Enabling TRX1 and TRX2 on TEF810x using S32R274
sowmya_n
We are trying to enable 2RF and 8 antenna config on TEF810x with S32R274. Two identical profile configs are defined, one for each transmitter, trying to send profile0 128 times(Tx1)and then profile1 128 times(Tx2).
s32r274‌tef810x rsdk #mimo
txsw1 = {1,0,0};
txsw2 = {0,1,0};
txpon1 = {1,1,0};
txpon2 = {0,1,0};
ProfileStayCnt = 128;
Profile mode = 4;
chip_Chirp_Program(0, narrowBand, downChirp, &effFc, effBW, loopBW, tDwell, tSettle, tJumpback, tReset, num_samples*deci, deci, false, bps, txsw1, txpon1, rxpon); // profile 0
chip_Chirp_Program(1, narrowBand, downChirp, &effFc, effBW, loopBW, tDwell, tSettle, tJumpback, tReset, num_samples*deci, deci, false, bps, txsw2, txpon2, rxpon); // profile 1
Is this the right way to configure the profiles and sequence ?
how to test if Tx2 is actually enabled and is transmitting profile1?
Thank you!
Labels (2)
Tags (4)
