How to read Multiple ICODE ILT tags using clrc6630B module ? I have tried the Basic and advance discovery loop evaluation examples. But it only read one tag . I have modified the device limit to 50 and getting the error
"refer ph_status.h" . what all the modification needed other than device limit to read multiple icode ilt tags say 50 tags?
Currently the NXP NFC Reader Library also implements the Type-V anticollision. If you follow the path of the Discovery Loop you will end up at the anticollision function for Type-V in a file called 'phacDiscLoop_SW_Int_V.c', the method 'phacDiscLoop_Sw_Int_CollisionResolutionV(...)' implements the anticollision.
Estephania
