I'm using the Classic Code Warrior. I would like to Migrate to S32DS
We developed a bootloader for CCW with modified .lcf files.
Kindly help in writing an .ld file for S32DS PA. Currently, the generated .ld file is very simple.
Also, I want to fit one of my function into a ram section.
Kindly help in this regard.
Thanks in advance,
Raju.
Solved! Go to Solution.
