RFIDDISCOVER CLI tool?
Question asked by Wilmer Suarez on Dec 13, 2019
Latest reply on Dec 19, 2019 by Kan_Li
I just wanted to know if a CLI tool is available to use for the RFIDDISCOVER software? I would like to write a script that sends a set of fixed commands to the device instead of having to manually input the parameters for each command each time. If not, is there a way to preconfigure a list of commands and their parameters in the the software itself?
If that is also not possible, is my only option to directly modify the firmware of my reader? If so, how do I access that?
I am using the Pegoda EV710 reader.
Thank you
