AUTOSAR control LED toggle
Question asked by WANG LI on Dec 16, 2019
Latest reply on Dec 18, 2019 by Hung Nguyen Phi
hi,
use S32K148  +  AUTOSAR  control  PTE-21.22.23  LED toggle.
i do not konw  how to do ?
step1: EB_tresos tool  generate  AUTOSAR_code.
step2: porting AUTOSAR_code to S32DS .
step3: integrated development on  S32DS.
But I try to generate AUTOSAR_code are NULL , feel like useless functions.
#ifdef __cplusplus
extern "C" {
#endif
* INCLUDE FILES
* 1) system and project includes
* 2) needed interfaces from external units
* 3) internal and external interfaces from this unit
#include "Dio.h"
#if (defined(DIO_PRECOMPILE_SUPPORT) || defined(DIO_LINKTIME_SUPPORT))
* SOURCE FILE VERSION INFORMATION
#define DIO_VENDOR_ID_CFG_C 43
/** @violates @ref Dio_Cfg_C_REF_1 The used compilers use more than 31 chars for identifiers. */
#define DIO_AR_RELEASE_MAJOR_VERSION_CFG_C 4
#define DIO_AR_RELEASE_MINOR_VERSION_CFG_C 3
#define DIO_AR_RELEASE_REVISION_VERSION_CFG_C 1
#define DIO_SW_MAJOR_VERSION_CFG_C 1
#define DIO_SW_MINOR_VERSION_CFG_C 0
#define DIO_SW_PATCH_VERSION_CFG_C 1
* FILE VERSION CHECKS
#if (((DIO_AR_RELEASE_MAJOR_VERSION_CFG_C != DIO_AR_RELEASE_MAJOR_VERSION) || \
(DIO_AR_RELEASE_MINOR_VERSION_CFG_C != DIO_AR_RELEASE_MINOR_VERSION) \
(DIO_AR_RELEASE_REVISION_VERSION_CFG_C != DIO_AR_RELEASE_REVISION_VERSION)\
#error "AutoSar Version Numbers of Dio_Cfg.c and Dio.h are different"
#endif
#if ((DIO_SW_MAJOR_VERSION_CFG_C != DIO_SW_MAJOR_VERSION) || \
(DIO_SW_MINOR_VERSION_CFG_C != DIO_SW_MINOR_VERSION) || \
(DIO_SW_PATCH_VERSION_CFG_C != DIO_SW_PATCH_VERSION) \
#error "Software Version Numbers of Dio_Cfg.c and Dio.h are different"
#endif
#if ((DIO_VENDOR_ID_CFG_C != DIO_VENDOR_ID))
#error "VENDOR ID for Dio_Cfg.c and Dio.h is different"
#endif
* LOCAL TYPEDEFS (STRUCTURES, UNIONS, ENUMS)
* LOCAL MACROS
* LOCAL CONSTANTS
* LOCAL VARIABLES
* GLOBAL CONSTANTS
#define DIO_START_SEC_CONFIG_DATA_UNSPECIFIED
/** @violates @ref Dio_Cfg_C_REF_2 MISRA 2004 Required Rule 19.15,
Precautions to prevent the contents of a header file being included twice.*/
#include "Dio_MemMap.h"
* @brief Platform implemented port pins representation.
* @details Array of bit maps reflecting the available pins in each port.
* The number of elements in the array corresponds to the number of
* ports implemented in the platform package. Rightmost bit of each
* array element corresponds to channel 0 of the associated port,
* while leftmost bit of each array element corresponds to channel 31
* of the associated port. A 0 bit means that the correspondent channel
* is not available in the platform package, while a bit of 1 means
* that the correspondent channel is available in the platform package.
* @api
/** @violates @ref Dio_Cfg_C_REF_4 This warning appears when defining functions or objects that will be used by the upper layers. */
CONST(Dio_PortLevelType, DIO_CONST) Dio_aAvailablePinsForWrite[DIO_NUM_PORTS_U16] =
(Dio_PortLevelType)0xFFFFFFFFUL,
(Dio_PortLevelType)0x0FFFFFFFUL
CONST(Dio_PortLevelType, DIO_CONST) Dio_aAvailablePinsForRead[DIO_NUM_PORTS_U16] =
/* ========== DioConfig ========== */
* @brief Data structure for configuration DioConfig.
CONST(Dio_ConfigType, DIO_CONST) DioConfig =
(uint8)0x0,
NULL_PTR
#define DIO_STOP_SEC_CONFIG_DATA_UNSPECIFIED
/** @violates @ref Dio_Cfg_C_REF_3 MISRA 2004 Advisory Rule 19.1,
Only preprocessor statements and comments before '#include'.*/
* GLOBAL VARIABLES
* LOCAL FUNCTION PROTOTYPES
* LOCAL FUNCTIONS
* GLOBAL FUNCTIONS
#endif /* (defined(DIO_PRECOMPILE_SUPPORT) || defined(DIO_LINKTIME_SUPPORT)) */
#ifdef __cplusplus
#endif
BRS
Grayli
