Custom wayland compositor on IMX8M
fredericduchass
I 'm using IMX8M with yocto / wayland image.
Is it possible to avoid using weston and use my own compositor ?
I try using some Qt examples (pure-qml, minimal-cpp, minimal-qml....) but i can't find a compositor which runs successfully.
This compositior needs "eglfs" as backend (and as far as i know, eglfs is not supported on imx8m) in order to accept later custom application with wayland backend.
I hope i my explanation were clear.
BR and many thanks for your help.
Frédéric
Tags (2)
Bio_TICFSL
Hello Frederic,
Is not possible to use your own compositor if you are working with yocto NXP release, egls is not supported by the i.MX8M.
fredericduchass
Of course I have seen in yocto nxp BSP support that only wayland or xwayland is supported.
So the only possibility if we'd like a compositor is to use weston ?
Weston should use some tricks.... and my own compositor couldn't use same tricks ?
I tried every compositor from Qt and i can't make any of them working.
Weston is too big for our application...
