I am working on LSDK 19.09(flexbuild_lsdk1909_update_221019).
I changed the CONFIG_APP_OPTEE=y in configs/buld_lsdk.cfg file, and I was expecting some new directory optee_os, optee_client, and optee_test will show up under package/apps folder after I do: flex-builder -i repo-fetch
However, the repo-fetch stops on repo: wayland_protocols , and didn't proceed to fetch other repos.
What's wrong with my configuration? Is CONFIG_APP_OPTEE=y not enough?
BTW, the name "flexbuild_lsdk1909_update_221019" is a little bit confusing, does it need another base SDK package or it is a standalone package. It used to be named without the 'update', say "flexbuild_lsdk1903".
Zhenchuan
Hello Zhenchuan Chai,
Please execute the following commands to get source code optee_os, optee_client, and optee_test in packages/apps/.
$ flex-builder -i repo-fetch -B optee_os
$ flex-builder -i repo-fetch -B optee_test
$ flex-builder -i repo-fetch -B optee_client
Yiping
