MifareWnd log option
aymeric_laloy
I'm evaluating MIFARE NFC device with Pegoda 701 reader. I have a simple test that is using MifareWnd software where I simply perform read and write operations with authentication first (see attached 'Capture_mifarewnd_read.PNG'). I need to perform robustness tests, hence long cycles of read and write operations. If I do it continously, let's say 1000 cycles in a row, then I need to extract the results from history, which I can't as the SW does not allow any copy of the history window nor propose a log output option.
Could you, please, provide me solution ?
Thanks in advance for your support,
Aymeric.
Jonathan_Iglesias
Hi Aymeric Laloy,
Hope you are doing great,  I believe this is a very old tool, as you can see the  user manual is from 2001, https://www.nxp.com/docs/en/user-guide/066410.pdf
 please try to use our latest tool the  RFIDDiscover | NXP , the full version can be found in https://www.docstore.nxp.com/ .
Have a great day !
Jonathan
