD00B 022CE00B 022CF00B
         022C000C 022C100C 022C200C 022C300C
         022C400C 022C500C 022C600C 022C700C
         022C800C 022C900C 022CA00C 022CB00C
         022CC00C 022CD00C 022CE00C 022CF00C
         022C000D 022C100D 022C200D 022C300D
         022C400D 022C500D 022C600D 022C700D
         022C800D 022C900D 022CA00D 022CB00D
         022CC00D 022CD00D 022CE00D 022CF00D
         022C000E 022C100E 022C200E 022C300E
         022C400E 022C500E 022C600E 022C700E
         022C800E 022C900E 022CA00E 022CB00E
         022CC00E 022CD00E 022CE00E 022CF00E
         022C000F 022C100F 022C200F 022C300F
         022C400F 022C500F 022C600F 022C700F
         022C800F 022C900F 022CA00F 022CB00F
         022CC00F 022CD00F 022CE00F 022CF00F
         0E1C0110 0E1C1110 0E1C2110 0E1C3110
         0E1C4110 0E1C5110 0E1C6110 0E1C7110
         0E1C8110 0E1C9110 0E1CA110 0E1CB110
         0E1CC110 0E1CD110 0E1CE110 0E1CF110
         0E1C0111 0E1C1111 0E1C2111 0E1C3111
         0E1C4111 0E1C5111 0E1C6111 0E1C7111
         0E1C8111 0E1C9111 0E1CA111 0E1CB111
         0E1CC111 0E1CD111 0E1CE111 0E1CF111
         0E1C0112 0E1C1112 0E1C2112 0E1C3112
         0E1C4112 0E1C5112 0E1C6112 0E1C7112
         0E1C8112 0E1C9112 0E1CA112 0E1CB112
         0E1CC112 0E1CD112 0E1CE112 0E1CF112
         0E1C0113 0E1C1113 0E1C2113 0E1C3113
         0E1C4113 0E1C5113 0E1C6113 0E1C7113
         0E1C8113 0E1C9113 0E1CA113 0E1CB113
         0E1CC113 0E1CD113 0E1CE113 0E1CF113
         0E1C0114 0E1C1114 0E1C2114 0E1C3114
         0E1C4114 0E1C5114 0E1C6114 0E1C7114
         0E1C8114 0E1C9114 0E1CA114 0E1CB114
         0E1CC114 0E1CD114 0E1CE114 0E1CF114
         0E1C0115 0E1C1115 0E1C2115 0E1C3115
         0E1C4115 0E1C5115 0E1C6115 0E1C7115
         0E1C8115 0E1C9115 0E1CA115 0E1CB115
         0E1CC115 0E1CD115 0E1CE115 0E1CF115
         0E1C0116 0E1C1116 0E1C2116 0E1C3116
         0E1C4116 0E1C5116 0E1C6116 0E1C7116
         0E1C8116 0E1C9116 0E1CA116 0E1CB116
         0E1CC116 0E1CD116 0E1CE116 0E1CF116
         0E1C0117 0E1C1117 0E1C2117 0E1C3117
         0E1C4117 0E1C5117 0E1C6117 0E1C7117
         0E1C8117 0E1C9117 0E1CA117 0E1CB117
         0E1CC117 0E1CD117 0E1CE117 0E1CF117
         0E1C0118 0E1C1118 0E1C2118 0E1C3118
         0E1C4118 0E1C5118 0E1C6118 0E1C7118
         0E1C8118 0E1C9118 0E1CA118 0E1CB118
         0E1CC118 0E1CD118 0E1CE118 0E1CF118
         0E1C0119 0E1C1119 0E1C2119 0E1C3119
         0E1C4119 0E1C5119 0E1C6119 0E1C7119
         0E1C8119 0E1C9119 0E1CA119 0E1CB119
         0E1CC119 0E1CD119 0E1CE119 0E1CF119
         0E1C011A 0E1C111A 0E1C211A 0E1C311A
         0E1C411A 0E1C511A 0E1C611A 0E1C711A
         0E1C811A 0E1C911A 0E1CA11A 0E1CB11A
         0E1CC11A 0E1CD11A 0E1CE11A 0E1CF11A
         0E1C011B 0E1C111B 0E1C211B 0E1C311B
         0E1C411B 0E1C511B 0E1C611B 0E1C711B
         0E1C811B 0E1C911B 0E1CA11B 0E1CB11B
         0E1CC11B 0E1CD11B 0E1CE11B 0E1CF11B
         0E1C011C 0E1C111C 0E1C211C 0E1C311C
         0E1C411C 0E1C511C 0E1C611C 0E1C711C
         0E1C811C 0E1C911C 0E1CA11C 0E1CB11C
         0E1CC11C 0E1CD11C 0E1CE11C 0E1CF11C
         0E1C011D 0E1C111D 0E1C211D 0E1C311D
         0E1C411D 0E1C511D 0E1C611D 0E1C711D
         0E1C811D 0E1C911D 0E1CA11D 0E1CB11D
         0E1CC11D 0E1CD11D 0E1CE11D 0E1CF11D
         0E1C011E 0E1C111E 0E1C211E 0E1C311E
         0E1C411E 0E1C511E 0E1C611E 0E1C711E
         0E1C811E 0E1C911E 0E1CA11E 0E1CB11E
         0E1CC11E 0E1CD11E 0E1CE11E 0E1CF11E
         0E1C011F 0E1C111F 0E1C211F 0E1C311F
         0E1C411F 0E1C511F 0E1C611F 0E1C711F
         0E1C811F 0E1C911F 0E1CA11F 0E1CB11F
         0E1CC11F 0E1CD11F 0E1CE11F 0E1CF11F
         0E1C0120 0E1C1120 0E1C2120 0E1C3120
         0E1C4120 0E1C5120 0E1C6120 0E1C7120
         0E1C8120 0E1C9120 0E1CA120 0E1CB120
         0E1CC120 0E1CD120 0E1CE120 0E1CF120
         0E1C0121 0E1C1121 0E1C2121 0E1C3121
         0E1C4121 0E1C5121 0E1C6121 0E1C7121
         0E1C8121 0E1C9121 0E1CA121 0E1CB121
         0E1CC121 0E1CD121 0E1CE121 0E1CF121
         0E1C0122 0E1C1122 0E1C2122 0E1C3122
         0E1C4122 0E1C5122 0E1C6122 0E1C7122
         0E1C8122 0E1C9122 0E1CA122 0E1CB122
         0E1CC122 0E1CD122 0E1CE122 0E1CF122
         0E1C0123 0E1C1123 0E1C2123 0E1C3123
         0E1C4123 0E1C5123 0E1C6123 0E1C7123
         0E1C8123 0E1C9123 0E1CA123 0E1CB123
         0E1CC123 0E1CD123 0E1CE123 0E1CF123
         0E1C0124 0E1C1124 0E1C2124 0E1C3124
         0E1C4124 0E1C5124 0E1C6124 0E1C7124
         0E1C8124 0E1C9124 0E1CA124 0E1CB124
         0E1CC124 0E1CD124 0E1CE124 0E1CF124
         0E1C0125 0E1C1125 0E1C2125 0E1C3125
         0E1C4125 0E1C5125 0E1C6125 0E1C7125
         0E1C8125 0E1C9125 0E1CA125 0E1CB125
         0E1CC125 0E1CD125 0E1CE125 0E1CF125
         0E1C0126 0E1C1126 0E1C2126 0E1C3126
         0E1C4126 0E1C5126 0E1C6126 0E1C7126
         0E1C8126 0E1C9126 0E1CA126 0E1CB126
         0E1CC126 0E1CD126 0E1CE126 0E1CF126
         0E1C0127 0E1C1127 0E1C2127 0E1C3127
         0E1C4127 0E1C5127 0E1C6127 0E1C7127
         0E1C8127 0E1C9127 0E1CA127 0E1CB127
         0E1CC127 0E1CD127 0E1CE127 0E1CF127
         0E1C0128 0E1C1128 0E1C2128 0E1C3128
         0E1C4128 0E1C5128 0E1C6128 0E1C7128
         0E1C8128 0E1C9128 0E1CA128 0E1CB128
         0E1CC128 0E1CD128 0E1CE128 0E1CF128
         0E1C0129 0E1C1129 0E1C2129 0E1C3129
         0E1C4129 0E1C5129 0E1C6129 0E1C7129
         0E1C8129 0E1C9129 0E1CA129 0E1CB129
         0E1CC129 0E1CD129 0E1CE129 0E1CF129
         0E1C012A 0E1C112A 0E1C212A 0E1C312A
         0E1C412A 0E1C512A 0E1C612A 0E1C712A
         0E1C812A 0E1C912A 0E1CA12A 0E1CB12A
         0E1CC12A 0E1CD12A 0E1CE12A 0E1CF12A
         0E1C012B 0E1C112B 0E1C212B 0E1C312B
         0E1C412B 0E1C512B 0E1C612B 0E1C712B
         0E1C812B 0E1C912B 0E1CA12B 0E1CB12B
         0E1CC12B 0E1CD12B 0E1CE12B 0E1CF12B
         0E1C012C 0E1C112C 0E1C212C 0E1C312C
         0E1C412C 0E1C512C 0E1C612C 0E1C712C
         0E1C812C 0E1C912C 0E1CA12C 0E1CB12C
         0E1CC12C 0E1CD12C 0E1CE12C 0E1CF12C
         0E1C012D 0E1C112D 0E1C212D 0E1C312D
         0E1C412D 0E1C512D 0E1C612D 0E1C712D
         0E1C812D 0E1C912D 0E1CA12D 0E1CB12D
         0E1CC12D 0E1CD12D 0E1CE12D 0E1CF12D
         0E1C012E 0E1C112E 0E1C212E 0E1C312E
         0E1C412E 0E1C512E 0E1C612E 0E1C712E
         0E1C812E 0E1C912E 0E1CA12E 0E1CB12E
         0E1CC12E 0E1CD12E 0E1CE12E 0E1CF12E
         0E1C012F 0E1C112F 0E1C212F 0E1C312F
         0E1C412F 0E1C512F 0E1C612F 0E1C712F
         0E1C812F 0E1C912F 0E1CA12F 0E1CB12F
         0E1CC12F 0E1CD12F 0E1CE12F 0E1CF12F
         0E1C0130 0E1C1130 0E1C2130 0E1C3130
         0E1C4130 0E1C5130 0E1C6130 0E1C7130
         0E1C8130 0E1C9130 0E1CA130 0E1CB130
         0E1CC130 0E1CD130 0E1CE130 0E1CF130
         0E1C0131 0E1C1131 0E1C2131 0E1C3131
         0E1C4131 0E1C5131 0E1C6131 0E1C7131
         0E1C8131 0E1C9131 0E1CA131 0E1CB131
         0E1CC131 0E1CD131 0E1CE131 0E1CF131
         0E1C0132 0E1C1132 0E1C2132 0E1C3132
         0E1C4132 0E1C5132 0E1C6132 0E1C7132
         0E1C8132 0E1C9132 0E1CA132 0E1CB132
         0E1CC132 0E1CD132 0E1CE132 0E1CF132
         0E1C0133 0E1C1133 0E1C2133 0E1C3133
         0E1C4133 0E1C5133 0E1C6133 0E1C7133
         0E1C8133 0E1C9133 0E1CA133 0E1CB133
         0E1CC133 0E1CD133 0E1CE133 0E1CF133
         0E1C0134 0E1C1134 0E1C2134 0E1C3134
         0E1C4134 0E1C5134 0E1C6134 0E1C7134
         0E1C8134 0E1C9134 0E1CA134 0E1CB134
         0E1CC134 0E1CD134 0E1CE134 0E1CF134
         0E1C0135 0E1C1135 0E1C2135 0E1C3135
         0E1C4135 0E1C5135 0E1C6135 0E1C7135
         0E1C8135 0E1C9135 0E1CA135 0E1CB135
         0E1CC135 0E1CD135 0E1CE135 0E1CF135
         0E1C0136 0E1C1136 0E1C2136 0E1C3136
         0E1C4136 0E1C5136 0E1C6136 0E1C7136
         0E1C8136 0E1C9136 0E1CA136 0E1CB136
         0E1CC136 0E1CD136 0E1CE136 0E1CF136
         0E1C0137 0E1C1137 0E1C2137 0E1C3137
         0E1C4137 0E1C5137 0E1C6137 0E1C7137
         0E1C8137 0E1C9137 0E1CA137 0E1CB137
         0E1CC137 0E1CD137 0E1CE137 0E1CF137
         0E1C0138 0E1C1138 0E1C2138 0E1C3138
         0E1C4138 0E1C5138 0E1C6138 0E1C7138
         0E1C8138 0E1C9138 0E1CA138 0E1CB138
         0E1CC138 0E1CD138 0E1CE138 0E1CF138
         0E1C0139 0E1C1139 0E1C2139 0E1C3139
         0E1C4139 0E1C5139 0E1C6139 0E1C7139
         0E1C8139 0E1C9139 0E1CA139 0E1CB139
         0E1CC139 0E1CD139 0E1CE139 0E1CF139
         0E1C013A 0E1C113A 0E1C213A 0E1C313A
         0E1C413A 0E1C513A 0E1C613A 0E1C713A
         0E1C813A 0E1C913A 0E1CA13A 0E1CB13A
         0E1CC13A 0E1CD13A 0E1CE13A 0E1CF13A
         0E1C013B 0E1C113B 0E1C213B 0E1C313B
         0E1C413B 0E1C513B 0E1C613B 0E1C713B
         0E1C813B 0E1C913B 0E1CA13B 0E1CB13B
         0E1CC13B 0E1CD13B 0E1CE13B 0E1CF13B
         0E1C013C 0E1C113C 0E1C213C 0E1C313C
         0E1C413C 0E1C513C 0E1C613C 0E1C713C
         0E1C813C 0E1C913C 0E1CA13C 0E1CB13C
         0E1CC13C 0E1CD13C 0E1CE13C 0E1CF13C
         0E1C013D 0E1C113D 0E1C213D 0E1C313D
         0E1C413D 0E1C513D 0E1C613D 0E1C713D
         0E1C813D 0E1C913D 0E1CA13D 0E1CB13D
         0E1CC13D 0E1CD13D 0E1CE13D 0E1CF13D
         0E1C013E 0E1C113E 0E1C213E 0E1C313E
         0E1C413E 0E1C513E 0E1C613E 0E1C713E
         0E1C813E 0E1C913E 0E1CA13E 0E1CB13E
         0E1CC13E 0E1CD13E 0E1CE13E 0E1CF13E
         0E1C013F 0E1C113F 0E1C213F 0E1C313F
         0E1C413F 0E1C513F 0E1C613F 0E1C713F
         0E1C813F 0E1C913F 0E1CA13F 0E1CB13F
         0E1CC13F 0E1CD13F 0E1CE13F 0E1CF13F
         022C0040 022C1040 022C2040 022C3040
         022C4040 022C5040 022C6040 022C7040
         022C8040 022C9040 022CA040 022CB040
         022CC040 022CD040 022CE040 022CF040
         022C0041 022C1041 022C2041 022C3041
         022C4041 022C5041 022C6041 022C7041
         022C8041 022C9041 022CA041 022CB041
         022CC041 022CD041 022CE041 022CF041
         022C0042 022C1042 022C2042 022C3042
         022C4042 022C5042 022C6042 022C7042
         022C8042 022C9042 022CA042 022CB042
         022CC042 022CD042 022CE042 022CF042
         022C0043 022C1043 022C2043 022C3043
         022C4043 022C5043 022C6043 022C7043
         022C8043 022C9043 022CA043 022CB043
         022CC043 022CD043 022CE043 022CF043
         022C0044 022C1044 022C2044 022C3044
         022C4044 022C5044 022C6044 022C7044
         022C8044 022C9044 022CA044 022CB044
         022CC044 022CD044 022CE044 022CF044
         022C0045 022C1045 022C2045 022C3045
         022C4045 022C5045 022C6045 022C7045
         022C8045 022C9045 022CA045 022CB045
         022CC045 022CD045 022CE045 022CF045
         022C0046 022C1046 022C2046 022C3046
         022C4046 022C5046 022C6046 022C7046
         022C8046 022C9046 022CA046 022CB046
         022CC046 022CD046 022CE046 022CF046
         022C0047 022C1047 022C2047 022C3047
         022C4047 022C5047 022C6047 022C7047
         022C8047 022C9047 022CA047 022CB047
         022CC047 022CD047 022CE047 022CF047
         022C0048 022C1048 022C2048 022C3048
         022C4048 022C5048 022C6048 022C7048
         022C8048 022C9048 022CA048 022CB048
         022CC048 022CD048 022CE048 022CF048
         022C0049 022C1049 022C2049 022C3049
         022C4049 022C5049 022C6049 022C7049
         022C8049 022C9049 022CA049 022CB049
         022CC049 022CD049 022CE049 022CF049
         022C004A 022C104A 022C204A 022C304A
         022C404A 022C504A 022C604A 022C704A
         022C804A 022C904A 022CA04A 022CB04A
         022CC04A 022CD04A 022CE04A 022CF04A
         022C004B 022C104B 022C204B 022C304B
         022C404B 022C504B 022C604B 022C704B
         022C804B 022C904B 022CA04B 022CB04B
         022CC04B 022CD04B 022CE04B 022CF04B
         022C004C 022C104C 022C204C 022C304C
         022C404C 022C504C 022C604C 022C704C
         022C804C 022C904C 022CA04C 022CB04C
         022CC04C 022CD04C 022CE04C 022CF04C
         022C004D 022C104D 022C204D 022C304D
         022C404D 022C504D 022C604D 022C704D
         022C804D 022C904D 022CA04D 022CB04D
         022CC04D 022CD04D 022CE04D 022CF04D
         022C004E 022C104E 022C204E 022C304E
         022C404E 022C504E 022C604E 022C704E
         022C804E 022C904E 022CA04E 022CB04E
         022CC04E 022CD04E 022CE04E 022CF04E
         022C004F 022C104F 022C204F 022C304F
         022C404F 022C504F 022C604F 022C704F
         022C804F 022C904F 022CA04F 022CB04F
         022CC04F 022CD04F 022CE04F 022CF04F
         022C0050 022C1050 022C2050 022C3050
         022C4050 022C5050 022C6050 022C7050
         022C8050 022C9050 022CA050 022CB050
         022CC050 022CD050 022CE050 022CF050
         022C0051 022C1051 022C2051 022C3051
         022C4051 022C5051 022C6051 022C7051
         022C8051 022C9051 022CA051 022CB051
         022CC051 022CD051 022CE051 022CF051
         022C0052 022C1052 022C2052 022C3052
         022C4052 022C5052 022C6052 022C7052
         022C8052 022C9052 022CA052 022CB052
         022CC052 022CD052 022CE052 022CF052
         022C0053 022C1053 022C2053 022C3053
         022C4053 022C5053 022C6053 022C7053
         022C8053 022C9053 022CA053 022CB053
         022CC053 022CD053 022CE053 022CF053
         022C0054 022C1054 022C2054 022C3054
         022C4054 022C5054 022C6054 022C7054
         022C8054 022C9054 022CA054 022CB054
         022CC054 022CD054 022CE054 022CF054
         022C0055 022C1055 022C2055 022C3055
         022C4055 022C5055 022C6055 022C7055
         022C8055 022C9055 022CA055 022CB055
         022CC055 022CD055 022CE055 022CF055
         022C0056 022C1056 022C2056 022C3056
         022C4056 022C5056 022C6056 022C7056
         022C8056 022C9056 022CA056 022CB056
         022CC056 022CD056 022CE056 022CF056
         022C0057 022C1057 022C2057 022C3057
         022C4057 022C5057 022C6057 022C7057
         022C8057 022C9057 022CA057 022CB057
         022CC057 022CD057 022CE057 022CF057
         022C0058 022C1058 022C2058 022C3058
         022C4058 022C5058 022C6058 022C7058
         022C8058 022C9058 022CA058 022CB058
         022CC058 022CD058 022CE058 022CF058
         022C0059 022C1059 022C2059 022C3059
         022C4059 022C5059 022C6059 022C7059
         022C8059 022C9059 022CA059 022CB059
         022CC059 022CD059 022CE059 022CF059
         022C005A 022C105A 022C205A 022C305A
         022C405A 022C505A 022C605A 022C705A
         022C805A 022C905A 022CA05A 022CB05A
         022CC05A 022CD05A 022CE05A 022CF05A
         022C005B 022C105B 022C205B 022C305B
         022C405B 022C505B 022C605B 022C705B
         022C805B 022C905B 022CA05B 022CB05B
         022CC05B 022CD05B 022CE05B 022CF05B
         022C005C 022C105C 022C205C 022C305C
         022C405C 022C505C 022C605C 022C705C
         022C805C 022C905C 022CA05C 022CB05C
         022CC05C 022CD05C 022CE05C 022CF05C
         022C005D 022C105D 022C205D 022C305D
         022C405D 022C505D 022C605D 022C705D
         022C805D 022C905D 022CA05D 022CB05D
         022CC05D 022CD05D 022CE05D 022CF05D
         022C005E 022C105E 022C205E 022C305E
         022C405E 022C505E 022C605E 022C705E
         022C805E 022C905E 022CA05E 022CB05E
         022CC05E 022CD05E 022CE05E 022CF05E
         022C005F 022C105F 022C205F 022C305F
         022C405F 022C505F 022C605F 022C705F
         022C805F 022C905F 022CA05F 022CB05F
         022CC05F 022CD05F 022CE05F 022CF05F
         022C0060 022C1060 022C2060 022C3060
         022C4060 022C5060 022C6060 022C7060
         022C8060 022C9060 022CA060 022CB060
         022CC060 022CD060 022CE060 022CF060
         022C0061 022C1061 022C2061 022C3061
         022C4061 022C5061 022C6061 022C7061
         022C8061 022C9061 022CA061 022CB061
         022CC061 022CD061 022CE061 022CF061
         022C0062 022C1062 022C2062 022C3062
         022C4062 022C5062 022C6062 022C7062
         022C8062 022C9062 022CA062 022CB062
         022CC062 022CD062 022CE062 022CF062
         022C0063 022C1063 022C2063 022C3063
         022C4063 022C5063 022C6063 022C7063
         022C8063 022C9063 022CA063 022CB063
         022CC063 022CD063 022CE063 022CF063
         022C0064 022C1064 022C2064 022C3064
         022C4064 022C5064 022C6064 022C7064
         022C8064 022C9064 022CA064 022CB064
         022CC064 022CD064 022CE064 022CF064
         022C0065 022C1065 022C2065 022C3065
         022C4065 022C5065 022C6065 022C7065
         022C8065 022C9065 022CA065 022CB065
         022CC065 022CD065 022CE065 022CF065
         022C0066 022C1066 022C2066 022C3066
         022C4066 022C5066 022C6066 022C7066
         022C8066 022C9066 022CA066 022CB066
         022CC066 022CD066 022CE066 022CF066
         022C0067 022C1067 022C2067 022C3067
         022C4067 022C5067 022C6067 022C7067
         022C8067 022C9067 022CA067 022CB067
         022CC067 022CD067 022CE067 022CF067
         022C0068 022C1068 022C2068 022C3068
         022C4068 022C5068 022C6068 022C7068
         022C8068 022C9068 022CA068 022CB068
         022CC068 022CD068 022CE068 022CF068
         022C0069 022C1069 022C2069 022C3069
         022C4069 022C5069 022C6069 022C7069
         022C8069 022C9069 022CA069 022CB069
         022CC069 022CD069 022CE069 022CF069
         022C006A 022C106A 022C206A 022C306A
         022C406A 022C506A 022C606A 022C706A
         022C806A 022C906A 022CA06A 022CB06A
         022CC06A 022CD06A 022CE06A 022CF06A
         022C006B 022C106B 022C206B 022C306B
         022C406B 022C506B 022C606B 022C706B
         022C806B 022C906B 022CA06B 022CB06B
         022CC06B 022CD06B 022CE06B 022CF06B
         022C006C 022C106C 022C206C 022C306C
         022C406C 022C506C 022C606C 022C706C
         022C806C 022C906C 022CA06C 022CB06C
         022CC06C 022CD06C 022CE06C 022CF06C
         022C006D 022C106D 022C206D 022C306D
         022C406D 022C506D 022C606D 022C706D
         022C806D 022C906D 022CA06D 022CB06D
         022CC06D 022CD06D 022CE06D 022CF06D
         022C006E 022C106E 022C206E 022C306E
         022C406E 022C506E 022C606E 022C706E
         022C806E 022C906E 022CA06E 022CB06E
         022CC06E 022CD06E 022CE06E 022CF06E
         022C006F 022C106F 022C206F 022C306F
         022C406F 022C506F 022C606F 022C706F
         022C806F 022C906F 022CA06F 022CB06F
         022CC06F 022CD06F 022CE06F 022CF06F
         022C0070 022C1070 022C2070 022C3070
         022C4070 022C5070 022C6070 022C7070
         022C8070 022C9070 022CA070 022CB070
         022CC070 022CD070 022CE070 022CF070
         022C0071 022C1071 022C2071 022C3071
         022C4071 022C5071 022C6071 022C7071
         022C8071 022C9071 022CA071 022CB071
         022CC071 022CD071 022CE071 022CF071
         022C0072 022C1072 022C2072 022C3072
         022C4072 022C5072 022C6072 022C7072
         022C8072 022C9072 022CA072 022CB072
         022CC072 022CD072 022CE072 022CF072
         022C0073 022C1073 022C2073 022C3073
         022C4073 022C5073 022C6073 022C7073
         022C8073 022C9073 022CA073 022CB073
         022CC073 022CD073 022CE073 022CF073
         022C0074 022C1074 022C2074 022C3074
         022C4074 022C5074 022C6074 022C7074
         022C8074 022C9074 022CA074 022CB074
         022CC074 022CD074 022CE074 022CF074
         022C0075 022C1075 022C2075 022C3075
         022C4075 022C5075 022C6075 022C7075
         022C8075 022C9075 022CA075 022CB075
         022CC075 022CD075 022CE075 022CF075
         022C0076 022C1076 022C2076 022C3076
         022C4076 022C5076 022C6076 022C7076
         022C8076 022C9076 022CA076 022CB076
         022CC076 022CD076 022CE076 022CF076
         022C0077 022C1077 022C2077 022C3077
         022C4077 022C5077 022C6077 022C7077
         022C8077 022C9077 022CA077 022CB077
         022CC077 022CD077 022CE077 022CF077
         022C0078 022C1078 022C2078 022C3078
         022C4078 022C5078 022C6078 022C7078
         022C8078 022C9078 022CA078 022CB078
         022CC078 022CD078 022CE078 022CF078
         022C0079 022C1079 022C2079 022C3079
         022C4079 022C5079 022C6079 022C7079
         022C8079 022C9079 022CA079 022CB079
         022CC079 022CD079 022CE079 022CF079
         022C007A 022C107A 022C207A 022C307A
         022C407A 022C507A 022C607A 022C707A
         022C807A 022C907A 022CA07A 022CB07A
         022CC07A 022CD07A 022CE07A 022CF07A
         022C007B 022C107B 022C207B 022C307B
         022C407B 022C507B 022C607B 022C707B
         022C807B 022C907B 022CA07B 022CB07B
         022CC07B 022CD07B 022CE07B 022CF07B
         022C007C 022C107C 022C207C 022C307C
         022C407C 022C507C 022C607C 022C707C
         022C807C 022C907C 022CA07C 022CB07C
         022CC07C 022CD07C 022CE07C 022CF07C
         022C007D 022C107D 022C207D 022C307D
         022C407D 022C507D 022C607D 022C707D
         022C807D 022C907D 022CA07D 022CB07D
         022CC07D 022CD07D 022CE07D 022CF07D
         022C007E 022C107E 022C207E 022C307E
         022C407E 022C507E 022C607E 022C707E
         022C807E 022C907E 022CA07E 022CB07E
         022CC07E 022CD07E 022CE07E 022CF07E
         022C007F 022C107F 022C207F 022C307F
         022C407F 022C507F 022C607F 022C707F
         022C807F 022C907F 022CA07F 022CB07F
         022CC07F 022CD07F 022CE07F 022CF07F
         0E1C0180 0E1C1180 0E1C2180 0E1C3180
         0E1C4180 0E1C5180 0E1C6180 0E1C7180
         0E1C8180 0E1C9180 0E1CA180 0E1CB180
         0E1CC180 0E1CD180 0E1CE180 0E1CF180
         0E1C0181 0E1C1181 0E1C2181 0E1C3181
         0E1C4181 0E1C5181 0E1C6181 0E1C7181
         0E1C8181 0E1C9181 0E1CA181 0E1CB181
         0E1CC181 0E1CD181 0E1CE181 0E1CF181
         0E1C0182 0E1C1182 0E1C2182 0E1C3182
         0E1C4182 0E1C5182 0E1C6182 0E1C7182
         0E1C8182 0E1C9182 0E1CA182 0E1CB182
         0E1CC182 0E1CD182 0E1CE182 0E1CF182
         0E1C0183 0E1C1183 0E1C2183 0E1C3183
         0E1C4183 0E1C5183 0E1C6183 0E1C7183
         0E1C8183 0E1C9183 0E1CA183 0E1CB183
         0E1CC183 0E1CD183 0E1CE183 0E1CF183
         0E1C0184 0E1C1184 0E1C2184 0E1C3184
         0E1C4184 0E1C5184 0E1C6184 0E1C7184
         0E1C8184 0E1C9184 0E1CA184 0E1CB184
         0E1CC184 0E1CD184 0E1CE184 0E1CF184
         0E1C0185 0E1C1185 0E1C2185 0E1C3185
         0E1C4185 0E1C5185 0E1C6185 0E1C7185
         0E1C8185 0E1C9185 0E1CA185 0E1CB185
         0E1CC185 0E1CD185 0E1CE185 0E1CF185
         0E1C0186 0E1C1186 0E1C2186 0E1C3186
         0E1C4186 0E1C5186 0E1C6186 0E1C7186
         0E1C8186 0E1C9186 0E1CA186 0E1CB186
         0E1CC186 0E1CD186 0E1CE186 0E1CF186
         0E1C0187 0E1C1187 0E1C2187 0E1C3187
         0E1C4187 0E1C5187 0E1C6187 0E1C7187
         0E1C8187 0E1C9187 0E1CA187 0E1CB187
         0E1CC187 0E1CD187 0E1CE187 0E1CF187
         0E1C0188 0E1C1188 0E1C2188 0E1C3188
         0E1C4188 0E1C5188 0E1C6188 0E1C7188
         0E1C8188 0E1C9188 0E1CA188 0E1CB188
         0E1CC188 0E1CD188 0E1CE188 0E1CF188
         0E1C0189 0E1C1189 0E1C2189 0E1C3189
         0E1C4189 0E1C5189 0E1C6189 0E1C7189
         0E1C8189 0E1C9189 0E1CA189 0E1CB189
         0E1CC189 0E1CD189 0E1CE189 0E1CF189
         0E1C018A 0E1C118A 0E1C218A 0E1C318A
         0E1C418A 0E1C518A 0E1C618A 0E1C718A
         0E1C818A 0E1C918A 0E1CA18A 0E1CB18A
         0E1CC18A 0E1CD18A 0E1CE18A 0E1CF18A
         0E1C018B 0E1C118B 0E1C218B 0E1C318B
         0E1C418B 0E1C518B 0E1C618B 0E1C718B
         0E1C818B 0E1C918B 0E1CA18B 0E1CB18B
         0E1CC18B 0E1CD18B 0E1CE18B 0E1CF18B
         0E1C018C 0E1C118C 0E1C218C 0E1C318C
         0E1C418C 0E1C518C 0E1C618C 0E1C718C
         0E1C818C 0E1C918C 0E1CA18C 0E1CB18C
         0E1CC18C 0E1CD18C 0E1CE18C 0E1CF18C
         0E1C018D 0E1C118D 0E1C218D 0E1C318D
         0E1C418D 0E1C518D 0E1C618D 0E1C718D
         0E1C818D 0E1C918D 0E1CA18D 0E1CB18D
         0E1CC18D 0E1CD18D 0E1CE18D 0E1CF18D
         0E1C018E 0E1C118E 0E1C218E 0E1C318E
         0E1C418E 0E1C518E 0E1C618E 0E1C718E
         0E1C818E 0E1C918E 0E1CA18E 0E1CB18E
         0E1CC18E 0E1CD18E 0E1CE18E 0E1CF18E
         0E1C018F 0E1C118F 0E1C218F 0E1C318F
         0E1C418F 0E1C518F 0E1C618F 0E1C718F
         0E1C818F 0E1C918F 0E1CA18F 0E1CB18F
         0E1CC18F 0E1CD18F 0E1CE18F 0E1CF18F
         0E1C0190 0E1C1190 0E1C2190 0E1C3190
         0E1C4190 0E1C5190 0E1C6190 0E1C7190
         0E1C8190 0E1C9190 0E1CA190 0E1CB190
         0E1CC190 0E1CD190 0E1CE190 0E1CF190
         0E1C0191 0E1C1191 0E1C2191 0E1C3191
         0E1C4191 0E1C5191 0E1C6191 0E1C7191
         0E1C8191 0E1C9191 0E1CA191 0E1CB191
         0E1CC191 0E1CD191 0E1CE191 0E1CF191
         0E1C0192 0E1C1192 0E1C2192 0E1C3192
         0E1C4192 0E1C5192 0E1C6192 0E1C7192
         0E1C8192 0E1C9192 0E1CA192 0E1CB192
         0E1CC192 0E1CD192 0E1CE192 0E1CF192
         0E1C0193 0E1C1193 0E1C2193 0E1C3193
         0E1C4193 0E1C5193 0E1C6193 0E1C7193
         0E1C8193 0E1C9193 0E1CA193 0E1CB193
         0E1CC193 0E1CD193 0E1CE193 0E1CF193
         0E1C0194 0E1C1194 0E1C2194 0E1C3194
         0E1C4194 0E1C5194 0E1C6194 0E1C7194
         0E1C8194 0E1C9194 0E1CA194 0E1CB194
         0E1CC194 0E1CD194 0E1CE194 0E1CF194
         0E1C0195 0E1C1195 0E1C2195 0E1C3195
         0E1C4195 0E1C5195 0E1C6195 0E1C7195
         0E1C8195 0E1C9195 0E1CA195 0E1CB195
         0E1CC195 0E1CD195 0E1CE195 0E1CF195
         0E1C0196 0E1C1196 0E1C2196 0E1C3196
         0E1C4196 0E1C5196 0E1C6196 0E1C7196
         0E1C8196 0E1C9196 0E1CA196 0E1CB196
         0E1CC196 0E1CD196 0E1CE196 0E1CF196
         0E1C0197 0E1C1197 0E1C2197 0E1C3197
         0E1C4197 0E1C5197 0E1C6197 0E1C7197
         0E1C8197 0E1C9197 0E1CA197 0E1CB197
         0E1CC197 0E1CD197 0E1CE197 0E1CF197
         0E1C0198 0E1C1198 0E1C2198 0E1C3198
         0E1C4198 0E1C5198 0E1C6198 0E1C7198
         0E1C8198 0E1C9198 0E1CA198 0E1CB198
         0E1CC198 0E1CD198 0E1CE198 0E1CF198
         0E1C0199 0E1C1199 0E1C2199 0E1C3199
         0E1C4199 0E1C5199 0E1C6199 0E1C7199
         0E1C8199 0E1C9199 0E1CA199 0E1CB199
         0E1CC199 0E1CD199 0E1CE199 0E1CF199
         0E1C019A 0E1C119A 0E1C219A 0E1C319A
         0E1C419A 0E1C519A 0E1C619A 0E1C719A
         0E1C819A 0E1C919A 0E1CA19A 0E1CB19A
         0E1CC19A 0E1CD19A 0E1CE19A 0E1CF19A
         0E1C019B 0E1C119B 0E1C219B 0E1C319B
         0E1C419B 0E1C519B 0E1C619B 0E1C719B
         0E1C819B 0E1C919B 0E1CA19B 0E1CB19B
         0E1CC19B 0E1CD19B 0E1CE19B 0E1CF19B
         0E1C019C 0E1C119C 0E1C219C 0E1C319C
         0E1C419C 0E1C519C 0E1C619C 0E1C719C
         0E1C819C 0E1C919C 0E1CA19C 0E1CB19C
         0E1CC19C 0E1CD19C 0E1CE19C 0E1CF19C
         0E1C019D 0E1C119D 0E1C219D 0E1C319D
         0E1C419D 0E1C519D 0E1C619D 0E1C719D
         0E1C819D 0E1C919D 0E1CA19D 0E1CB19D
         0E1CC19D 0E1CD19D 0E1CE19D 0E1CF19D
         0E1C019E 0E1C119E 0E1C219E 0E1C319E
         0E1C419E 0E1C519E 0E1C619E 0E1C719E
         0E1C819E 0E1C919E 0E1CA19E 0E1CB19E
         0E1CC19E 0E1CD19E 0E1CE19E 0E1CF19E
         0E1C019F 0E1C119F 0E1C219F 0E1C319F
         0E1C419F 0E1C519F 0E1C619F 0E1C719F
         0E1C819F 0E1C919F 0E1CA19F 0E1CB19F
         0E1CC19F 0E1CD19F 0E1CE19F 0E1CF19F
         0E1C01A0 0E1C11A0 0E1C21A0 0E1C31A0
         0E1C41A0 0E1C51A0 0E1C61A0 0E1C71A0
         0E1C81A0 0E1C91A0 0E1CA1A0 0E1CB1A0
         0E1CC1A0 0E1CD1A0 0E1CE1A0 0E1CF1A0
         0E1C01A1 0E1C11A1 0E1C21A1 0E1C31A1
         0E1C41A1 0E1C51A1 0E1C61A1 0E1C71A1
         0E1C81A1 0E1C91A1 0E1CA1A1 0E1CB1A1
         0E1CC1A1 0E1CD1A1 0E1CE1A1 0E1CF1A1
         0E1C01A2 0E1C11A2 0E1C21A2 0E1C31A2
         0E1C41A2 0E1C51A2 0E1C61A2 0E1C71A2
         0E1C81A2 0E1C91A2 0E1CA1A2 0E1CB1A2
         0E1CC1A2 0E1CD1A2 0E1CE1A2 0E1CF1A2
         0E1C01A3 0E1C11A3 0E1C21A3 0E1C31A3
         0E1C41A3 0E1C51A3 0E1C61A3 0E1C71A3
         0E1C81A3 0E1C91A3 0E1CA1A3 0E1CB1A3
         0E1CC1A3 0E1CD1A3 0E1CE1A3 0E1CF1A3
         0E1C01A4 0E1C11A4 0E1C21A4 0E1C31A4
         0E1C41A4 0E1C51A4 0E1C61A4 0E1C71A4
         0E1C81A4 0E1C91A4 0E1CA1A4 0E1CB1A4
         0E1CC1A4 0E1CD1A4 0E1CE1A4 0E1CF1A4
         0E1C01A5 0E1C11A5 0E1C21A5 0E1C31A5
         0E1C41A5 0E1C51A5 0E1C61A5 0E1C71A5
         0E1C81A5 0E1C91A5 0E1CA1A5 0E1CB1A5
         0E1CC1A5 0E1CD1A5 0E1CE1A5 0E1CF1A5
         0E1C01A6 0E1C11A6 0E1C21A6 0E1C31A6
         0E1C41A6 0E1C51A6 0E1C61A6 0E1C71A6
         0E1C81A6 0E1C91A6 0E1CA1A6 0E1CB1A6
         0E1CC1A6 0E1CD1A6 0E1CE1A6 0E1CF1A6
         0E1C01A7 0E1C11A7 0E1C21A7 0E1C31A7
         0E1C41A7 0E1C51A7 0E1C61A7 0E1C71A7
         0E1C81A7 0E1C91A7 0E1CA1A7 0E1CB1A7
         0E1CC1A7 0E1CD1A7 0E1CE1A7 0E1CF1A7
         0E1C01A8 0E1C11A8 0E1C21A8 0E1C31A8
         0E1C41A8 0E1C51A8 0E1C61A8 0E1C71A8
         0E1C81A8 0E1C91A8 0E1CA1A8 0E1CB1A8
         0E1CC1A8 0E1CD1A8 0E1CE1A8 0E1CF1A8
         0E1C01A9 0E1C11A9 0E1C21A9 0E1C31A9
         0E1C41A9 0E1C51A9 0E1C61A9 0E1C71A9
         0E1C81A9 0E1C91A9 0E1CA1A9 0E1CB1A9
         0E1CC1A9 0E1CD1A9 0E1CE1A9 0E1CF1A9
         0E1C01AA 0E1C11AA 0E1C21AA 0E1C31AA
         0E1C41AA 0E1C51AA 0E1C61AA 0E1C71AA
         0E1C81AA 0E1C91AA 0E1CA1AA 0E1CB1AA
         0E1CC1AA 0E1CD1AA 0E1CE1AA 0E1CF1AA
         0E1C01AB 0E1C11AB 0E1C21AB 0E1C31AB
         0E1C41AB 0E1C51AB 0E1C61AB 0E1C71AB
         0E1C81AB 0E1C91AB 0E1CA1AB 0E1CB1AB
         0E1CC1AB 0E1CD1AB 0E1CE1AB 0E1CF1AB
         0E1C01AC 0E1C11AC 0E1C21AC 0E1C31AC
         0E1C41AC 0E1C51AC 0E1C61AC 0E1C71AC
         0E1C81AC 0E1C91AC 0E1CA1AC 0E1CB1AC
         0E1CC1AC 0E1CD1AC 0E1CE1AC 0E1CF1AC
         0E1C01AD 0E1C11AD 0E1C21AD 0E1C31AD
         0E1C41AD 0E1C51AD 0E1C61AD 0E1C71AD
         0E1C81AD 0E1C91AD 0E1CA1AD 0E1CB1AD
         0E1CC1AD 0E1CD1AD 0E1CE1AD 0E1CF1AD
         0E1C01AE 0E1C11AE 0E1C21AE 0E1C31AE
         0E1C41AE 0E1C51AE 0E1C61AE 0E1C71AE
         0E1C81AE 0E1C91AE 0E1CA1AE 0E1CB1AE
         0E1CC1AE 0E1CD1AE 0E1CE1AE 0E1CF1AE
         0E1C01AF 0E1C11AF 0E1C21AF 0E1C31AF
         0E1C41AF 0E1C51AF 0E1C61AF 0E1C71AF
         0E1C81AF 0E1C91AF 0E1CA1AF 0E1CB1AF
         0E1CC1AF 0E1CD1AF 0E1CE1AF 0E1CF1AF
         0E1C01B0 0E1C11B0 0E1C21B0 0E1C31B0
         0E1C41B0 0E1C51B0 0E1C61B0 0E1C71B0
         0E1C81B0 0E1C91B0 0E1CA1B0 0E1CB1B0
         0E1CC1B0 0E1CD1B0 0E1CE1B0 0E1CF1B0
         0E1C01B1 0E1C11B1 0E1C21B1 0E1C31B1
         0E1C41B1 0E1C51B1 0E1C61B1 0E1C71B1
         0E1C81B1 0E1C91B1 0E1CA1B1 0E1CB1B1
         0E1CC1B1 0E1CD1B1 0E1CE1B1 0E1CF1B1
         0E1C01B2 0E1C11B2 0E1C21B2 0E1C31B2
         0E1C41B2 0E1C51B2 0E1C61B2 0E1C71B2
         0E1C81B2 0E1C91B2 0E1CA1B2 0E1CB1B2
         0E1CC1B2 0E1CD1B2 0E1CE1B2 0E1CF1B2
         0E1C01B3 0E1C11B3 0E1C21B3 0E1C31B3
         0E1C41B3 0E1C51B3 0E1C61B3 0E1C71B3
         0E1C81B3 0E1C91B3 0E1CA1B3 0E1CB1B3
         0E1CC1B3 0E1CD1B3 0E1CE1B3 0E1CF1B3
         0E1C01B4 0E1C11B4 0E1C21B4 0E1C31B4
         0E1C41B4 0E1C51B4 0E1C61B4 0E1C71B4
         0E1C81B4 0E1C91B4 0E1CA1B4 0E1CB1B4
         0E1CC1B4 0E1CD1B4 0E1CE1B4 0E1CF1B4
         0E1C01B5 0E1C11B5 0E1C21B5 0E1C31B5
         0E1C41B5 0E1C51B5 0E1C61B5 0E1C71B5
         0E1C81B5 0E1C91B5 0E1CA1B5 0E1CB1B5
         0E1CC1B5 0E1CD1B5 0E1CE1B5 0E1CF1B5
         0E1C01B6 0E1C11B6 0E1C21B6 0E1C31B6
         0E1C41B6 0E1C51B6 0E1C61B6 0E1C71B6
         0E1C81B6 0E1C91B6 0E1CA1B6 0E1CB1B6
         0E1CC1B6 0E1CD1B6 0E1CE1B6 0E1CF1B6
         0E1C01B7 0E1C11B7 0E1C21B7 0E1C31B7
         0E1C41B7 0E1C51B7 0E1C61B7 0E1C71B7
         0E1C81B7 0E1C91B7 0E1CA1B7 0E1CB1B7
         0E1CC1B7 0E1CD1B7 0E1CE1B7 0E1CF1B7
         0E1C01B8 0E1C11B8 0E1C21B8 0E1C31B8
         0E1C41B8 0E1C51B8 0E1C61B8 0E1C71B8
         0E1C81B8 0E1C91B8 0E1CA1B8 0E1CB1B8
         0E1CC1B8 0E1CD1B8 0E1CE1B8 0E1CF1B8
         0E1C01B9 0E1C11B9 0E1C21B9 0E1C31B9
         0E1C41B9 0E1C51B9 0E1C61B9 0E1C71B9
         0E1C81B9 0E1C91B9 0E1CA1B9 0E1CB1B9
         0E1CC1B9 0E1CD1B9 0E1CE1B9 0E1CF1B9
         0E1C01BA 0E1C11BA 0E1C21BA 0E1C31BA
         0E1C41BA 0E1C51BA 0E1C61BA 0E1C71BA
         0E1C81BA 0E1C91BA 0E1CA1BA 0E1CB1BA
         0E1CC1BA 0E1CD1BA 0E1CE1BA 0E1CF1BA
         0E1C01BB 0E1C11BB 0E1C21BB 0E1C31BB
         0E1C41BB 0E1C51BB 0E1C61BB 0E1C71BB
         0E1C81BB 0E1C91BB 0E1CA1BB 0E1CB1BB
         0E1CC1BB 0E1CD1BB 0E1CE1BB 0E1CF1BB
         0E1C01BC 0E1C11BC 0E1C21BC 0E1C31BC
         0E1C41BC 0E1C51BC 0E1C61BC 0E1C71BC
         0E1C81BC 0E1C91BC 0E1CA1BC 0E1CB1BC
         0E1CC1BC 0E1CD1BC 0E1CE1BC 0E1CF1BC
         0E1C01BD 0E1C11BD 0E1C21BD 0E1C31BD
         0E1C41BD 0E1C51BD 0E1C61BD 0E1C71BD
         0E1C81BD 0E1C91BD 0E1CA1BD 0E1CB1BD
         0E1CC1BD 0E1CD1BD 0E1CE1BD 0E1CF1BD
         0E1C01BE 0E1C11BE 0E1C21BE 0E1C31BE
         0E1C41BE 0E1C51BE 0E1C61BE 0E1C71BE
         0E1C81BE 0E1C91BE 0E1CA1BE 0E1CB1BE
         0E1CC1BE 0E1CD1BE 0E1CE1BE 0E1CF1BE
         0E1C01BF 0E1C11BF 0E1C21BF 0E1C31BF
         0E1C41BF 0E1C51BF 0E1C61BF 0E1C71BF
         0E1C81BF 0E1C91BF 0E1CA1BF 0E1CB1BF
         0E1CC1BF 0E1CD1BF 0E1CE1BF 0E1CF1BF
         0E1C01C0 0E1C11C0 0E1C21C0 0E1C31C0
         0E1C41C0 0E1C51C0 0E1C61C0 0E1C71C0
         0E1C81C0 0E1C91C0 0E1CA1C0 0E1CB1C0
         0E1CC1C0 0E1CD1C0 0E1CE1C0 0E1CF1C0
         0E1C01C1 0E1C11C1 0E1C21C1 0E1C31C1
         0E1C41C1 0E1C51C1 0E1C61C1 0E1C71C1
         0E1C81C1 0E1C91C1 0E1CA1C1 0E1CB1C1
         0E1CC1C1 0E1CD1C1 0E1CE1C1 0E1CF1C1
         0E1C01C2 0E1C11C2 0E1C21C2 0E1C31C2
         0E1C41C2 0E1C51C2 0E1C61C2 0E1C71C2
         0E1C81C2 0E1C91C2 0E1CA1C2 0E1CB1C2
         0E1CC1C2 0E1CD1C2 0E1CE1C2 0E1CF1C2
         0E1C01C3 0E1C11C3 0E1C21C3 0E1C31C3
         0E1C41C3 0E1C51C3 0E1C61C3 0E1C71C3
         0E1C81C3 0E1C91C3 0E1CA1C3 0E1CB1C3
         0E1CC1C3 0E1CD1C3 0E1CE1C3 0E1CF1C3
         0E1C01C4 0E1C11C4 0E1C21C4 0E1C31C4
         0E1C41C4 0E1C51C4 0E1C61C4 0E1C71C4
         0E1C81C4 0E1C91C4 0E1CA1C4 0E1CB1C4
         0E1CC1C4 0E1CD1C4 0E1CE1C4 0E1CF1C4
         0E1C01C5 0E1C11C5 0E1C21C5 0E1C31C5
         0E1C41C5 0E1C51C5 0E1C61C5 0E1C71C5
         0E1C81C5 0E1C91C5 0E1CA1C5 0E1CB1C5
         0E1CC1C5 0E1CD1C5 0E1CE1C5 0E1CF1C5
         0E1C01C6 0E1C11C6 0E1C21C6 0E1C31C6
         0E1C41C6 0E1C51C6 0E1C61C6 0E1C71C6
         0E1C81C6 0E1C91C6 0E1CA1C6 0E1CB1C6
         0E1CC1C6 0E1CD1C6 0E1CE1C6 0E1CF1C6
         0E1C01C7 0E1C11C7 0E1C21C7 0E1C31C7
         0E1C41C7 0E1C51C7 0E1C61C7 0E1C71C7
         0E1C81C7 0E1C91C7 0E1CA1C7 0E1CB1C7
         0E1CC1C7 0E1CD1C7 0E1CE1C7 0E1CF1C7
         0E1C01C8 0E1C11C8 0E1C21C8 0E1C31C8
         0E1C41C8 0E1C51C8 0E1C61C8 0E1C71C8
         0E1C81C8 0E1C91C8 0E1CA1C8 0E1CB1C8
         0E1CC1C8 0E1CD1C8 0E1CE1C8 0E1CF1C8
         0E1C01C9 0E1C11C9 0E1C21C9 0E1C31C9
         0E1C41C9 0E1C51C9 0E1C61C9 0E1C71C9
         0E1C81C9 0E1C91C9 0E1CA1C9 0E1CB1C9
         0E1CC1C9 0E1CD1C9 0E1CE1C9 0E1CF1C9
         0E1C01CA 0E1C11CA 0E1C21CA 0E1C31CA
         0E1C41CA 0E1C51CA 0E1C61CA 0E1C71CA
         0E1C81CA 0E1C91CA 0E1CA1CA 0E1CB1CA
         0E1CC1CA 0E1CD1CA 0E1CE1CA 0E1CF1CA
         0E1C01CB 0E1C11CB 0E1C21CB 0E1C31CB
         0E1C41CB 0E1C51CB 0E1C61CB 0E1C71CB
         0E1C81CB 0E1C91CB 0E1CA1CB 0E1CB1CB
         0E1CC1CB 0E1CD1CB 0E1CE1CB 0E1CF1CB
         0E1C01CC 0E1C11CC 0E1C21CC 0E1C31CC
         0E1C41CC 0E1C51CC 0E1C61CC 0E1C71CC
         0E1C81CC 0E1C91CC 0E1CA1CC 0E1CB1CC
         0E1CC1CC 0E1CD1CC 0E1CE1CC 0E1CF1CC
         0E1C01CD 0E1C11CD 0E1C21CD 0E1C31CD
         0E1C41CD 0E1C51CD 0E1C61CD 0E1C71CD
         0E1C81CD 0E1C91CD 0E1CA1CD 0E1CB1CD
         0E1CC1CD 0E1CD1CD 0E1CE1CD 0E1CF1CD
         0E1C01CE 0E1C11CE 0E1C21CE 0E1C31CE
         0E1C41CE 0E1C51CE 0E1C61CE 0E1C71CE
         0E1C81CE 0E1C91CE 0E1CA1CE 0E1CB1CE
         0E1CC1CE 0E1CD1CE 0E1CE1CE 0E1CF1CE
         0E1C01CF 0E1C11CF 0E1C21CF 0E1C31CF
         0E1C41CF 0E1C51CF 0E1C61CF 0E1C71CF
         0E1C81CF 0E1C91CF 0E1CA1CF 0E1CB1CF
         0E1CC1CF 0E1CD1CF 0E1CE1CF 0E1CF1CF
         0E1C01D0 0E1C11D0 0E1C21D0 0E1C31D0
         0E1C41D0 0E1C51D0 0E1C61D0 0E1C71D0
         0E1C81D0 0E1C91D0 0E1CA1D0 0E1CB1D0
         0E1CC1D0 0E1CD1D0 0E1CE1D0 0E1CF1D0
         0E1C01D1 0E1C11D1 0E1C21D1 0E1C31D1
         0E1C41D1 0E1C51D1 0E1C61D1 0E1C71D1
         0E1C81D1 0E1C91D1 0E1CA1D1 0E1CB1D1
         0E1CC1D1 0E1CD1D1 0E1CE1D1 0E1CF1D1
         0E1C01D2 0E1C11D2 0E1C21D2 0E1C31D2
         0E1C41D2 0E1C51D2 0E1C61D2 0E1C71D2
         0E1C81D2 0E1C91D2 0E1CA1D2 0E1CB1D2
         0E1CC1D2 0E1CD1D2 0E1CE1D2 0E1CF1D2
         0E1C01D3 0E1C11D3 0E1C21D3 0E1C31D3
         0E1C41D3 0E1C51D3 0E1C61D3 0E1C71D3
         0E1C81D3 0E1C91D3 0E1CA1D3 0E1CB1D3
         0E1CC1D3 0E1CD1D3 0E1CE1D3 0E1CF1D3
         0E1C01D4 0E1C11D4 0E1C21D4 0E1C31D4
         0E1C41D4 0E1C51D4 0E1C61D4 0E1C71D4
         0E1C81D4 0E1C91D4 0E1CA1D4 0E1CB1D4
         0E1CC1D4 0E1CD1D4 0E1CE1D4 0E1CF1D4
         0E1C01D5 0E1C11D5 0E1C21D5 0E1C31D5
         0E1C41D5 0E1C51D5 0E1C61D5 0E1C71D5
         0E1C81D5 0E1C91D5 0E1CA1D5 0E1CB1D5
         0E1CC1D5 0E1CD1D5 0E1CE1D5 0E1CF1D5
         0E1C01D6 0E1C11D6 0E1C21D6 0E1C31D6
         0E1C41D6 0E1C51D6 0E1C61D6 0E1C71D6
         0E1C81D6 0E1C91D6 0E1CA1D6 0E1CB1D6
         0E1CC1D6 0E1CD1D6 0E1CE1D6 0E1CF1D6
         0E1C01D7 0E1C11D7 0E1C21D7 0E1C31D7
         0E1C41D7 0E1C51D7 0E1C61D7 0E1C71D7
         0E1C81D7 0E1C91D7 0E1CA1D7 0E1CB1D7
         0E1CC1D7 0E1CD1D7 0E1CE1D7 0E1CF1D7
         0E1C01D8 0E1C11D8 0E1C21D8 0E1C31D8
         0E1C41D8 0E1C51D8 0E1C61D8 0E1C71D8
         0E1C81D8 0E1C91D8 0E1CA1D8 0E1CB1D8
         0E1CC1D8 0E1CD1D8 0E1CE1D8 0E1CF1D8
         0E1C01D9 0E1C11D9 0E1C21D9 0E1C31D9
         0E1C41D9 0E1C51D9 0E1C61D9 0E1C71D9
         0E1C81D9 0E1C91D9 0E1CA1D9 0E1CB1D9
         0E1CC1D9 0E1CD1D9 0E1CE1D9 0E1CF1D9
         0E1C01DA 0E1C11DA 0E1C21DA 0E1C31DA
         0E1C41DA 0E1C51DA 0E1C61DA 0E1C71DA
         0E1C81DA 0E1C91DA 0E1CA1DA 0E1CB1DA
         0E1CC1DA 0E1CD1DA 0E1CE1DA 0E1CF1DA
         0E1C01DB 0E1C11DB 0E1C21DB 0E1C31DB
         0E1C41DB 0E1C51DB 0E1C61DB 0E1C71DB
         0E1C81DB 0E1C91DB 0E1CA1DB 0E1CB1DB
         0E1CC1DB 0E1CD1DB 0E1CE1DB 0E1CF1DB
         0E1C01DC 0E1C11DC 0E1C21DC 0E1C31DC
         0E1C41DC 0E1C51DC 0E1C61DC 0E1C71DC
         0E1C81DC 0E1C91DC 0E1CA1DC 0E1CB1DC
         0E1CC1DC 0E1CD1DC 0E1CE1DC 0E1CF1DC
         0E1C01DD 0E1C11DD 0E1C21DD 0E1C31DD
         0E1C41DD 0E1C51DD 0E1C61DD 0E1C71DD
         0E1C81DD 0E1C91DD 0E1CA1DD 0E1CB1DD
         0E1CC1DD 0E1CD1DD 0E1CE1DD 0E1CF1DD
         0E1C01DE 0E1C11DE 0E1C21DE 0E1C31DE
         0E1C41DE 0E1C51DE 0E1C61DE 0E1C71DE
         0E1C81DE 0E1C91DE 0E1CA1DE 0E1CB1DE
         0E1CC1DE 0E1CD1DE 0E1CE1DE 0E1CF1DE
         0E1C01DF 0E1C11DF 0E1C21DF 0E1C31DF
         0E1C41DF 0E1C51DF 0E1C61DF 0E1C71DF
         0E1C81DF 0E1C91DF 0E1CA1DF 0E1CB1DF
         0E1CC1DF 0E1CD1DF 0E1CE1DF 0E1CF1DF
         0E1C01E0 0E1C11E0 0E1C21E0 0E1C31E0
         0E1C41E0 0E1C51E0 0E1C61E0 0E1C71E0
         0E1C81E0 0E1C91E0 0E1CA1E0 0E1CB1E0
         0E1CC1E0 0E1CD1E0 0E1CE1E0 0E1CF1E0
         0E1C01E1 0E1C11E1 0E1C21E1 0E1C31E1
         0E1C41E1 0E1C51E1 0E1C61E1 0E1C71E1
         0E1C81E1 0E1C91E1 0E1CA1E1 0E1CB1E1
         0E1CC1E1 0E1CD1E1 0E1CE1E1 0E1CF1E1
         0E1C01E2 0E1C11E2 0E1C21E2 0E1C31E2
         0E1C41E2 0E1C51E2 0E1C61E2 0E1C71E2
         0E1C81E2 0E1C91E2 0E1CA1E2 0E1CB1E2
         0E1CC1E2 0E1CD1E2 0E1CE1E2 0E1CF1E2
         0E1C01E3 0E1C11E3 0E1C21E3 0E1C31E3
         0E1C41E3 0E1C51E3 0E1C61E3 0E1C71E3
         0E1C81E3 0E1C91E3 0E1CA1E3 0E1CB1E3
         0E1CC1E3 0E1CD1E3 0E1CE1E3 0E1CF1E3
         0E1C01E4 0E1C11E4 0E1C21E4 0E1C31E4
         0E1C41E4 0E1C51E4 0E1C61E4 0E1C71E4
         0E1C81E4 0E1C91E4 0E1CA1E4 0E1CB1E4
         0E1CC1E4 0E1CD1E4 0E1CE1E4 0E1CF1E4
         0E1C01E5 0E1C11E5 0E1C21E5 0E1C31E5
         0E1C41E5 0E1C51E5 0E1C61E5 0E1C71E5
         0E1C81E5 0E1C91E5 0E1CA1E5 0E1CB1E5
         0E1CC1E5 0E1CD1E5 0E1CE1E5 0E1CF1E5
         0E1C01E6 0E1C11E6 0E1C21E6 0E1C31E6
         0E1C41E6 0E1C51E6 0E1C61E6 0E1C71E6
         0E1C81E6 0E1C91E6 0E1CA1E6 0E1CB1E6
         0E1CC1E6 0E1CD1E6 0E1CE1E6 0E1CF1E6
         0E1C01E7 0E1C11E7 0E1C21E7 0E1C31E7
         0E1C41E7 0E1C51E7 0E1C61E7 0E1C71E7
         0E1C81E7 0E1C91E7 0E1CA1E7 0E1CB1E7
         0E1CC1E7 0E1CD1E7 0E1CE1E7 0E1CF1E7
         0E1C01E8 0E1C11E8 0E1C21E8 0E1C31E8
         0E1C41E8 0E1C51E8 0E1C61E8 0E1C71E8
         0E1C81E8 0E1C91E8 0E1CA1E8 0E1CB1E8
         0E1CC1E8 0E1CD1E8 0E1CE1E8 0E1CF1E8
         0E1C01E9 0E1C11E9 0E1C21E9 0E1C31E9
         0E1C41E9 0E1C51E9 0E1C61E9 0E1C71E9
         0E1C81E9 0E1C91E9 0E1CA1E9 0E1CB1E9
         0E1CC1E9 0E1CD1E9 0E1CE1E9 0E1CF1E9
         0E1C01EA 0E1C11EA 0E1C21EA 0E1C31EA
         0E1C41EA 0E1C51EA 0E1C61EA 0E1C71EA
         0E1C81EA 0E1C91EA 0E1CA1EA 0E1CB1EA
         0E1CC1EA 0E1CD1EA 0E1CE1EA 0E1CF1EA
         0E1C01EB 0E1C11EB 0E1C21EB 0E1C31EB
         0E1C41EB 0E1C51EB 0E1C61EB 0E1C71EB
         0E1C81EB 0E1C91EB 0E1CA1EB 0E1CB1EB
         0E1CC1EB 0E1CD1EB 0E1CE1EB 0E1CF1EB
         0E1C01EC 0E1C11EC 0E1C21EC 0E1C31EC
         0E1C41EC 0E1C51EC 0E1C61EC 0E1C71EC
         0E1C81EC 0E1C91EC 0E1CA1EC 0E1CB1EC
         0E1CC1EC 0E1CD1EC 0E1CE1EC 0E1CF1EC
         0E1C01ED 0E1C11ED 0E1C21ED 0E1C31ED
         0E1C41ED 0E1C51ED 0E1C61ED 0E1C71ED
         0E1C81ED 0E1C91ED 0E1CA1ED 0E1CB1ED
         0E1CC1ED 0E1CD1ED 0E1CE1ED 0E1CF1ED
         0E1C01EE 0E1C11EE 0E1C21EE 0E1C31EE
         0E1C41EE 0E1C51EE 0E1C61EE 0E1C71EE
         0E1C81EE 0E1C91EE 0E1CA1EE 0E1CB1EE
         0E1CC1EE 0E1CD1EE 0E1CE1EE 0E1CF1EE
         0E1C01EF 0E1C11EF 0E1C21EF 0E1C31EF
         0E1C41EF 0E1C51EF 0E1C61EF 0E1C71EF
         0E1C81EF 0E1C91EF 0E1CA1EF 0E1CB1EF
         0E1CC1EF 0E1CD1EF 0E1CE1EF 0E1CF1EF
         0E1C01F0 0E1C11F0 0E1C21F0 0E1C31F0
         0E1C41F0 0E1C51F0 0E1C61F0 0E1C71F0
         0E1C81F0 0E1C91F0 0E1CA1F0 0E1CB1F0
         0E1CC1F0 0E1CD1F0 0E1CE1F0 0E1CF1F0
         0E1C01F1 0E1C11F1 0E1C21F1 0E1C31F1
         0E1C41F1 0E1C51F1 0E1C61F1 0E1C71F1
         0E1C81F1 0E1C91F1 0E1CA1F1 0E1CB1F1
         0E1CC1F1 0E1CD1F1 0E1CE1F1 0E1CF1F1
         0E1C01F2 0E1C11F2 0E1C21F2 0E1C31F2
         0E1C41F2 0E1C51F2 0E1C61F2 0E1C71F2
         0E1C81F2 0E1C91F2 0E1CA1F2 0E1CB1F2
         0E1CC1F2 0E1CD1F2 0E1CE1F2 0E1CF1F2
         0E1C01F3 0E1C11F3 0E1C21F3 0E1C31F3
         0E1C41F3 0E1C51F3 0E1C61F3 0E1C71F3
         0E1C81F3 0E1C91F3 0E1CA1F3 0E1CB1F3
         0E1CC1F3 0E1CD1F3 0E1CE1F3 0E1CF1F3
         0E1C01F4 0E1C11F4 0E1C21F4 0E1C31F4
         0E1C41F4 0E1C51F4 0E1C61F4 0E1C71F4
         0E1C81F4 0E1C91F4 0E1CA1F4 0E1CB1F4
         0E1CC1F4 0E1CD1F4 0E1CE1F4 0E1CF1F4
         0E1C01F5 0E1C11F5 0E1C21F5 0E1C31F5
         0E1C41F5 0E1C51F5 0E1C61F5 0E1C71F5
         0E1C81F5 0E1C91F5 0E1CA1F5 0E1CB1F5
         0E1CC1F5 0E1CD1F5 0E1CE1F5 0E1CF1F5
         0E1C01F6 0E1C11F6 0E1C21F6 0E1C31F6
         0E1C41F6 0E1C51F6 0E1C61F6 0E1C71F6
         0E1C81F6 0E1C91F6 0E1CA1F6 0E1CB1F6
         0E1CC1F6 0E1CD1F6 0E1CE1F6 0E1CF1F6
         0E1C01F7 0E1C11F7 0E1C21F7 0E1C31F7
         0E1C41F7 0E1C51F7 0E1C61F7 0E1C71F7
         0E1C81F7 0E1C91F7 0E1CA1F7 0E1CB1F7
         0E1CC1F7 0E1CD1F7 0E1CE1F7 0E1CF1F7
         0E1C01F8 0E1C11F8 0E1C21F8 0E1C31F8
         0E1C41F8 0E1C51F8 0E1C61F8 0E1C71F8
         0E1C81F8 0E1C91F8 0E1CA1F8 0E1CB1F8
         0E1CC1F8 0E1CD1F8 0E1CE1F8 0E1CF1F8
         0E1C01F9 0E1C11F9 0E1C21F9 0E1C31F9
         0E1C41F9 0E1C51F9 0E1C61F9 0E1C71F9
         0E1C81F9 0E1C91F9 0E1CA1F9 0E1CB1F9
         0E1CC1F9 0E1CD1F9 0E1CE1F9 0E1CF1F9
         0E1C01FA 0E1C11FA 0E1C21FA 0E1C31FA
         0E1C41FA 0E1C51FA 0E1C61FA 0E1C71FA
         0E1C81FA 0E1C91FA 0E1CA1FA 0E1CB1FA
         0E1CC1FA 0E1CD1FA 0E1CE1FA 0E1CF1FA
         0E1C01FB 0E1C11FB 0E1C21FB 0E1C31FB
         0E1C41FB 0E1C51FB 0E1C61FB 0E1C71FB
         0E1C81FB 0E1C91FB 0E1CA1FB 0E1CB1FB
         0E1CC1FB 0E1CD1FB 0E1CE1FB 0E1CF1FB
         0E1C01FC 0E1C11FC 0E1C21FC 0E1C31FC
         0E1C41FC 0E1C51FC 0E1C61FC 0E1C71FC
         0E1C81FC 0E1C91FC 0E1CA1FC 0E1CB1FC
         0E1CC1FC 0E1CD1FC 0E1CE1FC 0E1CF1FC
         0E1C01FD 0E1C11FD 0E1C21FD 0E1C31FD
         0E1C41FD 0E1C51FD 0E1C61FD 0E1C71FD
         0E1C81FD 0E1C91FD 0E1CA1FD 0E1CB1FD
         0E1CC1FD 0E1CD1FD 0E1CE1FD 0E1CF1FD
         0E1C01FE 0E1C11FE 0E1C21FE 0E1C31FE
         0E1C41FE 0E1C51FE 0E1C61FE 0E1C71FE
         0E1C81FE 0E1C91FE 0E1CA1FE 0E1CB1FE
         0E1CC1FE 0E1CD1FE 0E1CE1FE 0E1CF1FE
         0E1C01FF 0E1C11FF 0E1C21FF 0E1C31FF
         0E1C41FF 0E1C51FF 0E1C61FF 0E1C71FF
         0E1C81FF 0E1C91FF 0E1CA1FF 0E1CB1FF
         0E1CC1FF 0E1CD1FF 0E1CE1FF 0E1CF1FF
    ccs_write_memory; ccs_error = 0; duration=1138 ms
ccs_write_register
    coreh = [serverh:0;cc_index:0;chain_pos:9]
    index = 8703
    count = 1
    size = 4
    value: (size = 4)
         80000130
    ccs_write_register; ccs_error = 0; duration=2 ms
ccs_read_register
    index = 8703
    count = 1
    size = 4
    value: (size = 4)
         80000130
    ccs_read_register; ccs_error = 0; duration=2 ms
ccs_read_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x80000100]
    data: (size = 256)
         00889D80 00480440 04B08DC0 08D00000
         003080C0 08300244 08001BC4 DAFF0000
         08301BC0 01308240 08300BC4 F9FF0000
         CA0000C0 16009040 471F8CC0 56340000
         14019CC4 00109044 000051C0 01000000
         20119CC4 00108044 081090C4 0C200000
         000051C4 0000000A 01D080C0 00000000
         0000000A 01AC8240 001090C0 01B00000
         017080C0 D4009644 D4209FC4 00200000
         B50000C0 1B010040 150090C0 CC100000
         563412C0 C4109640 000090C0 01000000
         0130D1C4 00005240 11000008 20000000
         FAFFDCC8 22005240 27005310 03200000
         20208010 01104112 02000CC0 01000000
         0130D100 00005240 05000008 03000000
         FAFFD418 00209040 013051C0 00200000
    ccs_read_memory; ccs_error = 0; duration=14 ms
ccs_write_register
    index = 4103
    count = 1
    size = 4
    value: (size = 4)
         04000004
    ccs_write_register; ccs_error = 0; duration=3 ms
ccs_read_memory
    addr = [space:0;size:4;address_hi:0x00000000;address_lo:0x80000104]
    data: (size = 4)
         00485240
    ccs_read_memory; ccs_error = 0; duration=4 ms
ccs_write_memory
    data: (size = 4)
         700020E1
    ccs_write_memory; ccs_error = 0; duration=6 ms
ccs_read_memory
    data: (size = 4)
         70002040
    ccs_read_memory; ccs_error = 0; duration=5 ms
ccs_write_memory
    data: (size = 4)
         700020E1
    ccs_write_memory; ccs_error = 0; duration=5 ms
ccs_read_memory
    data: (size = 4)
         70002040
ccs_write_memory
    data: (size = 4)
         700020E1
ccs_read_memory
    data: (size = 4)
         70002040
ccs_write_memory
    data: (size = 4)
         700020E1
ccs_read_memory
    data: (size = 4)
         70002040
ccs_write_register
    index = 4160
    count = 1
    size = 4
    value: (size = 4)
         80000104
ccs_write_register
    index = 4176
    count = 1
    size = 4
    value: (size = 4)
         000021E7
ccs_run_core
    ccs_run_core; ccs_error = 0
ccs_read_register
    index = 8703
    count = 1
    size = 4
    value: (size = 4)
         80000130
    ccs_read_register; ccs_error = 0; duration=3 ms
ccs_read_register
    index = 12319
    count = 1
    size = 4
    value: (size = 4)
         000001D3
ccs_read_register
    index = 4130
    count = 1
    size = 4
    value: (size = 4)
         02004012
ccs_read_register
    index = 4130
    count = 1
    size = 4
    value: (size = 4)
         02004012
yipingwang
Hello Elias Bitbaker,
Please try to use RAM initialization file to initialize the target board. Then in ARM Flash Programmer Task panel, specify the Target RAM address at 0x80000000 to run flash programming algorithm in DDR RAM.
Yiping
jiye
Contributor V
that is what I did
See this
yipingwang
Would you please try whether it is possible to run the bareboard "Hello World" sample program in DDR RAM?
Yiping
jiye
Contributor V
Hi Yiping,
(1)Are you able to provide procedures to do this ?
(2) Also my eMMC size is 8GB what is the right device name from the CW I suppose to use is it stilL SDSG16GB?
yipingwang
1. Please refer to the section "3.2 Creating and building bareboard project" and "3.3 Debugging bareboard project"  in C:\Freescale\CW4NET_v2017.03_armv7\CW_ARMv7\ARMv7\CW_ARMv7_Getting_Started_Guide.pdf.
2. The algorithm SDSG16GB could be used.
jiye
Contributor V
Hi Yiping,
I understand all these debugs to perform necessary tasks. However, my situation is I can't even run debug let's say step over in the DDR debug mode (I used the correct RAM init script and mem srcipt)
On the right there is no memory mapping if you see from OCRAM
you are able to see all the memory address mappings
yipingwang
There is problem with DDR controller configuration in the initialization file.
Do you have LS1021ATWR board? If yes, please try whether you can program SD card on LS1021ATWR with OCRAM launch configuration connecting to the target board.
Yiping
jiye
Contributor V
it takes me 22 hours to flash a binary from the CW to the SD card via OCRAM. This is definitely not a good practice. Can you give me the right configuration file for DDR?
yipingwang
For DDR controller configuration, you need to create a QCVS DDR project to generate the initial configuration parameters according to your DDR datasheet or reading from SPD, then use DDRv tool to do validation and optimization.
You could refer to https://community.nxp.com/docs/DOC-333349 .
Yiping
