I accidentally changed the state of some signals from "no pin routed" to a specific pin.
I am able able to assign another pin (among a list of allowable pins) to these signals but am unable to change any back to "no pin routed".
How do I change the pin assignment of a signal back to "no pin routed"?
See attached with picture of this.
Solved! Go to Solution.
Hi hw,
You can select "Pins" in View Mode, and uncheck the selected function.
Then it will back to "no pin routed".
Robin
I just realized I "double-posted". I posted very similar contents again because (completely my own fault) I couldn't find this post today.
My apologies.
Hi hw,
Robin
Thanks Robin. It worked like a charm. :smileyhappy:
