How to debug the MBD generated code in the S32 Design Studio using PEmicro debugger?
rafael_barbosa
I am using the Devkit MPC5744P and the Model Based Design Toolbox 3.0.0.
I would like to debug the generated code on the target microcontroller using the PEmicro debugger.
What are the steps to import the generated code in the S32 Design Studio in order to run the debugger?
Kind Regards, Rafael
mariuslucianandrei
rafael_barbosa
Hello mariuslucianandrei
I could use the PEmicro debugger for MBD generated code by importing the project.xml file generated by the MBD toolbox into the S32 Design Studio.
tl007
Dear @rafael_barbosa
For some reason, i did the same but was not able to proceed with flashing the new project imported.
Can you maybe provide the next steps?
https://youtu.be/PjFWds2M4nQ
rafael_barbosa
